RTEMS classic networking: fixed FXP driver works under QEMU on Linux
Wed Sep 21 05:06:00 UTC 2016
Hello Pavel,
the interrupt server with the simple interrupt vector disable/enable via
the interrupt controller is an easy solution that worked on all boards I
used so far with the libbsd. However, it certainly doesn't work on all
systems. It allowed to easily use the FreeBSD device drivers which use
mutexes in their interrupt service routines.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
