Warning/Build Status on Master
Wed Apr 5 00:18:50 UTC 2017
nit: aspiring GSoC Students.
On Tue, Apr 4, 2017 at 3:46 PM, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> After adding linpack to the exclude list of a number of BSPs since
> it wouldn't fit into memory, I successfully built all BSPs except the
> nios2.
> The warning report is at:
> ftp://ftp.rtems.org/pub/rtems/people/joel/warnings/warnings-4.12-master-20170404/
> This is much better than a couple of months ago with about 1/2 the warnings
> gone. But it is still worse than the 4.11 branch where there are 12 unique
> warnings
> rather than 265.
> If GSoC students would take a shot at some, that would be appreciated.
> I expect the many of them are straightforward to address. Help is definitely
> appreciated from anyone in the community.
> Unique Warnings         :  265
> BSPs                    :  170
> BSPs with Zero          :  0
> BSPs with only in shared:  128
>          Warnings by Class
>       1 array-bounds
>       5 attributes
>     130 format=
>      28 format-extra-args
>      19 implicit-function-declaration
>       2 incompatible-pointer-types
>      20 maybe-uninitialized
>       5 misleading-indentation
>       3 missing-braces
>       6 missing-prototypes
>      19 nested-externs
>       2 pointer-to-int-cast
>       4 return-type
>       2 strict-prototypes
>       4 unused-local-typedefs
>      Top Ten BSPs with Warnings
> 20 m68k-mrm332  (inBSP=6 inLibCPU=0)
> 16 lm32-milkymist  (inBSP=7 inLibCPU=0)
> 18 sparc-leon3  (inBSP=9 inLibCPU=0)
> 18 sparc-ngmp  (inBSP=9 inLibCPU=0)
> 22 m68k-uC5282  (inBSP=9 inLibCPU=0)
> 22 powerpc-haleakala  (inBSP=11 inLibCPU=0)
> 21 sparc-leon2  (inBSP=12 inLibCPU=0)
> 22 powerpc-virtex4  (inBSP=13 inLibCPU=0)
> 22 powerpc-virtex5  (inBSP=13 inLibCPU=0)
> 41 m68k-gen68340  (inBSP=28 inLibCPU=0)
> --joel
> devel mailing list
> devel at rtems.org
