[PATCH 3/5] tests: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
Fri Sep 16 12:23:21 UTC 2016
Avoid unnecessary use of CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM.
 testsuites/libtests/complex/init.c    | 1 -
 testsuites/libtests/math/init.c       | 1 -
 testsuites/libtests/mathf/init.c      | 1 -
 testsuites/libtests/mathl/init.c      | 1 -
 testsuites/libtests/stringto01/init.c | 1 -
 testsuites/libtests/termios02/init.c  | 1 -
 testsuites/samples/hello/init.c       | 1 -
 7 files changed, 7 deletions(-)
diff --git a/testsuites/libtests/complex/init.c b/testsuites/libtests/complex/init.c
index 3d542fb..c4295e6 100644
--- a/testsuites/libtests/complex/init.c
+++ b/testsuites/libtests/complex/init.c
@@ -43,7 +43,6 @@ extern void docomplexl(void);
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
 #define CONFIGURE_MAXIMUM_TASKS            1
-#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
 #define CONFIGURE_INIT_TASK_ATTRIBUTES    RTEMS_FLOATING_POINT
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/libtests/math/init.c b/testsuites/libtests/math/init.c
index c045735..7329793 100644
--- a/testsuites/libtests/math/init.c
+++ b/testsuites/libtests/math/init.c
@@ -46,7 +46,6 @@ extern void domath(void);
diff --git a/testsuites/libtests/mathf/init.c b/testsuites/libtests/mathf/init.c
index c91e6fe..1f75f2b 100644
--- a/testsuites/libtests/mathf/init.c
+++ b/testsuites/libtests/mathf/init.c
@@ -42,7 +42,6 @@ extern void domathf(void);
diff --git a/testsuites/libtests/mathl/init.c b/testsuites/libtests/mathl/init.c
index ca26f11..4ae7511 100644
--- a/testsuites/libtests/mathl/init.c
+++ b/testsuites/libtests/mathl/init.c
@@ -42,7 +42,6 @@ extern void domathl(void);
diff --git a/testsuites/libtests/stringto01/init.c b/testsuites/libtests/stringto01/init.c
index 52ac62b..d36a4e5 100644
--- a/testsuites/libtests/stringto01/init.c
+++ b/testsuites/libtests/stringto01/init.c
@@ -166,7 +166,6 @@ rtems_task Init(
diff --git a/testsuites/libtests/termios02/init.c b/testsuites/libtests/termios02/init.c
index 181f317..fe16150 100644
--- a/testsuites/libtests/termios02/init.c
+++ b/testsuites/libtests/termios02/init.c
@@ -148,7 +148,6 @@ rtems_task Init(
diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
index acdabd8..a2d6c30 100644
--- a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
@@ -42,7 +42,6 @@ rtems_task Init(
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
1.8.4.5
