Context Switching measurement RTEMS
Sebastian Huber
Mon Sep 12 06:58:07 UTC 2016
Hello Babacar,
what is your definition of "context switching time"? To measure short
time intervals with little overhead, you can use the
rtems_counter_read() function (not supported on all BSPs).
The tmcontext01 test measures the low-level context switch time. To get
some samples for the thread dispatch time, you can enable profiling
(--enable-profiling configure command line option) and use the test
suite. Collect the output of all the tests and filter out the non-XML
data (filter-test-xml.py). Then you can use this XML file to get some
statistics (e.g. boxplot.py).
On 07/09/16 22:10, Babacar Diop wrote:
> Dear devels,
> I am using a multithreaded task and I would like to measure the
> context switching time.
> Do you have any idea on how to do this ?
> Kind Regards
> Babacar Diop
> 23 ans
> Élève ingénieur à Polytech' Paris-UPMC
> Section Électronique, Informatique des Systèmes Embarqués
> Année 5
> devel mailing list
> devel at rtems.org
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
E-Mail :sebastian.huber at embedded-brains.de
Type: text/x-python
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160912/f959777a/attachment-0004.py>
Type: text/x-python
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160912/f959777a/attachment-0005.py>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160912/f959777a/attachment-0002.png>
