[PATCH] cpukit: New SPI framework implemented #2776
Alexander Krutwig alexander.krutwig at embedded-brains.de
Mon Sep 12 13:10:37 UTC 2016
Linux Userspace API was taken as a template
Test libtests/spi01 is included into testsuite
 cpukit/dev/Makefile.am                     |  10 +
 cpukit/dev/include/dev/spi/spi.h           | 452 +++++++++++++++++++++++++++++
 cpukit/dev/include/linux/spi/spidev.h      | 242 +++++++++++++++
 cpukit/dev/spi/spi-bus.c                   | 362 +++++++++++++++++++++++
 cpukit/dev/spi/spi-dev.c                   | 291 +++++++++++++++++++
 testsuites/libtests/Makefile.am            |   1 +
 testsuites/libtests/spi01/buffer_test_io.h | 219 ++++++++++++++
 testsuites/libtests/spi01/init.c           | 256 ++++++++++++++++
 testsuites/libtests/spi01/spi01.doc        |  11 +
 testsuites/libtests/spi01/spi01.scn        |   2 +
 testsuites/libtests/spi01/tmacros.h        | 372 ++++++++++++++++++++++++
 11 files changed, 2218 insertions(+)
 create mode 100644 cpukit/dev/include/dev/spi/spi.h
 create mode 100644 cpukit/dev/include/linux/spi/spidev.h
 create mode 100644 cpukit/dev/spi/spi-bus.c
 create mode 100644 cpukit/dev/spi/spi-dev.c
 create mode 100644 testsuites/libtests/spi01/buffer_test_io.h
 create mode 100644 testsuites/libtests/spi01/init.c
 create mode 100644 testsuites/libtests/spi01/spi01.doc
 create mode 100644 testsuites/libtests/spi01/spi01.scn
 create mode 100644 testsuites/libtests/spi01/tmacros.h
diff --git a/cpukit/dev/Makefile.am b/cpukit/dev/Makefile.am
index 47a1585..3d39e38 100644
--- a/cpukit/dev/Makefile.am
+++ b/cpukit/dev/Makefile.am
@@ -11,11 +11,19 @@ include_dev_i2c_HEADERS += include/dev/i2c/gpio-nxp-pca9535.h
 include_dev_i2c_HEADERS += include/dev/i2c/i2c.h
 include_dev_i2c_HEADERS += include/dev/i2c/switch-nxp-pca9548a.h
+include_dev_spidir = $(includedir)/dev/spi
+include_dev_spi_HEADERS =
+include_dev_spi_HEADERS += include/dev/spi/spi.h
 include_linuxdir = $(includedir)/linux
 include_linux_HEADERS =
 include_linux_HEADERS += include/linux/i2c.h
 include_linux_HEADERS += include/linux/i2c-dev.h
+include_linux_spidir = $(includedir)/linux/spi
+include_linux_spi_HEADERS =
+include_linux_spi_HEADERS += include/linux/spi/spidev.h
 noinst_LIBRARIES = libdev.a
 libdev_a_SOURCES =
@@ -24,6 +32,8 @@ libdev_a_SOURCES += i2c/gpio-nxp-pca9535.c
 libdev_a_SOURCES += i2c/i2c-bus.c
 libdev_a_SOURCES += i2c/i2c-dev.c
 libdev_a_SOURCES += i2c/switch-nxp-pca9548a.c
+libdev_a_SOURCES += spi/spi-dev.c
+libdev_a_SOURCES += spi/spi-bus.c
 include $(srcdir)/preinstall.am
 include $(top_srcdir)/automake/local.am
diff --git a/cpukit/dev/include/dev/spi/spi.h b/cpukit/dev/include/dev/spi/spi.h
new file mode 100644
index 0000000..ce3fd7c
--- /dev/null
+++ b/cpukit/dev/include/dev/spi/spi.h
@@ -0,0 +1,452 @@
+ * @file
+ * @brief Inter-Integrated Circuit (SPI) Driver API
+ * @ingroup SPI
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef _DEV_SPI_SPI_H
+#define _DEV_SPI_SPI_H
+#include <linux/spi/spidev.h>
+#include <rtems.h>
+#include <rtems/seterr.h>
+#include <sys/ioctl.h>
+#include <sys/stat.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+typedef struct spi_ioc_transfer spi_ioc_transfer;
+typedef struct spi_bus spi_bus;
+typedef struct spi_dev spi_dev;
+typedef struct spi_rdwr_ioctl_data spi_rdwr_ioctl_data;
+ * @defgroup SPI Inter-Integrated Circuit (SPI) Driver
+ * @brief Inter-Integrated Circuit (SPI) bus and device driver support.
+ * @defgroup SPIBus SPI Bus Driver
+ * @ingroup SPI
+ * @name SPI IO Control Commands
+ * @brief Obtains the bus.
+ * This command has no argument.
+#define SPI_BUS_OBTAIN 0x800
+ * @brief Releases the bus.
+#define SPI_BUS_RELEASE 0x801
+ * @brief Gets the bus control.
+ * The argument type is a pointer to spi_bus pointer.
+#define SPI_BUS_GET_CONTROL 0x802
+ * @brief Sets the bus clock in Hz.
+ * The argument type is unsigned long.
+#define SPI_BUS_SET_CLOCK 0x803
+ * @brief Default SPI bus clock in Hz.
+#define SPI_BUS_CLOCK_DEFAULT 100000
+ * @brief Data Field of the SPI bus control
+typedef struct {
+   * @brief Current mode.
+  uint32_t mode;
+   * @brief Indicates the bits per word used on the device.
+  uint8_t bits_per_word;
+   * @brief Indicates the speed of the current device message.
+  uint32_t speed_hz;
+   * @brief Indicates the delay between transfers on different chip select
+   * devices.
+  uint16_t delay_usecs;
+   * @brief Indicates which device is selected by chip select
+  uint8_t cs;
+} spi_bus_data;
+ * @brief SPI bus control.
+struct spi_bus {
+   * @brief Transfers SPI messages.
+   * @param[in] bus The bus control.
+   * @param[in] msgs The messages to transfer.
+   * @param[in] msg_count The count of messages to transfer.  It must be
+   * positive.
+   * @retval 0 Successful operation.
+   * @retval negative Negative error number in case of an error.
+  int (*transfer)(spi_bus *bus, spi_ioc_transfer *msgs, uint32_t msg_count);
+   * @brief Sets the bus clock.
+   * @param[in] clock The desired bus clock in Hz.
+  int (*set_clock)(spi_bus *bus, unsigned long clock);
+   * @brief Destroys the bus.
+  void (*destroy)(spi_bus *bus);
+   * @brief Mutex to protect the bus access.
+  rtems_id mutex;
+   * @brief Maximum Speed in Hz
+  uint32_t max_speed;
+   * @brief Indicates if LSB is supposed to be transmitted first.
+  uint8_t lsb_first;
+   * @brief Indicates if chip select must be set high after transfer.
+  uint8_t cs_change;
+   * @brief Data field of the bus control.
+  spi_bus_data data;
+ * @brief Initializes a bus control.
+ * After a sucessful initialization the bus control must be destroyed via
+ * spi_bus_destroy().  A registered bus control will be automatically destroyed
+ * in case the device file is unlinked.  Make sure to call spi_bus_destroy() in
+ * a custom destruction handler.
+ * @retval -1 An error occurred.  The errno is set to indicate the error.
+ * @see spi_bus_register()
+int spi_bus_init(spi_bus *bus);
+ * @brief Allocates a bus control from the heap and initializes it.
+ * After a sucessful allocation and initialization the bus control must be
+ * destroyed via spi_bus_destroy_and_free().  A registered bus control will be
+ * automatically destroyed in case the device file is unlinked.  Make sure to
+ * call spi_bus_destroy_and_free() in a custom destruction handler.
+ * @param[in] size The size of the bus control.  This enables the addition of
+ * bus controller specific data to the base bus control.  The bus control is
+ * zero initialized.
+ * @retval non-NULL The new bus control.
+ * @retval NULL An error occurred.  The errno is set to indicate the error.
+spi_bus *spi_bus_alloc_and_init(size_t size);
+ * @brief Destroys a bus control.
+void spi_bus_destroy(spi_bus *bus);
+ * @brief Destroys a bus control and frees its memory.
+void spi_bus_destroy_and_free(spi_bus *bus);
+ * @brief Registers a bus control.
+ * This function claims ownership of the bus control regardless if the
+ * registration is successful or not.
+ * @param[in] bus_path The path to the bus device file.
+int spi_bus_register(
+  spi_bus *bus,
+  const char *bus_path
+void spi_bus_obtain(spi_bus *bus);
+void spi_bus_release(spi_bus *bus);
+ * The bus is obtained before the transfer and released afterwards.
+ * positive.
+int spi_bus_transfer(spi_bus *bus, spi_ioc_transfer *msgs, uint32_t msg_count);
+ * @defgroup SPIDevice SPI Device Driver
+ * @ingroup SPI
+ * @brief Base number for device IO control commands.
+#define SPI_DEV_IO_CONTROL 0x900
+ * @brief SPI slave device control.
+struct spi_dev {
+   * @brief Reads from the device.
+   * @retval non-negative Bytes transferred from device.
+  ssize_t (*read)(spi_dev *dev, void *buf, size_t n, off_t offset);
+   * @brief Writes to the device.
+   * @retval non-negative Bytes transferred to device.
+  ssize_t (*write)(spi_dev *dev, const void *buf, size_t n, off_t offset);
+   * @brief Device IO control.
+  int (*ioctl)(spi_dev *dev, ioctl_command_t command, void *arg);
+   * @brief Gets the file size.
+  off_t (*get_size)(spi_dev *dev);
+   * @brief Gets the file block size.
+  blksize_t (*get_block_size)(spi_dev *dev);
+   * @brief Destroys the device.
+  void (*destroy)(spi_dev *dev);
+   * @brief The bus control.
+  spi_bus *bus;
+   * @brief The device address.
+  uint16_t address;
+   * @brief File descriptor of the bus.
+   * This prevents destruction of the bus since we hold a reference to it with
+   * this.
+  int bus_fd;
+ * @brief Initializes a device control.
+ * After a sucessful initialization the device control must be destroyed via
+ * spi_dev_destroy().  A registered device control will be automatically
+ * destroyed in case the device file is unlinked.  Make sure to call
+ * spi_dev_destroy_and_free() in a custom destruction handler.
+ * @param[in] device The device control.
+ * @param[in] address The address of the device.
+ * @see spi_dev_register()
+int spi_dev_init(spi_dev *dev, const char *bus_path, uint16_t address);
+ * @brief Allocates a device control from the heap and initializes it.
+ * After a sucessful allocation and initialization the device control must be
+ * destroyed via spi_dev_destroy_and_free().  A registered device control will
+ * be automatically destroyed in case the device file is unlinked.  Make sure
+ * to call spi_dev_destroy_and_free() in a custom destruction handler.
+ * @param[in] size The size of the device control.  This enables the addition
+ * of device specific data to the base device control.  The device control is
+ * @retval non-NULL The new device control.
+spi_dev *spi_dev_alloc_and_init(
+  size_t size,
+  const char *bus_path,
+  uint16_t address
+ * @brief Destroys a device control.
+ * @param[in] dev The device control.
+void spi_dev_destroy(spi_dev *dev);
+ * @brief Destroys a device control and frees its memory.
+void spi_dev_destroy_and_free(spi_dev *dev);
+ * @brief Registers a device control.
+ * This function claims ownership of the device control regardless if the
+ * @param[in] dev The dev control.
+ * @param[in] dev_path The path to the device file of the device.
+int spi_dev_register(
+  spi_dev *dev,
+  const char *dev_path
+/** @} */  /* end of spi device driver */
+#ifdef __cplusplus
+#endif /* _DEV_SPI_SPI_H */
diff --git a/cpukit/dev/include/linux/spi/spidev.h b/cpukit/dev/include/linux/spi/spidev.h
index 0000000..a5b7df3
--- /dev/null
+++ b/cpukit/dev/include/linux/spi/spidev.h
@@ -0,0 +1,242 @@
+ * @file
+ * @brief RTEMS Port of Linux SPI API
+ * @ingroup SPILinux
+ * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifndef _UAPI_LINUX_SPI_H
+#define _UAPI_LINUX_SPI_H
+#include <stdint.h>
+#include <stdlib.h>
+#include <sys/ioccom.h>
+ * @defgroup SPILinux Linux SPI User-Space API
+ * @ingroup SPI
+ * @brief RTEMS port of Linux SPI user-space API.
+ * Additional documentation is available through the Linux sources, see
+ * - /usr/src/linux/include/uapi/linux/spidev.h, and
+ * - /usr/src/linux/Documentation/spi.
+#define SPI_MESSAGE_SIZE_POS 16
+#define SPI_MESSAGE_SIZE_BIT_LENGTH 14
+ * @name SPI Transfer Flags
+ * @brief SPI transfer flag which sets the clock phase.
+#define SPI_CPHA 0x01
+ * @brief SPI transfer flag which sets the clock polarity.
+#define SPI_CPOL 0x02
+ * @brief SPI transfer flag which sets SPI Mode 0 (clock starts low, sample on
+ * leading edge).
+#define SPI_MODE_0 (0|0)
+ * trailing edge).
+#define SPI_MODE_1 (0|SPI_CPHA)
+ * @brief SPI transfer flag which sets SPI Mode 0 (clock starts high, sample on
+ * leading edge).
+#define SPI_MODE_2 (SPI_CPOL|0)
+ * trailing edge).
+#define SPI_MODE_3 (SPI_CPOL|SPI_CPHA)
+ * @brief SPI transfer flag which selects the device by setting the chip select
+ * line.
+#define SPI_CS_HIGH 0x04
+ * @brief SPI transfer flag which triggers data transmission with the LSB being
+ * sent first.
+#define SPI_LSB_FIRST 0x08
+ * @brief SPI transfer flag which uses a shared wire for master input/slave
+ * output as well as master output/slave input.
+#define SPI_3WIRE 0x10
+ * @brief SPI transfer flag which initiates the loopback mode.
+#define SPI_LOOP 0x20
+ * @brief SPI transfer flag which indicates that no chip select is needed due to
+ * only one device on the bus.
+#define SPI_NO_CS 0x40
+ * @brief SPI transfer flag which pulls the slave to low level during pause.
+#define SPI_READY 0x80
+ * @brief SPI transfer flag which sets up dual mode for transmission.
+#define SPI_TX_DUAL 0x100
+ * @brief SPI transfer flag which sets up quad mode for transmission.
+#define SPI_TX_QUAD 0x200
+ * @brief SPI transfer flag which sets up dual mode for reception.
+#define SPI_RX_DUAL 0x400
+ * @brief SPI transfer flag which sets up quad mode for reception.
+#define SPI_RX_QUAD 0x800
+#define SPI_IOC_MAGIC 's'
+#define SPI_IOC_TRANSFER_MAGIC 'p'
+ * @brief SPI Transfer Structure.
+struct spi_ioc_transfer {
+   * @brief Buffer for receive data.
+  void *rx_buf;
+   * @brief Buffer for transmit data.
+  const void *tx_buf;
+   * @brief Length of rx_buf and tx_buf in bytes.
+  size_t len;
+   * @brief Sets the bitrate of the device.
+   * @brief Sets the delay after a transfer before the chip select status is
+   * changed and the next transfer is triggered.
+   * @brief Sets the device wordsize.
+   * @brief If true, device is deselected after transfer ended and before a new
+   * transfer is started.
+   * @brief Amount of bits that are used for reading.
+  uint8_t rx_nbits;
+   * @brief Amount of bits that are used for writing.
+  uint8_t tx_nbits;
+   * @brief Sets one of the possible modes that can be used for SPI transfers
+   * (dependent on clock phase and polarity).
+  uint32_t mode;
+   * @brief Indicates which device is currently used.
+  uint8_t cs;
+ * @brief Calculates the size of the SPI message.
+#define SPI_MSGSIZE(N) \
+  ((((N)*(sizeof (struct spi_ioc_transfer))) \
+  < (1 << SPI_MESSAGE_SIZE_BIT_LENGTH)) \
+  ? ((N)*(sizeof (struct spi_ioc_transfer))) : 0)
+ * @brief Transfers an array with SPI messages.
+#define SPI_IOC_MESSAGE(n) \
+  _IOW(SPI_IOC_TRANSFER_MAGIC, n, struct spi_ioc_transfer)
+ * @brief Reads and writes the SPI mode field (restriction to 8 bits).
+#define SPI_IOC_RD_MODE  _IOR(SPI_IOC_MAGIC, 1, uint8_t)
+#define SPI_IOC_WR_MODE  _IOW(SPI_IOC_MAGIC, 1, uint8_t)
+ * @brief Reads and writes the SPI LSB field.
+#define SPI_IOC_RD_LSB_FIRST  _IOR(SPI_IOC_MAGIC, 2, uint8_t)
+#define SPI_IOC_WR_LSB_FIRST  _IOW(SPI_IOC_MAGIC, 2, uint8_t)
+ * @brief Reads and writes the SPI Bits per word field.
+#define SPI_IOC_RD_BITS_PER_WORD  _IOR(SPI_IOC_MAGIC, 3, uint8_t)
+#define SPI_IOC_WR_BITS_PER_WORD  _IOW(SPI_IOC_MAGIC, 3, uint8_t)
+ * @brief Reads and writes the SPI maximum rx/tx speed field.
+#define SPI_IOC_RD_MAX_SPEED_HZ  _IOR(SPI_IOC_MAGIC, 4, uint32_t)
+#define SPI_IOC_WR_MAX_SPEED_HZ  _IOW(SPI_IOC_MAGIC, 4, uint32_t)
+ * @brief Reads and writes the SPI mode field (extended to 32 bits).
+#define SPI_IOC_RD_MODE32  _IOR(SPI_IOC_MAGIC, 5, uint32_t)
+#define SPI_IOC_WR_MODE32  _IOW(SPI_IOC_MAGIC, 5, uint32_t)
+#endif /* _UAPI_LINUX_SPI_H */
diff --git a/cpukit/dev/spi/spi-bus.c b/cpukit/dev/spi/spi-bus.c
index 0000000..a64b93f
--- /dev/null
+++ b/cpukit/dev/spi/spi-bus.c
@@ -0,0 +1,362 @@
+ * @file
+ * @brief Inter-Integrated Circuit (SPI) Bus Implementation
+ * @ingroup SPIBus
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <dev/spi/spi.h>
+#include <rtems/imfs.h>
+#include <string.h>
+  rtems_status_code sc;
+  sc = rtems_semaphore_obtain(bus->mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  _Assert(sc == RTEMS_SUCCESSFUL);
+  (void) sc;
+  sc = rtems_semaphore_release(bus->mutex);
+  (void) sc;
+  int err;
+  _Assert(msg_count > 0);
+  spi_bus_obtain(bus);
+  err = (*bus->transfer)(bus, msgs, msg_count);
+  spi_bus_release(bus);
+  return err;
+static ssize_t spi_bus_read(
+  rtems_libio_t *iop,
+  void *buffer,
+  size_t count
+  spi_bus *bus = IMFS_generic_get_context_by_iop(iop);
+  spi_ioc_transfer msg = {
+    .len = count,
+    .rx_buf = buffer,
+    .cs_change = bus->cs_change,
+    .cs = bus->data.cs,
+    .bits_per_word = bus->data.bits_per_word,
+    .mode = bus->data.mode,
+    .speed_hz = bus->data.speed_hz,
+    .delay_usecs = bus->data.delay_usecs
+  int err;
+  err = spi_bus_transfer(bus, &msg, 1);
+  if (err == 0) {
+    return msg.len;
+  } else {
+    rtems_set_errno_and_return_minus_one(-err);
+static ssize_t spi_bus_write(
+  const void *buffer,
+  size_t count
+    .len = (uint16_t) count,
+    .tx_buf = RTEMS_DECONST(void *, buffer),
+  int err;
+  if (err == 0) {
+    return msg.len;
+  } else {
+#if 1
+static int spi_get_ioc_message(uint32_t cmd, size_t *n_ioc)
+  uint32_t tmp;
+  tmp = (cmd >> SPI_MESSAGE_SIZE_POS) & ((1 << SPI_MESSAGE_SIZE_BIT_LENGTH)-1);
+  if ((tmp % sizeof(struct spi_ioc_transfer)) != 0){
+    return -EINVAL;
+  *n_ioc = tmp / sizeof(struct spi_ioc_transfer);
+  return 0;
+#endif
+static int spi_bus_ioctl(
+  ioctl_command_t command,
+  void *arg
+  int err;
+  uint32_t msg_count;
+  struct spi_ioc_transfer *ioc;
+  int i;
+  switch (command) {
+    case SPI_BUS_OBTAIN:
+      err = 0;
+      break;
+    case SPI_BUS_RELEASE:
+      err = 0;
+      break;
+    case SPI_BUS_GET_CONTROL:
+      *(spi_bus **) arg = bus;
+      err = 0;
+      break;
+    case SPI_BUS_SET_CLOCK:
+      err = (*bus->set_clock)(bus, (unsigned long) arg);
+      break;
+    case SPI_IOC_RD_MODE:
+    case SPI_IOC_RD_MODE32:
+      *(uint32_t *) arg = bus->data.mode;
+      err = 0;
+      break;
+    case SPI_IOC_RD_LSB_FIRST:
+      *(uint32_t *) arg = bus->lsb_first;
+      err = 0;
+      break;
+    case SPI_IOC_RD_BITS_PER_WORD:
+      *(uint32_t *) arg = bus->data.bits_per_word;
+      err = 0;
+      break;
+    case SPI_IOC_RD_MAX_SPEED_HZ:
+      *(uint32_t *) arg = bus->max_speed;
+      err = 0;
+      break;
+    case SPI_IOC_WR_MODE:
+    case SPI_IOC_WR_MODE32:
+      bus->data.mode = (uint32_t) arg;
+      err = 0;
+      break;
+    case SPI_IOC_WR_LSB_FIRST:
+      bus->lsb_first = (uint32_t) arg;
+      err = 0;
+      break;
+    case SPI_IOC_WR_BITS_PER_WORD:
+      bus->data.bits_per_word = (uint32_t) arg;
+      err = 0;
+      break;
+    case SPI_IOC_WR_MAX_SPEED_HZ:
+      bus->max_speed = (uint32_t) arg;
+      err = 0;
+      break;
+    default:
+      if (IOCGROUP(command) == SPI_IOC_TRANSFER_MAGIC) {
+        size_t n;
+        err = spi_get_ioc_message(command, &n);
+        if (err == 0){
+          err = spi_bus_transfer(bus, arg, n);
+      } else {
+        err = -EINVAL;
+      break;
+  if (err == 0) {
+    return 0;
+  } else {
+static const rtems_filesystem_file_handlers_r spi_bus_handler = {
+  .open_h = rtems_filesystem_default_open,
+  .close_h = rtems_filesystem_default_close,
+  .read_h = spi_bus_read,
+  .write_h = spi_bus_write,
+  .ioctl_h = spi_bus_ioctl,
+  .lseek_h = rtems_filesystem_default_lseek,
+  .fstat_h = IMFS_stat,
+  .ftruncate_h = rtems_filesystem_default_ftruncate,
+  .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+  .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
+  .fcntl_h = rtems_filesystem_default_fcntl,
+  .kqfilter_h = rtems_filesystem_default_kqfilter,
+  .poll_h = rtems_filesystem_default_poll,
+  .readv_h = rtems_filesystem_default_readv,
+  .writev_h = rtems_filesystem_default_writev
+static void spi_bus_node_destroy(IMFS_jnode_t *node)
+  spi_bus *bus;
+  bus = IMFS_generic_get_context_by_node(node);
+  (*bus->destroy)(bus);
+  IMFS_node_destroy_default(node);
+static const IMFS_node_control spi_bus_node_control = IMFS_GENERIC_INITIALIZER(
+  &spi_bus_handler,
+  IMFS_node_initialize_generic,
+  spi_bus_node_destroy
+  spi_bus *bus,
+  int rv;
+  rv = IMFS_make_generic_node(
+    bus_path,
+    S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
+    &spi_bus_node_control,
+    bus
+  if (rv != 0) {
+  return rv;
+static int spi_bus_transfer_default(
+  spi_bus *bus,
+  spi_ioc_transfer *msgs,
+  (void) bus;
+  (void) msgs;
+  (void) msg_count;
+  return -EIO;
+static int spi_bus_set_clock_default(spi_bus *bus, unsigned long clock)
+  (void) bus;
+  (void) clock;
+  return -EIO;
+static int spi_bus_do_init(
+  spi_bus *bus,
+  sc = rtems_semaphore_create(
+    rtems_build_name('S', 'P', 'I', ' '),
+    1,
+    RTEMS_BINARY_SEMAPHORE | RTEMS_INHERIT_PRIORITY | RTEMS_PRIORITY,
+    0,
+    &bus->mutex
+  if (sc != RTEMS_SUCCESSFUL) {
+    (*destroy)(bus);
+    rtems_set_errno_and_return_minus_one(ENOMEM);
+  bus->transfer = spi_bus_transfer_default;
+  bus->set_clock = spi_bus_set_clock_default;
+  bus->destroy = destroy;
+  /* Default max speed */
+  bus->max_speed = 50000000;
+  return 0;
+  sc = rtems_semaphore_delete(bus->mutex);
+  (void) sc;
+  spi_bus_destroy(bus);
+  free(bus);
+  memset(bus, 0, sizeof(*bus));
+  return spi_bus_do_init(bus, spi_bus_destroy);
+  spi_bus *bus = NULL;
+  if (size >= sizeof(*bus)) {
+    bus = calloc(1, size);
+    if (bus != NULL) {
+      int rv;
+      rv = spi_bus_do_init(bus, spi_bus_destroy_and_free);
+      if (rv != 0) {
+        return NULL;
+  return bus;
diff --git a/cpukit/dev/spi/spi-dev.c b/cpukit/dev/spi/spi-dev.c
index 0000000..72309ef
--- /dev/null
+++ b/cpukit/dev/spi/spi-dev.c
@@ -0,0 +1,291 @@
+ * @file
+ * @ingroup SPIDevice
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/score/assert.h>
+#include <fcntl.h>
+#include <unistd.h>
+static ssize_t spi_dev_read(
+  void *buffer,
+  size_t count
+  spi_dev *dev = IMFS_generic_get_context_by_iop(iop);
+  ssize_t n;
+  n = (*dev->read)(dev, buffer, count, iop->offset);
+  if (n >= 0) {
+    iop->offset += n;
+    return n;
+  } else {
+    rtems_set_errno_and_return_minus_one(-n);
+static ssize_t spi_dev_write(
+  size_t count
+  ssize_t n;
+  n = (*dev->write)(dev, buffer, count, iop->offset);
+  if (n >= 0) {
+    iop->offset += n;
+    return n;
+  } else {
+static int spi_dev_ioctl(
+  void *arg
+  int err;
+  err = (*dev->ioctl)(dev, command, arg);
+  if (err == 0) {
+    return 0;
+  } else {
+static int spi_dev_fstat(
+  const rtems_filesystem_location_info_t *loc,
+  struct stat *buf
+  spi_dev *dev = IMFS_generic_get_context_by_location(loc);
+  buf->st_size = (*dev->get_size)(dev);
+  buf->st_blksize = (*dev->get_block_size)(dev);
+  return IMFS_stat(loc, buf);
+static const rtems_filesystem_file_handlers_r spi_dev_handler = {
+  .read_h = spi_dev_read,
+  .write_h = spi_dev_write,
+  .ioctl_h = spi_dev_ioctl,
+  .lseek_h = rtems_filesystem_default_lseek_file,
+  .fstat_h = spi_dev_fstat,
+static void spi_dev_node_destroy(IMFS_jnode_t *node)
+  spi_dev *dev;
+  dev = IMFS_generic_get_context_by_node(node);
+  (*dev->destroy)(dev);
+static const IMFS_node_control spi_dev_node_control = IMFS_GENERIC_INITIALIZER(
+  &spi_dev_handler,
+  spi_dev_node_destroy
+  spi_dev *dev,
+  int rv;
+    dev_path,
+    &spi_dev_node_control,
+    dev
+  if (rv != 0) {
+  return rv;
+static ssize_t spi_dev_read_default(
+  spi_dev *dev,
+  void *buf,
+  size_t n,
+  off_t offset
+  (void) dev;
+  (void) buf;
+  (void) n;
+  (void) offset;
+  return -EIO;
+static ssize_t spi_dev_write_default(
+  spi_dev *dev,
+  const void *buf,
+  size_t n,
+  off_t offset
+  (void) dev;
+  (void) buf;
+  (void) n;
+  (void) offset;
+  return -EIO;
+static int spi_dev_ioctl_default(
+  spi_dev *dev,
+  void *arg
+  (void) dev;
+  (void) command;
+  (void) arg;
+  return -ENOTTY;
+static off_t spi_dev_get_size_default(spi_dev *dev)
+  (void) dev;
+  return 0;
+static blksize_t spi_dev_get_block_size_default(spi_dev *dev)
+  (void) dev;
+  return 1;
+static int spi_dev_do_init(
+  spi_dev *dev,
+  uint16_t address,
+  int rv;
+  dev->bus_fd = open(bus_path, O_RDWR);
+  if (dev->bus_fd < 0) {
+    (*destroy)(dev);
+    return -1;
+  rv = ioctl(dev->bus_fd, SPI_BUS_GET_CONTROL, &dev->bus);
+  if (rv != 0) {
+    (*destroy)(dev);
+    return -1;
+  dev->read = spi_dev_read_default;
+  dev->write = spi_dev_write_default;
+  dev->ioctl = spi_dev_ioctl_default;
+  dev->get_size = spi_dev_get_size_default;
+  dev->get_block_size = spi_dev_get_block_size_default;
+  dev->destroy = destroy;
+  dev->address = address;
+  return 0;
+  int rv;
+  rv = close(dev->bus_fd);
+  _Assert(dev->bus_fd < 0 || rv == 0);
+  (void) rv;
+  spi_dev_destroy(dev);
+  free(dev);
+  return spi_dev_do_init(dev, bus_path, address, spi_dev_destroy);
+  size_t size,
+  uint16_t address
+  spi_dev *dev = NULL;
+  if (size >= sizeof(*dev)) {
+    dev = calloc(1, size);
+    if (dev != NULL) {
+      int rv;
+      rv = spi_dev_do_init(dev, bus_path, address, spi_dev_destroy_and_free);
+      if (rv != 0) {
+        return NULL;
+  return dev;
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index dbd96cb..c00916a 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -9,6 +9,7 @@ _SUBDIRS += pwdgrp01
 _SUBDIRS += crypt01
 _SUBDIRS += sha
 _SUBDIRS += i2c01
+_SUBDIRS += spi01
 _SUBDIRS += newlib01
 _SUBDIRS += block17
 _SUBDIRS += exit02
diff --git a/testsuites/libtests/spi01/buffer_test_io.h b/testsuites/libtests/spi01/buffer_test_io.h
index 0000000..ac73352
--- /dev/null
+++ b/testsuites/libtests/spi01/buffer_test_io.h
@@ -0,0 +1,219 @@
+ *  Support for running the test output through a buffer
+#ifndef __BUFFER_TEST_IO_h
+#define __BUFFER_TEST_IO_h
+#include <rtems/bspIo.h>
+#include <rtems/test.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *  Uncomment this to get buffered test output.  When commented out,
+ *  test output behaves as it always has and is printed using stdio.
+/* #define TESTS_BUFFER_OUTPUT */
+/* #define TESTS_USE_PRINTK */
+ *  USE PRINTK TO MINIMIZE SIZE
+#if defined(TESTS_USE_PRINTK)
+#include <rtems/print.h>
+  #undef printf
+  #define printf(...) \
+    do { \
+       printk( __VA_ARGS__); \
+    } while (0)
+  #undef puts
+  #define puts(_s) \
+    do { \
+       printk( "%s\n", _s); \
+    } while (0)
+  #undef putchar
+  #define putchar(_c) \
+    do { \
+       printk( "%c", _c ); \
+    } while (0)
+  /* Do not call exit() since it closes stdin, etc and pulls in stdio code */
+  #define rtems_test_exit(_s) \
+    do { \
+      rtems_shutdown_executive(0); \
+    } while (0)
+  #define FLUSH_OUTPUT() \
+    do { \
+    } while (0)
+  #define TEST_BEGIN() printk(TEST_BEGIN_STRING)
+  #define TEST_END() printk(TEST_END_STRING)
+ *  BUFFER TEST OUTPUT
+#elif defined(TESTS_BUFFER_OUTPUT)
+  #include <stdio.h>
+  #include <stdlib.h>
+  #define _TEST_OUTPUT_BUFFER_SIZE 2048
+  extern char _test_output_buffer[_TEST_OUTPUT_BUFFER_SIZE];
+  void _test_output_append(char *);
+  void _test_output_flush(void);
+    do { \
+      _test_output_flush(); \
+      exit(_s); \
+    } while (0)
+  #undef printf
+    do { \
+       char _buffer[128]; \
+       sprintf( _buffer, __VA_ARGS__); \
+       _test_output_append( _buffer ); \
+    } while (0)
+  #undef puts
+  #define puts(_string) \
+    do { \
+       sprintf( _buffer, "%s\n", _string ); \
+    } while (0)
+  #undef putchar
+    do { \
+       char _buffer[2]; \
+       _buffer[0] = _c; \
+       _buffer[1] = '\0'; \
+    } while (0)
+  /* we write to stderr when there is a pause() */
+  #define FLUSH_OUTPUT() _test_output_flush()
+  #if defined(TEST_INIT) || defined(CONFIGURE_INIT)
+    char _test_output_buffer[_TEST_OUTPUT_BUFFER_SIZE];
+    int _test_output_buffer_index = 0;
+    void _test_output_append(char *_buffer)
+      char *p;
+      for ( p=_buffer ; *p ; p++ ) {
+        _test_output_buffer[_test_output_buffer_index++] = *p;
+        _test_output_buffer[_test_output_buffer_index]   = '\0';
+        #if 0
+	  if ( *p == '\n' ) {
+	    fprintf( stderr, "BUFFER -- %s", _test_output_buffer );
+	    _test_output_buffer_index = 0;
+	   _test_output_buffer[0]   = '\0';
+        #endif
+	if ( _test_output_buffer_index >= (_TEST_OUTPUT_BUFFER_SIZE - 80) )
+    #include <termios.h>
+    #include <unistd.h>
+      fprintf( stderr, "%s", _test_output_buffer );
+      tcdrain( 2 );
+    #endif
+#elif defined(TESTS_USE_PRINTF)
+    do { \
+      exit(_s); \
+    } while (0)
+    do { \
+      fflush(stdout); \
+    } while (0)
+  #define TEST_BEGIN() printf(TEST_BEGIN_STRING)
+  #define TEST_END() printf(TEST_END_STRING)
+ *  USE IPRINT
+#else
+  /* do not use iprintf if strict ansi mode */
+  #if defined(_NEWLIB_VERSION) && !defined(__STRICT_ANSI__)
+    #undef printf
+      do { \
+         fiprintf( stderr, __VA_ARGS__ ); \
+      } while (0)
+  #else
+    #undef printf
+      do { \
+         fprintf( stderr, __VA_ARGS__ ); \
+      } while (0)
+  #endif
+  #undef puts
+      do { \
+         printf( "%s\n", _s ); \
+      } while (0)
+  #undef putchar
+    do { \
+       printf( "%c", _c ); \
+    } while (0)
+    do { \
+      exit(_s); \
+    } while (0)
+    do { \
+      fflush(stdout); \
+    } while (0)
+  #define TEST_BEGIN() fiprintf( stderr, TEST_BEGIN_STRING)
+  #define TEST_END()  fiprintf( stderr, TEST_END_STRING)
+#endif
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/testsuites/libtests/spi01/init.c b/testsuites/libtests/spi01/init.c
index 0000000..e80ad18
--- /dev/null
+++ b/testsuites/libtests/spi01/init.c
@@ -0,0 +1,256 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifdef HAVE_CONFIG_H
+#endif
+#include <errno.h>
+#include <fcntl.h>
+#include <rtems/libcsupport.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SPI 1";
+typedef struct test_device test_device;
+struct test_device {
+  int (*transfer)(
+    spi_bus *bus,
+    uint32_t msg_count,
+    test_device *dev
+typedef struct {
+  test_device base;
+  char buf[3];
+} test_device_simple_read_write;
+typedef struct {
+  spi_bus base;
+  unsigned long clock;
+  test_device *device;
+  test_device_simple_read_write simple_read_write;
+} test_bus;
+static const char bus_path[] = "/dev/spi-0";
+static int test_simple_read_write_transfer(
+  spi_bus *bus,
+  test_device *base
+  (void)bus;
+  test_device_simple_read_write *dev = (test_device_simple_read_write *) base;
+  if (msg_count == 1 && msgs[0].len == sizeof(dev->buf)) {
+    if (msgs[0].rx_buf == 0){
+        memcpy(&dev->buf[0], msgs[0].tx_buf, sizeof(dev->buf));
+    } else if (msgs[0].tx_buf == 0){
+        memcpy(msgs[0].rx_buf, &dev->buf[0], sizeof(dev->buf));
+    } else {
+        return -EIO;
+  } else {
+    return -EIO;
+  return 0;
+static int test_transfer(spi_bus *base, spi_ioc_transfer *msgs, uint32_t msg_count)
+  test_bus *bus = (test_bus *) base;
+  test_device *dev;
+  dev = bus->device;
+  return (*dev->transfer)(&bus->base, msgs, msg_count, dev);
+static int test_set_clock(spi_bus *base, unsigned long clock)
+  bus->clock = clock;
+  return 0;
+static void test_destroy(spi_bus *base)
+  spi_bus_destroy_and_free(base);
+static void test_simple_read_write(test_bus *bus, int fd)
+  static const char zero[] = { 0, 0, 0 };
+  static const char abc[] = { 'a', 'b', 'c' };
+  int rv;
+  char buf[3];
+  ssize_t n;
+  errno = 0;
+  rv = ioctl(fd, 0xb00b);
+  rtems_test_assert(rv == -1);
+  rtems_test_assert(errno == ENOTTY);
+  errno = 0;
+  n = write(fd, &buf[0], 1000);
+  rtems_test_assert(n == -1);
+  rtems_test_assert(errno == EIO);
+  errno = 0;
+  n = read(fd, &buf[0], 1000);
+    memcmp(&bus->simple_read_write.buf[0], &zero[0], sizeof(buf)) == 0
+  n = write(fd, &abc[0], sizeof(buf));
+  rtems_test_assert(n == (ssize_t) sizeof(buf));
+    memcmp(&bus->simple_read_write.buf[0], &abc[0], sizeof(buf)) == 0
+  n = read(fd, &buf[0], sizeof(buf));
+  rtems_test_assert(memcmp(&buf[0], &abc[0], sizeof(buf)) == 0);
+static void test(void)
+  rtems_resource_snapshot snapshot;
+  test_bus *bus;
+  int rv;
+  int fd;
+  rtems_resource_snapshot_take(&snapshot);
+  bus = (test_bus *) spi_bus_alloc_and_init(sizeof(*bus));
+  rtems_test_assert(bus != NULL);
+  bus->base.transfer = test_transfer;
+  bus->base.set_clock = test_set_clock;
+  bus->base.destroy = test_destroy;
+  bus->simple_read_write.base.transfer = test_simple_read_write_transfer;
+  bus->device = &bus->simple_read_write.base;
+  rv = spi_bus_register(&bus->base, &bus_path[0]);
+  rtems_test_assert(rv == 0);
+  fd = open(&bus_path[0], O_RDWR);
+  rtems_test_assert(fd >= 0);
+  rtems_test_assert(bus->clock == 0);
+  rv = ioctl(fd, SPI_BUS_SET_CLOCK, 0xdeadbeefUL);
+  rtems_test_assert(bus->clock == 0xdeadbeef);
+  rv = ioctl(fd, SPI_BUS_OBTAIN);
+  rv = ioctl(fd, SPI_BUS_RELEASE);
+  rv = ioctl(fd, SPI_IOC_WR_MAX_SPEED_HZ, 0x12345678);
+  rv = ioctl(fd, SPI_IOC_RD_MAX_SPEED_HZ, &bus->base.max_speed);
+  rtems_test_assert(bus->base.max_speed == 0x12345678);
+  rv = ioctl(fd, SPI_IOC_WR_LSB_FIRST, 1);
+  rv = ioctl(fd, SPI_IOC_RD_LSB_FIRST, &bus->base.lsb_first);
+  rtems_test_assert(bus->base.lsb_first == 1);
+  rv = ioctl(fd, SPI_IOC_WR_MODE, 0xA5);
+  rv = ioctl(fd, SPI_IOC_RD_MODE, &bus->base.data.mode);
+  rtems_test_assert(bus->base.data.mode == 0xA5);
+  rv = ioctl(fd, SPI_IOC_WR_BITS_PER_WORD, 8);
+  rv = ioctl(fd, SPI_IOC_RD_BITS_PER_WORD, &bus->base.data.bits_per_word);
+  rtems_test_assert(bus->base.data.bits_per_word == 8);
+  rv = ioctl(fd, SPI_IOC_WR_MODE32, 0x5A5A5A5A);
+  rv = ioctl(fd, SPI_IOC_RD_MODE32, &bus->base.data.mode);
+  rtems_test_assert(bus->base.data.mode == 0x5A5A5A5A);
+  test_simple_read_write(bus, fd);
+  rv = close(fd);
+  rv = unlink(&bus_path[0]);
+  rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
+static void Init(rtems_task_argument arg)
+  (void)arg;
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_MICROSECONDS_PER_TICK 2000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 7
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/spi01/spi01.doc b/testsuites/libtests/spi01/spi01.doc
index 0000000..754aa8a
--- /dev/null
+++ b/testsuites/libtests/spi01/spi01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spi01
+directives:
+  TBD
+concepts:
+  - Ensure that the SPI driver framework works.
diff --git a/testsuites/libtests/spi01/spi01.scn b/testsuites/libtests/spi01/spi01.scn
index 0000000..6d8f6cc
--- /dev/null
+++ b/testsuites/libtests/spi01/spi01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SPI 1 ***
+*** END OF TEST SPI 1 ***
diff --git a/testsuites/libtests/spi01/tmacros.h b/testsuites/libtests/spi01/tmacros.h
index 0000000..d8aec2a
--- /dev/null
+++ b/testsuites/libtests/spi01/tmacros.h
@@ -0,0 +1,372 @@
+ * @file
+ * This include file contains macros which are useful in the RTEMS
+ * test suites.
+ *  COPYRIGHT (c) 1989-2014.
+ *  On-Line Applications Research Corporation (OAR).
+#ifndef __TMACROS_h
+#define __TMACROS_h
+#include <inttypes.h>
+#include <bsp.h>    /* includes <rtems.h> */
+#include <ctype.h>
+#include <stdio.h>
+#include <rtems/error.h>
+#include <rtems/score/threaddispatch.h>
+#include <buffer_test_io.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define FOREVER 1                  /* infinite loop */
+#ifdef CONFIGURE_INIT
+#define TEST_EXTERN
+#else
+#define TEST_EXTERN extern
+#endif
+ *  Check that that the dispatch disable level is proper for the
+ *  mode/state of the test.  Normally it should be 0 when in task space.
+ *  This test is only valid when in a non-SMP system.  In an smp system
+ *  another cpu may be accessing the core at any point when this core
+ *  does not have it locked.
+#if defined SMPTEST
+ #define check_dispatch_disable_level( _expect )
+#else
+ #define check_dispatch_disable_level( _expect ) \
+  do { \
+    if ( (_expect) != -1 \
+           && (((!_Thread_Dispatch_is_enabled()) == false && (_expect) != 0) \
+             || ((!_Thread_Dispatch_is_enabled()) && (_expect) == 0)) \
+      printk( \
+        "\n_Thread_Dispatch_disable_level is (%i)" \
+           " not %d detected at %s:%d\n", \
+         !_Thread_Dispatch_is_enabled(), (_expect), __FILE__, __LINE__ ); \
+      FLUSH_OUTPUT(); \
+      rtems_test_exit( 1 ); \
+  } while ( 0 )
+#endif
+ *  Check that that the allocator mutex is not owned by the executing thread.
+#include <rtems/score/apimutex.h>
+#define check_if_allocator_mutex_is_not_owned() \
+  do { \
+    if ( _RTEMS_Allocator_is_owner() ) { \
+      printk( \
+        "\nRTEMS Allocator Mutex is owned by executing thread " \
+          "and should not be.\n" \
+        "Detected at %s:%d\n", \
+        __FILE__, \
+        __LINE__ \
+      FLUSH_OUTPUT(); \
+  } while ( 0 )
+ *  These macros properly report errors within the Classic API
+#define directive_failed( _dirstat, _failmsg )  \
+ fatal_directive_status( _dirstat, RTEMS_SUCCESSFUL, _failmsg )
+#define directive_failed_with_level( _dirstat, _failmsg, _level )  \
+ fatal_directive_status_with_level( \
+      _dirstat, RTEMS_SUCCESSFUL, _failmsg, _level )
+#define fatal_directive_status( _stat, _desired, _msg ) \
+  fatal_directive_status_with_level( _stat, _desired, _msg, 0 )
+#define fatal_directive_check_status_only( _stat, _desired, _msg ) \
+  do { \
+    if ( (_stat) != (_desired) ) { \
+      printf( "\n%s FAILED -- expected (%s) got (%s)\n", \
+              (_msg), rtems_status_text(_desired), rtems_status_text(_stat) ); \
+      FLUSH_OUTPUT(); \
+      rtems_test_exit( _stat ); \
+  } while ( 0 )
+#define fatal_directive_status_with_level( _stat, _desired, _msg, _level ) \
+  do { \
+    check_dispatch_disable_level( _level ); \
+    check_if_allocator_mutex_is_not_owned(); \
+    fatal_directive_check_status_only( _stat, _desired, _msg ); \
+  } while ( 0 )
+ *  These macros properly report errors from the POSIX API
+#define posix_service_failed( _dirstat, _failmsg )  \
+ fatal_posix_service_status( _dirstat, 0, _failmsg )
+#define posix_service_failed_with_level( _dirstat, _failmsg, _level )  \
+ fatal_posix_service_status_with_level( _dirstat, 0, _failmsg, _level )
+#define fatal_posix_service_status_errno( _stat, _desired, _msg ) \
+  if ( (_stat != -1) && (errno) != (_desired) ) { \
+    long statx = _stat; \
+    check_dispatch_disable_level( 0 ); \
+    printf( "\n%s FAILED -- expected (%d - %s) got (%ld %d - %s)\n", \
+	    (_msg), _desired, strerror(_desired), \
+            statx, errno, strerror(errno) ); \
+    FLUSH_OUTPUT(); \
+#define fatal_posix_service_status( _stat, _desired, _msg ) \
+  fatal_posix_service_status_with_level( _stat, _desired, _msg, 0 )
+#define fatal_posix_service_status_with_level( _stat, _desired, _msg, _level ) \
+  do { \
+      printf( "\n%s FAILED -- expected (%d - %s) got (%d - %s)\n", \
+              (_msg), _desired, strerror(_desired), _stat, strerror(_stat) ); \
+      printf( "\n FAILED -- errno (%d - %s)\n", \
+              errno, strerror(errno) ); \
+      FLUSH_OUTPUT(); \
+  } while ( 0 )
+ * This macro evaluates the semaphore id returned.
+#define fatal_posix_sem( _ptr, _msg ) \
+  if ( (_ptr != SEM_FAILED) ) { \
+    printf( "\n%s FAILED -- expected (-1) got (%p - %d/%s)\n", \
+	    (_msg), _ptr, errno, strerror(errno) ); \
+    FLUSH_OUTPUT(); \
+    rtems_test_exit( -1 ); \
+ * This macro evaluates the message queue id returned.
+#define fatal_posix_mqd( _ptr, _msg ) \
+  if ( (_ptr != (mqd_t) -1) ) { \
+    printf( "\n%s FAILED -- expected (-1) got (%" PRId32 " - %d/%s)\n", \
+    FLUSH_OUTPUT(); \
+ *  Generic integer version of the error reporting
+#define int_service_failed( _dirstat, _failmsg )  \
+ fatal_int_service_status( _dirstat, RTEMS_SUCCESSFUL, _failmsg )
+#define int_service_failed_with_level( _dirstat, _failmsg, _level )  \
+ fatal_int_service_status_with_level( \
+#define fatal_int_service_status( _stat, _desired, _msg ) \
+  fatal_int_service_status_with_level( _stat, _desired, _msg, 0 )
+#define fatal_int_service_status_with_level( _stat, _desired, _msg, _level ) \
+  do { \
+      printf( "\n%s FAILED -- expected (%d) got (%d)\n", \
+              (_msg), (_desired), (_stat) ); \
+      FLUSH_OUTPUT(); \
+  } while ( 0 )
+ *  Print the time
+#define sprint_time(_str, _s1, _tb, _s2) \
+  do { \
+    sprintf( (_str), "%s%02d:%02d:%02d   %02d/%02d/%04d%s", \
+       _s1, (_tb)->hour, (_tb)->minute, (_tb)->second, \
+       (_tb)->month, (_tb)->day, (_tb)->year, _s2 ); \
+  } while ( 0 )
+#define print_time(_s1, _tb, _s2) \
+  do { \
+    printf( "%s%02" PRIu32 ":%02" PRIu32 ":%02" PRIu32 "   %02" PRIu32 "/%02" PRIu32 "/%04" PRIu32 "%s", \
+  } while ( 0 )
+#define put_dot( _c ) \
+  do { \
+    putchar( _c ); \
+    FLUSH_OUTPUT(); \
+  } while ( 0 )
+#define new_line  puts( "" )
+#define puts_nocr printf
+#ifdef RTEMS_TEST_NO_PAUSE
+#define rtems_test_pause() \
+    do { \
+      printf( "<pause>\n" ); \
+      FLUSH_OUTPUT(); \
+  } while ( 0 )
+#define rtems_test_pause_and_screen_number( _screen ) \
+  do { \
+    printf( "<pause - screen %d>\n", (_screen) ); \
+    FLUSH_OUTPUT(); \
+  } while ( 0 )
+#else
+  do { \
+    char buffer[ 80 ]; \
+    printf( "<pause>" ); \
+    FLUSH_OUTPUT(); \
+    gets( buffer ); \
+    puts( "" ); \
+  } while ( 0 )
+  do { \
+    printf( "<pause - screen %d>", (_screen) ); \
+    FLUSH_OUTPUT(); \
+    gets( buffer ); \
+    puts( "" ); \
+  } while ( 0 )
+#endif
+#define put_name( name, crlf ) \
+{ int c0, c1, c2, c3; \
+  c0 = (name >> 24) & 0xff; \
+  c1 = (name >> 16) & 0xff; \
+  c2 = (name >> 8) & 0xff; \
+  c3 = name & 0xff; \
+  putchar( (isprint(c0)) ? c0 : '*' ); \
+  if ( c1 ) putchar( (isprint(c1)) ? c1 : '*' ); \
+  if ( c2 ) putchar( (isprint(c2)) ? c2 : '*' ); \
+  if ( c3 ) putchar( (isprint(c3)) ? c3 : '*' ); \
+  if ( crlf ) \
+    putchar( '\n' ); \
+#ifndef build_time
+#define build_time( TB, MON, DAY, YR, HR, MIN, SEC, TK ) \
+  { (TB)->year   = YR;  \
+    (TB)->month  = MON; \
+    (TB)->day    = DAY; \
+    (TB)->hour   = HR;  \
+    (TB)->minute = MIN; \
+    (TB)->second = SEC; \
+    (TB)->ticks  = TK; }
+#endif
+#define task_number( tid ) \
+  ( rtems_object_id_get_index( tid ) - \
+      rtems_configuration_get_rtems_api_configuration()-> \
+        number_of_initialization_tasks )
+#define rtems_test_assert(__exp) \
+  do { \
+    if (!(__exp)) { \
+      printf( "%s: %d %s\n", __FILE__, __LINE__, #__exp ); \
+      rtems_test_exit(0); \
+  } while (0)
+ * Various inttypes.h-stype macros to assist printing
+ * certain system types on different targets.
+#if defined(RTEMS_USE_16_BIT_OBJECT)
+#define PRIxrtems_id PRIx16
+#else
+#define PRIxrtems_id PRIx32
+#endif
+/* c.f. cpukit/score/include/rtems/score/priority.h */
+#define PRIdPriority_Control PRId32
+#define PRIxPriority_Control PRIx32
+/* rtems_task_priority is a typedef to Priority_Control */
+#define PRIdrtems_task_priority PRIdPriority_Control
+#define PRIxrtems_task_priority PRIxPriority_Control
+/* c.f. cpukit/score/include/rtems/score/watchdog.h */
+#define PRIdWatchdog_Interval PRIu32
+/* rtems_interval is a typedef to Watchdog_Interval */
+#define PRIdrtems_interval    PRIdWatchdog_Interval
+/* c.f. cpukit/score/include/rtems/score/thread.h */
+#define PRIdThread_Entry_numeric_type PRIuPTR
+/* rtems_task_argument is a typedef to Thread_Entry_numeric_type */
+#define PRIdrtems_task_argument PRIdThread_Entry_numeric_type
+/* rtems_event_set is a typedef to unit32_t */
+#define PRIxrtems_event_set PRIx32
+/* HACK: newlib defines pthread_t as a typedef to __uint32_t */
+/* HACK: There is no portable way to print pthread_t's */
+#define PRIxpthread_t PRIx32
+/* rtems_signal_set is a typedef to uint32_t */
+#define PRIxrtems_signal_set PRIx32
+/* newlib's ino_t is a typedef to "unsigned long" */
+#define PRIxino_t "lx"
+ * This assists in clearly disabling warnings on GCC in certain very
+ * specific cases.
+ * + -Wnon-null - If a method is declared as never having a NULL first
+ *   parameter. We need to explicitly disable this compiler warning to make
+ *   the code warning free.
+#ifdef __GNUC__
+  #define COMPILER_DIAGNOSTIC_SETTINGS_PUSH _Pragma("GCC diagnostic push")
+  #define COMPILER_DIAGNOSTIC_SETTINGS_POP _Pragma("GCC diagnostic pop")
+  #define COMPILER_DIAGNOSTIC_SETTINGS_DISABLE_NONNULL \
+    _Pragma("GCC diagnostic ignored \"-Wnonnull\"")
+#else
+#endif
+#ifdef __cplusplus
+#endif
+#endif
1.8.4.5
