GSoC 2017 -- initial proof
Sun Apr 2 13:20:32 UTC 2017
Joel's e-mail client messed up my reply thread. ;) Andy, have a read
through https://gedare.github.io/pdf/FelShe15A.pdf if you haven't
found it already.
Getting qemu-couverture to build via RSB and then integrating the
coverage scripts into rtems-test, would be a good start to a project.
There is a student (Tanu) who has proposed rtems-test improvements, so
you two would need to coordinate efforts for this piece to avoid too
much duplicated work/waste. Improvements to the reports etc are also
welcome, and then of course using the reports to guide code
refactoring to improve coverage is somewhat open-ended.
-Gedare
On Sat, Apr 1, 2017 at 9:34 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Apr 1, 2017 7:59 PM, "Andy MacGregor" <amacgregor.2018 at comcast.net>
> wrote:
> On 03/31/2017 09:52 PM, Gedare Bloom wrote:
> Don't forget the deadline is Monday to submit your Final
> PDF and proof of enrollment. The "Final" PDF can be submitted multiple
> times, so go ahead and submit it when you finish a first draft. Add
> your draft proposal to the tracking table at
> https://devel.rtems.org/wiki/GSoC/2017 also, to get some possible
> feedback.
> Thanks for the welcome! (I realize I am late to the GSOC application table).
> I'm set on improving code coverage of the testsuite, but I found some
> questions as I'm starting to look into how its done.
> The link on the wiki to the current code status is currently broken, so I
> tried to generate a sample coverage report for 4.12 using ./do_coverage,
> ./run_coverage and ./coverage_cron as suggested on the wiki here but without
> any luck. Is there an up to date coverage report available?
> I modified the VERSIONS-COVERAGE file like the wiki said, and once that
> didn't work dug around in the script but fix it myself quickly.
> Could updating these coverage analysis scripts be a viable component of a
> GSOC proposal?
> Yes. In fact, the idea was to rework the coverage scripts in shell to be
> part of the rtems-tester package and in Python. There is some work on this
> by a previous student which you can find or one of us can dig out. Starting
> with it, making it work across multiple BSPs, independent of any hard coded
> paths, improving the output (we did not get far enough that I recall
> worrying about the quality of the output), etc could be a fair amount of
> work.
> Also we have privately discussed switching the RSB qemu upstream source to
> GNATCoverage at GitHub. This is a coverage and embedded focused downstream
> which includes the coverage trace output I used for the qemu support in
> covoar. I'm
> In addition, I'd like to actually make some improvements the code coverage
> itself.
> The most recent information I could find was these bar graphs from 2009.
> If these graphs reflect the current coverage state, I think that improving
> coverage for the i386/pc386,
> would be interesting because there is room for improvement in both the
> Baseline and Developmental groups (if these coverage statistics are up to
> date).
> It doesn't matter which BSP you choose for coverage since the code and tests
> are the same.
> This also reminds me of the other improvements we had wanted. We wanted to
> switch from Baseline and developmental to a more directory oriented approach
> for the reports. For example, the reports should be at a granularity of say
> the Dos file system or shell as reports. The way reports are generated now
> it results in a skewed view when a large body of code is added to the
> developmental set. Adding the Dos filesystem resulted in a 15-20% drop in
> the coverage reported in the Developmental set. That is a bad way to report
> and misleading. It detracts from the directories which have near 100%
> coverage.
> Does anyone know of a good reason to choose another BSP over i386/pc386?
> Users fly the SPARC leon3 and not the pc386. :)
> I've just posted a draft of my proposal to the GSOC page.
> If there's any feedback I'll be sure to update my proposal in time.
> Dinner time here. Hopefully my feedback makes sense and you can incorporate
> it.
> -Andy MacGregor
> devel mailing list
> devel at rtems.org
> devel mailing list
> devel at rtems.org
