GSoC 2017 -- initial proof
Andy MacGregor
amacgregor.2018 at comcast.net
Sun Apr 2 00:59:08 UTC 2017
On 03/31/2017 09:52 PM, Gedare Bloom wrote:
> Don't forget the deadline is Monday to submit your Final
> PDF and proof of enrollment. The "Final" PDF can be submitted multiple
> times, so go ahead and submit it when you finish a first draft. Add
> your draft proposal to the tracking table at
> https://devel.rtems.org/wiki/GSoC/2017 also, to get some possible
> feedback.
Thanks for the welcome! (I realize I am late to the GSOC application table).
I'm set on improving code coverage of the testsuite, but I found some
questions as I'm starting to look into how its done.
The link on the wiki to the current code status is currently broken
<https://www.rtems.org/ftp/pub/rtems/people/joel/coverage/>, so I tried
to generate a sample coverage report for 4.12 using ./do_coverage,
./run_coverage and ./coverage_cron as suggested on the wiki here
<https://devel.rtems.org/wiki/TBR/UserManual/RTEMS_Coverage_Analysis#HowitisDoneNow>but
without any luck. Is there an up to date coverage report available?
I modified the VERSIONS-COVERAGE file like the wiki said, and once that
didn't work dug around in the script but fix it myself quickly.
Could updating these coverage analysis scripts be a viable component of
a GSOC proposal?
In addition, I'd like to actually make some improvements the code
coverage itself.
The most recent information I could find was these bar graphs from 2009.
<https://devel.rtems.org/wiki/Developer/Coverage/Status>
If these graphs reflect the current coverage state, I think that
improving coverage for the i386/pc386,
would be interesting because there is room for improvement in both the
Baseline and Developmental groups (if these coverage statistics are up
to date).
Does anyone know of a good reason to choose another BSP over i386/pc386?
I've just posted a draft of my proposal to the GSOC page.
If there's any feedback I'll be sure to update my proposal in time.
-Andy MacGregor
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170402/75d8b383/attachment-0001.html>
