[PATCH] score: Unify CORE mutex seize/surrender
Sebastian Huber
Tue Sep 27 13:25:25 UTC 2016
Use the Thread_Control::resource_count for the no protocol mutexes.
Merge the no protocol and priority inherit CORE mutex seize/surrender
operations.
cpukit/libnetworking/rtems/rtems_glue.c | 2 +
cpukit/posix/src/mutexlocksupp.c | 3 +-
cpukit/posix/src/mutexunlock.c | 3 +-
cpukit/rtems/src/semobtain.c | 3 +-
cpukit/rtems/src/semrelease.c | 4 +-
cpukit/score/include/rtems/score/coremuteximpl.h | 93 ++----------------------
cpukit/score/src/apimutexlock.c | 1 +
cpukit/score/src/apimutexunlock.c | 1 +
8 files changed, 18 insertions(+), 92 deletions(-)
diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
index 9a7f82f..46f8765 100644
--- a/cpukit/libnetworking/rtems/rtems_glue.c
+++ b/cpukit/libnetworking/rtems/rtems_glue.c
@@ -379,6 +379,7 @@ rtems_bsdnet_semaphore_obtain (void)
_Thread_queue_Context_set_no_timeout( &queue_context );
status = _CORE_recursive_mutex_Seize (
&the_networkSemaphore->Core_control.Mutex.Recursive,
+ CORE_MUTEX_TQ_PRIORITY_INHERIT_OPERATIONS,
_Thread_Executing,
true, /* wait */
_CORE_recursive_mutex_Seize_nested,
@@ -412,6 +413,7 @@ rtems_bsdnet_semaphore_release (void)
_ISR_lock_ISR_disable(&queue_context.Lock_context.Lock_context);
status = _CORE_recursive_mutex_Surrender(
_Thread_Executing,
&queue_context
diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
index 1da6238..ea4c4e3 100644
--- a/cpukit/posix/src/mutexlocksupp.c
+++ b/cpukit/posix/src/mutexlocksupp.c
@@ -76,7 +76,7 @@ int _POSIX_Mutex_Lock_support(
break;
case POSIX_MUTEX_NO_PROTOCOL:
- status = _CORE_recursive_mutex_Seize_no_protocol(
+ status = _CORE_recursive_mutex_Seize(
&the_mutex->Mutex.Recursive,
POSIX_MUTEX_NO_PROTOCOL_TQ_OPERATIONS,
executing,
@@ -89,6 +89,7 @@ int _POSIX_Mutex_Lock_support(
_Assert( the_mutex->protocol == POSIX_MUTEX_PRIORITY_INHERIT );
executing,
wait,
_POSIX_Mutex_Lock_nested,
diff --git a/cpukit/posix/src/mutexunlock.c b/cpukit/posix/src/mutexunlock.c
index 3144314..c15f7e6 100644
--- a/cpukit/posix/src/mutexunlock.c
+++ b/cpukit/posix/src/mutexunlock.c
@@ -53,7 +53,7 @@ int pthread_mutex_unlock(
break;
- status = _CORE_recursive_mutex_Surrender_no_protocol(
+ status = _CORE_recursive_mutex_Surrender(
executing,
@@ -64,6 +64,7 @@ int pthread_mutex_unlock(
executing,
&queue_context
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index 9afef54..b81612e 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -75,6 +75,7 @@ rtems_status_code rtems_semaphore_obtain(
case SEMAPHORE_VARIANT_MUTEX_INHERIT_PRIORITY:
&the_semaphore->Core_control.Mutex.Recursive,
executing,
wait,
@@ -91,7 +92,7 @@ rtems_status_code rtems_semaphore_obtain(
break;
case SEMAPHORE_VARIANT_MUTEX_NO_PROTOCOL:
_Semaphore_Get_operations( the_semaphore ),
executing,
diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
index 39c467d..40860a1 100644
--- a/cpukit/rtems/src/semrelease.c
+++ b/cpukit/rtems/src/semrelease.c
@@ -52,6 +52,7 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
executing,
&queue_context
@@ -64,13 +65,12 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
break;
- _CORE_recursive_mutex_Surrender_no_protocol(
executing,
&queue_context
- status = STATUS_SUCCESSFUL;
break;
case SEMAPHORE_VARIANT_SIMPLE_BINARY:
status = _CORE_semaphore_Surrender(
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index d30e38d..2580606 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -134,6 +134,7 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize_nested(
RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize(
CORE_recursive_mutex_Control *the_mutex,
+ const Thread_queue_Operations *operations,
Thread_Control *executing,
bool wait,
Status_Control ( *nested )( CORE_recursive_mutex_Control * ),
@@ -163,7 +164,7 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize(
return _CORE_mutex_Seize_slow(
&the_mutex->Mutex,
- CORE_MUTEX_TQ_PRIORITY_INHERIT_OPERATIONS,
+ operations,
executing,
wait,
queue_context
@@ -171,9 +172,10 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize(
RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Surrender(
- CORE_recursive_mutex_Control *the_mutex,
- Thread_Control *executing,
- Thread_queue_Context *queue_context
+ CORE_recursive_mutex_Control *the_mutex,
+ Thread_Control *executing,
+ Thread_queue_Context *queue_context
unsigned int nest_level;
@@ -209,91 +211,8 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Surrender(
heads,
executing,
queue_context,
- return STATUS_SUCCESSFUL;
-RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize_no_protocol(
- const Thread_queue_Operations *operations,
- bool wait,
- Status_Control ( *nested )( CORE_recursive_mutex_Control * ),
- Thread_Control *owner;
- _CORE_mutex_Acquire_critical( &the_mutex->Mutex, queue_context );
- owner = _CORE_mutex_Get_owner( &the_mutex->Mutex );
- if ( owner == NULL ) {
- _CORE_mutex_Set_owner( &the_mutex->Mutex, executing );
- _CORE_mutex_Release( &the_mutex->Mutex, queue_context );
- if ( owner == executing ) {
- Status_Control status;
- status = ( *nested )( the_mutex );
- return status;
- return _CORE_mutex_Seize_slow(
- &the_mutex->Mutex,
- operations,
- executing,
- wait,
- queue_context
-RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Surrender_no_protocol(
- unsigned int nest_level;
- Thread_Control *new_owner;
- if ( !_CORE_mutex_Is_owner( &the_mutex->Mutex, executing ) ) {
- return STATUS_NOT_OWNER;
- nest_level = the_mutex->nest_level;
- if ( nest_level > 0 ) {
- the_mutex->nest_level = nest_level - 1;
- new_owner = _Thread_queue_First_locked(
- &the_mutex->Mutex.Wait_queue,
operations
- _CORE_mutex_Set_owner( &the_mutex->Mutex, new_owner );
- if ( new_owner == NULL ) {
- _Thread_queue_Extract_critical(
- &the_mutex->Mutex.Wait_queue.Queue,
- operations,
- new_owner,
- queue_context
diff --git a/cpukit/score/src/apimutexlock.c b/cpukit/score/src/apimutexlock.c
index cf90a76..879562d 100644
--- a/cpukit/score/src/apimutexlock.c
+++ b/cpukit/score/src/apimutexlock.c
@@ -36,6 +36,7 @@ void _API_Mutex_Lock( API_Mutex_Control *the_mutex )
&the_mutex->Mutex,
_Thread_Executing,
true,
diff --git a/cpukit/score/src/apimutexunlock.c b/cpukit/score/src/apimutexunlock.c
index f04e47a..e1fe645 100644
--- a/cpukit/score/src/apimutexunlock.c
+++ b/cpukit/score/src/apimutexunlock.c
@@ -35,6 +35,7 @@ void _API_Mutex_Unlock( API_Mutex_Control *the_mutex )
_ISR_lock_ISR_disable( &queue_context.Lock_context.Lock_context );
&the_mutex->Mutex,
_Thread_Executing,
&queue_context
1.8.4.5
