[PATCH] cpukit: Add nxp-sc16is752 serial device driver
Mon Sep 19 18:56:32 UTC 2016
Sorry, this is a bug in the driver.  We will fix this before we commit it.
----- Am 19. Sep 2016 um 20:53 schrieb Alan Cudmore alan.cudmore at gmail.com:
> I applied this patch and tried building the raspberrypi BSP and got this error:
> ../../../../../../../rtems-src/rtems/c/src/../../cpukit/dev/serial/nxp-sc16is752.c:17:27:
> fatal error: bsp/atsam-spi.h: No such file or directory
> #include <bsp/atsam-spi.h>
> Will this only build for the atsam BSP?
> I am interested in this driver. The Raspberry Pi only has one usable UART. I
> have a SC16IS750 device I would like to use to add a couple of UARTs to my
> board so I could connect a GPS and keep the original UART free.
> To use this, we will have to supply the new Linux user API SPI driver for the
> Raspberry Pi similar to the spi driver in the atsam BSP, correct?
> Thanks,
> Alan
>> On Sep 19, 2016, at 12:13 PM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> Hello Joel,
>> ----- Joel Sherrill <joel.sherrill at gmail.com> schrieb:
>>> Sebastian,
>>> This is yet another style of serial port driver in recent history and
>>> the software tax hasn't been paid on the last round of changes.
>> this is not a new style of serial port drivers.  It uses the new Termios device
>> driver model which I changed in the last patch set to use IMFS generic nodes.
>> This particular serial device (NXP SC16IS752) is attached via an I2C or SPI
>> bus.  So, this is highly board/application specific.  Adding such a device to a
>> particular BSP would end up in a configuration nightmare.
>>> Merging this will result in three different styles of serial port drivers
>>> by my count.
>>> I am not opposed to improvement but this is rapidly heading
>>> down the "old vs new PowerPC interrupt" path and that sucked
>>> for years.
>> With the recent change for the new Termios device driver model its easier to
>> move the existing console drivers, since there is no need to maintain
>> major/minor numbers anymore.  The drawback is that you have to use IMFS as the
>> base file system.  However, its just a matter of doing it to strip down the
>> IMFS to have similar size demands than the current devfs.
>>> --joel
>>> On Mon, Sep 19, 2016 at 8:57 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>>> It will be good to have some documentation (BSP/driver manual) about
>>>> how to write these kind of termios drivers. Usually without it we will
>>>> see someone just copy-paste this one and modify until they get it
>>>> right... So lacking a plain english doc, this "first" implementation
>>>> should provide enough comments to make it easy to copy-paste-modify.
>>>> On Mon, Sep 19, 2016 at 4:11 AM, Sebastian Huber
>>>>> Please note that this is the first Termios device driver that is
>>>> independent
>>>>> of a BSP, CPU architecture and console driver. It is currently work in
>>>>> progress and lacks support for interrupts. We will add this probably in
>>>> one
>>>>> or two weeks.
>>>>> Sebastian Huber, embedded brains GmbH
>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>> Phone   : +49 89 189 47 41-16
>>>>> Fax     : +49 89 189 47 41-09
>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>> PGP     : Public key available on request.
>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>> devel mailing list
>>>> devel at rtems.org
>> devel mailing list
>> devel at rtems.org
