[PATCH] cpukit: Add nxp-sc16is752 serial device driver
Alan Cudmore alan.cudmore at gmail.com
Mon Sep 19 19:29:02 UTC 2016
Thanks.. No hurry, I need to implement the new SPI api for the Pi anyway,
Alan
> On Sep 19, 2016, at 2:56 PM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> Sorry, this is a bug in the driver.  We will fix this before we commit it.
> ----- Am 19. Sep 2016 um 20:53 schrieb Alan Cudmore alan.cudmore at gmail.com:
>> I applied this patch and tried building the raspberrypi BSP and got this error:
>> ../../../../../../../rtems-src/rtems/c/src/../../cpukit/dev/serial/nxp-sc16is752.c:17:27:
>> fatal error: bsp/atsam-spi.h: No such file or directory
>> #include <bsp/atsam-spi.h>
>> Will this only build for the atsam BSP?
>> I am interested in this driver. The Raspberry Pi only has one usable UART. I
>> have a SC16IS750 device I would like to use to add a couple of UARTs to my
>> board so I could connect a GPS and keep the original UART free.
>> To use this, we will have to supply the new Linux user API SPI driver for the
>> Raspberry Pi similar to the spi driver in the atsam BSP, correct?
>> Thanks,
>> Alan
>>> On Sep 19, 2016, at 12:13 PM, Sebastian Huber
>>> Hello Joel,
>>> ----- Joel Sherrill <joel.sherrill at gmail.com> schrieb:
>>>> Sebastian,
>>>> This is yet another style of serial port driver in recent history and
>>>> the software tax hasn't been paid on the last round of changes.
>>> this is not a new style of serial port drivers.  It uses the new Termios device
>>> driver model which I changed in the last patch set to use IMFS generic nodes.
>>> This particular serial device (NXP SC16IS752) is attached via an I2C or SPI
>>> bus.  So, this is highly board/application specific.  Adding such a device to a
>>> particular BSP would end up in a configuration nightmare.
>>>> Merging this will result in three different styles of serial port drivers
>>>> by my count.
>>>> I am not opposed to improvement but this is rapidly heading
>>>> down the "old vs new PowerPC interrupt" path and that sucked
>>>> for years.
>>> With the recent change for the new Termios device driver model its easier to
>>> move the existing console drivers, since there is no need to maintain
>>> major/minor numbers anymore.  The drawback is that you have to use IMFS as the
>>> base file system.  However, its just a matter of doing it to strip down the
>>> IMFS to have similar size demands than the current devfs.
>>>> --joel
>>>> On Mon, Sep 19, 2016 at 8:57 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> It will be good to have some documentation (BSP/driver manual) about
>>>>> how to write these kind of termios drivers. Usually without it we will
>>>>> see someone just copy-paste this one and modify until they get it
>>>>> right... So lacking a plain english doc, this "first" implementation
>>>>> should provide enough comments to make it easy to copy-paste-modify.
>>>>> On Mon, Sep 19, 2016 at 4:11 AM, Sebastian Huber
>>>>>> Please note that this is the first Termios device driver that is
>>>>> independent
>>>>>> of a BSP, CPU architecture and console driver. It is currently work in
>>>>>> progress and lacks support for interrupts. We will add this probably in
>>>>> one
>>>>>> or two weeks.
>>>>>> Sebastian Huber, embedded brains GmbH
>>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>>> Phone   : +49 89 189 47 41-16
>>>>>> Fax     : +49 89 189 47 41-09
>>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>>> PGP     : Public key available on request.
>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>> devel mailing list
>>>>> devel at rtems.org
>>> devel mailing list
>>> devel at rtems.org
