What to do with Thread_Control::resource_count?
Fri Sep 23 09:19:45 UTC 2016
Hello,
due to the new thread priority management, the
Thread_Control::resource_count is no longer needed to maintain the
thread priority. The only relevant user of the thread resource count is
static void _Thread_Make_zombie( Thread_Control *the_thread )
   if ( _Thread_Owns_resources( the_thread ) ) {
     _Terminate(
       INTERNAL_ERROR_CORE,
       false,
       INTERNAL_ERROR_RESOURCE_IN_USE
which issues a fatal error in case a thread terminates with a non-zero
resource count.
The question is now: should we maintain the resource count solely for
this diagnostic purpose (the resource count increment/decrement is in
the hot path of the mutex obtain/release)?
Terminating threads which own mutexes make these mutexes indestructible
or lead to surprises in case the thread control block is re-used by a
new thread. The current fatal error is new in 4.11, previous RTEMS
didn't detect this situation.
If we decide to keep the resource count, then I suggest to use it for
the no-protocol mutexes as well. This leads to code re-use with the
priority inheritance mutexes.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
