[PATCH] [RTEMS] Always use atomic builtins for libstdc++
Sebastian Huber
Thu Sep 22 07:41:16 UTC 2016
libstdc++-v3/
* config/cpu/m68k/atomicity.h: Adjust comment.
* acinclude.m4 (GLIBCXX_ENABLE_ATOMIC_BUILTINS): Honor
explicit atomicity_dir setup via configure.host.
* configure.host (rtems-*): Set atomicity_dir.
* configure: Regenerate.
libstdc++-v3/acinclude.m4 | 5 +++--
libstdc++-v3/config/cpu/m68k/atomicity.h | 3 +++
libstdc++-v3/configure | 11 ++++++-----
libstdc++-v3/configure.host | 4 ++++
4 files changed, 16 insertions(+), 7 deletions(-)
diff --git a/libstdc++-v3/acinclude.m4 b/libstdc++-v3/acinclude.m4
index 6d897be..3256ce4 100644
--- a/libstdc++-v3/acinclude.m4
+++ b/libstdc++-v3/acinclude.m4
@@ -3490,9 +3490,10 @@ EOF
AC_LANG_RESTORE
# Set atomicity_dir to builtins if all but the long long test above passes.
- if test "$glibcxx_cv_atomic_bool" = yes \
+ if ( test "$glibcxx_cv_atomic_bool" = yes \
&& test "$glibcxx_cv_atomic_short" = yes \
- && test "$glibcxx_cv_atomic_int" = yes; then
+ && test "$glibcxx_cv_atomic_int" = yes ) \
+ || test "$atomicity_dir" = "cpu/generic/atomicity_builtins"; then
AC_DEFINE(_GLIBCXX_ATOMIC_BUILTINS, 1,
[Define if the compiler supports C++11 atomics.])
atomicity_dir=cpu/generic/atomicity_builtins
diff --git a/libstdc++-v3/config/cpu/m68k/atomicity.h b/libstdc++-v3/config/cpu/m68k/atomicity.h
index f421330..a9ddc6b 100644
--- a/libstdc++-v3/config/cpu/m68k/atomicity.h
+++ b/libstdc++-v3/config/cpu/m68k/atomicity.h
@@ -48,6 +48,9 @@ _GLIBCXX_BEGIN_NAMESPACE_VERSION
#elif defined(__rtems__)
+ // This code is only provided for reference. RTEMS uses now the atomic
+ // builtins and libatomic. See configure.host.
// TAS/JBNE is unsafe on systems with strict priority-based scheduling.
// Disable interrupts, which we can do only from supervisor mode.
_Atomic_word
diff --git a/libstdc++-v3/configure b/libstdc++-v3/configure
index 6332c4d..ac9282d 100755
--- a/libstdc++-v3/configure
+++ b/libstdc++-v3/configure
@@ -15539,9 +15539,10 @@ ac_compiler_gnu=$ac_cv_c_compiler_gnu
$as_echo "#define _GLIBCXX_ATOMIC_BUILTINS 1" >>confdefs.h
@@ -15573,7 +15574,7 @@ $as_echo "$as_me: WARNING: Performance of certain classes will degrade as a resu
# unnecessary for this test.
cat > conftest.$ac_ext << EOF
-#line 15576 "configure"
+#line 15577 "configure"
int main()
_Decimal32 d1;
@@ -15615,7 +15616,7 @@ ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-#line 15618 "configure"
+#line 15619 "configure"
template<typename T1, typename T2>
struct same
{ typedef T2 type; };
@@ -15649,7 +15650,7 @@ $as_echo "$enable_int128" >&6; }
rm -f conftest*
-#line 15652 "configure"
+#line 15653 "configure"
struct same
diff --git a/libstdc++-v3/configure.host b/libstdc++-v3/configure.host
index c0cc3ee..eb56ab1 100644
--- a/libstdc++-v3/configure.host
+++ b/libstdc++-v3/configure.host
@@ -296,6 +296,10 @@ case "${host_os}" in
os_include_dir="os/qnx/qnx6.1"
c_model=c
+ rtems*)
+ # Use libatomic if necessary and avoid libstdc++ specific atomicity support
+ atomicity_dir="cpu/generic/atomicity_builtins"
solaris2)
# This too-vague configuration does not provide enough information
# to select a ctype include, and thus os_include_dir is a crap shoot.
1.8.4.5
