[PATCH] [RTEMS] Always use atomic builtins for libstdc++
Tue Sep 27 11:24:57 UTC 2016
On 22/09/16 12:55, Jonathan Wakely wrote:
> N.B. if you're going to require libatomic for RTEMS then you should
> check if the preprocessor conditions in libsupc++/exception_ptr.h
> and libsupc++/eh_ptr.cc are appropriate. If exception_ptr is not
> currently enabled for RTEMS then you could enable it, since libatomic
> will ensure the required atomics are available.
Thanks for the hint. I added a ticket for RTEMS:
http://devel.rtems.org/ticket/2791
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
