[PATCH 0/5] arm/tms570: include hardware initialization and selftests to run RTEMS directly from Flash without loader on TMS570LS3137 HDK.
Tue Sep 13 19:42:48 UTC 2016
I'm slowly reading through these. Is there a doc or is it worth it to
generate one that maps the HalcoGen functions to their RTEMS renamed
versions? I'm not sure if it is of much value.
On Mon, Sep 12, 2016 at 5:47 PM,  <pisa at cmp.felk.cvut.cz> wrote:
> From: Pavel Pisa <pisa at cmp.felk.cvut.cz>
> The code introduces initialization algorithms bases on Ti HalCoGen
> generated files. The most of the code has been rewritten to use
> RTEMS much more complete header files. This allowed to replace most
> of the hardcoded hexadecimal values by appropriate fields macros documenting
> how values are build.
> The parity self-tests have been rewritten completely to minimize
> code duplication. The solution is much better prepared to cover
> variations of integrated peripherals between different Hercules
> family chips.
> The pin multiplexer code is written from scratch and complete
> pin alternative functions "database" is included for easy
> preparation of configurations for different chips and even
> runtime pin functions changes.
> Original Ti HalCoGen generated files include a BSD-like license.
> It has been preserved where the file is mostly based Ti code.
> Some other smaller (mostly rewritten) fragments are without
> copyright header for now.
> The code is reformatted to conform RTEMS coding style mostly.
> There are left some original functions names and comments
> using C++ delimiters "//". I expect to remove them in long
> term perspective. But I would like to use them for matching
> code and algorithms with other chip family members code
> generated by HalCoGen. When two or three variants are fully
> supported then we learn how to write support portable
> and configurable way in the C code and these remarks would
> not be required anymore.
> The code taking care about internal SRAM parity self-test
> is disabled for now because it clashes with code testing
> for internal RAM linking variant. The MPU initialization
> is missing as well. It would be required to use external
> SDRAM for code.
> Generally, there is much work required still to make BSP
> full industry grade one. But I think that actual state
> is the great step forward and work worth to be included
> in RTEMS mainline in the actual state to simplify testing
> and be base for new projects.
> The second patch is quite huge so if it does not pass
> through list then it can be accessed on GitHub
> The branch: https://github.com/AoLaD/rtems/commits/tms570-bsp
> Patch 2/5:  https://github.com/AoLaD/rtems/commit/9d06f3be64f9b5e9e1988163762b613daba0963c
> Pavel Pisa (5):
>   arm/tms570: define base addresses of all TMS570LS3137 SPI interfaces.
>   arm/tms570: include hardware initialization and selftest based on Ti
>     HalCoGen generated files.
>   arm/tms570: include TMS570_USE_HWINIT_STARTUP option to select bare
>     metal startup and selftest.
>   arm/tms570: document BSP setup with included hardware initialization.
>   arm/tms570: update bootstrap generated preinstall.am
>  c/src/lib/libbsp/arm/tms570/Makefile.am            |  21 +
>  c/src/lib/libbsp/arm/tms570/README                 | 104 +++-
>  c/src/lib/libbsp/arm/tms570/configure.ac           |   4 +
>  .../arm/tms570/hwinit/bspstarthooks-hwinit.c       | 393 ++++++++++++++
>  .../libbsp/arm/tms570/hwinit/fail_notification.c   |  17 +
>  .../lib/libbsp/arm/tms570/hwinit/init_emif_sdram.c |  59 +++
>  c/src/lib/libbsp/arm/tms570/hwinit/init_esm.c      |  50 ++
>  c/src/lib/libbsp/arm/tms570/hwinit/init_pinmux.c   | 195 +++++++
>  c/src/lib/libbsp/arm/tms570/hwinit/init_system.c   | 380 +++++++++++++
>  c/src/lib/libbsp/arm/tms570/hwinit/tms570_hwinit.h |  23 +
>  .../libbsp/arm/tms570/hwinit/tms570_parity_can.c   |  60 +++
>  .../arm/tms570/hwinit/tms570_parity_mibspi.c       |  72 +++
>  .../libbsp/arm/tms570/hwinit/tms570_parity_std.c   |  55 ++
>  .../libbsp/arm/tms570/hwinit/tms570_parity_tests.c | 273 ++++++++++
>  .../libbsp/arm/tms570/hwinit/tms570_parity_tests.h |  75 +++
>  .../lib/libbsp/arm/tms570/hwinit/tms570_selftest.c | 589 +++++++++++++++++++++
>  .../lib/libbsp/arm/tms570/hwinit/tms570_selftest.h | 156 ++++++
>  .../lib/libbsp/arm/tms570/hwinit/tms570_sys_core.S | 575 ++++++++++++++++++++
>  c/src/lib/libbsp/arm/tms570/include/tms570.h       |   6 +-
>  c/src/lib/libbsp/arm/tms570/preinstall.am          |  13 +
>  20 files changed, 3097 insertions(+), 23 deletions(-)
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/bspstarthooks-hwinit.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/fail_notification.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/init_emif_sdram.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/init_esm.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/init_pinmux.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/init_system.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/tms570_hwinit.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/tms570_parity_can.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/tms570_parity_mibspi.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/tms570_parity_std.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/tms570_parity_tests.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/tms570_parity_tests.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/tms570_selftest.c
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/tms570_selftest.h
>  create mode 100644 c/src/lib/libbsp/arm/tms570/hwinit/tms570_sys_core.S
> 1.9.1
