[PATCH] score: Simplify CORE mutex seize
Fri Sep 23 09:45:52 UTC 2016
Rename _CORE_mutex_Seize_no_protocol_slow() in _CORE_mutex_Seize_slow().
Remove previous _CORE_mutex_Seize_slow() since the protocol handling is
now done in the thread queue operations.
 cpukit/score/include/rtems/score/coremuteximpl.h | 14 ++----
 cpukit/score/src/coremutexseize.c                | 59 ------------------------
 2 files changed, 3 insertions(+), 70 deletions(-)
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index a30d1a8..d30e38d 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -93,14 +93,6 @@ RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_locked(
 Status_Control _CORE_mutex_Seize_slow(
-  CORE_mutex_Control   *the_mutex,
-  Thread_Control       *executing,
-  Thread_Control       *owner,
-  bool                  wait,
-  Thread_queue_Context *queue_context
-Status_Control _CORE_mutex_Seize_no_protocol_slow(
   const Thread_queue_Operations *operations,
@@ -171,8 +163,8 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize(
   return _CORE_mutex_Seize_slow(
     &the_mutex->Mutex,
+    CORE_MUTEX_TQ_PRIORITY_INHERIT_OPERATIONS,
     executing,
-    owner,
     wait,
     queue_context
@@ -251,7 +243,7 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize_no_protocol(
     return status;
-  return _CORE_mutex_Seize_no_protocol_slow(
+  return _CORE_mutex_Seize_slow(
     &the_mutex->Mutex,
     operations,
     executing,
@@ -444,7 +436,7 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_ceiling_mutex_Seize(
     return status;
     &the_mutex->Recursive.Mutex,
     CORE_MUTEX_TQ_OPERATIONS,
     executing,
diff --git a/cpukit/score/src/coremutexseize.c b/cpukit/score/src/coremutexseize.c
index 89b5c56..01a5ffb 100644
--- a/cpukit/score/src/coremutexseize.c
+++ b/cpukit/score/src/coremutexseize.c
@@ -24,65 +24,6 @@
-  bool                  wait,
-  if ( !wait ) {
-    _CORE_mutex_Release( the_mutex, queue_context );
-    return STATUS_UNAVAILABLE;
-#if !defined(RTEMS_SMP)
-   * We must disable thread dispatching here since we enable the interrupts for
-   * priority inheritance mutexes.
-  _Thread_Dispatch_disable();
-   * To enable interrupts here works only since exactly one executing thread
-   * exists and only threads are allowed to seize and surrender mutexes with
-   * the priority inheritance protocol.  On SMP configurations more than one
-   * executing thread may exist, so here we must not release the lock, since
-   * otherwise the current owner may be no longer the owner of the mutex
-   * once we released the lock.
-#endif
-#if defined(RTEMS_SMP)
-  _Thread_queue_Context_set_expected_level( queue_context, 1 );
-#else
-  _ISR_lock_ISR_disable( &queue_context->Lock_context.Lock_context );
-  _CORE_mutex_Acquire_critical( the_mutex, queue_context );
-  _Thread_queue_Context_set_expected_level( queue_context, 2 );
-#endif
-  _Thread_queue_Context_set_deadlock_callout(
-    queue_context,
-    _Thread_queue_Deadlock_status
-  _Thread_queue_Enqueue_critical(
-    &the_mutex->Wait_queue.Queue,
-    CORE_MUTEX_TQ_PRIORITY_INHERIT_OPERATIONS,
-    executing,
-    STATES_WAITING_FOR_MUTEX,
-    queue_context
-  _Thread_Dispatch_enable( _Per_CPU_Get() );
-#endif
-  return _Thread_Wait_get_status( executing );
1.8.4.5
