SDIO stack in RTEM
Mon Apr 3 10:43:46 UTC 2017
On 03/04/17 12:34, faizan khan wrote:
> I dont get it, RTEMs has a port of sdmmc stack
> https://git.rtems.org/rtems-libbsd
> <https://git.rtems.org/rtems-libbsd> but not all the drivers are using
> it. For example I saw, stmf32 implement its own command sending
> mechanism. Shouldnt that be generic, the sending of commands. Only the
> lower controller level detail should change.
Yes, not all BSPs use this. The driver area in RTEMS is quite heterogeneous.
> Also I don't get the connection with freebsd code, do we use that code
> directly in RTEMs, is all of that ported???
The libbsd can be used to import code from FreeBSD, see
https://git.rtems.org/rtems-libbsd/tree/libbsd.txt#n781
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
