[PATCH] cpukit: Add nxp-sc16is752 serial device driver
Alexander Krutwig
alexander.krutwig at embedded-brains.de
Fri Sep 16 13:36:24 UTC 2016
cpukit/dev/Makefile.am | 7 +
cpukit/dev/include/dev/serial/nxp-sc16is752.h | 68 ++++++
cpukit/dev/preinstall.am | 9 +
cpukit/dev/serial/nxp-sc16is752-regs.h | 122 ++++++++++
cpukit/dev/serial/nxp-sc16is752-spi.c | 90 +++++++
cpukit/dev/serial/nxp-sc16is752.c | 324 ++++++++++++++++++++++++++
6 files changed, 620 insertions(+)
create mode 100644 cpukit/dev/include/dev/serial/nxp-sc16is752.h
create mode 100644 cpukit/dev/serial/nxp-sc16is752-regs.h
create mode 100644 cpukit/dev/serial/nxp-sc16is752-spi.c
create mode 100644 cpukit/dev/serial/nxp-sc16is752.c
diff --git a/cpukit/dev/Makefile.am b/cpukit/dev/Makefile.am
index 2b65390..cdc3fe8 100644
--- a/cpukit/dev/Makefile.am
+++ b/cpukit/dev/Makefile.am
@@ -15,6 +15,10 @@ include_dev_spidir = $(includedir)/dev/spi
include_dev_spi_HEADERS =
include_dev_spi_HEADERS += include/dev/spi/spi.h
+include_dev_serialdir = $(includedir)/dev/serial
+include_dev_serial_HEADERS =
+include_dev_serial_HEADERS += include/dev/serial/nxp-sc16is752.h
include_linuxdir = $(includedir)/linux
include_linux_HEADERS =
include_linux_HEADERS += include/linux/i2c.h
@@ -33,6 +37,9 @@ libdev_a_SOURCES += i2c/i2c-bus.c
libdev_a_SOURCES += i2c/i2c-dev.c
libdev_a_SOURCES += i2c/switch-nxp-pca9548a.c
libdev_a_SOURCES += spi/spi-bus.c
+libdev_a_SOURCES += serial/nxp-sc16is752.c
+libdev_a_SOURCES += serial/nxp-sc16is752-spi.c
+libdev_a_SOURCES += serial/nxp-sc16is752-regs.h
include $(srcdir)/preinstall.am
include $(top_srcdir)/automake/local.am
diff --git a/cpukit/dev/include/dev/serial/nxp-sc16is752.h b/cpukit/dev/include/dev/serial/nxp-sc16is752.h
new file mode 100644
index 0000000..2566ebe
--- /dev/null
+++ b/cpukit/dev/include/dev/serial/nxp-sc16is752.h
@@ -0,0 +1,68 @@
+ * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <info at embedded-brains.de>
+#ifndef _DEV_SERIAL_SC16IS752_H
+#define _DEV_SERIAL_SC16IS752_H
+#include <rtems/termiostypes.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+/* General device paths */
+#define SC16IS752_PATH "/dev/ttyUARTSC16IS752"
+typedef struct {
+ const char *spi_nxp_path;
+ uint8_t cs;
+ uint32_t speed_hz;
+} sc16is752_reg_ctx;
+typedef struct {
+ rtems_termios_device_context base;
+ sc16is752_reg_ctx *reg_ctx;
+ int (*write_reg)(int fd,
+ sc16is752_reg_ctx *reg_ctx,
+ uint8_t addr,
+ uint8_t data
+ int (*read_reg)(int fd,
+ uint8_t addr,
+ uint8_t *data
+ uint32_t input_frequency;
+ rtems_vector_number irq;
+ int fd;
+ bool rs485_wanted;
+#ifdef SC16IS752_USE_INTERRUPTS
+ bool transmitting;
+#endif
+} sc16is752_uart_ctx;
+rtems_status_code sc16is752_initialize(
+ sc16is752_uart_ctx *uart_ctx,
+ uint32_t input_frequency,
+ rtems_vector_number irq,
+ bool rs485_wanted,
+ void *arg
+#ifdef __cplusplus
+#endif /* _DEV_SERIAL_SC16IS752_H */
diff --git a/cpukit/dev/preinstall.am b/cpukit/dev/preinstall.am
index d2e63ba..801bdb5 100644
--- a/cpukit/dev/preinstall.am
+++ b/cpukit/dev/preinstall.am
@@ -48,6 +48,15 @@ $(PROJECT_INCLUDE)/dev/spi/spi.h: include/dev/spi/spi.h $(PROJECT_INCLUDE)/dev/s
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/dev/spi/spi.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/dev/spi/spi.h
+$(PROJECT_INCLUDE)/dev/serial/$(dirstamp):
+ @$(MKDIR_P) $(PROJECT_INCLUDE)/dev/serial
+ @: > $(PROJECT_INCLUDE)/dev/serial/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/dev/serial/$(dirstamp)
+$(PROJECT_INCLUDE)/dev/serial/nxp-sc16is752.h: include/dev/serial/nxp-sc16is752.h $(PROJECT_INCLUDE)/dev/serial/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/dev/serial/nxp-sc16is752.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/dev/serial/nxp-sc16is752.h
$(PROJECT_INCLUDE)/linux/$(dirstamp):
@$(MKDIR_P) $(PROJECT_INCLUDE)/linux
@: > $(PROJECT_INCLUDE)/linux/$(dirstamp)
diff --git a/cpukit/dev/serial/nxp-sc16is752-regs.h b/cpukit/dev/serial/nxp-sc16is752-regs.h
index 0000000..0b1c024
--- /dev/null
+++ b/cpukit/dev/serial/nxp-sc16is752-regs.h
@@ -0,0 +1,122 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#ifndef LIBBSP_ARM_ATSAM_SC16IS752_H
+#define LIBBSP_ARM_ATSAM_SC16IS752_H
+#include <dev/serial/nxp-sc16is752.h>
+#ifdef __cplusplus
+extern "C" {
+/* General register set */
+#define SC16IS752_RHR 0x0
+#define SC16IS752_THR 0x0
+#define SC16IS752_IER 0x1
+#define SC16IS752_FCR 0x2
+#define SC16IS752_IIR 0x2
+#define SC16IS752_LCR 0x3
+#define SC16IS752_MCR 0x4
+#define SC16IS752_LSR 0x5
+#define SC16IS752_MSR 0x6
+#define SC16IS752_TCR 0x6
+#define SC16IS752_SPR 0x7
+#define SC16IS752_TLR 0x7
+#define SC16IS752_TXLVL 0x8
+#define SC16IS752_RXLVL 0x9
+#define SC16IS752_IODIR 0xA
+#define SC16IS752_IOSTATE 0xB
+#define SC16IS752_IOINTENA 0xC
+#define SC16IS752_IOCONTROL 0xE
+#define SC16IS752_EFCR 0xF
+/* Special register set */
+#define SC16IS752_DLL 0x0
+#define SC16IS752_DLH 0x1
+/* Enhanced register set */
+#define SC16IS752_EFR 0x2
+#define SC16IS752_XON1 0x4
+#define SC16IS752_XON2 0x5
+#define SC16IS752_XOFF1 0x6
+#define SC16IS752_XOFF2 0x7
+/* EFCR Bit masks */
+#define EFCR_RS485ENABLE (1 << 0)
+#define EFCR_RXENABLE (0 << 1)
+#define EFCR_TXENABLE (0 << 2)
+/* IER Bit masks */
+#define IER_ENABLE_RHR_INTERRUPT (1u << 0)
+#define IER_ENABLE_THR_INTERRUPT (1u << 1)
+/* LCR Bit masks */
+#define LCR_CHRL_5_BIT (0u << 1) | (0u << 0)
+#define LCR_CHRL_6_BIT (0u << 1) | (1u << 0)
+#define LCR_CHRL_7_BIT (1u << 1) | (0u << 0)
+#define LCR_CHRL_8_BIT (1u << 1) | (1u << 0)
+#define LCR_2_STOP_BIT (1u << 2)
+#define LCR_SET_PARITY (1u << 3)
+#define LCR_EVEN_PARITY (1u << 4)
+#define LCR_ENABLE_DIVISOR (1u << 7)
+/* LSR Bit masks */
+#define LSR_TXEMPTY (1u << 5)
+#define LSR_RXRDY (1u << 0)
+#define LSR_ERROR_BITS (7u << 2)
+/* MCR Bit masks */
+#define MCR_PRESCALE_NEEDED (1u << 0)
+ * @brief Writes a value to a register specified by an offset.
+ * @param[in] reg_addr The register address expressed as an offset.
+ * @param[in] reg_val The register value that shall be written to the specified
+ * address.
+ * @param[in] msg The message that shall be sent.
+int sc16is752_write_register (
+ int fd,
+ sc16is752_reg_ctx *ctx,
+ uint8_t reg_addr,
+ const uint8_t reg_val
+ * @brief Reads a value from a register specified by an offset.
+ * @param[out] reg_val The register value that shall be read from the specified
+ * address.
+int sc16is752_read_register (
+ int fd,
+ uint8_t reg_addr,
+ uint8_t *reg_val
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_ATSAM_SC16IS752_H */
diff --git a/cpukit/dev/serial/nxp-sc16is752-spi.c b/cpukit/dev/serial/nxp-sc16is752-spi.c
index 0000000..65f7070
--- /dev/null
+++ b/cpukit/dev/serial/nxp-sc16is752-spi.c
@@ -0,0 +1,90 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#include <assert.h>
+#include <fcntl.h>
+#include <inttypes.h>
+#include <unistd.h>
+#include <bsp/spi.h>
+#include <bsp/atsam-spi.h>
+#include "nxp-sc16is752-regs.h"
+static void set_default_msg(
+ struct spi_ioc_transfer *msg,
+ uint8_t cs,
+ uint32_t speed,
+ uint8_t *rx_buf,
+ uint8_t *tx_buf
+ msg->rx_buf = rx_buf;
+ msg->tx_buf = tx_buf;
+ msg->len = REGISTER_COMMAND_LENGTH;
+ msg->speed_hz = speed;
+ msg->delay_usecs = 1;
+ msg->bits_per_word = 8;
+ msg->cs_change = 1;
+ msg->rx_nbits = 0;
+ msg->tx_nbits = 0;
+ msg->mode = 0;
+ msg->cs = cs;
+int sc16is752_write_register(
+ int fd,
+ uint8_t reg_addr,
+ int rv;
+ spi_ioc_transfer msg;
+ uint8_t tx_buf[REGISTER_COMMAND_LENGTH];
+ uint8_t rx_buf[REGISTER_COMMAND_LENGTH];
+ tx_buf[0] = reg_addr << 3;
+ tx_buf[1] = reg_val;
+ set_default_msg(&msg, ctx->cs, ctx->speed_hz, &rx_buf[0], &tx_buf[0]);
+ rv = ioctl(fd, SPI_IOC_MESSAGE(1), &msg);
+ return rv;
+int sc16is752_read_register(
+ int fd,
+ uint8_t reg_addr,
+ uint8_t *reg_val
+ int rv;
+ tx_buf[0] = 0x80 | reg_addr << 3;
+ tx_buf[1] = 0x00;
+ *reg_val = rx_buf[1];
+ return rv;
diff --git a/cpukit/dev/serial/nxp-sc16is752.c b/cpukit/dev/serial/nxp-sc16is752.c
index 0000000..f6435e8
--- /dev/null
+++ b/cpukit/dev/serial/nxp-sc16is752.c
@@ -0,0 +1,324 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+#include <fcntl.h>
+static void sc16is752_uart_set_baud_rate(
+ sc16is752_uart_ctx *ctx,
+ uint32_t value_mcr,
+ uint32_t divisor
+ uint8_t value_lcr;
+ ctx->read_reg(ctx->fd, ctx->reg_ctx, SC16IS752_LCR, &value_lcr);
+ value_lcr |= LCR_ENABLE_DIVISOR;
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_LCR, value_lcr);
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_MCR, value_mcr);
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_DLH, divisor >> 8);
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_DLL, divisor);
+ value_lcr &= ~LCR_ENABLE_DIVISOR;
+static bool sc16is752_uart_prepare_baud_rate(
+ rtems_termios_baud_t baud
+ uint32_t freq = ctx->input_frequency;
+ uint8_t value_mcr;
+ uint32_t divisor;
+ ctx->read_reg(ctx->fd, ctx->reg_ctx, SC16IS752_MCR, &value_mcr);
+ divisor = freq / baud / 16;
+ if (divisor > 0xFFFF){
+ divisor = (freq / (4 * baud)) / 16;
+ return false;
+ } else {
+ value_mcr |= MCR_PRESCALE_NEEDED;
+ sc16is752_uart_set_baud_rate(ctx, value_mcr, divisor);
+ } else {
+ value_mcr &= ~MCR_PRESCALE_NEEDED;
+ return true;
+static void sc16is752_uart_interrupt(void *arg)
+ rtems_termios_tty *tty = arg;
+ sc16is752_uart_ctx *ctx = rtems_termios_get_device_context(tty);
+ uint8_t value_lsr;
+ uint8_t value_rhr;
+ ctx->read_reg(ctx->fd, ctx->reg_ctx, SC16IS752_LSR, &value_lsr);
+ while ((value & LSR_RXRDY) != 0) {
+ char c;
+ ctx->read_reg(ctx->fd, ctx->reg_ctx, SC16IS752_RHR, &value_rhr);
+ c = (char) value_rhr;
+ rtems_termios_enqueue_raw_characters(tty, &c, 1);
+ if (ctx->transmitting && (value_lsr & LSR_TXEMPTY) != 0) {
+ rtems_termios_dequeue_characters(tty, 1);
+#endif
+static bool sc16is752_uart_set_attributes(
+ rtems_termios_device_context *base,
+ const struct termios *term
+ sc16is752_uart_ctx *ctx = (sc16is752_uart_ctx *) base;
+ uint8_t lcr_value = 0;
+ uint8_t efcr_value = 0;
+ bool baud_successful;
+ rtems_termios_baud_t baud;
+ baud = rtems_termios_baud_to_number(term->c_cflag);
+ baud_successful = sc16is752_uart_prepare_baud_rate(ctx, baud);
+ if (!baud_successful){
+ return false;
+ if (ctx->rs485_wanted){
+ efcr_value = EFCR_RS485ENABLE;
+ if ((term->c_cflag & CREAD) != 0){
+ efcr_value |= EFCR_RXENABLE | EFCR_TXENABLE;
+ } else {
+ efcr_value |= EFCR_TXENABLE;
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_EFCR, efcr_value);
+ switch (term->c_cflag & CSIZE) {
+ case CS5:
+ lcr_value |= LCR_CHRL_5_BIT;
+ break;
+ case CS6:
+ lcr_value |= LCR_CHRL_6_BIT;
+ break;
+ case CS7:
+ lcr_value |= LCR_CHRL_7_BIT;
+ break;
+ case CS8:
+ lcr_value |= LCR_CHRL_8_BIT;
+ break;
+ if ((term->c_cflag & PARENB) != 0){
+ if ((term->c_cflag & PARODD) != 0) {
+ lcr_value &= ~LCR_EVEN_PARITY;
+ } else {
+ lcr_value |= LCR_EVEN_PARITY;
+ } else {
+ lcr_value &= ~LCR_SET_PARITY;
+ if ((term->c_cflag & CSTOPB) != 0) {
+ lcr_value |= LCR_2_STOP_BIT;
+ } else {
+ lcr_value &= ~LCR_2_STOP_BIT;
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_LCR, lcr_value);
+ return true;
+static bool sc16is752_uart_first_open(
+ rtems_termios_tty *tty,
+ struct termios *term,
+ rtems_libio_open_close_args_t *args
+ (void)args;
+ rtems_status_code sc;
+#endif
+ ctx->fd = open(ATSAM_SPI_0_BUS_PATH, O_RDWR);
+ if (ctx->fd < 0) {
+ return false;
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_FCR, 0x7);
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_IER, 0x0);
+ rtems_termios_set_initial_baud(tty, ATSAM_CONSOLE_BAUD);
+ sc16is752_uart_set_attributes(base, term);
+ ctx->read_reg(ctx->fd, ctx->reg_ctx, SC16IS752_IER, &value);
+ value |= IER_ENABLE_RHR_INTERRUPT;
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_IER, value);
+ sc = rtems_interrupt_handler_install(
+ ctx->irq,
+ "SC16IS752",
+ RTEMS_INTERRUPT_SHARED,
+ sc16is752_uart_interrupt,
+ tty
+ if (sc != RTEMS_SUCCESSFUL) {
+ return false;
+#endif
+ return true;
+static void sc16is752_uart_last_close(
+ (void) tty;
+ (void) args;
+ rtems_interrupt_handler_remove(ctx->irq, sc16is752_uart_interrupt, tty);
+#endif
+ close(ctx->fd);
+static void sc16is752_uart_write(
+ const char *buf,
+ size_t len
+ uint8_t value;
+ if (len > 0) {
+ ctx->transmitting = true;
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_THR, buf[0]);
+ ctx->write_reg(
+ ctx->fd,
+ ctx->reg_ctx,
+ SC16IS752_IER,
+ IER_ENABLE_THR_INTERRUPT
+ } else {
+ ctx->transmitting = false;
+ ctx->write_reg(
+ ctx->fd,
+ ctx->reg_ctx,
+ SC16IS752_IER,
+ IER_DISABLE_THR_INTERRUPT
+#else
+ size_t i;
+ for (i = 0; i < len; i++) {
+ do{
+ ctx->read_reg(ctx->fd, ctx->reg_ctx, SC16IS752_LSR, &value);
+ } while ((value & LSR_TXEMPTY) == 0);
+ ctx->write_reg(ctx->fd, ctx->reg_ctx, SC16IS752_THR, buf[i]);
+#endif
+#ifndef SC16IS752_USE_INTERRUPTS
+static int sc16is752_uart_read(rtems_termios_device_context *base)
+ uint8_t status;
+ uint8_t rhr;
+ uint8_t rx_amount;
+ ctx->read_reg(ctx->fd, ctx->reg_ctx, SC16IS752_RXLVL, &rx_amount);
+ ctx->read_reg(ctx->fd, ctx->reg_ctx, SC16IS752_LSR, &status);
+ if (((status & LSR_RXRDY) != 0) && ((status & LSR_ERROR_BITS) == 0)) {
+ ctx->read_reg(ctx->fd, ctx->reg_ctx, SC16IS752_RHR, &rhr);
+ return (char) rhr;
+ } else {
+ return -1;
+#endif
+static const rtems_termios_device_handler sc16is752_uart_handler = {
+ .first_open = sc16is752_uart_first_open,
+ .last_close = sc16is752_uart_last_close,
+ .write = sc16is752_uart_write,
+ .set_attributes = sc16is752_uart_set_attributes,
+ .mode = TERMIOS_IRQ_DRIVEN
+#else
+ .poll_read = sc16is752_uart_read,
+ .mode = TERMIOS_POLLED
+#endif
+ void *arg
+ (void)arg;
+ rtems_termios_initialize();
+ uart_ctx->reg_ctx = reg_ctx;
+ uart_ctx->write_reg = sc16is752_write_register;
+ uart_ctx->read_reg = sc16is752_read_register;
+ uart_ctx->input_frequency = input_frequency;
+ uart_ctx->irq = irq;
+ char uart_sc16is752[] = "/dev/ttyUARTSC16IS752";
+ rtems_termios_device_install(
+ &uart_sc16is752[0],
+ &sc16is752_uart_handler,
+ NULL,
+ &uart_ctx->base
+ uart_ctx->rs485_wanted = rs485_wanted;
+ return RTEMS_SUCCESSFUL;
1.8.4.5
