[PATCH v2] cpukit: New SPI framework implemented #2776
Alexander Krutwig
alexander.krutwig at embedded-brains.de
Mon Sep 12 13:47:01 UTC 2016
Linux Userspace API was taken as a template
Test libtests/spi01 is included into testsuite
cpukit/dev/Makefile.am | 10 +
cpukit/dev/include/dev/spi/spi.h | 452 +++++++++++++++++++++++++++++
cpukit/dev/include/linux/spi/spidev.h | 263 +++++++++++++++++
cpukit/dev/spi/spi-bus.c | 345 ++++++++++++++++++++++
cpukit/dev/spi/spi-dev.c | 291 +++++++++++++++++++
testsuites/libtests/Makefile.am | 1 +
testsuites/libtests/spi01/buffer_test_io.h | 219 ++++++++++++++
testsuites/libtests/spi01/init.c | 256 ++++++++++++++++
testsuites/libtests/spi01/spi01.doc | 11 +
testsuites/libtests/spi01/spi01.scn | 2 +
testsuites/libtests/spi01/tmacros.h | 372 ++++++++++++++++++++++++
11 files changed, 2222 insertions(+)
create mode 100644 cpukit/dev/include/dev/spi/spi.h
create mode 100644 cpukit/dev/include/linux/spi/spidev.h
create mode 100644 cpukit/dev/spi/spi-bus.c
create mode 100644 cpukit/dev/spi/spi-dev.c
create mode 100644 testsuites/libtests/spi01/buffer_test_io.h
create mode 100644 testsuites/libtests/spi01/init.c
create mode 100644 testsuites/libtests/spi01/spi01.doc
create mode 100644 testsuites/libtests/spi01/spi01.scn
create mode 100644 testsuites/libtests/spi01/tmacros.h
diff --git a/cpukit/dev/Makefile.am b/cpukit/dev/Makefile.am
index 47a1585..3d39e38 100644
--- a/cpukit/dev/Makefile.am
+++ b/cpukit/dev/Makefile.am
@@ -11,11 +11,19 @@ include_dev_i2c_HEADERS += include/dev/i2c/gpio-nxp-pca9535.h
include_dev_i2c_HEADERS += include/dev/i2c/i2c.h
include_dev_i2c_HEADERS += include/dev/i2c/switch-nxp-pca9548a.h
+include_dev_spidir = $(includedir)/dev/spi
+include_dev_spi_HEADERS =
+include_dev_spi_HEADERS += include/dev/spi/spi.h
include_linuxdir = $(includedir)/linux
include_linux_HEADERS =
include_linux_HEADERS += include/linux/i2c.h
include_linux_HEADERS += include/linux/i2c-dev.h
+include_linux_spidir = $(includedir)/linux/spi
+include_linux_spi_HEADERS =
+include_linux_spi_HEADERS += include/linux/spi/spidev.h
noinst_LIBRARIES = libdev.a
libdev_a_SOURCES =
@@ -24,6 +32,8 @@ libdev_a_SOURCES += i2c/gpio-nxp-pca9535.c
libdev_a_SOURCES += i2c/i2c-bus.c
libdev_a_SOURCES += i2c/i2c-dev.c
libdev_a_SOURCES += i2c/switch-nxp-pca9548a.c
+libdev_a_SOURCES += spi/spi-dev.c
+libdev_a_SOURCES += spi/spi-bus.c
include $(srcdir)/preinstall.am
include $(top_srcdir)/automake/local.am
diff --git a/cpukit/dev/include/dev/spi/spi.h b/cpukit/dev/include/dev/spi/spi.h
new file mode 100644
index 0000000..8d1ad04
--- /dev/null
+++ b/cpukit/dev/include/dev/spi/spi.h
@@ -0,0 +1,452 @@
+ * @file
+ * @brief Inter-Integrated Circuit (SPI) Driver API
+ * @ingroup SPI
+ * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+#ifndef _DEV_SPI_SPI_H
+#define _DEV_SPI_SPI_H
+#include <linux/spi/spidev.h>
+#include <rtems.h>
+#include <rtems/seterr.h>
+#include <sys/ioctl.h>
+#include <sys/stat.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+typedef struct spi_ioc_transfer spi_ioc_transfer;
+typedef struct spi_bus spi_bus;
+typedef struct spi_dev spi_dev;
+typedef struct spi_rdwr_ioctl_data spi_rdwr_ioctl_data;
+ * @defgroup SPI Inter-Integrated Circuit (SPI) Driver
+ * @brief Inter-Integrated Circuit (SPI) bus and device driver support.
+ * @defgroup SPIBus SPI Bus Driver
+ * @ingroup SPI
+ * @name SPI IO Control Commands
+ * @brief Obtains the bus.
+ * This command has no argument.
+#define SPI_BUS_OBTAIN 0x800
+ * @brief Releases the bus.
+#define SPI_BUS_RELEASE 0x801
+ * @brief Gets the bus control.
+ * The argument type is a pointer to spi_bus pointer.
+#define SPI_BUS_GET_CONTROL 0x802
+ * @brief Sets the bus clock in Hz.
+ * The argument type is unsigned long.
+#define SPI_BUS_SET_CLOCK 0x803
+ * @brief Default SPI bus clock in Hz.
+#define SPI_BUS_CLOCK_DEFAULT 100000
+ * @brief Data Field of the SPI bus control
+typedef struct {
+ * @brief Current mode.
+ uint32_t mode;
+ * @brief Indicates the bits per word used on the device.
+ uint8_t bits_per_word;
+ * @brief Indicates the speed of the current device message.
+ uint32_t speed_hz;
+ * @brief Indicates the delay between transfers on different chip select
+ * devices.
+ uint16_t delay_usecs;
+ * @brief Indicates which device is selected by chip select
+ uint8_t cs;
+} spi_bus_data;
+ * @brief SPI bus control.
+struct spi_bus {
+ * @brief Transfers SPI messages.
+ * @param[in] bus The bus control.
+ * @param[in] msgs The messages to transfer.
+ * @param[in] msg_count The count of messages to transfer. It must be
+ * positive.
+ * @retval 0 Successful operation.
+ * @retval negative Negative error number in case of an error.
+ int (*transfer)(spi_bus *bus, spi_ioc_transfer *msgs, uint32_t msg_count);
+ * @brief Sets the bus clock.
+ * @param[in] clock The desired bus clock in Hz.
+ int (*set_clock)(spi_bus *bus, unsigned long clock);
+ * @brief Destroys the bus.
+ void (*destroy)(spi_bus *bus);
+ * @brief Mutex to protect the bus access.
+ rtems_id mutex;
+ * @brief Maximum Speed in Hz
+ uint32_t max_speed;
+ * @brief Indicates if LSB is supposed to be transmitted first.
+ uint8_t lsb_first;
+ * @brief Indicates if chip select must be set high after transfer.
+ uint8_t cs_change;
+ * @brief Data field of the bus control.
+ spi_bus_data data;
+ * @brief Initializes a bus control.
+ * After a sucessful initialization the bus control must be destroyed via
+ * spi_bus_destroy(). A registered bus control will be automatically destroyed
+ * in case the device file is unlinked. Make sure to call spi_bus_destroy() in
+ * a custom destruction handler.
+ * @retval -1 An error occurred. The errno is set to indicate the error.
+ * @see spi_bus_register()
+int spi_bus_init(spi_bus *bus);
+ * @brief Allocates a bus control from the heap and initializes it.
+ * After a sucessful allocation and initialization the bus control must be
+ * destroyed via spi_bus_destroy_and_free(). A registered bus control will be
+ * automatically destroyed in case the device file is unlinked. Make sure to
+ * call spi_bus_destroy_and_free() in a custom destruction handler.
+ * @param[in] size The size of the bus control. This enables the addition of
+ * bus controller specific data to the base bus control. The bus control is
+ * zero initialized.
+ * @retval non-NULL The new bus control.
+ * @retval NULL An error occurred. The errno is set to indicate the error.
+spi_bus *spi_bus_alloc_and_init(size_t size);
+ * @brief Destroys a bus control.
+void spi_bus_destroy(spi_bus *bus);
+ * @brief Destroys a bus control and frees its memory.
+void spi_bus_destroy_and_free(spi_bus *bus);
+ * @brief Registers a bus control.
+ * This function claims ownership of the bus control regardless if the
+ * registration is successful or not.
+ * @param[in] bus_path The path to the bus device file.
+int spi_bus_register(
+ spi_bus *bus,
+ const char *bus_path
+void spi_bus_obtain(spi_bus *bus);
+void spi_bus_release(spi_bus *bus);
+ * The bus is obtained before the transfer and released afterwards.
+ * positive.
+int spi_bus_transfer(spi_bus *bus, spi_ioc_transfer *msgs, uint32_t msg_count);
+ * @defgroup SPIDevice SPI Device Driver
+ * @ingroup SPI
+ * @brief Base number for device IO control commands.
+#define SPI_DEV_IO_CONTROL 0x900
+ * @brief SPI slave device control.
+struct spi_dev {
+ * @brief Reads from the device.
+ * @retval non-negative Bytes transferred from device.
+ ssize_t (*read)(spi_dev *dev, void *buf, size_t n, off_t offset);
+ * @brief Writes to the device.
+ * @retval non-negative Bytes transferred to device.
+ ssize_t (*write)(spi_dev *dev, const void *buf, size_t n, off_t offset);
+ * @brief Device IO control.
+ int (*ioctl)(spi_dev *dev, ioctl_command_t command, void *arg);
+ * @brief Gets the file size.
+ off_t (*get_size)(spi_dev *dev);
+ * @brief Gets the file block size.
+ blksize_t (*get_block_size)(spi_dev *dev);
+ * @brief Destroys the device.
+ void (*destroy)(spi_dev *dev);
+ * @brief The bus control.
+ spi_bus *bus;
+ * @brief The device address.
+ uint16_t address;
+ * @brief File descriptor of the bus.
+ * This prevents destruction of the bus since we hold a reference to it with
+ * this.
+ int bus_fd;
+ * @brief Initializes a device control.
+ * After a sucessful initialization the device control must be destroyed via
+ * spi_dev_destroy(). A registered device control will be automatically
+ * destroyed in case the device file is unlinked. Make sure to call
+ * spi_dev_destroy_and_free() in a custom destruction handler.
+ * @param[in] device The device control.
+ * @param[in] address The address of the device.
+ * @see spi_dev_register()
+int spi_dev_init(spi_dev *dev, const char *bus_path, uint16_t address);
+ * @brief Allocates a device control from the heap and initializes it.
+ * After a sucessful allocation and initialization the device control must be
+ * destroyed via spi_dev_destroy_and_free(). A registered device control will
+ * be automatically destroyed in case the device file is unlinked. Make sure
+ * to call spi_dev_destroy_and_free() in a custom destruction handler.
+ * @param[in] size The size of the device control. This enables the addition
+ * of device specific data to the base device control. The device control is
+ * @retval non-NULL The new device control.
+spi_dev *spi_dev_alloc_and_init(
+ size_t size,
+ const char *bus_path,
+ uint16_t address
+ * @brief Destroys a device control.
+ * @param[in] dev The device control.
+void spi_dev_destroy(spi_dev *dev);
+ * @brief Destroys a device control and frees its memory.
+void spi_dev_destroy_and_free(spi_dev *dev);
+ * @brief Registers a device control.
+ * This function claims ownership of the device control regardless if the
+ * @param[in] dev The dev control.
+ * @param[in] dev_path The path to the device file of the device.
+int spi_dev_register(
+ spi_dev *dev,
+ const char *dev_path
+/** @} */ /* end of spi device driver */
+#ifdef __cplusplus
+#endif /* _DEV_SPI_SPI_H */
diff --git a/cpukit/dev/include/linux/spi/spidev.h b/cpukit/dev/include/linux/spi/spidev.h
index 0000000..878dd42
--- /dev/null
+++ b/cpukit/dev/include/linux/spi/spidev.h
@@ -0,0 +1,263 @@
+ * @file
+ * @brief RTEMS Port of Linux SPI API
+ * @ingroup SPILinux
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#ifndef _UAPI_LINUX_SPI_H
+#define _UAPI_LINUX_SPI_H
+#include <stdint.h>
+#include <stdlib.h>
+#include <sys/ioccom.h>
+ * @defgroup SPILinux Linux SPI User-Space API
+ * @ingroup SPI
+ * @brief RTEMS port of Linux SPI user-space API.
+ * Additional documentation is available through the Linux sources, see
+ * - /usr/src/linux/include/uapi/linux/spidev.h, and
+ * - /usr/src/linux/Documentation/spi.
+#define SPI_MESSAGE_SIZE_POS 16
+#define SPI_MESSAGE_SIZE_BIT_LENGTH 14
+#define SPI_MESSAGE_AMOUNT_MASK 0xFF
+ * @name SPI Transfer Flags
+ * @brief SPI transfer flag which sets the clock phase.
+#define SPI_CPHA 0x01
+ * @brief SPI transfer flag which sets the clock polarity.
+#define SPI_CPOL 0x02
+ * @brief SPI transfer flag which sets SPI Mode 0 (clock starts low, sample on
+ * leading edge).
+#define SPI_MODE_0 (0|0)
+ * trailing edge).
+#define SPI_MODE_1 (0|SPI_CPHA)
+ * @brief SPI transfer flag which sets SPI Mode 0 (clock starts high, sample on
+ * leading edge).
+#define SPI_MODE_2 (SPI_CPOL|0)
+ * trailing edge).
+#define SPI_MODE_3 (SPI_CPOL|SPI_CPHA)
+ * @brief SPI transfer flag which selects the device by setting the chip select
+ * line.
+#define SPI_CS_HIGH 0x04
+ * @brief SPI transfer flag which triggers data transmission with the LSB being
+ * sent first.
+#define SPI_LSB_FIRST 0x08
+ * @brief SPI transfer flag which uses a shared wire for master input/slave
+ * output as well as master output/slave input.
+#define SPI_3WIRE 0x10
+ * @brief SPI transfer flag which initiates the loopback mode.
+#define SPI_LOOP 0x20
+ * @brief SPI transfer flag which indicates that no chip select is needed due to
+ * only one device on the bus.
+#define SPI_NO_CS 0x40
+ * @brief SPI transfer flag which pulls the slave to low level during pause.
+#define SPI_READY 0x80
+ * @brief SPI transfer flag which sets up dual mode for transmission.
+#define SPI_TX_DUAL 0x100
+ * @brief SPI transfer flag which sets up quad mode for transmission.
+#define SPI_TX_QUAD 0x200
+ * @brief SPI transfer flag which sets up dual mode for reception.
+#define SPI_RX_DUAL 0x400
+ * @brief SPI transfer flag which sets up quad mode for reception.
+#define SPI_RX_QUAD 0x800
+#define SPI_IOC_MAGIC 's'
+#define SPI_IOC_TRANSFER_MAGIC 'p'
+ * @brief SPI Transfer Structure.
+struct spi_ioc_transfer {
+ * @brief Buffer for receive data.
+ void *rx_buf;
+ * @brief Buffer for transmit data.
+ const void *tx_buf;
+ * @brief Length of rx_buf and tx_buf in bytes.
+ size_t len;
+ * @brief Sets the bitrate of the device.
+ * @brief Sets the delay after a transfer before the chip select status is
+ * changed and the next transfer is triggered.
+ * @brief Sets the device wordsize.
+ * @brief If true, device is deselected after transfer ended and before a new
+ * transfer is started.
+ * @brief Amount of bits that are used for reading.
+ uint8_t rx_nbits;
+ * @brief Amount of bits that are used for writing.
+ uint8_t tx_nbits;
+ * @brief Sets one of the possible modes that can be used for SPI transfers
+ * (dependent on clock phase and polarity).
+ uint32_t mode;
+ * @brief Indicates which device is currently used.
+ uint8_t cs;
+ * @brief Calculates the size of the SPI message.
+#define SPI_MSGSIZE(N) \
+ ((((N)*(sizeof (struct spi_ioc_transfer))) \
+ < (1 << SPI_MESSAGE_SIZE_BIT_LENGTH)) \
+ ? ((N)*(sizeof (struct spi_ioc_transfer))) : 0)
+ * @brief Transfers an array with SPI messages.
+#define SPI_IOC_MESSAGE(n) \
+ _IOW(SPI_IOC_TRANSFER_MAGIC, n, struct spi_ioc_transfer)
+ * @brief Reads the SPI mode field (restriction to 8 bits).
+#define SPI_IOC_RD_MODE _IOR(SPI_IOC_MAGIC, 1, uint8_t)
+ * @brief Writes the SPI mode field (restriction to 8 bits).
+#define SPI_IOC_WR_MODE _IOW(SPI_IOC_MAGIC, 1, uint8_t)
+ * @brief Reads the SPI LSB field.
+#define SPI_IOC_RD_LSB_FIRST _IOR(SPI_IOC_MAGIC, 2, uint8_t)
+ * @brief Writes the SPI LSB field.
+#define SPI_IOC_WR_LSB_FIRST _IOW(SPI_IOC_MAGIC, 2, uint8_t)
+ * @brief Reads the SPI Bits per word field.
+#define SPI_IOC_RD_BITS_PER_WORD _IOR(SPI_IOC_MAGIC, 3, uint8_t)
+ * @brief Writes the SPI Bits per word field.
+#define SPI_IOC_WR_BITS_PER_WORD _IOW(SPI_IOC_MAGIC, 3, uint8_t)
+ * @brief Reads the SPI maximum rx/tx speed field.
+#define SPI_IOC_RD_MAX_SPEED_HZ _IOR(SPI_IOC_MAGIC, 4, uint32_t)
+ * @brief Writes the SPI maximum rx/tx speed field.
+#define SPI_IOC_WR_MAX_SPEED_HZ _IOW(SPI_IOC_MAGIC, 4, uint32_t)
+ * @brief Reads the SPI mode field (extended to 32 bits).
+#define SPI_IOC_RD_MODE32 _IOR(SPI_IOC_MAGIC, 5, uint32_t)
+ * @brief Writes the SPI mode field (extended to 32 bits).
+#define SPI_IOC_WR_MODE32 _IOW(SPI_IOC_MAGIC, 5, uint32_t)
+#endif /* _UAPI_LINUX_SPI_H */
diff --git a/cpukit/dev/spi/spi-bus.c b/cpukit/dev/spi/spi-bus.c
index 0000000..87254cb
--- /dev/null
+++ b/cpukit/dev/spi/spi-bus.c
@@ -0,0 +1,345 @@
+ * @file
+ * @brief Inter-Integrated Circuit (SPI) Bus Implementation
+ * @ingroup SPIBus
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <dev/spi/spi.h>
+#include <rtems/imfs.h>
+#include <string.h>
+ rtems_status_code sc;
+ sc = rtems_semaphore_obtain(bus->mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ _Assert(sc == RTEMS_SUCCESSFUL);
+ (void) sc;
+ sc = rtems_semaphore_release(bus->mutex);
+ (void) sc;
+ int err;
+ _Assert(msg_count > 0);
+ spi_bus_obtain(bus);
+ err = (*bus->transfer)(bus, msgs, msg_count);
+ spi_bus_release(bus);
+ return err;
+static ssize_t spi_bus_read(
+ rtems_libio_t *iop,
+ void *buffer,
+ size_t count
+ spi_bus *bus = IMFS_generic_get_context_by_iop(iop);
+ spi_ioc_transfer msg = {
+ .len = count,
+ .rx_buf = buffer,
+ .cs_change = bus->cs_change,
+ .cs = bus->data.cs,
+ .bits_per_word = bus->data.bits_per_word,
+ .mode = bus->data.mode,
+ .speed_hz = bus->data.speed_hz,
+ .delay_usecs = bus->data.delay_usecs
+ int err;
+ err = spi_bus_transfer(bus, &msg, 1);
+ if (err == 0) {
+ return msg.len;
+ } else {
+ rtems_set_errno_and_return_minus_one(-err);
+static ssize_t spi_bus_write(
+ const void *buffer,
+ size_t count
+ .len = (uint16_t) count,
+ .tx_buf = RTEMS_DECONST(void *, buffer),
+ int err;
+ if (err == 0) {
+ return msg.len;
+ } else {
+static int spi_bus_ioctl(
+ ioctl_command_t command,
+ void *arg
+ int err;
+ uint32_t msg_count;
+ struct spi_ioc_transfer *ioc;
+ int i;
+ switch (command) {
+ case SPI_BUS_OBTAIN:
+ err = 0;
+ break;
+ case SPI_BUS_RELEASE:
+ err = 0;
+ break;
+ case SPI_BUS_GET_CONTROL:
+ *(spi_bus **) arg = bus;
+ err = 0;
+ break;
+ case SPI_BUS_SET_CLOCK:
+ err = (*bus->set_clock)(bus, (unsigned long) arg);
+ break;
+ case SPI_IOC_RD_MODE:
+ case SPI_IOC_RD_MODE32:
+ *(uint32_t *) arg = bus->data.mode;
+ err = 0;
+ break;
+ case SPI_IOC_RD_LSB_FIRST:
+ *(uint32_t *) arg = bus->lsb_first;
+ err = 0;
+ break;
+ case SPI_IOC_RD_BITS_PER_WORD:
+ *(uint32_t *) arg = bus->data.bits_per_word;
+ err = 0;
+ break;
+ case SPI_IOC_RD_MAX_SPEED_HZ:
+ *(uint32_t *) arg = bus->max_speed;
+ err = 0;
+ break;
+ case SPI_IOC_WR_MODE:
+ case SPI_IOC_WR_MODE32:
+ bus->data.mode = (uint32_t) arg;
+ err = 0;
+ break;
+ case SPI_IOC_WR_LSB_FIRST:
+ bus->lsb_first = (uint32_t) arg;
+ err = 0;
+ break;
+ case SPI_IOC_WR_BITS_PER_WORD:
+ bus->data.bits_per_word = (uint32_t) arg;
+ err = 0;
+ break;
+ case SPI_IOC_WR_MAX_SPEED_HZ:
+ bus->max_speed = (uint32_t) arg;
+ err = 0;
+ break;
+ default:
+ if (IOCGROUP(command) == SPI_IOC_TRANSFER_MAGIC) {
+ size_t number_of_messages;
+ number_of_messages = command & SPI_MESSAGE_AMOUNT_MASK;
+ err = spi_bus_transfer(bus, arg, number_of_messages);
+ } else {
+ err = -EINVAL;
+ break;
+ if (err == 0) {
+ return 0;
+ } else {
+static const rtems_filesystem_file_handlers_r spi_bus_handler = {
+ .open_h = rtems_filesystem_default_open,
+ .close_h = rtems_filesystem_default_close,
+ .read_h = spi_bus_read,
+ .write_h = spi_bus_write,
+ .ioctl_h = spi_bus_ioctl,
+ .lseek_h = rtems_filesystem_default_lseek,
+ .fstat_h = IMFS_stat,
+ .ftruncate_h = rtems_filesystem_default_ftruncate,
+ .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fcntl_h = rtems_filesystem_default_fcntl,
+ .kqfilter_h = rtems_filesystem_default_kqfilter,
+ .poll_h = rtems_filesystem_default_poll,
+ .readv_h = rtems_filesystem_default_readv,
+ .writev_h = rtems_filesystem_default_writev
+static void spi_bus_node_destroy(IMFS_jnode_t *node)
+ spi_bus *bus;
+ bus = IMFS_generic_get_context_by_node(node);
+ (*bus->destroy)(bus);
+ IMFS_node_destroy_default(node);
+static const IMFS_node_control spi_bus_node_control = IMFS_GENERIC_INITIALIZER(
+ &spi_bus_handler,
+ IMFS_node_initialize_generic,
+ spi_bus_node_destroy
+ spi_bus *bus,
+ int rv;
+ rv = IMFS_make_generic_node(
+ bus_path,
+ S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
+ &spi_bus_node_control,
+ bus
+ if (rv != 0) {
+ return rv;
+static int spi_bus_transfer_default(
+ spi_bus *bus,
+ spi_ioc_transfer *msgs,
+ (void) bus;
+ (void) msgs;
+ (void) msg_count;
+ return -EIO;
+static int spi_bus_set_clock_default(spi_bus *bus, unsigned long clock)
+ (void) bus;
+ (void) clock;
+ return -EIO;
+static int spi_bus_do_init(
+ spi_bus *bus,
+ sc = rtems_semaphore_create(
+ rtems_build_name('S', 'P', 'I', ' '),
+ 1,
+ RTEMS_BINARY_SEMAPHORE | RTEMS_INHERIT_PRIORITY | RTEMS_PRIORITY,
+ 0,
+ &bus->mutex
+ if (sc != RTEMS_SUCCESSFUL) {
+ (*destroy)(bus);
+ rtems_set_errno_and_return_minus_one(ENOMEM);
+ bus->transfer = spi_bus_transfer_default;
+ bus->set_clock = spi_bus_set_clock_default;
+ bus->destroy = destroy;
+ /* Default max speed */
+ bus->max_speed = 50000000;
+ return 0;
+ sc = rtems_semaphore_delete(bus->mutex);
+ (void) sc;
+ spi_bus_destroy(bus);
+ free(bus);
+ memset(bus, 0, sizeof(*bus));
+ return spi_bus_do_init(bus, spi_bus_destroy);
+ spi_bus *bus = NULL;
+ if (size >= sizeof(*bus)) {
+ bus = calloc(1, size);
+ if (bus != NULL) {
+ int rv;
+ rv = spi_bus_do_init(bus, spi_bus_destroy_and_free);
+ if (rv != 0) {
+ return NULL;
+ return bus;
diff --git a/cpukit/dev/spi/spi-dev.c b/cpukit/dev/spi/spi-dev.c
index 0000000..19eacb6
--- /dev/null
+++ b/cpukit/dev/spi/spi-dev.c
@@ -0,0 +1,291 @@
+ * @file
+ * @ingroup SPIDevice
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/score/assert.h>
+#include <fcntl.h>
+#include <unistd.h>
+static ssize_t spi_dev_read(
+ void *buffer,
+ size_t count
+ spi_dev *dev = IMFS_generic_get_context_by_iop(iop);
+ ssize_t n;
+ n = (*dev->read)(dev, buffer, count, iop->offset);
+ if (n >= 0) {
+ iop->offset += n;
+ return n;
+ } else {
+ rtems_set_errno_and_return_minus_one(-n);
+static ssize_t spi_dev_write(
+ size_t count
+ ssize_t n;
+ n = (*dev->write)(dev, buffer, count, iop->offset);
+ if (n >= 0) {
+ iop->offset += n;
+ return n;
+ } else {
+static int spi_dev_ioctl(
+ void *arg
+ int err;
+ err = (*dev->ioctl)(dev, command, arg);
+ if (err == 0) {
+ return 0;
+ } else {
+static int spi_dev_fstat(
+ const rtems_filesystem_location_info_t *loc,
+ struct stat *buf
+ spi_dev *dev = IMFS_generic_get_context_by_location(loc);
+ buf->st_size = (*dev->get_size)(dev);
+ buf->st_blksize = (*dev->get_block_size)(dev);
+ return IMFS_stat(loc, buf);
+static const rtems_filesystem_file_handlers_r spi_dev_handler = {
+ .read_h = spi_dev_read,
+ .write_h = spi_dev_write,
+ .ioctl_h = spi_dev_ioctl,
+ .lseek_h = rtems_filesystem_default_lseek_file,
+ .fstat_h = spi_dev_fstat,
+static void spi_dev_node_destroy(IMFS_jnode_t *node)
+ spi_dev *dev;
+ dev = IMFS_generic_get_context_by_node(node);
+ (*dev->destroy)(dev);
+static const IMFS_node_control spi_dev_node_control = IMFS_GENERIC_INITIALIZER(
+ &spi_dev_handler,
+ spi_dev_node_destroy
+ spi_dev *dev,
+ int rv;
+ dev_path,
+ &spi_dev_node_control,
+ dev
+ if (rv != 0) {
+ return rv;
+static ssize_t spi_dev_read_default(
+ spi_dev *dev,
+ void *buf,
+ size_t n,
+ off_t offset
+ (void) dev;
+ (void) buf;
+ (void) n;
+ (void) offset;
+ return -EIO;
+static ssize_t spi_dev_write_default(
+ spi_dev *dev,
+ const void *buf,
+ size_t n,
+ off_t offset
+ (void) dev;
+ (void) buf;
+ (void) n;
+ (void) offset;
+ return -EIO;
+static int spi_dev_ioctl_default(
+ spi_dev *dev,
+ void *arg
+ (void) dev;
+ (void) command;
+ (void) arg;
+ return -ENOTTY;
+static off_t spi_dev_get_size_default(spi_dev *dev)
+ (void) dev;
+ return 0;
+static blksize_t spi_dev_get_block_size_default(spi_dev *dev)
+ (void) dev;
+ return 1;
+static int spi_dev_do_init(
+ spi_dev *dev,
+ uint16_t address,
+ int rv;
+ dev->bus_fd = open(bus_path, O_RDWR);
+ if (dev->bus_fd < 0) {
+ (*destroy)(dev);
+ return -1;
+ rv = ioctl(dev->bus_fd, SPI_BUS_GET_CONTROL, &dev->bus);
+ if (rv != 0) {
+ (*destroy)(dev);
+ return -1;
+ dev->read = spi_dev_read_default;
+ dev->write = spi_dev_write_default;
+ dev->ioctl = spi_dev_ioctl_default;
+ dev->get_size = spi_dev_get_size_default;
+ dev->get_block_size = spi_dev_get_block_size_default;
+ dev->destroy = destroy;
+ dev->address = address;
+ return 0;
+ int rv;
+ rv = close(dev->bus_fd);
+ _Assert(dev->bus_fd < 0 || rv == 0);
+ (void) rv;
+ spi_dev_destroy(dev);
+ free(dev);
+ return spi_dev_do_init(dev, bus_path, address, spi_dev_destroy);
+ size_t size,
+ uint16_t address
+ spi_dev *dev = NULL;
+ if (size >= sizeof(*dev)) {
+ dev = calloc(1, size);
+ if (dev != NULL) {
+ int rv;
+ rv = spi_dev_do_init(dev, bus_path, address, spi_dev_destroy_and_free);
+ if (rv != 0) {
+ return NULL;
+ return dev;
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index dbd96cb..c00916a 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -9,6 +9,7 @@ _SUBDIRS += pwdgrp01
_SUBDIRS += crypt01
_SUBDIRS += sha
_SUBDIRS += i2c01
+_SUBDIRS += spi01
_SUBDIRS += newlib01
_SUBDIRS += block17
_SUBDIRS += exit02
diff --git a/testsuites/libtests/spi01/buffer_test_io.h b/testsuites/libtests/spi01/buffer_test_io.h
index 0000000..ac73352
--- /dev/null
+++ b/testsuites/libtests/spi01/buffer_test_io.h
@@ -0,0 +1,219 @@
+ * Support for running the test output through a buffer
+#ifndef __BUFFER_TEST_IO_h
+#define __BUFFER_TEST_IO_h
+#include <rtems/bspIo.h>
+#include <rtems/test.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * Uncomment this to get buffered test output. When commented out,
+ * test output behaves as it always has and is printed using stdio.
+/* #define TESTS_BUFFER_OUTPUT */
+/* #define TESTS_USE_PRINTK */
+ * USE PRINTK TO MINIMIZE SIZE
+#if defined(TESTS_USE_PRINTK)
+#include <rtems/print.h>
+ #undef printf
+ #define printf(...) \
+ do { \
+ printk( __VA_ARGS__); \
+ } while (0)
+ #undef puts
+ #define puts(_s) \
+ do { \
+ printk( "%s\n", _s); \
+ } while (0)
+ #undef putchar
+ #define putchar(_c) \
+ do { \
+ printk( "%c", _c ); \
+ } while (0)
+ /* Do not call exit() since it closes stdin, etc and pulls in stdio code */
+ #define rtems_test_exit(_s) \
+ do { \
+ rtems_shutdown_executive(0); \
+ } while (0)
+ #define FLUSH_OUTPUT() \
+ do { \
+ } while (0)
+ #define TEST_BEGIN() printk(TEST_BEGIN_STRING)
+ #define TEST_END() printk(TEST_END_STRING)
+ * BUFFER TEST OUTPUT
+#elif defined(TESTS_BUFFER_OUTPUT)
+ #include <stdio.h>
+ #include <stdlib.h>
+ #define _TEST_OUTPUT_BUFFER_SIZE 2048
+ extern char _test_output_buffer[_TEST_OUTPUT_BUFFER_SIZE];
+ void _test_output_append(char *);
+ void _test_output_flush(void);
+ do { \
+ _test_output_flush(); \
+ exit(_s); \
+ } while (0)
+ #undef printf
+ do { \
+ char _buffer[128]; \
+ sprintf( _buffer, __VA_ARGS__); \
+ _test_output_append( _buffer ); \
+ } while (0)
+ #undef puts
+ #define puts(_string) \
+ do { \
+ sprintf( _buffer, "%s\n", _string ); \
+ } while (0)
+ #undef putchar
+ do { \
+ char _buffer[2]; \
+ _buffer[0] = _c; \
+ _buffer[1] = '\0'; \
+ } while (0)
+ /* we write to stderr when there is a pause() */
+ #define FLUSH_OUTPUT() _test_output_flush()
+ #if defined(TEST_INIT) || defined(CONFIGURE_INIT)
+ char _test_output_buffer[_TEST_OUTPUT_BUFFER_SIZE];
+ int _test_output_buffer_index = 0;
+ void _test_output_append(char *_buffer)
+ char *p;
+ for ( p=_buffer ; *p ; p++ ) {
+ _test_output_buffer[_test_output_buffer_index++] = *p;
+ _test_output_buffer[_test_output_buffer_index] = '\0';
+ #if 0
+ if ( *p == '\n' ) {
+ fprintf( stderr, "BUFFER -- %s", _test_output_buffer );
+ _test_output_buffer_index = 0;
+ _test_output_buffer[0] = '\0';
+ #endif
+ if ( _test_output_buffer_index >= (_TEST_OUTPUT_BUFFER_SIZE - 80) )
+ #include <termios.h>
+ #include <unistd.h>
+ fprintf( stderr, "%s", _test_output_buffer );
+ tcdrain( 2 );
+ #endif
+#elif defined(TESTS_USE_PRINTF)
+ do { \
+ exit(_s); \
+ } while (0)
+ do { \
+ fflush(stdout); \
+ } while (0)
+ #define TEST_BEGIN() printf(TEST_BEGIN_STRING)
+ #define TEST_END() printf(TEST_END_STRING)
+ * USE IPRINT
+#else
+ /* do not use iprintf if strict ansi mode */
+ #if defined(_NEWLIB_VERSION) && !defined(__STRICT_ANSI__)
+ #undef printf
+ do { \
+ fiprintf( stderr, __VA_ARGS__ ); \
+ } while (0)
+ #else
+ #undef printf
+ do { \
+ fprintf( stderr, __VA_ARGS__ ); \
+ } while (0)
+ #endif
+ #undef puts
+ do { \
+ printf( "%s\n", _s ); \
+ } while (0)
+ #undef putchar
+ do { \
+ printf( "%c", _c ); \
+ } while (0)
+ do { \
+ exit(_s); \
+ } while (0)
+ do { \
+ fflush(stdout); \
+ } while (0)
+ #define TEST_BEGIN() fiprintf( stderr, TEST_BEGIN_STRING)
+ #define TEST_END() fiprintf( stderr, TEST_END_STRING)
+#endif
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/testsuites/libtests/spi01/init.c b/testsuites/libtests/spi01/init.c
index 0000000..e80ad18
--- /dev/null
+++ b/testsuites/libtests/spi01/init.c
@@ -0,0 +1,256 @@
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#ifdef HAVE_CONFIG_H
+#endif
+#include <errno.h>
+#include <fcntl.h>
+#include <rtems/libcsupport.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SPI 1";
+typedef struct test_device test_device;
+struct test_device {
+ int (*transfer)(
+ spi_bus *bus,
+ uint32_t msg_count,
+ test_device *dev
+typedef struct {
+ test_device base;
+ char buf[3];
+} test_device_simple_read_write;
+typedef struct {
+ spi_bus base;
+ unsigned long clock;
+ test_device *device;
+ test_device_simple_read_write simple_read_write;
+} test_bus;
+static const char bus_path[] = "/dev/spi-0";
+static int test_simple_read_write_transfer(
+ spi_bus *bus,
+ test_device *base
+ (void)bus;
+ test_device_simple_read_write *dev = (test_device_simple_read_write *) base;
+ if (msg_count == 1 && msgs[0].len == sizeof(dev->buf)) {
+ if (msgs[0].rx_buf == 0){
+ memcpy(&dev->buf[0], msgs[0].tx_buf, sizeof(dev->buf));
+ } else if (msgs[0].tx_buf == 0){
+ memcpy(msgs[0].rx_buf, &dev->buf[0], sizeof(dev->buf));
+ } else {
+ return -EIO;
+ } else {
+ return -EIO;
+ return 0;
+static int test_transfer(spi_bus *base, spi_ioc_transfer *msgs, uint32_t msg_count)
+ test_bus *bus = (test_bus *) base;
+ test_device *dev;
+ dev = bus->device;
+ return (*dev->transfer)(&bus->base, msgs, msg_count, dev);
+static int test_set_clock(spi_bus *base, unsigned long clock)
+ bus->clock = clock;
+ return 0;
+static void test_destroy(spi_bus *base)
+ spi_bus_destroy_and_free(base);
+static void test_simple_read_write(test_bus *bus, int fd)
+ static const char zero[] = { 0, 0, 0 };
+ static const char abc[] = { 'a', 'b', 'c' };
+ int rv;
+ char buf[3];
+ ssize_t n;
+ errno = 0;
+ rv = ioctl(fd, 0xb00b);
+ rtems_test_assert(rv == -1);
+ rtems_test_assert(errno == ENOTTY);
+ errno = 0;
+ n = write(fd, &buf[0], 1000);
+ rtems_test_assert(n == -1);
+ rtems_test_assert(errno == EIO);
+ errno = 0;
+ n = read(fd, &buf[0], 1000);
+ memcmp(&bus->simple_read_write.buf[0], &zero[0], sizeof(buf)) == 0
+ n = write(fd, &abc[0], sizeof(buf));
+ rtems_test_assert(n == (ssize_t) sizeof(buf));
+ memcmp(&bus->simple_read_write.buf[0], &abc[0], sizeof(buf)) == 0
+ n = read(fd, &buf[0], sizeof(buf));
+ rtems_test_assert(memcmp(&buf[0], &abc[0], sizeof(buf)) == 0);
+static void test(void)
+ rtems_resource_snapshot snapshot;
+ test_bus *bus;
+ int rv;
+ int fd;
+ rtems_resource_snapshot_take(&snapshot);
+ bus = (test_bus *) spi_bus_alloc_and_init(sizeof(*bus));
+ rtems_test_assert(bus != NULL);
+ bus->base.transfer = test_transfer;
+ bus->base.set_clock = test_set_clock;
+ bus->base.destroy = test_destroy;
+ bus->simple_read_write.base.transfer = test_simple_read_write_transfer;
+ bus->device = &bus->simple_read_write.base;
+ rv = spi_bus_register(&bus->base, &bus_path[0]);
+ rtems_test_assert(rv == 0);
+ fd = open(&bus_path[0], O_RDWR);
+ rtems_test_assert(fd >= 0);
+ rtems_test_assert(bus->clock == 0);
+ rv = ioctl(fd, SPI_BUS_SET_CLOCK, 0xdeadbeefUL);
+ rtems_test_assert(bus->clock == 0xdeadbeef);
+ rv = ioctl(fd, SPI_BUS_OBTAIN);
+ rv = ioctl(fd, SPI_BUS_RELEASE);
+ rv = ioctl(fd, SPI_IOC_WR_MAX_SPEED_HZ, 0x12345678);
+ rv = ioctl(fd, SPI_IOC_RD_MAX_SPEED_HZ, &bus->base.max_speed);
+ rtems_test_assert(bus->base.max_speed == 0x12345678);
+ rv = ioctl(fd, SPI_IOC_WR_LSB_FIRST, 1);
+ rv = ioctl(fd, SPI_IOC_RD_LSB_FIRST, &bus->base.lsb_first);
+ rtems_test_assert(bus->base.lsb_first == 1);
+ rv = ioctl(fd, SPI_IOC_WR_MODE, 0xA5);
+ rv = ioctl(fd, SPI_IOC_RD_MODE, &bus->base.data.mode);
+ rtems_test_assert(bus->base.data.mode == 0xA5);
+ rv = ioctl(fd, SPI_IOC_WR_BITS_PER_WORD, 8);
+ rv = ioctl(fd, SPI_IOC_RD_BITS_PER_WORD, &bus->base.data.bits_per_word);
+ rtems_test_assert(bus->base.data.bits_per_word == 8);
+ rv = ioctl(fd, SPI_IOC_WR_MODE32, 0x5A5A5A5A);
+ rv = ioctl(fd, SPI_IOC_RD_MODE32, &bus->base.data.mode);
+ rtems_test_assert(bus->base.data.mode == 0x5A5A5A5A);
+ test_simple_read_write(bus, fd);
+ rv = close(fd);
+ rv = unlink(&bus_path[0]);
+ rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
+static void Init(rtems_task_argument arg)
+ (void)arg;
+ TEST_BEGIN();
+ test();
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_MICROSECONDS_PER_TICK 2000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 7
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/spi01/spi01.doc b/testsuites/libtests/spi01/spi01.doc
index 0000000..754aa8a
--- /dev/null
+++ b/testsuites/libtests/spi01/spi01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spi01
+directives:
+ TBD
+concepts:
+ - Ensure that the SPI driver framework works.
diff --git a/testsuites/libtests/spi01/spi01.scn b/testsuites/libtests/spi01/spi01.scn
index 0000000..6d8f6cc
--- /dev/null
+++ b/testsuites/libtests/spi01/spi01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SPI 1 ***
+*** END OF TEST SPI 1 ***
diff --git a/testsuites/libtests/spi01/tmacros.h b/testsuites/libtests/spi01/tmacros.h
index 0000000..d8aec2a
--- /dev/null
+++ b/testsuites/libtests/spi01/tmacros.h
@@ -0,0 +1,372 @@
+ * @file
+ * This include file contains macros which are useful in the RTEMS
+ * test suites.
+ * COPYRIGHT (c) 1989-2014.
+ * On-Line Applications Research Corporation (OAR).
+#ifndef __TMACROS_h
+#define __TMACROS_h
+#include <inttypes.h>
+#include <bsp.h> /* includes <rtems.h> */
+#include <ctype.h>
+#include <stdio.h>
+#include <rtems/error.h>
+#include <rtems/score/threaddispatch.h>
+#include <buffer_test_io.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define FOREVER 1 /* infinite loop */
+#ifdef CONFIGURE_INIT
+#define TEST_EXTERN
+#else
+#define TEST_EXTERN extern
+#endif
+ * Check that that the dispatch disable level is proper for the
+ * mode/state of the test. Normally it should be 0 when in task space.
+ * This test is only valid when in a non-SMP system. In an smp system
+ * another cpu may be accessing the core at any point when this core
+ * does not have it locked.
+#if defined SMPTEST
+ #define check_dispatch_disable_level( _expect )
+#else
+ #define check_dispatch_disable_level( _expect ) \
+ do { \
+ if ( (_expect) != -1 \
+ && (((!_Thread_Dispatch_is_enabled()) == false && (_expect) != 0) \
+ || ((!_Thread_Dispatch_is_enabled()) && (_expect) == 0)) \
+ printk( \
+ "\n_Thread_Dispatch_disable_level is (%i)" \
+ " not %d detected at %s:%d\n", \
+ !_Thread_Dispatch_is_enabled(), (_expect), __FILE__, __LINE__ ); \
+ FLUSH_OUTPUT(); \
+ rtems_test_exit( 1 ); \
+ } while ( 0 )
+#endif
+ * Check that that the allocator mutex is not owned by the executing thread.
+#include <rtems/score/apimutex.h>
+#define check_if_allocator_mutex_is_not_owned() \
+ do { \
+ if ( _RTEMS_Allocator_is_owner() ) { \
+ printk( \
+ "\nRTEMS Allocator Mutex is owned by executing thread " \
+ "and should not be.\n" \
+ "Detected at %s:%d\n", \
+ __FILE__, \
+ __LINE__ \
+ FLUSH_OUTPUT(); \
+ } while ( 0 )
+ * These macros properly report errors within the Classic API
+#define directive_failed( _dirstat, _failmsg ) \
+ fatal_directive_status( _dirstat, RTEMS_SUCCESSFUL, _failmsg )
+#define directive_failed_with_level( _dirstat, _failmsg, _level ) \
+ fatal_directive_status_with_level( \
+ _dirstat, RTEMS_SUCCESSFUL, _failmsg, _level )
+#define fatal_directive_status( _stat, _desired, _msg ) \
+ fatal_directive_status_with_level( _stat, _desired, _msg, 0 )
+#define fatal_directive_check_status_only( _stat, _desired, _msg ) \
+ do { \
+ if ( (_stat) != (_desired) ) { \
+ printf( "\n%s FAILED -- expected (%s) got (%s)\n", \
+ (_msg), rtems_status_text(_desired), rtems_status_text(_stat) ); \
+ FLUSH_OUTPUT(); \
+ rtems_test_exit( _stat ); \
+ } while ( 0 )
+#define fatal_directive_status_with_level( _stat, _desired, _msg, _level ) \
+ do { \
+ check_dispatch_disable_level( _level ); \
+ check_if_allocator_mutex_is_not_owned(); \
+ fatal_directive_check_status_only( _stat, _desired, _msg ); \
+ } while ( 0 )
+ * These macros properly report errors from the POSIX API
+#define posix_service_failed( _dirstat, _failmsg ) \
+ fatal_posix_service_status( _dirstat, 0, _failmsg )
+#define posix_service_failed_with_level( _dirstat, _failmsg, _level ) \
+ fatal_posix_service_status_with_level( _dirstat, 0, _failmsg, _level )
+#define fatal_posix_service_status_errno( _stat, _desired, _msg ) \
+ if ( (_stat != -1) && (errno) != (_desired) ) { \
+ long statx = _stat; \
+ check_dispatch_disable_level( 0 ); \
+ printf( "\n%s FAILED -- expected (%d - %s) got (%ld %d - %s)\n", \
+ (_msg), _desired, strerror(_desired), \
+ statx, errno, strerror(errno) ); \
+ FLUSH_OUTPUT(); \
+#define fatal_posix_service_status( _stat, _desired, _msg ) \
+ fatal_posix_service_status_with_level( _stat, _desired, _msg, 0 )
+#define fatal_posix_service_status_with_level( _stat, _desired, _msg, _level ) \
+ do { \
+ printf( "\n%s FAILED -- expected (%d - %s) got (%d - %s)\n", \
+ (_msg), _desired, strerror(_desired), _stat, strerror(_stat) ); \
+ printf( "\n FAILED -- errno (%d - %s)\n", \
+ errno, strerror(errno) ); \
+ FLUSH_OUTPUT(); \
+ } while ( 0 )
+ * This macro evaluates the semaphore id returned.
+#define fatal_posix_sem( _ptr, _msg ) \
+ if ( (_ptr != SEM_FAILED) ) { \
+ printf( "\n%s FAILED -- expected (-1) got (%p - %d/%s)\n", \
+ (_msg), _ptr, errno, strerror(errno) ); \
+ FLUSH_OUTPUT(); \
+ rtems_test_exit( -1 ); \
+ * This macro evaluates the message queue id returned.
+#define fatal_posix_mqd( _ptr, _msg ) \
+ if ( (_ptr != (mqd_t) -1) ) { \
+ printf( "\n%s FAILED -- expected (-1) got (%" PRId32 " - %d/%s)\n", \
+ FLUSH_OUTPUT(); \
+ * Generic integer version of the error reporting
+#define int_service_failed( _dirstat, _failmsg ) \
+ fatal_int_service_status( _dirstat, RTEMS_SUCCESSFUL, _failmsg )
+#define int_service_failed_with_level( _dirstat, _failmsg, _level ) \
+ fatal_int_service_status_with_level( \
+#define fatal_int_service_status( _stat, _desired, _msg ) \
+ fatal_int_service_status_with_level( _stat, _desired, _msg, 0 )
+#define fatal_int_service_status_with_level( _stat, _desired, _msg, _level ) \
+ do { \
+ printf( "\n%s FAILED -- expected (%d) got (%d)\n", \
+ (_msg), (_desired), (_stat) ); \
+ FLUSH_OUTPUT(); \
+ } while ( 0 )
+ * Print the time
+#define sprint_time(_str, _s1, _tb, _s2) \
+ do { \
+ sprintf( (_str), "%s%02d:%02d:%02d %02d/%02d/%04d%s", \
+ _s1, (_tb)->hour, (_tb)->minute, (_tb)->second, \
+ (_tb)->month, (_tb)->day, (_tb)->year, _s2 ); \
+ } while ( 0 )
+#define print_time(_s1, _tb, _s2) \
+ do { \
+ printf( "%s%02" PRIu32 ":%02" PRIu32 ":%02" PRIu32 " %02" PRIu32 "/%02" PRIu32 "/%04" PRIu32 "%s", \
+ } while ( 0 )
+#define put_dot( _c ) \
+ do { \
+ putchar( _c ); \
+ FLUSH_OUTPUT(); \
+ } while ( 0 )
+#define new_line puts( "" )
+#define puts_nocr printf
+#ifdef RTEMS_TEST_NO_PAUSE
+#define rtems_test_pause() \
+ do { \
+ printf( "<pause>\n" ); \
+ FLUSH_OUTPUT(); \
+ } while ( 0 )
+#define rtems_test_pause_and_screen_number( _screen ) \
+ do { \
+ printf( "<pause - screen %d>\n", (_screen) ); \
+ FLUSH_OUTPUT(); \
+ } while ( 0 )
+#else
+ do { \
+ char buffer[ 80 ]; \
+ printf( "<pause>" ); \
+ FLUSH_OUTPUT(); \
+ gets( buffer ); \
+ puts( "" ); \
+ } while ( 0 )
+ do { \
+ printf( "<pause - screen %d>", (_screen) ); \
+ FLUSH_OUTPUT(); \
+ gets( buffer ); \
+ puts( "" ); \
+ } while ( 0 )
+#endif
+#define put_name( name, crlf ) \
+{ int c0, c1, c2, c3; \
+ c0 = (name >> 24) & 0xff; \
+ c1 = (name >> 16) & 0xff; \
+ c2 = (name >> 8) & 0xff; \
+ c3 = name & 0xff; \
+ putchar( (isprint(c0)) ? c0 : '*' ); \
+ if ( c1 ) putchar( (isprint(c1)) ? c1 : '*' ); \
+ if ( c2 ) putchar( (isprint(c2)) ? c2 : '*' ); \
+ if ( c3 ) putchar( (isprint(c3)) ? c3 : '*' ); \
+ if ( crlf ) \
+ putchar( '\n' ); \
+#ifndef build_time
+#define build_time( TB, MON, DAY, YR, HR, MIN, SEC, TK ) \
+ { (TB)->year = YR; \
+ (TB)->month = MON; \
+ (TB)->day = DAY; \
+ (TB)->hour = HR; \
+ (TB)->minute = MIN; \
+ (TB)->second = SEC; \
+ (TB)->ticks = TK; }
+#endif
+#define task_number( tid ) \
+ ( rtems_object_id_get_index( tid ) - \
+ rtems_configuration_get_rtems_api_configuration()-> \
+ number_of_initialization_tasks )
+#define rtems_test_assert(__exp) \
+ do { \
+ if (!(__exp)) { \
+ printf( "%s: %d %s\n", __FILE__, __LINE__, #__exp ); \
+ rtems_test_exit(0); \
+ } while (0)
+ * Various inttypes.h-stype macros to assist printing
+ * certain system types on different targets.
+#if defined(RTEMS_USE_16_BIT_OBJECT)
+#define PRIxrtems_id PRIx16
+#else
+#define PRIxrtems_id PRIx32
+#endif
+/* c.f. cpukit/score/include/rtems/score/priority.h */
+#define PRIdPriority_Control PRId32
+#define PRIxPriority_Control PRIx32
+/* rtems_task_priority is a typedef to Priority_Control */
+#define PRIdrtems_task_priority PRIdPriority_Control
+#define PRIxrtems_task_priority PRIxPriority_Control
+/* c.f. cpukit/score/include/rtems/score/watchdog.h */
+#define PRIdWatchdog_Interval PRIu32
+/* rtems_interval is a typedef to Watchdog_Interval */
+#define PRIdrtems_interval PRIdWatchdog_Interval
+/* c.f. cpukit/score/include/rtems/score/thread.h */
+#define PRIdThread_Entry_numeric_type PRIuPTR
+/* rtems_task_argument is a typedef to Thread_Entry_numeric_type */
+#define PRIdrtems_task_argument PRIdThread_Entry_numeric_type
+/* rtems_event_set is a typedef to unit32_t */
+#define PRIxrtems_event_set PRIx32
+/* HACK: newlib defines pthread_t as a typedef to __uint32_t */
+/* HACK: There is no portable way to print pthread_t's */
+#define PRIxpthread_t PRIx32
+/* rtems_signal_set is a typedef to uint32_t */
+#define PRIxrtems_signal_set PRIx32
+/* newlib's ino_t is a typedef to "unsigned long" */
+#define PRIxino_t "lx"
+ * This assists in clearly disabling warnings on GCC in certain very
+ * specific cases.
+ * + -Wnon-null - If a method is declared as never having a NULL first
+ * parameter. We need to explicitly disable this compiler warning to make
+ * the code warning free.
+#ifdef __GNUC__
+ #define COMPILER_DIAGNOSTIC_SETTINGS_PUSH _Pragma("GCC diagnostic push")
+ #define COMPILER_DIAGNOSTIC_SETTINGS_POP _Pragma("GCC diagnostic pop")
+ #define COMPILER_DIAGNOSTIC_SETTINGS_DISABLE_NONNULL \
+ _Pragma("GCC diagnostic ignored \"-Wnonnull\"")
+#else
+#endif
+#ifdef __cplusplus
+#endif
+#endif
1.8.4.5
