[PATCH 1/2] beagle i2c: Add beaglebone i2c driver code
Sun Apr 2 12:53:08 UTC 2017
Hello Sichen Zhao,
In general it takes a few days for patches to get reviewed, and very
little happens on the mailing list over the weekend. Please wait about
a week and if no one has commented on your patches then you can send a
polite ping like this. Thanks.
-Gedare
On Sun, Apr 2, 2017 at 8:36 AM, Sichen Zhao <sichen.zhao at qq.com> wrote:
> Hi Gedare Bloom, Hi all,
> Is there any problem about my patch? If any, please let me know, and i will
> try my best to modify it.
> Because this is my first time to submit patch, I may will make many
> mistakes, but i will do my best.
> Thanks
> Best Regards
> Sichen Zhao
> ------------------ Original ------------------
> From:  "Sichen Zhao";<1473996754 at qq.com>;
> Date:  Fri, Mar 31, 2017 01:42 PM
> To:  "devel"<devel at rtems.org>;
> Cc:  "Punit Vara"<punitvara at gmail.com>;
> Subject:  [PATCH 1/2] beagle i2c: Add beaglebone i2c driver code
> From: Punit Vara <punitvara at gmail.com>
> This patch add the I2C driver code for Beaglebone Black:
> - Add beagle/i2c/bbb-i2c.c  i2c driver code
> - Modify include/i2c.h
> - Modify beagle/Makefile.am
> But i2c can not work currently
>  c/src/lib/libbsp/arm/beagle/Makefile.am   |   4 +-
>  c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 796
>  c/src/lib/libbsp/arm/beagle/include/i2c.h | 153 +++++-
>  3 files changed, 934 insertions(+), 19 deletions(-)
>  create mode 100644 c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am
> b/c/src/lib/libbsp/arm/beagle/Makefile.am
> index 8bb8478..4da72bc 100644
> --- a/c/src/lib/libbsp/arm/beagle/Makefile.am
> +++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
> @@ -88,7 +88,6 @@ libbsp_a_SOURCES += ../../shared/timerstub.c
>  libbsp_a_SOURCES += ../../shared/cpucounterread.c
>  libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
>  libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
> -libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
>  # Startup
>  libbsp_a_SOURCES += startup/bspreset.c
> @@ -116,6 +115,9 @@ libbsp_a_SOURCES += ../../shared/console.c \
>  # I2C
>  libbsp_a_SOURCES += misc/i2c.c
> +# i2c
> +libbsp_a_SOURCES += i2c/bbb-i2c.c
>  # GPIO
>  libbsp_a_SOURCES += gpio/bbb-gpio.c
> diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> new file mode 100644
> index 0000000..6b790e5
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> @@ -0,0 +1,796 @@
> + * @file
> + * @ingroup arm_beagle
> + * @brief BeagleBoard I2C bus initialization and API Support.
> + * Copyright (c) 2016 Punit Vara <punitvara at gmail.com>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#include <stdio.h>
> +#include <bsp/i2c.h>
> +#include <libcpu/am335x.h>
> +#include <rtems/irq-extension.h>
> +#include <bsp/bbb-gpio.h>
> +#include <rtems/score/assert.h>
> +static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
> +  bool status =true;
> +    // We will check i2c_bus_id in am335x_i2c_bus_register
> +    // Apart from mode and pull_up register what about SCREWCTRL & RXACTIVE
> +  if (bus->i2c_bus_id == I2C1) {
> +    REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_CS0) = (BBB_MUXMODE(MODE2) |
> BBB_PU_EN);
> +    REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D1) = (BBB_MUXMODE(MODE2) |
> BBB_PU_EN);
> +    REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_TXD) = (BBB_MUXMODE(MODE3)
> | BBB_PU_EN);
> +    REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RXD) = (BBB_MUXMODE(MODE3)
> | BBB_PU_EN);
> +  } else if (bus->i2c_bus_id == I2C2) {
> +    REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RTSN) = (BBB_MUXMODE(MODE3)
> | BBB_PU_EN);
> +    REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_CTSN) = (BBB_MUXMODE(MODE3)
> | BBB_PU_EN);
> +    REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = (BBB_MUXMODE(MODE3) |
> BBB_PU_EN);
> +    REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = (BBB_MUXMODE(MODE3)
> | BBB_PU_EN);
> +  } else {
> +  status = false;
> +  return status;
> +/* ref. Table 21-4 I2C Clock Signals */
> + For I2C1/2
> + Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
> + Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
> +static void am335x_i2c1_i2c2_module_clk_config(bbb_i2c_bus *bus)
> +/*0x2 = SW_WKUP : SW_WKUP: Start a software forced wake-up
> +transition on the domain. */
> +  REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) |=
> +                        AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> +  while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
> +                        AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=
> +                        AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
> +/* 0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
> +used for functions) may be gated according to the clock domain
> +state. Functional clocks are guarantied to stay present. As long as in
> +this configuration, power domain sleep transition cannot happen.*/
> + /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
> +                        AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
> +  while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
> +      AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) !=
> AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
> +/*0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
> +  REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
> +                             AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
> +  while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
> +     AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) !=
> AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
> +  REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
> +                             AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE;
> +  while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
> +     AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) !=
> AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
> +  while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
> +           (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
> +            AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
> +static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
> +  REG(bus->regs + AM335X_CONF_I2C0_SDA) =
> +  (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
> +  REG(bus->regs + AM335X_CONF_I2C0_SCL) =
> +static void I2C0ModuleClkConfig(void)
> +    /* Configuring L3 Interface Clocks. */
> +    /* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */
> +    REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) |=
> +          CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
> +    /* Waiting for MODULEMODE field to reflect the written value. */
> +    while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE !=
> +          (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) &
> +           CM_PER_L3_CLKCTRL_MODULEMODE));
> +    /* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */
> +    REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) |=
> +          CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
> +    while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE !=
> +          (REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) &
> +           CM_PER_L3_INSTR_CLKCTRL_MODULEMODE));
> +    /* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */
> +    REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) |=
> +          CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> +    /* Waiting for CLKTRCTRL field to reflect the written value. */
> +    while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> +          (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) &
> +           CM_PER_L3_CLKSTCTRL_CLKTRCTRL));
> +    /* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */
> +    REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) |=
> +          CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> +    /*Waiting for CLKTRCTRL field to reflect the written value. */
> +    while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> +          (REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) &
> +           CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL));
> +    /* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */
> +    REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) |=
> +          CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> +    while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> +          (REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) &
> +           CM_PER_L3S_CLKSTCTRL_CLKTRCTRL));
> +    /* Checking fields for necessary values.  */
> +    /* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to
> 0x0. */
> +    while((CM_PER_L3_CLKCTRL_IDLEST_FUNC <<
> CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!=
> +           CM_PER_L3_CLKCTRL_IDLEST));
> +    ** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to
> attain the
> +    ** desired value.
> +    while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC <<
> +           CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!=
> +           CM_PER_L3_INSTR_CLKCTRL_IDLEST));
> +    ** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL
> register to
> +    ** attain the desired value.
> +    while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK !=
> +           CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
> +    ** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in
> +    ** register to attain the desired value.
> +    while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK !=
> +           CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK));
> +    ** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL
> register
> +    ** to attain the desired value.
> +    while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK !=
> +          CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
> +    /* Configuring registers related to Wake-Up region. */
> +    /* Writing to MODULEMODE field of CM_WKUP_CONTROL_CLKCTRL register. */
> +    REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) |=
> +          CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE;
> +    while(CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE !=
> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) &
> +           CM_WKUP_CONTROL_CLKCTRL_MODULEMODE));
> +    REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) |=
> +          CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> +    while(CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) &
> +           CM_WKUP_CLKSTCTRL_CLKTRCTRL));
> +    /* Writing to CLKTRCTRL field of CM_L3_AON_CLKSTCTRL register. */
> +    REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) |=
> +          CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> +    while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) &
> +           CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL));
> +    /* Writing to MODULEMODE field of CM_WKUP_I2C0_CLKCTRL register. */
> +    REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) |=
> +          CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE;
> +    while(CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE !=
> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) &
> +           CM_WKUP_I2C0_CLKCTRL_MODULEMODE));
> +    /* Verifying if the other bits are set to required settings. */
> +    ** Waiting for IDLEST field in CM_WKUP_CONTROL_CLKCTRL register to
> attain
> +    ** desired value.
> +    while((CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
> +           CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT) !=
> +           CM_WKUP_CONTROL_CLKCTRL_IDLEST));
> +    ** Waiting for CLKACTIVITY_L3_AON_GCLK field in CM_L3_AON_CLKSTCTRL
> +    ** register to attain desired value.
> +    while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK !=
> +           CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK));
> +    ** Waiting for IDLEST field in CM_WKUP_L4WKUP_CLKCTRL register to
> attain
> +    ** desired value.
> +    while((CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC <<
> +           CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT) !=
> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_L4WKUP_CLKCTRL) &
> +           CM_WKUP_L4WKUP_CLKCTRL_IDLEST));
> +    ** Waiting for CLKACTIVITY_L4_WKUP_GCLK field in CM_WKUP_CLKSTCTRL
> register
> +    ** to attain desired value.
> +    while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK !=
> +           CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK));
> +    ** Waiting for CLKACTIVITY_L4_WKUP_AON_GCLK field in
> CM_L4_WKUP_AON_CLKSTCTRL
> +    while(CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK !=
> +          (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL) &
> +           CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK));
> +    ** Waiting for CLKACTIVITY_I2C0_GFCLK field in CM_WKUP_CLKSTCTRL
> +    while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
> +           CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK));
> +    ** Waiting for IDLEST field in CM_WKUP_I2C0_CLKCTRL register to attain
> +    ** desired value.
> +    while((CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
> +           CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT) !=
> +           CM_WKUP_I2C0_CLKCTRL_IDLEST));
> +void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
> +  // am335x_i2c_pinmux()
> +  // am335x_i2c1_i2c2_module_clk_config
> +static bool am335x_i2c_busbusy(volatile bbb_i2c_regs *regs)
> +  bool status;
> +  if (REG(&regs->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
> +    status = true;
> +  } else {
> +    status = false;
> +  return status;
> +static void am335x_i2c_reset(bbb_i2c_bus *bus)
> +  volatile bbb_i2c_regs *regs = bus->regs;
> +  printk("reset bus->reg is %x \n",bus->regs);
> +  /* Disable I2C module at the time of initialization*/
> +  /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
> +  printk("inside BBB_I2C_CON value is %x \n",&regs->BBB_I2C_CON);
> +  mmio_clear((&regs->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
> +  mmio_clear((&regs->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
> +  //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
> +  //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
> +  can I clear all the interrupt here ?
> +  mmio_write(get_reg_addr(bbb_i2c_bus->reg->AM335X_I2C_IRQ_ENABLE_CLR), ??)
> +Possible values for msg->flag
> +   * - @ref I2C_M_TEN,
> +   * - @ref I2C_M_RD,
> +   * - @ref I2C_M_STOP,
> +   * - @ref I2C_M_NOSTART,
> +   * - @ref I2C_M_REV_DIR_ADDR,
> +   * - @ref I2C_M_IGNORE_NAK,
> +   * - @ref I2C_M_NO_RD_ACK, and
> +   * - @ref I2C_M_RECV_LEN.
> +static void am335x_i2c_set_address_size(const i2c_msg *msgs,volatile
> bbb_i2c_regs *regs)
> +    /*can be configured multiple modes here. Need to think about own
> address modes*/
> +  if ((msgs->flags & I2C_M_TEN) == 0)  {/* 7-bit mode slave address mode*/
> +  mmio_write(&regs->BBB_I2C_CON,(AM335X_I2C_CFG_7BIT_SLAVE_ADDR |
> AM335X_I2C_CON_I2C_EN));
> +  } else { /* 10-bit slave address mode*/
> +  mmio_write(&regs->BBB_I2C_CON,(AM335X_I2C_CFG_10BIT_SLAVE_ADDR |
> +static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
> +  i2c_msg *msg;
> +  printk("Enter next_byte\n");
> +  ++bus->msgs;
> +  --bus->msg_todo;
> +  msg = &bus->msgs[0];
> +  bus->current_msg_todo = msg->len;
> +  bus->current_msg_byte = msg->buf;
> +static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
> +  return (REG(&regs->BBB_I2C_IRQSTATUS_RAW));
> +static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs,
> unsigned int flag)
> +  REG(&regs->BBB_I2C_IRQENABLE_SET) |= flag;
> +static void am335x_i2c_masterint_disable(volatile bbb_i2c_regs *regs,
> unsigned int flag)
> + REG(&regs->BBB_I2C_IRQENABLE_CLR) = flag;
> +static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int
> flag)
> +  REG(&regs->BBB_I2C_IRQSTATUS) = flag;
> +static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
> +  am335x_i2c_masterint_enable(regs,0x7FFF);
> +  am335x_int_clear(regs,0x7FFF);
> +  am335x_i2c_masterint_disable(regs,0x7FFF);
> +static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile
> bbb_i2c_regs *regs, const i2c_msg *msgs, bool send_stop)
> +  volatile unsigned int no_bytes;
> +  //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
> +   // No of data to be transmitted at a time
> +  REG(&regs->BBB_I2C_CNT) = 0x02;
> +  no_bytes = REG(&regs->BBB_I2C_CNT);
> +  // I2C Controller in Master Mode
> +  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN |
> AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
> +  printk("set master in transmission mode %x \n",REG(&regs->BBB_I2C_CON));
> +  // Set Slave address & Master enable, bring out of reset
> +  REG(&regs->BBB_I2C_SA) = msgs->addr;
> +  printf("slave address : %x\n",REG(&regs->BBB_I2C_SA));
> +  // clear status of all interrupts
> +  am335x_clean_interrupts(regs);
> +  printk("\n set memory address to read\n");
> +  // transmit interrupt is enabled
> +  am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
> +  printk("Enable transmit interrupt \n");
> +  //start condition
> +  REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_START;
> +  printk("start transmission \n");
> +  while(am335x_i2c_busbusy(regs) == 0);
> +  printk("bus is free \n");
> +  printk("CNT : %x\n", no_bytes);
> +  while(0 != no_bytes);
> +  printk("total msg count for tranmission is zero \n");
> +  while( !(am335x_i2c_intrawstatus(regs) & (AM335X_I2C_IRQSTATUS_ARDY)));
> +  printk("Enter read transfer \n");
> +   // No of data to be received at a time(msg_count!!)
> +  printk("msg_todo for read is %d \n",bus->msg_todo);
> +  REG(&regs->BBB_I2C_CNT) = bus->msg_todo;
> +  //am335x_clean_interrupts(regs);
> +  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_RX | AM335X_I2C_CON_I2C_EN |
> AM335X_I2C_CON_MST;
> +  printk("Set master to receiver mode %x \n", REG(&regs->BBB_I2C_CON));
> +  // receive interrupt is enabled
> +  am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY |
> AM335X_I2C_INT_STOP_CONDITION);
> +  if (send_stop) {
> +    // stop condition
> +    printk("stop to read\n");
> +    REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
> +  } else {
> +    // start condition
> +    printk("start to read\n");
> +  printk("Exit read transfer\n");
> +static void am335x_i2c_continue_read_transfer(
> +  bbb_i2c_bus *bus,
> +  printk("enter continue read transfer \n");
> +  bus->current_msg_byte[bus->already_transferred] =
> REG(&regs->BBB_I2C_DATA);
> +  bus->already_transferred++;
> +  am335x_int_clear(regs,AM335X_I2C_INT_RECV_READY);
> +  printk("clear RRDY in continue read transfer\n");
> +  if (bus->already_transferred == REG(&regs->BBB_I2C_CNT)) {
> +    printk("continue read transfer finished \n");
> +    //am335x_i2c_setup_read_transfer(bus,regs,false);
> +    am335x_i2c_masterint_disable(regs, AM335X_I2C_INT_RECV_READY);
> +    printk("disable RRDY in continue read transfer\n");
> +    printk("stop condition in continue read transfer
> %x\n",REG(&regs->BBB_I2C_CON));
> +static void am335x_i2c_continue_write(bbb_i2c_bus *bus, volatile
> bbb_i2c_regs *regs)
> +   REG(&regs->BBB_I2C_DATA) = 0x00;
> +   am335x_int_clear(regs, AM335X_I2C_IRQSTATUS_XRDY);
> +   printk("clear XRDY continue write\n");
> +   printk("\n finished transfer \n");
> +   am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY);
> +   printk("disable XRDY continue write \n");
> +   } else {
> +     printk("write memory address \n");
> +     REG(&regs->BBB_I2C_DATA) = *bus->current_msg_byte;
> +   if (bus->already_transferred == bus->msg_todo) {
> +     printk("finished transfer \n");
> +   } else {
> +     printk("remaining byte \n");
> bus->current_msg_byte[bus->already_transferred];
> +     printk("%s",REG(&regs->BBB_I2C_DATA));
> +static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile
> bbb_i2c_regs *regs)
> +  printk(" \n Enter write transfer \n");
> +  // Following data count specify bytes to be transmitted
> +  // Already cleaned during reset
> +  // I2C Controller in Master transmitter Mode
> +  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN;
> +  printk("enable master in transmiter mode setup write
> +  printk("enable XRDY setup write\n");
> +  //start condition
> +  printk("set start condition in setup write %x
> +  printk("CNT in setup write : %x \n",REG(&regs->BBB_I2C_CNT));
> +  printk("setup write msg_todo %x \n",bus->current_todo);
> +  printk("check whether ???\n");
> +  printk("RAW =  %x",REG(&regs->BBB_I2C_IRQSTATUS_RAW));
> +  while( !((am335x_i2c_intrawstatus(regs)) & (AM335X_I2C_IRQSTATUS_ARDY)));
> +  printk("exit setup write \n");
> +static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile
> bbb_i2c_regs *regs)
> +  const i2c_msg *msgs = bus->msgs;
> +  uint32_t msg_todo = bus->msg_todo;
> +  bool send_stop = false;
> +  uint32_t i;
> +  printk("Enter setup transfer\n");
> +  bus->current_todo = msgs[0].len;
> +  for (i = 1; i < msg_todo && (msgs[i].flags & I2C_M_NOSTART) != 0; ++i) {
> +    bus->current_todo += msgs[i].len;
> +  regs = bus->regs;
> +  REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
> +  REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
> +  am335x_i2c_set_address_size(msgs,regs);
> +  bus->read = ((bus->read == true) ? 0:1);
> +  bus->already_transferred = (bus->read == true) ? 0 : 1;
> +  if (bus->read) {
> +    if (REG(&regs->BBB_I2C_CNT) == 1) {
> +      send_stop = true;
> +    printk("configure to read bus\n");
> +    am335x_i2c_setup_read_transfer(bus,regs,msgs,send_stop);
> +  } else {
> +    printk("configure to write bus\n");
> +    am335x_i2c_setup_write_transfer(bus,regs);
> +static void am335x_i2c_interrupt(void *arg)
> +  bbb_i2c_bus *bus = arg;
> +  /* get status of enabled interrupts */
> +  uint32_t irqstatus = REG(&regs->BBB_I2C_IRQSTATUS);
> +  bool done = false;
> +  printk("\n inside interrupt function \n");
> +  /* Clear all enabled interrupt except receive ready and transmit ready
> interrupt in status register */
> +  REG(&regs->BBB_I2C_IRQSTATUS) = (irqstatus & ~(AM335X_I2C_IRQSTATUS_RRDY
> | AM335X_I2C_IRQSTATUS_XRDY));
> +  printk("\n irqstatus = %x \n",REG(&regs->BBB_I2C_IRQSTATUS));
> +  if (irqstatus & AM335X_I2C_INT_RECV_READY) {
> +     printk("\nInside receive interrupt\n");
> +    am335x_i2c_continue_read_transfer(bus, regs);
> +  if (irqstatus & AM335X_I2C_IRQSTATUS_XRDY) {
> +    printk("\ninside transmit interrupt \n");
> +    am335x_i2c_continue_write(bus,regs);
> +  if (irqstatus & AM335X_I2C_IRQSTATUS_NACK) {
> +    done = true;
> +    printk("inside NACK\n");
> +    am335x_i2c_masterint_disable(regs,AM335X_I2C_IRQSTATUS_NACK);
> +  if (irqstatus & AM335X_I2C_IRQSTATUS_BF) {
> +    done = true;
> +    printk("inside BF \n ");
> +  if (done) {
> +    uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
> +    printk("interrupt done \n");
> +    am335x_i2c_next_byte(bus);
> +    if (bus->msg_todo == 0 || err != 0) {
> +    rtems_status_code sc;
> +    // am335x_i2c_disable_interrupts(regs);
> +    am335x_i2c_masterint_disable(regs, (AM335X_I2C_IRQSTATUS_RRDY |
> AM335X_I2C_IRQSTATUS_XRDY | AM335X_I2C_IRQSTATUS_BF));
> +    REG(&regs->BBB_I2C_IRQSTATUS) = err;
> +    sc = rtems_event_transient_send(bus->task_id);
> +    _Assert(sc == RTEMS_SUCCESSFUL);
> +    (void) sc;
> +    } else {
> +      am335x_i2c_setup_transfer(bus, regs);
> +static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t
> msg_count)
> +  bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
> +  volatile bbb_i2c_regs *regs;
> +  uint32_t i;
> + printk("\n enter transfer ");
> +  rtems_task_wake_after(1);
> +  if (msg_count < 1){
> +    return 1;
> +  for (i=0; i<msg_count;++i) {
> +      if ((msgs[i].flags & I2C_M_RECV_LEN) != 0) {
> +        return -EINVAL;
> +  bus->msgs = &msgs[0];
> +  bus->msg_todo = msg_count;
> +  printk("total msg = msg_count : %x \n",bus->msg_todo);
> +  bus->current_msg_todo = msgs[0].len;// current data size
> +  bus->current_msg_byte = msgs[0].buf;// current data
> +  printk("\n current_msg_todo %x \n ",msgs[0].len);
> +  printk("\n current_msg_byte %x \n ",msgs[0].buf);
> +  bus->task_id = rtems_task_self();
> +  regs = bus->regs;
> +  am335x_i2c_setup_transfer(bus,regs);
> +  REG(&regs->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
> +  sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
> +  // If timeout then return timeout error
> +  if (sc != RTEMS_SUCCESSFUL) {
> +    am335x_i2c_reset(bus);
> +    rtems_event_transient_clear();
> +    return -ETIMEDOUT;
> +  printk("exit transfer\n");
> +  // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
> +  return 0;
> +static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
> +  bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> +  uint32_t prescaler,divider;
> +  printk("set clock start\n");
> +  prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
> +  printk("PSC offset %x \n ",&regs->BBB_I2C_PSC);
> +  printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
> +  //mmio_write((&regs->BBB_I2C_PSC), prescaler);
> +  REG(&bus->regs->BBB_I2C_PSC) = prescaler;
> +  divider = BBB_I2C_INTERNAL_CLK/(2*clock);
> +  printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
> +  //mmio_write((&regs->BBB_I2C_SCLL), (divider - 7));
> +  REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
> +  //mmio_write((&regs->BBB_I2C_SCLH), (divider - 5));
> +  printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
> +  REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
> +  printk("set clock end \n");
> +  return 0;
> +static void am335x_i2c_destroy(i2c_bus *base)
> +  printk(" starting destroy\n");
> +  sc = rtems_interrupt_handler_remove(bus->irq, am335x_i2c_interrupt, bus);
> +  (void)sc;
> +  printk("end destroy\n");
> +  i2c_bus_destroy_and_free(&bus->base);
> +int am335x_i2c_bus_register(
> +  const char *bus_path,
> +  uintptr_t register_base,
> +  uint32_t input_clock,
> +  rtems_vector_number irq
> +  bbb_i2c_bus *bus;
> +  int err;
> +  /*check bus number is >0 & <MAX*/
> +  bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init(sizeof(*bus));
> +  if (bus == NULL) {
> +    return -1;
> +  bus->regs = (volatile bbb_i2c_regs *) register_base;
> +// 1. Enable clock for I2CX
> +  I2C0ModuleClkConfig();
> +// 2. pinmux setup
> +  am335x_i2c0_pinmux(bus);
> +// 3. RESET : Disable Master, autoideal
> +// 4. configure bus speed
> +  bus->input_clock = input_clock; // By default 100KHz. Normally pass
> 100KHz as argument
> +  printk("Before set clock \n");
> +  err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
> +  if (err != 0) {
> +    (*bus->base.destroy)(&bus->base);
> +    rtems_set_errno_and_return_minus_one(-err);
> +   bus->irq = irq;
> +  //bring I2C out of reset
> +   REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
> +  // 5. Start interrupt service routine & one interrupt at a time
> +  sc  = rtems_interrupt_handler_install(
> +    irq,
> +    "BBB I2C",
> +    RTEMS_INTERRUPT_UNIQUE,
> +    am335x_i2c_interrupt,
> +    bus
> +    rtems_set_errno_and_return_minus_one(EIO);
> +  // 6. start transfer for reading and writing
> +  bus->base.transfer = am335x_i2c_transfer;
> +  bus->base.set_clock = am335x_i2c_set_clock;
> +  bus->base.destroy = am335x_i2c_destroy;
> +  printk("exit register\n");
> +  return i2c_bus_register(&bus->base,bus_path);
> diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h
> b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> index e7d1716..d4a9e32 100644
> --- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
> +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> @@ -1,5 +1,5 @@
> - * @file
> @@ -24,7 +24,7 @@
>  #define LIBBSP_ARM_BEAGLE_I2C_H
>  #include <rtems.h>
> +#include <dev/i2c/i2c.h>
>  #include <bsp.h>
>  #ifdef __cplusplus
> @@ -180,20 +180,8 @@ struct i2c {
>    unsigned short res15;
> -static unsigned short wait_for_pin( void );
> -static void wait_for_bb( void );
> -static void flush_fifo( void );
>  void i2c_init( int speed, int slaveadd );
> -static int i2c_read_byte(
> -  unsigned char devaddr,
> -  unsigned char regoffset,
> -  unsigned char *value
>  int i2c_write(
>    unsigned char chip,
>    unsigned int addr,
> @@ -210,10 +198,6 @@ int i2c_read(
>    int len
> -static int imw ( unsigned char  chip, unsigned long addr, unsigned char
> byte );
> -static int imd( unsigned char chip, unsigned int addr, unsigned int length
>   * @brief Initializes the I2C module @a i2c.
> @@ -361,6 +345,139 @@ static inline rtems_status_code beagle_i2c_read(
>    return beagle_i2c_write_and_read(i2c, addr, NULL, 0, in, in_size);
> +#define BBB_I2C_SYSCLK 48000000
> +#define BBB_I2C_INTERNAL_CLK 12000000
> +#define BBB_I2C_SPEED_CLK 100000
> +#define BBB_I2C_IRQ_ERROR \
> +  (AM335X_I2C_IRQSTATUS_NACK \
> +    | AM335X_I2C_IRQSTATUS_ROVR \
> +    | AM335X_I2C_IRQSTATUS_AL \
> +    | AM335X_I2C_IRQSTATUS_ARDY \
> +    | AM335X_I2C_IRQSTATUS_RRDY \
> +    | AM335X_I2C_IRQSTATUS_XRDY \
> +    | AM335X_I2C_IRQSTATUS_XUDF)
> +#define BBB_I2C_IRQ_USED \
> +  ( BBB_I2C_IRQ_ERROR \
> +    | AM335X_I2C_IRQSTATUS_AAS \
> +    | AM335X_I2C_IRQSTATUS_BF \
> +    | AM335X_I2C_IRQSTATUS_STC \
> +    | AM335X_I2C_IRQSTATUS_GC \
> +    | AM335X_I2C_IRQSTATUS_XDR \
> +    | AM335X_I2C_IRQSTATUS_RDR)
> +#define BBB_I2C_0_BUS_PATH "/dev/i2c-0"
> +#define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
> +#define BBB_I2C_2_BUS_PATH "/dev/i2c-2"
> +#define BBB_I2C0_IRQ 70
> +#define BBB_I2C1_IRQ 71
> +#define BBB_I2C2_IRQ 30
> +#define MODE2 2
> +#define MODE3 3
> +typedef enum {
> +  I2C0,
> +  I2C1,
> +  I2C2,
> +  I2C_COUNT
> +}bbb_i2c_id_t;
> +typedef struct i2c_regs
> +  uint32_t BBB_I2C_REVNB_LO; // 0h
> +  uint32_t BBB_I2C_REVNB_HI; //4h
> +  uint32_t dummy1[2];
> +  uint32_t BBB_I2C_SYSC;  // 10h =16
> +  uint32_t dummy2[4];
> +  uint32_t BBB_I2C_IRQSTATUS_RAW;  //24h =36
> +  uint32_t BBB_I2C_IRQSTATUS;  //28h =40
> +  uint32_t BBB_I2C_IRQENABLE_SET;  //2Ch =44
> +  uint32_t BBB_I2C_IRQENABLE_CLR; //30h =48
> +  uint32_t BBB_I2C_WE;  // 34h = 52
> +  uint32_t BBB_I2C_DMARXENABLE_SET; //38h = 56
> +  uint32_t BBB_I2C_DMATXENABLE_SET;  //3Ch = 60
> +  uint32_t BBB_I2C_DMARXENABLE_CLR;  //40h = 64
> +  uint32_t BBB_I2C_DMATXENABLE_CLR;  //44h = 68
> +  uint32_t BBB_I2C_DMARXWAKE_EN;  //48h = 72
> +  uint32_t BBB_I2C_DMATXWAKE_EN;  //4Ch =76
> +  uint32_t dummy3[16];
> +  uint32_t BBB_I2C_SYSS;  // 90h =144
> +  uint32_t BBB_I2C_BUF;  // 94h =148
> +  uint32_t BBB_I2C_CNT;  // 98h =152
> +  uint32_t BBB_I2C_DATA; //9Ch =156
> +  uint32_t dummy4;
> +  uint32_t BBB_I2C_CON;  // A4h = 164
> +  uint32_t BBB_I2C_OA;  //A8h = 168
> +  uint32_t BBB_I2C_SA;  //ACh = 172
> +  uint32_t BBB_I2C_PSC;  //B0h = 176
> +  uint32_t BBB_I2C_SCLL;  //B4h = 180
> +  uint32_t BBB_I2C_SCLH;  //B8h = 184
> +  uint32_t BBB_I2C_SYSTEST;  //BCh = 188
> +  uint32_t BBB_I2C_BUFSTAT;  //C0h 192
> +  uint32_t BBB_I2C_OA1;  //C4h 196
> +  uint32_t BBB_I2C_OA2;  //C8h 200
> +  uint32_t BBB_I2C_OA3;  //CCh 204
> +  uint32_t BBB_I2C_ACTOA;  //D0h 208
> +  uint32_t BBB_I2C_SBLOCK;  //D4h 212
> +}bbb_i2c_regs;
> +typedef struct bbb_i2c_bus{
> +  i2c_bus base;
> +  i2c_msg *msgs;
> +  uint32_t msg_todo;
> +  uint32_t current_msg_todo; // current_data_size
> +  uint8_t *current_msg_byte; // current_data
> +  uint32_t current_todo;
> +  bool read;
> +  bool hold;
> +  rtems_id task_id;
> +  rtems_vector_number irq;
> +  uint32_t input_clock;
> +  uint32_t already_transferred;
> +} bbb_i2c_bus;
> +static inline int bbb_register_i2c_0(void)
> +  return am335x_i2c_bus_register(
> +    BBB_I2C_0_BUS_PATH,
> +    AM335X_I2C0_BASE,
> +    I2C_BUS_CLOCK_DEFAULT,
> +    BBB_I2C0_IRQ
> +static inline int bbb_register_i2c_1(void)
> +    BBB_I2C_1_BUS_PATH,
> +    AM335X_I2C1_BASE,
> +    BBB_I2C1_IRQ
> +static inline int bbb_register_i2c_2(void)
> +    BBB_I2C_2_BUS_PATH,
> +    AM335X_I2C2_BASE,
> +    BBB_I2C2_IRQ
>  #ifdef __cplusplus
>  #endif /* __cplusplus */
> 2.7.4
> devel mailing list
> devel at rtems.org
