[PATCH 0/5] arm/tms570: include hardware initialization and selftests to run RTEMS directly from Flash without loader on TMS570LS3137 HDK.
Pavel Pisa ppisa4lists at pikron.com
Sat Sep 17 22:34:21 UTC 2016
Hello Gedare,
I have tried to update code according to your review.
I have added even enabled/uncommented and added implementation
for some more test. Especially ECC integrated TCRAM single errors
correction and reporting test. I have commented why double errors
abort exception based test is commented out because it would require
significantly more work. Have left original commits unchanged for now
  1a98178 arm/tms570: define base addresses of all TMS570LS3137 SPI interfaces.
  9d06f3b arm/tms570: include hardware initialization and selftest based on Ti HalCoGen generated files.
  1ef345e arm/tms570: include TMS570_USE_HWINIT_STARTUP option to select bare metal startup and selftest.
  74b20a1 arm/tms570: document BSP setup with included hardware initialization.
  b38ecb7 arm/tms570: update bootstrap generated preinstall.am
I think that even for you it is easier to read diffs against reviewed state for now.
I plan to collapse/rearrange commits then. I can send updated series
to mainling list then if the V2 complete review is preferred.
The new updates
  472a561 arm/tms570: include HalCoGen generated MPU initialization.
     used to test MPU and SDRAM or real HW, this is not mainline material for this round
  b092a83 bsps/arm: Export bsp_start_hook_0_done symbol from ARM start.S.
  b204502 arm/tms570: Enable more self-tests including integrated TCRAM and its ECC functionality testing.
     this is a little dancing between eggs, but works
  aed1d28 arm/tms570: Add data barriers to external SDRAM setup code.
     there are still some problems with first configuration/reset cycle after power on reset
  c4cbfe8 arm/tms570: Update comments, document functions and add references to the corresponding HalCoGen functions.
  45fda72 arm/tms570: readme and configure help extended a little.
  9f83ada arm/tms570: change ESM parity selftests related functions/types prefix from tms570_partest_ to tms570_selftest_par_ .
The commits, diffs can be read at GitHub
  https://github.com/AoLaD/rtems/commits/tms570-bsp
Best wishes,
               Pavel
