[PATCH 3/5] arm/tms570: include TMS570_USE_HWINIT_STARTUP option to select bare metal startup and selftest.
Thu Sep 15 00:16:50 UTC 2016
Can you provide some more elaboration in the RTEMS_BSPOPTS_HELP
description of the option? Such as, why to turn it on or to leave it
off.
On Mon, Sep 12, 2016 at 5:47 PM,  <pisa at cmp.felk.cvut.cz> wrote:
> From: Pavel Pisa <pisa at cmp.felk.cvut.cz>
>  c/src/lib/libbsp/arm/tms570/Makefile.am  | 21 +++++++++++++++++++++
>  c/src/lib/libbsp/arm/tms570/configure.ac |  4 ++++
>  2 files changed, 25 insertions(+)
> diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
> index c4d39bc..012ce23 100644
> --- a/c/src/lib/libbsp/arm/tms570/Makefile.am
> +++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
> @@ -168,8 +168,29 @@ libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
>  libbsp_a_SOURCES += ../../../libcpu/arm/shared/include/cache_.h
>  libbsp_a_CPPFLAGS += -I$(srcdir)/../../../libcpu/arm/shared/include
> +if TMS570_USE_HWINIT_STARTUP
> +libbsp_a_SOURCES += hwinit/tms570_sys_core.S
> +libbsp_a_SOURCES += hwinit/fail_notification.c
> +libbsp_a_SOURCES += hwinit/init_pinmux.c
> +libbsp_a_SOURCES += hwinit/init_system.c
> +libbsp_a_SOURCES += hwinit/init_emif_sdram.c
> +libbsp_a_SOURCES += hwinit/init_esm.c
> +libbsp_a_SOURCES += hwinit/tms570_selftest.c
> +libbsp_a_SOURCES += hwinit/tms570_parity_tests.c
> +libbsp_a_SOURCES += hwinit/tms570_parity_std.c
> +libbsp_a_SOURCES += hwinit/tms570_parity_can.c
> +libbsp_a_SOURCES += hwinit/tms570_parity_mibspi.c
> +include_bsp_HEADERS += hwinit/tms570_parity_tests.h
> +include_bsp_HEADERS += hwinit/tms570_hwinit.h
> +include_bsp_HEADERS += hwinit/tms570_selftest.h
> +# Start hooks
> +libbsp_a_SOURCES += hwinit/bspstarthooks-hwinit.c
> +else
>  # Start hooks
>  libbsp_a_SOURCES += startup/bspstarthooks.c
> +endif
>  # ------  Special Rules
> diff --git a/c/src/lib/libbsp/arm/tms570/configure.ac b/c/src/lib/libbsp/arm/tms570/configure.ac
> index e06d4e4..7662064 100644
> --- a/c/src/lib/libbsp/arm/tms570/configure.ac
> +++ b/c/src/lib/libbsp/arm/tms570/configure.ac
> @@ -50,6 +50,10 @@ RTEMS_BSPOPTS_HELP([TMS570_OSCILLATOR_RTC],[RTC oscillator frequency in Hz])
>  RTEMS_BSPOPTS_SET([TMS570_CCLK],[*],[96000000U])
>  RTEMS_BSPOPTS_HELP([TMS570_CCLK],[CPU clock in Hz])
> +RTEMS_BSPOPTS_SET([TMS570_USE_HWINIT_STARTUP],[*],[0])
> +RTEMS_BSPOPTS_HELP([TMS570_USE_HWINIT_STARTUP],[use minimalized startup code for TMS570LS3137])
> +AM_CONDITIONAL(TMS570_USE_HWINIT_STARTUP,test "$TMS570_USE_HWINIT_STARTUP" = "1")
>  RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
>  RTEMS_BSP_LINKCMDS
> 1.9.1
