[PATCH 2/7] Adding tty support files from FREEBSD tree
Kevin Kirspel
kevin-kirspel at idexx.com
Thu Apr 6 01:11:13 UTC 2017
freebsd/sys/kern/tty.c | 2349 ++++++++++++++++++++++++++++++++++++++++
freebsd/sys/kern/tty_inq.c | 497 +++++++++
freebsd/sys/kern/tty_outq.c | 347 ++++++
freebsd/sys/kern/tty_ttydisc.c | 1267 ++++++++++++++++++++++
freebsd/sys/sys/cons.h | 144 +++
freebsd/sys/sys/serial.h | 92 ++
6 files changed, 4696 insertions(+)
create mode 100644 freebsd/sys/kern/tty.c
create mode 100644 freebsd/sys/kern/tty_inq.c
create mode 100644 freebsd/sys/kern/tty_outq.c
create mode 100644 freebsd/sys/kern/tty_ttydisc.c
create mode 100644 freebsd/sys/sys/cons.h
create mode 100644 freebsd/sys/sys/serial.h
diff --git a/freebsd/sys/kern/tty.c b/freebsd/sys/kern/tty.c
new file mode 100644
index 0000000..95afaeb
--- /dev/null
+++ b/freebsd/sys/kern/tty.c
@@ -0,0 +1,2349 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2008 Ed Schouten <ed at FreeBSD.org>
+ * All rights reserved.
+ * Portions of this software were developed under sponsorship from Snow
+ * B.V., the Netherlands.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/local/opt_capsicum.h>
+#include <rtems/bsd/local/opt_compat.h>
+#include <rtems/bsd/sys/param.h>
+#include <sys/capsicum.h>
+#include <sys/conf.h>
+#include <sys/cons.h>
+#include <sys/fcntl.h>
+#include <sys/file.h>
+#include <sys/filedesc.h>
+#include <sys/filio.h>
+#ifdef COMPAT_43TTY
+#include <sys/ioctl_compat.h>
+#endif /* COMPAT_43TTY */
+#include <sys/kernel.h>
+#include <sys/limits.h>
+#include <sys/malloc.h>
+#include <sys/mount.h>
+#include <sys/poll.h>
+#include <sys/priv.h>
+#include <sys/proc.h>
+#include <sys/serial.h>
+#include <sys/signal.h>
+#include <sys/stat.h>
+#include <sys/sx.h>
+#include <sys/sysctl.h>
+#include <sys/systm.h>
+#include <sys/tty.h>
+#include <sys/ttycom.h>
+#define TTYDEFCHARS
+#include <sys/ttydefaults.h>
+#undef TTYDEFCHARS
+#include <sys/ucred.h>
+#include <sys/vnode.h>
+#include <machine/stdarg.h>
+static MALLOC_DEFINE(M_TTY, "tty", "tty device");
+static void tty_rel_free(struct tty *tp);
+static TAILQ_HEAD(, tty) tty_list = TAILQ_HEAD_INITIALIZER(tty_list);
+static struct sx tty_list_sx;
+SX_SYSINIT(tty_list, &tty_list_sx, "tty list");
+static unsigned int tty_list_count = 0;
+/* Character device of /dev/console. */
+static struct cdev *dev_console;
+static const char *dev_console_filename;
+ * Flags that are supported and stored by this implementation.
+#define TTYSUP_IFLAG (IGNBRK|BRKINT|IGNPAR|PARMRK|INPCK|ISTRIP|\
+ INLCR|IGNCR|ICRNL|IXON|IXOFF|IXANY|IMAXBEL)
+#define TTYSUP_OFLAG (OPOST|ONLCR|TAB3|ONOEOT|OCRNL|ONOCR|ONLRET)
+#define TTYSUP_LFLAG (ECHOKE|ECHOE|ECHOK|ECHO|ECHONL|ECHOPRT|\
+ ECHOCTL|ISIG|ICANON|ALTWERASE|IEXTEN|TOSTOP|\
+ FLUSHO|NOKERNINFO|NOFLSH)
+#define TTYSUP_CFLAG (CIGNORE|CSIZE|CSTOPB|CREAD|PARENB|PARODD|\
+ HUPCL|CLOCAL|CCTS_OFLOW|CRTS_IFLOW|CDTR_IFLOW|\
+ CDSR_OFLOW|CCAR_OFLOW)
+#define TTY_CALLOUT(tp,d) (dev2unit(d) & TTYUNIT_CALLOUT)
+static int tty_drainwait = 5 * 60;
+SYSCTL_INT(_kern, OID_AUTO, tty_drainwait, CTLFLAG_RWTUN,
+ &tty_drainwait, 0, "Default output drain timeout in seconds");
+ * Set TTY buffer sizes.
+#define TTYBUF_MAX 65536
+ * Allocate buffer space if necessary, and set low watermarks, based on speed.
+ * Note that the ttyxxxq_setsize() functions may drop and then reacquire the tty
+ * lock during memory allocation. They will return ENXIO if the tty disappears
+ * while unlocked.
+static int
+tty_watermarks(struct tty *tp)
+ size_t bs = 0;
+ int error;
+ /* Provide an input buffer for 2 seconds of data. */
+ if (tp->t_termios.c_cflag & CREAD)
+ bs = MIN(tp->t_termios.c_ispeed / 5, TTYBUF_MAX);
+ error = ttyinq_setsize(&tp->t_inq, tp, bs);
+ if (error != 0)
+ return (error);
+ /* Set low watermark at 10% (when 90% is available). */
+ tp->t_inlow = (ttyinq_getallocatedsize(&tp->t_inq) * 9) / 10;
+ /* Provide an output buffer for 2 seconds of data. */
+ bs = MIN(tp->t_termios.c_ospeed / 5, TTYBUF_MAX);
+ error = ttyoutq_setsize(&tp->t_outq, tp, bs);
+ if (error != 0)
+ return (error);
+ tp->t_outlow = (ttyoutq_getallocatedsize(&tp->t_outq) * 9) / 10;
+ return (0);
+static int
+tty_drain(struct tty *tp, int leaving)
+ sbintime_t timeout_at;
+ size_t bytes;
+ int error;
+ if (ttyhook_hashook(tp, getc_inject))
+ /* buffer is inaccessible */
+ return (0);
+ * For close(), use the recent historic timeout of "1 second without
+ * making progress". For tcdrain(), use t_drainwait as the timeout,
+ * with zero meaning "no timeout" which gives POSIX behavior.
+ if (leaving)
+ timeout_at = getsbinuptime() + SBT_1S;
+ else if (tp->t_drainwait != 0)
+ timeout_at = getsbinuptime() + SBT_1S * tp->t_drainwait;
+ else
+ timeout_at = 0;
+ * Poll the output buffer and the hardware for completion, at 10 Hz.
+ * Polling is required for devices which are not able to signal an
+ * interrupt when the transmitter becomes idle (most USB serial devs).
+ * The unusual structure of this loop ensures we check for busy one more
+ * time after tty_timedwait() returns EWOULDBLOCK, so that success has
+ * higher priority than timeout if the IO completed in the last 100mS.
+ error = 0;
+ bytes = ttyoutq_bytesused(&tp->t_outq);
+ for (;;) {
+ if (ttyoutq_bytesused(&tp->t_outq) == 0 && !ttydevsw_busy(tp))
+ return (0);
+ if (error != 0)
+ return (error);
+ ttydevsw_outwakeup(tp);
+ error = tty_timedwait(tp, &tp->t_outwait, hz / 10);
+ if (error != 0 && error != EWOULDBLOCK)
+ return (error);
+ else if (timeout_at == 0 || getsbinuptime() < timeout_at)
+ error = 0;
+ else if (leaving && ttyoutq_bytesused(&tp->t_outq) < bytes) {
+ /* In close, making progress, grant an extra second. */
+ error = 0;
+ timeout_at += SBT_1S;
+ * Though ttydev_enter() and ttydev_leave() seem to be related, they
+ * don't have to be used together. ttydev_enter() is used by the cdev
+ * operations to prevent an actual operation from being processed when
+ * the TTY has been abandoned. ttydev_leave() is used by ttydev_open()
+ * and ttydev_close() to determine whether per-TTY data should be
+ * deallocated.
+static __inline int
+ttydev_enter(struct tty *tp)
+ tty_lock(tp);
+ if (tty_gone(tp) || !tty_opened(tp)) {
+ /* Device is already gone. */
+ tty_unlock(tp);
+ return (ENXIO);
+ return (0);
+static void
+ttydev_leave(struct tty *tp)
+ tty_lock_assert(tp, MA_OWNED);
+ if (tty_opened(tp) || tp->t_flags & TF_OPENCLOSE) {
+ /* Device is still opened somewhere. */
+ tty_unlock(tp);
+ return;
+ tp->t_flags |= TF_OPENCLOSE;
+ /* Stop asynchronous I/O. */
+ funsetown(&tp->t_sigio);
+ /* Remove console TTY. */
+ if (constty == tp)
+ constty_clear();
+ /* Drain any output. */
+ if (!tty_gone(tp))
+ tty_drain(tp, 1);
+ ttydisc_close(tp);
+ /* Free i/o queues now since they might be large. */
+ ttyinq_free(&tp->t_inq);
+ tp->t_inlow = 0;
+ ttyoutq_free(&tp->t_outq);
+ tp->t_outlow = 0;
+ knlist_clear(&tp->t_inpoll.si_note, 1);
+ knlist_clear(&tp->t_outpoll.si_note, 1);
+ ttydevsw_close(tp);
+ tp->t_flags &= ~TF_OPENCLOSE;
+ cv_broadcast(&tp->t_dcdwait);
+ tty_rel_free(tp);
+ * Operations that are exposed through the character device in /dev.
+static int
+ttydev_open(struct cdev *dev, int oflags, int devtype __unused,
+ struct thread *td)
+ struct tty *tp;
+ int error;
+ tp = dev->si_drv1;
+ error = 0;
+ tty_lock(tp);
+ if (tty_gone(tp)) {
+ tty_unlock(tp);
+ return (ENXIO);
+ * Block when other processes are currently opening or closing
+ * the TTY.
+ while (tp->t_flags & TF_OPENCLOSE) {
+ error = tty_wait(tp, &tp->t_dcdwait);
+ if (error != 0) {
+ tty_unlock(tp);
+ return (error);
+ * Make sure the "tty" and "cua" device cannot be opened at the
+ * same time. The console is a "tty" device.
+ if (TTY_CALLOUT(tp, dev)) {
+ if (tp->t_flags & (TF_OPENED_CONS | TF_OPENED_IN)) {
+ error = EBUSY;
+ goto done;
+ } else {
+ if (tp->t_flags & TF_OPENED_OUT) {
+ error = EBUSY;
+ goto done;
+ if (tp->t_flags & TF_EXCLUDE && priv_check(td, PRIV_TTY_EXCLUSIVE)) {
+ error = EBUSY;
+ goto done;
+ if (!tty_opened(tp)) {
+ /* Set proper termios flags. */
+ tp->t_termios = tp->t_termios_init_out;
+ else
+ tp->t_termios = tp->t_termios_init_in;
+ ttydevsw_param(tp, &tp->t_termios);
+ /* Prevent modem control on callout devices and /dev/console. */
+ if (TTY_CALLOUT(tp, dev) || dev == dev_console)
+ tp->t_termios.c_cflag |= CLOCAL;
+ ttydevsw_modem(tp, SER_DTR|SER_RTS, 0);
+ error = ttydevsw_open(tp);
+ if (error != 0)
+ goto done;
+ ttydisc_open(tp);
+ error = tty_watermarks(tp);
+ if (error != 0)
+ goto done;
+ /* Wait for Carrier Detect. */
+ if ((oflags & O_NONBLOCK) == 0 &&
+ (tp->t_termios.c_cflag & CLOCAL) == 0) {
+ while ((ttydevsw_modem(tp, 0, 0) & SER_DCD) == 0) {
+ if (error != 0)
+ goto done;
+ if (dev == dev_console)
+ tp->t_flags |= TF_OPENED_CONS;
+ else if (TTY_CALLOUT(tp, dev))
+ tp->t_flags |= TF_OPENED_OUT;
+ else
+ tp->t_flags |= TF_OPENED_IN;
+ MPASS((tp->t_flags & (TF_OPENED_CONS | TF_OPENED_IN)) == 0 ||
+ (tp->t_flags & TF_OPENED_OUT) == 0);
+done: tp->t_flags &= ~TF_OPENCLOSE;
+ ttydev_leave(tp);
+ return (error);
+static int
+ttydev_close(struct cdev *dev, int fflag, int devtype __unused,
+ struct thread *td __unused)
+ struct tty *tp = dev->si_drv1;
+ tty_lock(tp);
+ * Don't actually close the device if it is being used as the
+ * console.
+ tp->t_flags &= ~TF_OPENED_CONS;
+ else
+ tp->t_flags &= ~(TF_OPENED_IN|TF_OPENED_OUT);
+ if (tp->t_flags & TF_OPENED) {
+ tty_unlock(tp);
+ return (0);
+ /* If revoking, flush output now to avoid draining it later. */
+ if (fflag & FREVOKE)
+ tty_flush(tp, FWRITE);
+ tp->t_flags &= ~TF_EXCLUDE;
+ /* Properly wake up threads that are stuck - revoke(). */
+ tp->t_revokecnt++;
+ tty_wakeup(tp, FREAD|FWRITE);
+ cv_broadcast(&tp->t_bgwait);
+ ttydev_leave(tp);
+ return (0);
+tty_is_ctty(struct tty *tp, struct proc *p)
+ return (p->p_session == tp->t_session && p->p_flag & P_CONTROLT);
+int
+tty_wait_background(struct tty *tp, struct thread *td, int sig)
+ struct proc *p = td->td_proc;
+ struct pgrp *pg;
+ ksiginfo_t ksi;
+ int error;
+ MPASS(sig == SIGTTIN || sig == SIGTTOU);
+ for (;;) {
+ PROC_LOCK(p);
+ * The process should only sleep, when:
+ * - This terminal is the controlling terminal
+ * - Its process group is not the foreground process
+ * group
+ * - The parent process isn't waiting for the child to
+ * exit
+ * - the signal to send to the process isn't masked
+ if (!tty_is_ctty(tp, p) || p->p_pgrp == tp->t_pgrp) {
+ /* Allow the action to happen. */
+ PROC_UNLOCK(p);
+ return (0);
+ if (SIGISMEMBER(p->p_sigacts->ps_sigignore, sig) ||
+ SIGISMEMBER(td->td_sigmask, sig)) {
+ /* Only allow them in write()/ioctl(). */
+ PROC_UNLOCK(p);
+ return (sig == SIGTTOU ? 0 : EIO);
+ pg = p->p_pgrp;
+ if (p->p_flag & P_PPWAIT || pg->pg_jobc == 0) {
+ /* Don't allow the action to happen. */
+ PROC_UNLOCK(p);
+ return (EIO);
+ PROC_UNLOCK(p);
+ * Send the signal and sleep until we're the new
+ * foreground process group.
+ if (sig != 0) {
+ ksiginfo_init(&ksi);
+ ksi.ksi_code = SI_KERNEL;
+ ksi.ksi_signo = sig;
+ sig = 0;
+ PGRP_LOCK(pg);
+ pgsignal(pg, ksi.ksi_signo, 1, &ksi);
+ PGRP_UNLOCK(pg);
+ error = tty_wait(tp, &tp->t_bgwait);
+ if (error)
+ return (error);
+static int
+ttydev_read(struct cdev *dev, struct uio *uio, int ioflag)
+ int error;
+ error = ttydev_enter(tp);
+ if (error)
+ goto done;
+ error = ttydisc_read(tp, uio, ioflag);
+ tty_unlock(tp);
+ * The read() call should not throw an error when the device is
+ * being destroyed. Silently convert it to an EOF.
+done: if (error == ENXIO)
+ error = 0;
+ return (error);
+static int
+ttydev_write(struct cdev *dev, struct uio *uio, int ioflag)
+ int error;
+ if (error)
+ return (error);
+ if (tp->t_termios.c_lflag & TOSTOP) {
+ error = tty_wait_background(tp, curthread, SIGTTOU);
+ if (error)
+ goto done;
+ if (ioflag & IO_NDELAY && tp->t_flags & TF_BUSY_OUT) {
+ /* Allow non-blocking writes to bypass serialization. */
+ error = ttydisc_write(tp, uio, ioflag);
+ } else {
+ /* Serialize write() calls. */
+ while (tp->t_flags & TF_BUSY_OUT) {
+ error = tty_wait(tp, &tp->t_outserwait);
+ if (error)
+ goto done;
+ tp->t_flags |= TF_BUSY_OUT;
+ tp->t_flags &= ~TF_BUSY_OUT;
+ cv_signal(&tp->t_outserwait);
+done: tty_unlock(tp);
+ return (error);
+static int
+ttydev_ioctl(struct cdev *dev, u_long cmd, caddr_t data, int fflag,
+ int error;
+ if (error)
+ return (error);
+ switch (cmd) {
+ case TIOCCBRK:
+ case TIOCCONS:
+ case TIOCDRAIN:
+ case TIOCEXCL:
+ case TIOCFLUSH:
+ case TIOCNXCL:
+ case TIOCSBRK:
+ case TIOCSCTTY:
+ case TIOCSETA:
+ case TIOCSETAF:
+ case TIOCSETAW:
+ case TIOCSPGRP:
+ case TIOCSTART:
+ case TIOCSTAT:
+ case TIOCSTI:
+ case TIOCSTOP:
+ case TIOCSWINSZ:
+#if 0
+ case TIOCSDRAINWAIT:
+ case TIOCSETD:
+#endif
+ case TIOCLBIC:
+ case TIOCLBIS:
+ case TIOCLSET:
+ case TIOCSETC:
+ case OTIOCSETD:
+ case TIOCSETN:
+ case TIOCSETP:
+ case TIOCSLTC:
+ * If the ioctl() causes the TTY to be modified, let it
+ * wait in the background.
+ if (error)
+ goto done;
+ if (cmd == TIOCSETA || cmd == TIOCSETAW || cmd == TIOCSETAF) {
+ struct termios *old = &tp->t_termios;
+ struct termios *new = (struct termios *)data;
+ struct termios *lock = TTY_CALLOUT(tp, dev) ?
+ &tp->t_termios_lock_out : &tp->t_termios_lock_in;
+ int cc;
+ * Lock state devices. Just overwrite the values of the
+ * commands that are currently in use.
+ new->c_iflag = (old->c_iflag & lock->c_iflag) |
+ (new->c_iflag & ~lock->c_iflag);
+ new->c_oflag = (old->c_oflag & lock->c_oflag) |
+ (new->c_oflag & ~lock->c_oflag);
+ new->c_cflag = (old->c_cflag & lock->c_cflag) |
+ (new->c_cflag & ~lock->c_cflag);
+ new->c_lflag = (old->c_lflag & lock->c_lflag) |
+ (new->c_lflag & ~lock->c_lflag);
+ for (cc = 0; cc < NCCS; ++cc)
+ if (lock->c_cc[cc])
+ new->c_cc[cc] = old->c_cc[cc];
+ if (lock->c_ispeed)
+ new->c_ispeed = old->c_ispeed;
+ if (lock->c_ospeed)
+ new->c_ospeed = old->c_ospeed;
+ error = tty_ioctl(tp, cmd, data, fflag, td);
+ return (error);
+static int
+ttydev_poll(struct cdev *dev, int events, struct thread *td)
+ int error, revents = 0;
+ if (error)
+ return ((events & (POLLIN|POLLRDNORM)) | POLLHUP);
+ if (events & (POLLIN|POLLRDNORM)) {
+ /* See if we can read something. */
+ if (ttydisc_read_poll(tp) > 0)
+ revents |= events & (POLLIN|POLLRDNORM);
+ if (tp->t_flags & TF_ZOMBIE) {
+ /* Hangup flag on zombie state. */
+ revents |= POLLHUP;
+ } else if (events & (POLLOUT|POLLWRNORM)) {
+ /* See if we can write something. */
+ if (ttydisc_write_poll(tp) > 0)
+ revents |= events & (POLLOUT|POLLWRNORM);
+ if (revents == 0) {
+ selrecord(td, &tp->t_inpoll);
+ if (events & (POLLOUT|POLLWRNORM))
+ selrecord(td, &tp->t_outpoll);
+ tty_unlock(tp);
+ return (revents);
+static int
+ttydev_mmap(struct cdev *dev, vm_ooffset_t offset, vm_paddr_t *paddr,
+ int nprot, vm_memattr_t *memattr)
+ int error;
+ /* Handle mmap() through the driver. */
+ if (error)
+ return (-1);
+ error = ttydevsw_mmap(tp, offset, paddr, nprot, memattr);
+ tty_unlock(tp);
+ return (error);
+ * kqueue support.
+static void
+tty_kqops_read_detach(struct knote *kn)
+ struct tty *tp = kn->kn_hook;
+ knlist_remove(&tp->t_inpoll.si_note, kn, 0);
+static int
+tty_kqops_read_event(struct knote *kn, long hint __unused)
+ if (tty_gone(tp) || tp->t_flags & TF_ZOMBIE) {
+ kn->kn_flags |= EV_EOF;
+ return (1);
+ } else {
+ kn->kn_data = ttydisc_read_poll(tp);
+ return (kn->kn_data > 0);
+static void
+tty_kqops_write_detach(struct knote *kn)
+ knlist_remove(&tp->t_outpoll.si_note, kn, 0);
+static int
+tty_kqops_write_event(struct knote *kn, long hint __unused)
+ return (1);
+ } else {
+ kn->kn_data = ttydisc_write_poll(tp);
+static struct filterops tty_kqops_read = {
+ .f_isfd = 1,
+ .f_detach = tty_kqops_read_detach,
+ .f_event = tty_kqops_read_event,
+static struct filterops tty_kqops_write = {
+ .f_isfd = 1,
+ .f_detach = tty_kqops_write_detach,
+ .f_event = tty_kqops_write_event,
+static int
+ttydev_kqfilter(struct cdev *dev, struct knote *kn)
+ int error;
+ if (error)
+ return (error);
+ switch (kn->kn_filter) {
+ case EVFILT_READ:
+ kn->kn_hook = tp;
+ kn->kn_fop = &tty_kqops_read;
+ knlist_add(&tp->t_inpoll.si_note, kn, 1);
+ break;
+ case EVFILT_WRITE:
+ kn->kn_hook = tp;
+ kn->kn_fop = &tty_kqops_write;
+ knlist_add(&tp->t_outpoll.si_note, kn, 1);
+ break;
+ default:
+ error = EINVAL;
+ break;
+ tty_unlock(tp);
+ return (error);
+static struct cdevsw ttydev_cdevsw = {
+ .d_version = D_VERSION,
+ .d_open = ttydev_open,
+ .d_close = ttydev_close,
+ .d_read = ttydev_read,
+ .d_write = ttydev_write,
+ .d_ioctl = ttydev_ioctl,
+ .d_kqfilter = ttydev_kqfilter,
+ .d_poll = ttydev_poll,
+ .d_mmap = ttydev_mmap,
+ .d_name = "ttydev",
+ .d_flags = D_TTY,
+ * Init/lock-state devices
+static int
+ttyil_open(struct cdev *dev, int oflags __unused, int devtype __unused,
+ struct tty *tp;
+ int error;
+ error = 0;
+ tty_lock(tp);
+ if (tty_gone(tp))
+ error = ENODEV;
+ tty_unlock(tp);
+ return (error);
+static int
+ttyil_close(struct cdev *dev __unused, int flag __unused, int mode __unused,
+ return (0);
+static int
+ttyil_rdwr(struct cdev *dev __unused, struct uio *uio __unused,
+ int ioflag __unused)
+ return (ENODEV);
+static int
+ttyil_ioctl(struct cdev *dev, u_long cmd, caddr_t data, int fflag,
+ int error;
+ tty_lock(tp);
+ error = ENODEV;
+ goto done;
+ error = ttydevsw_cioctl(tp, dev2unit(dev), cmd, data, td);
+ if (error != ENOIOCTL)
+ goto done;
+ error = 0;
+ switch (cmd) {
+ case TIOCGETA:
+ /* Obtain terminal flags through tcgetattr(). */
+ *(struct termios*)data = *(struct termios*)dev->si_drv2;
+ break;
+ case TIOCSETA:
+ /* Set terminal flags through tcsetattr(). */
+ error = priv_check(td, PRIV_TTY_SETA);
+ if (error)
+ break;
+ *(struct termios*)dev->si_drv2 = *(struct termios*)data;
+ break;
+ case TIOCGETD:
+ *(int *)data = TTYDISC;
+ break;
+ case TIOCGWINSZ:
+ bzero(data, sizeof(struct winsize));
+ break;
+ default:
+ error = ENOTTY;
+ return (error);
+static struct cdevsw ttyil_cdevsw = {
+ .d_open = ttyil_open,
+ .d_close = ttyil_close,
+ .d_read = ttyil_rdwr,
+ .d_write = ttyil_rdwr,
+ .d_ioctl = ttyil_ioctl,
+ .d_name = "ttyil",
+ .d_flags = D_TTY,
+static void
+tty_init_termios(struct tty *tp)
+ struct termios *t = &tp->t_termios_init_in;
+ t->c_cflag = TTYDEF_CFLAG;
+ t->c_iflag = TTYDEF_IFLAG;
+ t->c_lflag = TTYDEF_LFLAG;
+ t->c_oflag = TTYDEF_OFLAG;
+ t->c_ispeed = TTYDEF_SPEED;
+ t->c_ospeed = TTYDEF_SPEED;
+ memcpy(&t->c_cc, ttydefchars, sizeof ttydefchars);
+ tp->t_termios_init_out = *t;
+void
+tty_init_console(struct tty *tp, speed_t s)
+ struct termios *ti = &tp->t_termios_init_in;
+ struct termios *to = &tp->t_termios_init_out;
+ if (s != 0) {
+ ti->c_ispeed = ti->c_ospeed = s;
+ to->c_ispeed = to->c_ospeed = s;
+ ti->c_cflag |= CLOCAL;
+ to->c_cflag |= CLOCAL;
+ * Standard device routine implementations, mostly meant for
+ * pseudo-terminal device drivers. When a driver creates a new terminal
+ * device class, missing routines are patched.
+static int
+ttydevsw_defopen(struct tty *tp __unused)
+ return (0);
+static void
+ttydevsw_defclose(struct tty *tp __unused)
+static void
+ttydevsw_defoutwakeup(struct tty *tp __unused)
+ panic("Terminal device has output, while not implemented");
+static void
+ttydevsw_definwakeup(struct tty *tp __unused)
+static int
+ttydevsw_defioctl(struct tty *tp __unused, u_long cmd __unused,
+ caddr_t data __unused, struct thread *td __unused)
+ return (ENOIOCTL);
+static int
+ttydevsw_defcioctl(struct tty *tp __unused, int unit __unused,
+ u_long cmd __unused, caddr_t data __unused, struct thread *td __unused)
+static int
+ttydevsw_defparam(struct tty *tp __unused, struct termios *t)
+ * Allow the baud rate to be adjusted for pseudo-devices, but at
+ * least restrict it to 115200 to prevent excessive buffer
+ * usage. Also disallow 0, to prevent foot shooting.
+ if (t->c_ispeed < B50)
+ t->c_ispeed = B50;
+ else if (t->c_ispeed > B115200)
+ t->c_ispeed = B115200;
+ if (t->c_ospeed < B50)
+ t->c_ospeed = B50;
+ else if (t->c_ospeed > B115200)
+ t->c_ospeed = B115200;
+ t->c_cflag |= CREAD;
+ return (0);
+static int
+ttydevsw_defmodem(struct tty *tp __unused, int sigon __unused,
+ int sigoff __unused)
+ /* Simulate a carrier to make the TTY layer happy. */
+ return (SER_DCD);
+static int
+ttydevsw_defmmap(struct tty *tp __unused, vm_ooffset_t offset __unused,
+ vm_paddr_t *paddr __unused, int nprot __unused,
+ vm_memattr_t *memattr __unused)
+ return (-1);
+static void
+ttydevsw_defpktnotify(struct tty *tp __unused, char event __unused)
+static void
+ttydevsw_deffree(void *softc __unused)
+ panic("Terminal device freed without a free-handler");
+static bool
+ttydevsw_defbusy(struct tty *tp __unused)
+ return (FALSE);
+ * TTY allocation and deallocation. TTY devices can be deallocated when
+ * the driver doesn't use it anymore, when the TTY isn't a session's
+ * controlling TTY and when the device node isn't opened through devfs.
+struct tty *
+tty_alloc(struct ttydevsw *tsw, void *sc)
+ return (tty_alloc_mutex(tsw, sc, NULL));
+struct tty *
+tty_alloc_mutex(struct ttydevsw *tsw, void *sc, struct mtx *mutex)
+ struct tty *tp;
+ /* Make sure the driver defines all routines. */
+#define PATCH_FUNC(x) do { \
+ if (tsw->tsw_ ## x == NULL) \
+ tsw->tsw_ ## x = ttydevsw_def ## x; \
+} while (0)
+ PATCH_FUNC(open);
+ PATCH_FUNC(close);
+ PATCH_FUNC(outwakeup);
+ PATCH_FUNC(inwakeup);
+ PATCH_FUNC(ioctl);
+ PATCH_FUNC(cioctl);
+ PATCH_FUNC(param);
+ PATCH_FUNC(modem);
+ PATCH_FUNC(mmap);
+ PATCH_FUNC(pktnotify);
+ PATCH_FUNC(free);
+ PATCH_FUNC(busy);
+#undef PATCH_FUNC
+ tp = malloc(sizeof(struct tty), M_TTY, M_WAITOK|M_ZERO);
+ tp->t_devsw = tsw;
+ tp->t_devswsoftc = sc;
+ tp->t_flags = tsw->tsw_flags;
+ tp->t_drainwait = tty_drainwait;
+ tty_init_termios(tp);
+ cv_init(&tp->t_inwait, "ttyin");
+ cv_init(&tp->t_outwait, "ttyout");
+ cv_init(&tp->t_outserwait, "ttyosr");
+ cv_init(&tp->t_bgwait, "ttybg");
+ cv_init(&tp->t_dcdwait, "ttydcd");
+ /* Allow drivers to use a custom mutex to lock the TTY. */
+ if (mutex != NULL) {
+ tp->t_mtx = mutex;
+ } else {
+ tp->t_mtx = &tp->t_mtxobj;
+ mtx_init(&tp->t_mtxobj, "ttymtx", NULL, MTX_DEF);
+ knlist_init_mtx(&tp->t_inpoll.si_note, tp->t_mtx);
+ knlist_init_mtx(&tp->t_outpoll.si_note, tp->t_mtx);
+ return (tp);
+static void
+tty_dealloc(void *arg)
+ struct tty *tp = arg;
+ * ttyydev_leave() usually frees the i/o queues earlier, but it is
+ * not always called between queue allocation and here. The queues
+ * may be allocated by ioctls on a pty control device without the
+ * corresponding pty slave device ever being open, or after it is
+ * closed.
+ seldrain(&tp->t_inpoll);
+ seldrain(&tp->t_outpoll);
+ knlist_destroy(&tp->t_inpoll.si_note);
+ knlist_destroy(&tp->t_outpoll.si_note);
+ cv_destroy(&tp->t_inwait);
+ cv_destroy(&tp->t_outwait);
+ cv_destroy(&tp->t_bgwait);
+ cv_destroy(&tp->t_dcdwait);
+ cv_destroy(&tp->t_outserwait);
+ if (tp->t_mtx == &tp->t_mtxobj)
+ mtx_destroy(&tp->t_mtxobj);
+ ttydevsw_free(tp);
+ free(tp, M_TTY);
+static void
+tty_rel_free(struct tty *tp)
+ struct cdev *dev;
+#define TF_ACTIVITY (TF_GONE|TF_OPENED|TF_HOOK|TF_OPENCLOSE)
+ if (tp->t_sessioncnt != 0 || (tp->t_flags & TF_ACTIVITY) != TF_GONE) {
+ /* TTY is still in use. */
+ tty_unlock(tp);
+ return;
+ /* TTY can be deallocated. */
+ dev = tp->t_dev;
+ tp->t_dev = NULL;
+ tty_unlock(tp);
+ if (dev != NULL) {
+ sx_xlock(&tty_list_sx);
+ TAILQ_REMOVE(&tty_list, tp, t_list);
+ tty_list_count--;
+ sx_xunlock(&tty_list_sx);
+ destroy_dev_sched_cb(dev, tty_dealloc, tp);
+void
+tty_rel_pgrp(struct tty *tp, struct pgrp *pg)
+ MPASS(tp->t_sessioncnt > 0);
+ if (tp->t_pgrp == pg)
+ tp->t_pgrp = NULL;
+ tty_unlock(tp);
+void
+tty_rel_sess(struct tty *tp, struct session *sess)
+ /* Current session has left. */
+ if (tp->t_session == sess) {
+ tp->t_session = NULL;
+ MPASS(tp->t_pgrp == NULL);
+ tp->t_sessioncnt--;
+ tty_rel_free(tp);
+void
+tty_rel_gone(struct tty *tp)
+ MPASS(!tty_gone(tp));
+ /* Simulate carrier removal. */
+ ttydisc_modem(tp, 0);
+ /* Wake up all blocked threads. */
+ tp->t_flags |= TF_GONE;
+ tty_rel_free(tp);
+ * Exposing information about current TTY's through sysctl
+static void
+tty_to_xtty(struct tty *tp, struct xtty *xt)
+ xt->xt_size = sizeof(struct xtty);
+ xt->xt_insize = ttyinq_getsize(&tp->t_inq);
+ xt->xt_incc = ttyinq_bytescanonicalized(&tp->t_inq);
+ xt->xt_inlc = ttyinq_bytesline(&tp->t_inq);
+ xt->xt_inlow = tp->t_inlow;
+ xt->xt_outsize = ttyoutq_getsize(&tp->t_outq);
+ xt->xt_outcc = ttyoutq_bytesused(&tp->t_outq);
+ xt->xt_outlow = tp->t_outlow;
+ xt->xt_column = tp->t_column;
+ xt->xt_pgid = tp->t_pgrp ? tp->t_pgrp->pg_id : 0;
+ xt->xt_sid = tp->t_session ? tp->t_session->s_sid : 0;
+ xt->xt_flags = tp->t_flags;
+ xt->xt_dev = tp->t_dev ? dev2udev(tp->t_dev) : NODEV;
+static int
+sysctl_kern_ttys(SYSCTL_HANDLER_ARGS)
+ unsigned long lsize;
+ struct xtty *xtlist, *xt;
+ struct tty *tp;
+ int error;
+ sx_slock(&tty_list_sx);
+ lsize = tty_list_count * sizeof(struct xtty);
+ if (lsize == 0) {
+ sx_sunlock(&tty_list_sx);
+ return (0);
+ xtlist = xt = malloc(lsize, M_TTY, M_WAITOK);
+ TAILQ_FOREACH(tp, &tty_list, t_list) {
+ tty_lock(tp);
+ tty_to_xtty(tp, xt);
+ tty_unlock(tp);
+ xt++;
+ error = SYSCTL_OUT(req, xtlist, lsize);
+ free(xtlist, M_TTY);
+ return (error);
+SYSCTL_PROC(_kern, OID_AUTO, ttys, CTLTYPE_OPAQUE|CTLFLAG_RD|CTLFLAG_MPSAFE,
+ 0, 0, sysctl_kern_ttys, "S,xtty", "List of TTYs");
+ * Device node creation. Device has been set up, now we can expose it to
+ * the user.
+int
+tty_makedevf(struct tty *tp, struct ucred *cred, int flags,
+ const char *fmt, ...)
+ va_list ap;
+ struct make_dev_args args;
+ struct cdev *dev, *init, *lock, *cua, *cinit, *clock;
+ const char *prefix = "tty";
+ char name[SPECNAMELEN - 3]; /* for "tty" and "cua". */
+ uid_t uid;
+ gid_t gid;
+ mode_t mode;
+ int error;
+ /* Remove "tty" prefix from devices like PTY's. */
+ if (tp->t_flags & TF_NOPREFIX)
+ prefix = "";
+ va_start(ap, fmt);
+ vsnrprintf(name, sizeof name, 32, fmt, ap);
+ va_end(ap);
+ if (cred == NULL) {
+ /* System device. */
+ uid = UID_ROOT;
+ gid = GID_WHEEL;
+ mode = S_IRUSR|S_IWUSR;
+ } else {
+ /* User device. */
+ uid = cred->cr_ruid;
+ gid = GID_TTY;
+ mode = S_IRUSR|S_IWUSR|S_IWGRP;
+ flags = flags & TTYMK_CLONING ? MAKEDEV_REF : 0;
+ flags |= MAKEDEV_CHECKNAME;
+ /* Master call-in device. */
+ make_dev_args_init(&args);
+ args.mda_flags = flags;
+ args.mda_devsw = &ttydev_cdevsw;
+ args.mda_cr = cred;
+ args.mda_uid = uid;
+ args.mda_gid = gid;
+ args.mda_mode = mode;
+ args.mda_si_drv1 = tp;
+ error = make_dev_s(&args, &dev, "%s%s", prefix, name);
+ if (error != 0)
+ return (error);
+ tp->t_dev = dev;
+ init = lock = cua = cinit = clock = NULL;
+ /* Slave call-in devices. */
+ if (tp->t_flags & TF_INITLOCK) {
+ args.mda_devsw = &ttyil_cdevsw;
+ args.mda_unit = TTYUNIT_INIT;
+ args.mda_si_drv2 = &tp->t_termios_init_in;
+ error = make_dev_s(&args, &init, "%s%s.init", prefix, name);
+ if (error != 0)
+ goto fail;
+ dev_depends(dev, init);
+ args.mda_unit = TTYUNIT_LOCK;
+ args.mda_si_drv2 = &tp->t_termios_lock_in;
+ error = make_dev_s(&args, &lock, "%s%s.lock", prefix, name);
+ if (error != 0)
+ goto fail;
+ dev_depends(dev, lock);
+ /* Call-out devices. */
+ if (tp->t_flags & TF_CALLOUT) {
+ args.mda_uid = UID_UUCP;
+ args.mda_gid = GID_DIALER;
+ args.mda_mode = 0660;
+ args.mda_unit = TTYUNIT_CALLOUT;
+ error = make_dev_s(&args, &cua, "cua%s", name);
+ if (error != 0)
+ goto fail;
+ dev_depends(dev, cua);
+ /* Slave call-out devices. */
+ args.mda_unit = TTYUNIT_CALLOUT | TTYUNIT_INIT;
+ args.mda_si_drv2 = &tp->t_termios_init_out;
+ error = make_dev_s(&args, &cinit, "cua%s.init", name);
+ if (error != 0)
+ goto fail;
+ dev_depends(dev, cinit);
+ args.mda_unit = TTYUNIT_CALLOUT | TTYUNIT_LOCK;
+ args.mda_si_drv2 = &tp->t_termios_lock_out;
+ error = make_dev_s(&args, &clock, "cua%s.lock", name);
+ if (error != 0)
+ goto fail;
+ dev_depends(dev, clock);
+ TAILQ_INSERT_TAIL(&tty_list, tp, t_list);
+ tty_list_count++;
+ return (0);
+fail:
+ destroy_dev(dev);
+ if (init)
+ destroy_dev(init);
+ if (lock)
+ destroy_dev(lock);
+ if (cinit)
+ destroy_dev(cinit);
+ if (clock)
+ destroy_dev(clock);
+ return (error);
+ * Signalling processes.
+void
+tty_signal_sessleader(struct tty *tp, int sig)
+ struct proc *p;
+ MPASS(sig >= 1 && sig < NSIG);
+ /* Make signals start output again. */
+ tp->t_flags &= ~TF_STOPPED;
+ if (tp->t_session != NULL && tp->t_session->s_leader != NULL) {
+ p = tp->t_session->s_leader;
+ PROC_LOCK(p);
+ kern_psignal(p, sig);
+ PROC_UNLOCK(p);
+void
+tty_signal_pgrp(struct tty *tp, int sig)
+ ksiginfo_t ksi;
+ if (sig == SIGINFO && !(tp->t_termios.c_lflag & NOKERNINFO))
+ tty_info(tp);
+ if (tp->t_pgrp != NULL) {
+ PGRP_LOCK(tp->t_pgrp);
+ pgsignal(tp->t_pgrp, sig, 1, &ksi);
+ PGRP_UNLOCK(tp->t_pgrp);
+void
+tty_wakeup(struct tty *tp, int flags)
+ if (tp->t_flags & TF_ASYNC && tp->t_sigio != NULL)
+ pgsigio(&tp->t_sigio, SIGIO, (tp->t_session != NULL));
+ if (flags & FWRITE) {
+ cv_broadcast(&tp->t_outwait);
+ selwakeup(&tp->t_outpoll);
+ KNOTE_LOCKED(&tp->t_outpoll.si_note, 0);
+ if (flags & FREAD) {
+ cv_broadcast(&tp->t_inwait);
+ selwakeup(&tp->t_inpoll);
+ KNOTE_LOCKED(&tp->t_inpoll.si_note, 0);
+int
+tty_wait(struct tty *tp, struct cv *cv)
+ int error;
+ int revokecnt = tp->t_revokecnt;
+ tty_lock_assert(tp, MA_OWNED|MA_NOTRECURSED);
+ error = cv_wait_sig(cv, tp->t_mtx);
+ /* Bail out when the device slipped away. */
+ if (tty_gone(tp))
+ return (ENXIO);
+ /* Restart the system call when we may have been revoked. */
+ if (tp->t_revokecnt != revokecnt)
+ return (ERESTART);
+ return (error);
+int
+tty_timedwait(struct tty *tp, struct cv *cv, int hz)
+ int error;
+ error = cv_timedwait_sig(cv, tp->t_mtx, hz);
+ if (tty_gone(tp))
+ return (ENXIO);
+ return (error);
+void
+tty_flush(struct tty *tp, int flags)
+ tp->t_flags &= ~TF_HIWAT_OUT;
+ ttyoutq_flush(&tp->t_outq);
+ tty_wakeup(tp, FWRITE);
+ if (!tty_gone(tp)) {
+ ttydevsw_pktnotify(tp, TIOCPKT_FLUSHWRITE);
+ tty_hiwat_in_unblock(tp);
+ ttyinq_flush(&tp->t_inq);
+ tty_wakeup(tp, FREAD);
+ ttydevsw_inwakeup(tp);
+ ttydevsw_pktnotify(tp, TIOCPKT_FLUSHREAD);
+void
+tty_set_winsize(struct tty *tp, const struct winsize *wsz)
+ if (memcmp(&tp->t_winsize, wsz, sizeof(*wsz)) == 0)
+ return;
+ tp->t_winsize = *wsz;
+ tty_signal_pgrp(tp, SIGWINCH);
+static int
+tty_generic_ioctl(struct tty *tp, u_long cmd, void *data, int fflag,
+ int error;
+ switch (cmd) {
+ * Modem commands.
+ * The SER_* and TIOCM_* flags are the same, but one bit
+ * shifted. I don't know why.
+ case TIOCSDTR:
+ ttydevsw_modem(tp, SER_DTR, 0);
+ return (0);
+ case TIOCCDTR:
+ ttydevsw_modem(tp, 0, SER_DTR);
+ return (0);
+ case TIOCMSET: {
+ int bits = *(int *)data;
+ (bits & (TIOCM_DTR | TIOCM_RTS)) >> 1,
+ ((~bits) & (TIOCM_DTR | TIOCM_RTS)) >> 1);
+ return (0);
+ case TIOCMBIS: {
+ ttydevsw_modem(tp, (bits & (TIOCM_DTR | TIOCM_RTS)) >> 1, 0);
+ return (0);
+ case TIOCMBIC: {
+ ttydevsw_modem(tp, 0, (bits & (TIOCM_DTR | TIOCM_RTS)) >> 1);
+ return (0);
+ case TIOCMGET:
+ *(int *)data = TIOCM_LE + (ttydevsw_modem(tp, 0, 0) << 1);
+ return (0);
+ case FIOASYNC:
+ if (*(int *)data)
+ tp->t_flags |= TF_ASYNC;
+ else
+ tp->t_flags &= ~TF_ASYNC;
+ return (0);
+ case FIONBIO:
+ /* This device supports non-blocking operation. */
+ return (0);
+ case FIONREAD:
+ *(int *)data = ttyinq_bytescanonicalized(&tp->t_inq);
+ return (0);
+ case FIONWRITE:
+ case TIOCOUTQ:
+ *(int *)data = ttyoutq_bytesused(&tp->t_outq);
+ return (0);
+ case FIOSETOWN:
+ if (tp->t_session != NULL && !tty_is_ctty(tp, td->td_proc))
+ /* Not allowed to set ownership. */
+ return (ENOTTY);
+ /* Temporarily unlock the TTY to set ownership. */
+ tty_unlock(tp);
+ error = fsetown(*(int *)data, &tp->t_sigio);
+ tty_lock(tp);
+ return (error);
+ case FIOGETOWN:
+ return (ENOTTY);
+ /* Get ownership. */
+ *(int *)data = fgetown(&tp->t_sigio);
+ return (0);
+ case TIOCGETA:
+ *(struct termios*)data = tp->t_termios;
+ return (0);
+ case TIOCSETA:
+ case TIOCSETAW:
+ case TIOCSETAF: {
+ struct termios *t = data;
+ * Who makes up these funny rules? According to POSIX,
+ * input baud rate is set equal to the output baud rate
+ * when zero.
+ if (t->c_ispeed == 0)
+ t->c_ispeed = t->c_ospeed;
+ /* Discard any unsupported bits. */
+ t->c_iflag &= TTYSUP_IFLAG;
+ t->c_oflag &= TTYSUP_OFLAG;
+ t->c_lflag &= TTYSUP_LFLAG;
+ t->c_cflag &= TTYSUP_CFLAG;
+ if (cmd == TIOCSETAW || cmd == TIOCSETAF) {
+ error = tty_drain(tp, 0);
+ if (error)
+ return (error);
+ if (cmd == TIOCSETAF)
+ tty_flush(tp, FREAD);
+ * Only call param() when the flags really change.
+ if ((t->c_cflag & CIGNORE) == 0 &&
+ (tp->t_termios.c_cflag != t->c_cflag ||
+ ((tp->t_termios.c_iflag ^ t->c_iflag) &
+ (IXON|IXOFF|IXANY)) ||
+ tp->t_termios.c_ispeed != t->c_ispeed ||
+ tp->t_termios.c_ospeed != t->c_ospeed)) {
+ error = ttydevsw_param(tp, t);
+ if (error)
+ return (error);
+ /* XXX: CLOCAL? */
+ tp->t_termios.c_cflag = t->c_cflag & ~CIGNORE;
+ tp->t_termios.c_ispeed = t->c_ispeed;
+ tp->t_termios.c_ospeed = t->c_ospeed;
+ /* Baud rate has changed - update watermarks. */
+ if (error)
+ return (error);
+ /* Copy new non-device driver parameters. */
+ tp->t_termios.c_iflag = t->c_iflag;
+ tp->t_termios.c_oflag = t->c_oflag;
+ tp->t_termios.c_lflag = t->c_lflag;
+ memcpy(&tp->t_termios.c_cc, t->c_cc, sizeof t->c_cc);
+ ttydisc_optimize(tp);
+ if ((t->c_lflag & ICANON) == 0) {
+ * When in non-canonical mode, wake up all
+ * readers. Canonicalize any partial input. VMIN
+ * and VTIME could also be adjusted.
+ ttyinq_canonicalize(&tp->t_inq);
+ * For packet mode: notify the PTY consumer that VSTOP
+ * and VSTART may have been changed.
+ if (tp->t_termios.c_iflag & IXON &&
+ tp->t_termios.c_cc[VSTOP] == CTRL('S') &&
+ tp->t_termios.c_cc[VSTART] == CTRL('Q'))
+ ttydevsw_pktnotify(tp, TIOCPKT_DOSTOP);
+ else
+ ttydevsw_pktnotify(tp, TIOCPKT_NOSTOP);
+ return (0);
+ case TIOCGETD:
+ /* For compatibility - we only support TTYDISC. */
+ return (0);
+ case TIOCGPGRP:
+ if (!tty_is_ctty(tp, td->td_proc))
+ return (ENOTTY);
+ *(int *)data = tp->t_pgrp->pg_id;
+ else
+ *(int *)data = NO_PID;
+ return (0);
+ case TIOCGSID:
+ return (ENOTTY);
+ MPASS(tp->t_session);
+ *(int *)data = tp->t_session->s_sid;
+ return (0);
+ case TIOCSCTTY: {
+ /* XXX: This looks awful. */
+ tty_unlock(tp);
+ sx_xlock(&proctree_lock);
+ tty_lock(tp);
+ if (!SESS_LEADER(p)) {
+ /* Only the session leader may do this. */
+ sx_xunlock(&proctree_lock);
+ return (EPERM);
+ if (tp->t_session != NULL && tp->t_session == p->p_session) {
+ /* This is already our controlling TTY. */
+ return (0);
+ if (p->p_session->s_ttyp != NULL ||
+ (tp->t_session != NULL && tp->t_session->s_ttyvp != NULL &&
+ tp->t_session->s_ttyvp->v_type != VBAD)) {
+ * There is already a relation between a TTY and
+ * a session, or the caller is not the session
+ * leader.
+ * Allow the TTY to be stolen when the vnode is
+ * invalid, but the reference to the TTY is
+ * still active. This allows immediate reuse of
+ * TTYs of which the session leader has been
+ * killed or the TTY revoked.
+ return (EPERM);
+ /* Connect the session to the TTY. */
+ tp->t_session = p->p_session;
+ tp->t_session->s_ttyp = tp;
+ tp->t_sessioncnt++;
+ /* Assign foreground process group. */
+ tp->t_pgrp = p->p_pgrp;
+ PROC_LOCK(p);
+ p->p_flag |= P_CONTROLT;
+ PROC_UNLOCK(p);
+ return (0);
+ case TIOCSPGRP: {
+ struct pgrp *pg;
+ * XXX: Temporarily unlock the TTY to locate the process
+ * group. This code would be lot nicer if we would ever
+ * decompose proctree_lock.
+ tty_unlock(tp);
+ sx_slock(&proctree_lock);
+ pg = pgfind(*(int *)data);
+ if (pg != NULL)
+ PGRP_UNLOCK(pg);
+ if (pg == NULL || pg->pg_session != td->td_proc->p_session) {
+ sx_sunlock(&proctree_lock);
+ tty_lock(tp);
+ return (EPERM);
+ tty_lock(tp);
+ * Determine if this TTY is the controlling TTY after
+ * relocking the TTY.
+ if (!tty_is_ctty(tp, td->td_proc)) {
+ return (ENOTTY);
+ tp->t_pgrp = pg;
+ /* Wake up the background process groups. */
+ return (0);
+ case TIOCFLUSH: {
+ int flags = *(int *)data;
+ if (flags == 0)
+ flags = (FREAD|FWRITE);
+ else
+ flags &= (FREAD|FWRITE);
+ tty_flush(tp, flags);
+ return (0);
+ case TIOCDRAIN:
+ /* Drain TTY output. */
+ return tty_drain(tp, 0);
+ case TIOCGDRAINWAIT:
+ *(int *)data = tp->t_drainwait;
+ return (0);
+ error = priv_check(td, PRIV_TTY_DRAINWAIT);
+ if (error == 0)
+ tp->t_drainwait = *(int *)data;
+ return (error);
+ case TIOCCONS:
+ /* Set terminal as console TTY. */
+ if (*(int *)data) {
+ error = priv_check(td, PRIV_TTY_CONSOLE);
+ if (error)
+ return (error);
+ * XXX: constty should really need to be locked!
+ * XXX: allow disconnected constty's to be stolen!
+ return (0);
+ if (constty != NULL)
+ return (EBUSY);
+ tty_unlock(tp);
+ constty_set(tp);
+ tty_lock(tp);
+ } else if (constty == tp) {
+ constty_clear();
+ return (0);
+ case TIOCGWINSZ:
+ /* Obtain window size. */
+ *(struct winsize*)data = tp->t_winsize;
+ return (0);
+ case TIOCSWINSZ:
+ /* Set window size. */
+ tty_set_winsize(tp, data);
+ return (0);
+ case TIOCEXCL:
+ tp->t_flags |= TF_EXCLUDE;
+ return (0);
+ case TIOCNXCL:
+ return (0);
+ case TIOCSTOP:
+ tp->t_flags |= TF_STOPPED;
+ ttydevsw_pktnotify(tp, TIOCPKT_STOP);
+ return (0);
+ case TIOCSTART:
+ ttydevsw_pktnotify(tp, TIOCPKT_START);
+ return (0);
+ case TIOCSTAT:
+ tty_info(tp);
+ return (0);
+ case TIOCSTI:
+ if ((fflag & FREAD) == 0 && priv_check(td, PRIV_TTY_STI))
+ return (EPERM);
+ if (!tty_is_ctty(tp, td->td_proc) &&
+ priv_check(td, PRIV_TTY_STI))
+ return (EACCES);
+ ttydisc_rint(tp, *(char *)data, 0);
+ ttydisc_rint_done(tp);
+ return (0);
+ return tty_ioctl_compat(tp, cmd, data, fflag, td);
+#else /* !COMPAT_43TTY */
+int
+tty_ioctl(struct tty *tp, u_long cmd, void *data, int fflag, struct thread *td)
+ int error;
+ if (tty_gone(tp))
+ return (ENXIO);
+ error = ttydevsw_ioctl(tp, cmd, data, td);
+ if (error == ENOIOCTL)
+ error = tty_generic_ioctl(tp, cmd, data, fflag, td);
+ return (error);
+dev_t
+tty_udev(struct tty *tp)
+ if (tp->t_dev)
+ return (dev2udev(tp->t_dev));
+ else
+ return (NODEV);
+int
+tty_checkoutq(struct tty *tp)
+ /* 256 bytes should be enough to print a log message. */
+ return (ttyoutq_bytesleft(&tp->t_outq) >= 256);
+void
+tty_hiwat_in_block(struct tty *tp)
+ if ((tp->t_flags & TF_HIWAT_IN) == 0 &&
+ tp->t_termios.c_iflag & IXOFF &&
+ tp->t_termios.c_cc[VSTOP] != _POSIX_VDISABLE) {
+ * Input flow control. Only enter the high watermark when we
+ * can successfully store the VSTOP character.
+ if (ttyoutq_write_nofrag(&tp->t_outq,
+ &tp->t_termios.c_cc[VSTOP], 1) == 0)
+ tp->t_flags |= TF_HIWAT_IN;
+ } else {
+ /* No input flow control. */
+void
+tty_hiwat_in_unblock(struct tty *tp)
+ if (tp->t_flags & TF_HIWAT_IN &&
+ tp->t_termios.c_cc[VSTART] != _POSIX_VDISABLE) {
+ * Input flow control. Only leave the high watermark when we
+ * can successfully store the VSTART character.
+ &tp->t_termios.c_cc[VSTART], 1) == 0)
+ tp->t_flags &= ~TF_HIWAT_IN;
+ } else {
+ * TTY hooks interface.
+static int
+ttyhook_defrint(struct tty *tp, char c, int flags)
+ if (ttyhook_rint_bypass(tp, &c, 1) != 1)
+ return (-1);
+ return (0);
+int
+ttyhook_register(struct tty **rtp, struct proc *p, int fd, struct ttyhook *th,
+ void *softc)
+ struct tty *tp;
+ struct file *fp;
+ struct cdev *dev;
+ struct cdevsw *cdp;
+ struct filedesc *fdp;
+ cap_rights_t rights;
+ int error, ref;
+ /* Validate the file descriptor. */
+ fdp = p->p_fd;
+ error = fget_unlocked(fdp, fd, cap_rights_init(&rights, CAP_TTYHOOK),
+ &fp, NULL);
+ if (error != 0)
+ return (error);
+ if (fp->f_ops == &badfileops) {
+ error = EBADF;
+ goto done1;
+ * Make sure the vnode is bound to a character device.
+ * Unlocked check for the vnode type is ok there, because we
+ * only shall prevent calling devvn_refthread on the file that
+ * never has been opened over a character device.
+ if (fp->f_type != DTYPE_VNODE || fp->f_vnode->v_type != VCHR) {
+ error = EINVAL;
+ goto done1;
+ /* Make sure it is a TTY. */
+ cdp = devvn_refthread(fp->f_vnode, &dev, &ref);
+ if (cdp == NULL) {
+ error = ENXIO;
+ goto done1;
+ if (dev != fp->f_data) {
+ error = ENXIO;
+ goto done2;
+ if (cdp != &ttydev_cdevsw) {
+ error = ENOTTY;
+ goto done2;
+ /* Try to attach the hook to the TTY. */
+ error = EBUSY;
+ tty_lock(tp);
+ MPASS((tp->t_hook == NULL) == ((tp->t_flags & TF_HOOK) == 0));
+ if (tp->t_flags & TF_HOOK)
+ goto done3;
+ tp->t_flags |= TF_HOOK;
+ tp->t_hook = th;
+ tp->t_hooksoftc = softc;
+ *rtp = tp;
+ error = 0;
+ /* Maybe we can switch into bypass mode now. */
+ /* Silently convert rint() calls to rint_bypass() when possible. */
+ if (!ttyhook_hashook(tp, rint) && ttyhook_hashook(tp, rint_bypass))
+ th->th_rint = ttyhook_defrint;
+done3: tty_unlock(tp);
+done2: dev_relthread(dev, ref);
+done1: fdrop(fp, curthread);
+ return (error);
+void
+ttyhook_unregister(struct tty *tp)
+ MPASS(tp->t_flags & TF_HOOK);
+ /* Disconnect the hook. */
+ tp->t_flags &= ~TF_HOOK;
+ tp->t_hook = NULL;
+ /* Maybe we need to leave bypass mode. */
+ /* Maybe deallocate the TTY as well. */
+ tty_rel_free(tp);
+ * /dev/console handling.
+static int
+ttyconsdev_open(struct cdev *dev, int oflags, int devtype, struct thread *td)
+ struct tty *tp;
+ /* System has no console device. */
+ if (dev_console_filename == NULL)
+ return (ENXIO);
+ /* Look up corresponding TTY by device name. */
+ if (strcmp(dev_console_filename, tty_devname(tp)) == 0) {
+ dev_console->si_drv1 = tp;
+ break;
+ /* System console has no TTY associated. */
+ if (dev_console->si_drv1 == NULL)
+ return (ENXIO);
+ return (ttydev_open(dev, oflags, devtype, td));
+static int
+ttyconsdev_write(struct cdev *dev, struct uio *uio, int ioflag)
+ log_console(uio);
+ return (ttydev_write(dev, uio, ioflag));
+ * /dev/console is a little different than normal TTY's. When opened,
+ * it determines which TTY to use. When data gets written to it, it
+ * will be logged in the kernel message buffer.
+static struct cdevsw ttyconsdev_cdevsw = {
+ .d_open = ttyconsdev_open,
+ .d_write = ttyconsdev_write,
+ .d_name = "ttyconsdev",
+ .d_flags = D_TTY,
+static void
+ttyconsdev_init(void *unused __unused)
+ dev_console = make_dev_credf(MAKEDEV_ETERNAL, &ttyconsdev_cdevsw, 0,
+ NULL, UID_ROOT, GID_WHEEL, 0600, "console");
+SYSINIT(tty, SI_SUB_DRIVERS, SI_ORDER_FIRST, ttyconsdev_init, NULL);
+void
+ttyconsdev_select(const char *name)
+ dev_console_filename = name;
+ * Debugging routines.
+#include <rtems/bsd/local/opt_ddb.h>
+#ifdef DDB
+#include <ddb/ddb.h>
+#include <ddb/db_sym.h>
+static const struct {
+ int flag;
+ char val;
+} ttystates[] = {
+#if 0
+ { TF_NOPREFIX, 'N' },
+#endif
+ { TF_INITLOCK, 'I' },
+ { TF_CALLOUT, 'C' },
+ /* Keep these together -> 'Oi' and 'Oo'. */
+ { TF_OPENED, 'O' },
+ { TF_OPENED_IN, 'i' },
+ { TF_OPENED_OUT, 'o' },
+ { TF_OPENED_CONS, 'c' },
+ { TF_GONE, 'G' },
+ { TF_OPENCLOSE, 'B' },
+ { TF_ASYNC, 'Y' },
+ { TF_LITERAL, 'L' },
+ /* Keep these together -> 'Hi' and 'Ho'. */
+ { TF_HIWAT, 'H' },
+ { TF_HIWAT_IN, 'i' },
+ { TF_HIWAT_OUT, 'o' },
+ { TF_STOPPED, 'S' },
+ { TF_EXCLUDE, 'X' },
+ { TF_BYPASS, 'l' },
+ { TF_ZOMBIE, 'Z' },
+ { TF_HOOK, 's' },
+ /* Keep these together -> 'bi' and 'bo'. */
+ { TF_BUSY, 'b' },
+ { TF_BUSY_IN, 'i' },
+ { TF_BUSY_OUT, 'o' },
+ { 0, '\0'},
+#define TTY_FLAG_BITS \
+ "\20\1NOPREFIX\2INITLOCK\3CALLOUT\4OPENED_IN" \
+ "\5OPENED_OUT\6OPENED_CONS\7GONE\10OPENCLOSE" \
+ "\11ASYNC\12LITERAL\13HIWAT_IN\14HIWAT_OUT" \
+ "\15STOPPED\16EXCLUDE\17BYPASS\20ZOMBIE" \
+ "\21HOOK\22BUSY_IN\23BUSY_OUT"
+#define DB_PRINTSYM(name, addr) \
+ db_printf("%s " #name ": ", sep); \
+ db_printsym((db_addr_t) addr, DB_STGY_ANY); \
+ db_printf("\n");
+static void
+_db_show_devsw(const char *sep, const struct ttydevsw *tsw)
+ db_printf("%sdevsw: ", sep);
+ db_printsym((db_addr_t)tsw, DB_STGY_ANY);
+ db_printf(" (%p)\n", tsw);
+ DB_PRINTSYM(open, tsw->tsw_open);
+ DB_PRINTSYM(close, tsw->tsw_close);
+ DB_PRINTSYM(outwakeup, tsw->tsw_outwakeup);
+ DB_PRINTSYM(inwakeup, tsw->tsw_inwakeup);
+ DB_PRINTSYM(ioctl, tsw->tsw_ioctl);
+ DB_PRINTSYM(param, tsw->tsw_param);
+ DB_PRINTSYM(modem, tsw->tsw_modem);
+ DB_PRINTSYM(mmap, tsw->tsw_mmap);
+ DB_PRINTSYM(pktnotify, tsw->tsw_pktnotify);
+ DB_PRINTSYM(free, tsw->tsw_free);
+static void
+_db_show_hooks(const char *sep, const struct ttyhook *th)
+ db_printf("%shook: ", sep);
+ db_printsym((db_addr_t)th, DB_STGY_ANY);
+ db_printf(" (%p)\n", th);
+ if (th == NULL)
+ return;
+ DB_PRINTSYM(rint, th->th_rint);
+ DB_PRINTSYM(rint_bypass, th->th_rint_bypass);
+ DB_PRINTSYM(rint_done, th->th_rint_done);
+ DB_PRINTSYM(rint_poll, th->th_rint_poll);
+ DB_PRINTSYM(getc_inject, th->th_getc_inject);
+ DB_PRINTSYM(getc_capture, th->th_getc_capture);
+ DB_PRINTSYM(getc_poll, th->th_getc_poll);
+ DB_PRINTSYM(close, th->th_close);
+static void
+_db_show_termios(const char *name, const struct termios *t)
+ db_printf("%s: iflag 0x%x oflag 0x%x cflag 0x%x "
+ "lflag 0x%x ispeed %u ospeed %u\n", name,
+ t->c_iflag, t->c_oflag, t->c_cflag, t->c_lflag,
+ t->c_ispeed, t->c_ospeed);
+/* DDB command to show TTY statistics. */
+DB_SHOW_COMMAND(tty, db_show_tty)
+ struct tty *tp;
+ if (!have_addr) {
+ db_printf("usage: show tty <addr>\n");
+ return;
+ tp = (struct tty *)addr;
+ db_printf("%p: %s\n", tp, tty_devname(tp));
+ db_printf("\tmtx: %p\n", tp->t_mtx);
+ db_printf("\tflags: 0x%b\n", tp->t_flags, TTY_FLAG_BITS);
+ db_printf("\trevokecnt: %u\n", tp->t_revokecnt);
+ /* Buffering mechanisms. */
+ db_printf("\tinq: %p begin %u linestart %u reprint %u end %u "
+ "nblocks %u quota %u\n", &tp->t_inq, tp->t_inq.ti_begin,
+ tp->t_inq.ti_linestart, tp->t_inq.ti_reprint, tp->t_inq.ti_end,
+ tp->t_inq.ti_nblocks, tp->t_inq.ti_quota);
+ db_printf("\toutq: %p begin %u end %u nblocks %u quota %u\n",
+ &tp->t_outq, tp->t_outq.to_begin, tp->t_outq.to_end,
+ tp->t_outq.to_nblocks, tp->t_outq.to_quota);
+ db_printf("\tinlow: %zu\n", tp->t_inlow);
+ db_printf("\toutlow: %zu\n", tp->t_outlow);
+ _db_show_termios("\ttermios", &tp->t_termios);
+ db_printf("\twinsize: row %u col %u xpixel %u ypixel %u\n",
+ tp->t_winsize.ws_row, tp->t_winsize.ws_col,
+ tp->t_winsize.ws_xpixel, tp->t_winsize.ws_ypixel);
+ db_printf("\tcolumn: %u\n", tp->t_column);
+ db_printf("\twritepos: %u\n", tp->t_writepos);
+ db_printf("\tcompatflags: 0x%x\n", tp->t_compatflags);
+ /* Init/lock-state devices. */
+ _db_show_termios("\ttermios_init_in", &tp->t_termios_init_in);
+ _db_show_termios("\ttermios_init_out", &tp->t_termios_init_out);
+ _db_show_termios("\ttermios_lock_in", &tp->t_termios_lock_in);
+ _db_show_termios("\ttermios_lock_out", &tp->t_termios_lock_out);
+ /* Hooks */
+ _db_show_devsw("\t", tp->t_devsw);
+ _db_show_hooks("\t", tp->t_hook);
+ /* Process info. */
+ db_printf("\tpgrp: %p gid %d jobc %d\n", tp->t_pgrp,
+ tp->t_pgrp ? tp->t_pgrp->pg_id : 0,
+ tp->t_pgrp ? tp->t_pgrp->pg_jobc : 0);
+ db_printf("\tsession: %p", tp->t_session);
+ if (tp->t_session != NULL)
+ db_printf(" count %u leader %p tty %p sid %d login %s",
+ tp->t_session->s_count, tp->t_session->s_leader,
+ tp->t_session->s_ttyp, tp->t_session->s_sid,
+ tp->t_session->s_login);
+ db_printf("\n");
+ db_printf("\tsessioncnt: %u\n", tp->t_sessioncnt);
+ db_printf("\tdevswsoftc: %p\n", tp->t_devswsoftc);
+ db_printf("\thooksoftc: %p\n", tp->t_hooksoftc);
+ db_printf("\tdev: %p\n", tp->t_dev);
+/* DDB command to list TTYs. */
+DB_SHOW_ALL_COMMAND(ttys, db_show_all_ttys)
+ struct tty *tp;
+ size_t isiz, osiz;
+ int i, j;
+ /* Make the output look like `pstat -t'. */
+ db_printf("PTR ");
+#if defined(__LP64__)
+ db_printf(" ");
+#endif
+ db_printf(" LINE INQ CAN LIN LOW OUTQ USE LOW "
+ "COL SESS PGID STATE\n");
+ isiz = tp->t_inq.ti_nblocks * TTYINQ_DATASIZE;
+ osiz = tp->t_outq.to_nblocks * TTYOUTQ_DATASIZE;
+ db_printf("%p %10s %5zu %4u %4u %4zu %5zu %4u %4zu %5u %5d "
+ "%5d ", tp, tty_devname(tp), isiz,
+ tp->t_inq.ti_linestart - tp->t_inq.ti_begin,
+ tp->t_inq.ti_end - tp->t_inq.ti_linestart,
+ isiz - tp->t_inlow, osiz,
+ tp->t_outq.to_end - tp->t_outq.to_begin,
+ osiz - tp->t_outlow, MIN(tp->t_column, 99999),
+ tp->t_session ? tp->t_session->s_sid : 0,
+ tp->t_pgrp ? tp->t_pgrp->pg_id : 0);
+ /* Flag bits. */
+ for (i = j = 0; ttystates[i].flag; i++)
+ if (tp->t_flags & ttystates[i].flag) {
+ db_printf("%c", ttystates[i].val);
+ j++;
+ if (j == 0)
+ db_printf("-");
+ db_printf("\n");
+#endif /* DDB */
diff --git a/freebsd/sys/kern/tty_inq.c b/freebsd/sys/kern/tty_inq.c
index 0000000..acaa02a
--- /dev/null
+++ b/freebsd/sys/kern/tty_inq.c
@@ -0,0 +1,497 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <rtems/bsd/sys/lock.h>
+#include <sys/queue.h>
+#include <sys/uio.h>
+#include <vm/uma.h>
+ * TTY input queue buffering.
+ * Unlike the output queue, the input queue has more features that are
+ * needed to properly implement various features offered by the TTY
+ * interface:
+ * - Data can be removed from the tail of the queue, which is used to
+ * implement backspace.
+ * - Once in a while, input has to be `canonicalized'. When ICANON is
+ * turned on, this will be done after a CR has been inserted.
+ * Otherwise, it should be done after any character has been inserted.
+ * - The input queue can store one bit per byte, called the quoting bit.
+ * This bit is used by TTYDISC to make backspace work on quoted
+ * characters.
+ * In most cases, there is probably less input than output, so unlike
+ * the outq, we'll stick to 128 byte blocks here.
+static int ttyinq_flush_secure = 1;
+SYSCTL_INT(_kern, OID_AUTO, tty_inq_flush_secure, CTLFLAG_RW,
+ &ttyinq_flush_secure, 0, "Zero buffers while flushing");
+#define TTYINQ_QUOTESIZE (TTYINQ_DATASIZE / BMSIZE)
+#define BMSIZE 32
+#define GETBIT(tib,boff) \
+ ((tib)->tib_quotes[(boff) / BMSIZE] & (1 << ((boff) % BMSIZE)))
+#define SETBIT(tib,boff) \
+ ((tib)->tib_quotes[(boff) / BMSIZE] |= (1 << ((boff) % BMSIZE)))
+#define CLRBIT(tib,boff) \
+ ((tib)->tib_quotes[(boff) / BMSIZE] &= ~(1 << ((boff) % BMSIZE)))
+struct ttyinq_block {
+ struct ttyinq_block *tib_prev;
+ struct ttyinq_block *tib_next;
+ uint32_t tib_quotes[TTYINQ_QUOTESIZE];
+ char tib_data[TTYINQ_DATASIZE];
+static uma_zone_t ttyinq_zone;
+#define TTYINQ_INSERT_TAIL(ti, tib) do { \
+ if (ti->ti_end == 0) { \
+ tib->tib_prev = NULL; \
+ tib->tib_next = ti->ti_firstblock; \
+ ti->ti_firstblock = tib; \
+ } else { \
+ tib->tib_prev = ti->ti_lastblock; \
+ tib->tib_next = ti->ti_lastblock->tib_next; \
+ ti->ti_lastblock->tib_next = tib; \
+ if (tib->tib_next != NULL) \
+ tib->tib_next->tib_prev = tib; \
+ ti->ti_nblocks++; \
+} while (0)
+#define TTYINQ_REMOVE_HEAD(ti) do { \
+ ti->ti_firstblock = ti->ti_firstblock->tib_next; \
+ if (ti->ti_firstblock != NULL) \
+ ti->ti_firstblock->tib_prev = NULL; \
+ ti->ti_nblocks--; \
+} while (0)
+#define TTYINQ_RECYCLE(ti, tib) do { \
+ if (ti->ti_quota <= ti->ti_nblocks) \
+ uma_zfree(ttyinq_zone, tib); \
+ else \
+ TTYINQ_INSERT_TAIL(ti, tib); \
+} while (0)
+int
+ttyinq_setsize(struct ttyinq *ti, struct tty *tp, size_t size)
+ struct ttyinq_block *tib;
+ ti->ti_quota = howmany(size, TTYINQ_DATASIZE);
+ while (ti->ti_quota > ti->ti_nblocks) {
+ * List is getting bigger.
+ * Add new blocks to the tail of the list.
+ * We must unlock the TTY temporarily, because we need
+ * to allocate memory. This won't be a problem, because
+ * in the worst case, another thread ends up here, which
+ * may cause us to allocate too many blocks, but this
+ * will be caught by the loop below.
+ tty_unlock(tp);
+ tib = uma_zalloc(ttyinq_zone, M_WAITOK);
+ tty_lock(tp);
+ return (ENXIO);
+ return (0);
+void
+ttyinq_free(struct ttyinq *ti)
+ ttyinq_flush(ti);
+ ti->ti_quota = 0;
+ while ((tib = ti->ti_firstblock) != NULL) {
+ TTYINQ_REMOVE_HEAD(ti);
+ MPASS(ti->ti_nblocks == 0);
+int
+ttyinq_read_uio(struct ttyinq *ti, struct tty *tp, struct uio *uio,
+ size_t rlen, size_t flen)
+ MPASS(rlen <= uio->uio_resid);
+ while (rlen > 0) {
+ int error;
+ size_t cbegin, cend, clen;
+ /* See if there still is data. */
+ if (ti->ti_begin == ti->ti_linestart)
+ return (0);
+ tib = ti->ti_firstblock;
+ if (tib == NULL)
+ return (0);
+ * The end address should be the lowest of these three:
+ * - The write pointer
+ * - The blocksize - we can't read beyond the block
+ * - The end address if we could perform the full read
+ cbegin = ti->ti_begin;
+ cend = MIN(MIN(ti->ti_linestart, ti->ti_begin + rlen),
+ TTYINQ_DATASIZE);
+ clen = cend - cbegin;
+ MPASS(clen >= flen);
+ rlen -= clen;
+ * We can prevent buffering in some cases:
+ * - We need to read the block until the end.
+ * - We don't need to read the block until the end, but
+ * there is no data beyond it, which allows us to move
+ * the write pointer to a new block.
+ if (cend == TTYINQ_DATASIZE || cend == ti->ti_end) {
+ * Fast path: zero copy. Remove the first block,
+ * so we can unlock the TTY temporarily.
+ ti->ti_begin = 0;
+ * Because we remove the first block, we must
+ * fix up the block offsets.
+#define CORRECT_BLOCK(t) do { \
+ if (t <= TTYINQ_DATASIZE) \
+ t = 0; \
+ else \
+ t -= TTYINQ_DATASIZE; \
+} while (0)
+ CORRECT_BLOCK(ti->ti_linestart);
+ CORRECT_BLOCK(ti->ti_reprint);
+ CORRECT_BLOCK(ti->ti_end);
+#undef CORRECT_BLOCK
+ * Temporary unlock and copy the data to
+ * userspace. We may need to flush trailing
+ * bytes, like EOF characters.
+ tty_unlock(tp);
+ error = uiomove(tib->tib_data + cbegin,
+ clen - flen, uio);
+ tty_lock(tp);
+ /* Block can now be readded to the list. */
+ TTYINQ_RECYCLE(ti, tib);
+ } else {
+ char ob[TTYINQ_DATASIZE - 1];
+ * Slow path: store data in a temporary buffer.
+ memcpy(ob, tib->tib_data + cbegin, clen - flen);
+ ti->ti_begin += clen;
+ MPASS(ti->ti_begin < TTYINQ_DATASIZE);
+ /* Temporary unlock and copy the data to userspace. */
+ tty_unlock(tp);
+ error = uiomove(ob, clen - flen, uio);
+ tty_lock(tp);
+ if (error != 0)
+ return (error);
+ if (tty_gone(tp))
+ return (ENXIO);
+ return (0);
+static __inline void
+ttyinq_set_quotes(struct ttyinq_block *tib, size_t offset,
+ size_t length, int value)
+ if (value) {
+ /* Set the bits. */
+ for (; length > 0; length--, offset++)
+ SETBIT(tib, offset);
+ } else {
+ /* Unset the bits. */
+ CLRBIT(tib, offset);
+size_t
+ttyinq_write(struct ttyinq *ti, const void *buf, size_t nbytes, int quote)
+ const char *cbuf = buf;
+ unsigned int boff;
+ size_t l;
+ while (nbytes > 0) {
+ boff = ti->ti_end % TTYINQ_DATASIZE;
+ /* First time we're being used or drained. */
+ MPASS(ti->ti_begin == 0);
+ if (tib == NULL) {
+ /* Queue has no blocks. */
+ break;
+ ti->ti_lastblock = tib;
+ } else if (boff == 0) {
+ /* We reached the end of this block on last write. */
+ tib = ti->ti_lastblock->tib_next;
+ /* We've reached the watermark. */
+ break;
+ } else {
+ tib = ti->ti_lastblock;
+ /* Don't copy more than was requested. */
+ l = MIN(nbytes, TTYINQ_DATASIZE - boff);
+ MPASS(l > 0);
+ memcpy(tib->tib_data + boff, cbuf, l);
+ /* Set the quoting bits for the proper region. */
+ ttyinq_set_quotes(tib, boff, l, quote);
+ cbuf += l;
+ nbytes -= l;
+ ti->ti_end += l;
+ return (cbuf - (const char *)buf);
+int
+ttyinq_write_nofrag(struct ttyinq *ti, const void *buf, size_t nbytes, int quote)
+ size_t ret;
+ if (ttyinq_bytesleft(ti) < nbytes)
+ return (-1);
+ /* We should always be able to write it back. */
+ ret = ttyinq_write(ti, buf, nbytes, quote);
+ MPASS(ret == nbytes);
+ return (0);
+void
+ttyinq_canonicalize(struct ttyinq *ti)
+ ti->ti_linestart = ti->ti_reprint = ti->ti_end;
+ ti->ti_startblock = ti->ti_reprintblock = ti->ti_lastblock;
+size_t
+ttyinq_findchar(struct ttyinq *ti, const char *breakc, size_t maxlen,
+ char *lastc)
+ struct ttyinq_block *tib = ti->ti_firstblock;
+ unsigned int boff = ti->ti_begin;
+ unsigned int bend = MIN(MIN(TTYINQ_DATASIZE, ti->ti_linestart),
+ ti->ti_begin + maxlen);
+ MPASS(maxlen > 0);
+ if (tib == NULL)
+ return (0);
+ while (boff < bend) {
+ if (strchr(breakc, tib->tib_data[boff]) && !GETBIT(tib, boff)) {
+ *lastc = tib->tib_data[boff];
+ return (boff - ti->ti_begin + 1);
+ boff++;
+ /* Not found - just process the entire block. */
+ return (bend - ti->ti_begin);
+void
+ttyinq_flush(struct ttyinq *ti)
+ ti->ti_begin = 0;
+ ti->ti_linestart = 0;
+ ti->ti_reprint = 0;
+ ti->ti_end = 0;
+ /* Zero all data in the input queue to get rid of passwords. */
+ if (ttyinq_flush_secure) {
+ for (tib = ti->ti_firstblock; tib != NULL; tib = tib->tib_next)
+ bzero(&tib->tib_data, sizeof tib->tib_data);
+int
+ttyinq_peekchar(struct ttyinq *ti, char *c, int *quote)
+ struct ttyinq_block *tib = ti->ti_lastblock;
+ if (ti->ti_linestart == ti->ti_end)
+ return (-1);
+ MPASS(ti->ti_end > 0);
+ boff = (ti->ti_end - 1) % TTYINQ_DATASIZE;
+ *c = tib->tib_data[boff];
+ *quote = GETBIT(tib, boff);
+ return (0);
+void
+ttyinq_unputchar(struct ttyinq *ti)
+ MPASS(ti->ti_linestart < ti->ti_end);
+ if (--ti->ti_end % TTYINQ_DATASIZE == 0) {
+ /* Roll back to the previous block. */
+ ti->ti_lastblock = ti->ti_lastblock->tib_prev;
+ * This can only fail if we are unputchar()'ing the
+ * first character in the queue.
+ MPASS((ti->ti_lastblock == NULL) == (ti->ti_end == 0));
+void
+ttyinq_reprintpos_set(struct ttyinq *ti)
+ ti->ti_reprint = ti->ti_end;
+ ti->ti_reprintblock = ti->ti_lastblock;
+void
+ttyinq_reprintpos_reset(struct ttyinq *ti)
+ ti->ti_reprint = ti->ti_linestart;
+ ti->ti_reprintblock = ti->ti_startblock;
+static void
+ttyinq_line_iterate(struct ttyinq *ti,
+ ttyinq_line_iterator_t *iterator, void *data,
+ unsigned int offset, struct ttyinq_block *tib)
+ /* Use the proper block when we're at the queue head. */
+ if (offset == 0)
+ /* Iterate all characters and call the iterator function. */
+ for (; offset < ti->ti_end; offset++) {
+ boff = offset % TTYINQ_DATASIZE;
+ MPASS(tib != NULL);
+ /* Call back the iterator function. */
+ iterator(data, tib->tib_data[boff], GETBIT(tib, boff));
+ /* Last byte iterated - go to the next block. */
+ if (boff == TTYINQ_DATASIZE - 1)
+ tib = tib->tib_next;
+void
+ttyinq_line_iterate_from_linestart(struct ttyinq *ti,
+ ttyinq_line_iterator_t *iterator, void *data)
+ ttyinq_line_iterate(ti, iterator, data,
+ ti->ti_linestart, ti->ti_startblock);
+void
+ttyinq_line_iterate_from_reprintpos(struct ttyinq *ti,
+ ti->ti_reprint, ti->ti_reprintblock);
+static void
+ttyinq_startup(void *dummy)
+ ttyinq_zone = uma_zcreate("ttyinq", sizeof(struct ttyinq_block),
+ NULL, NULL, NULL, NULL, UMA_ALIGN_PTR, 0);
+SYSINIT(ttyinq, SI_SUB_DRIVERS, SI_ORDER_FIRST, ttyinq_startup, NULL);
diff --git a/freebsd/sys/kern/tty_outq.c b/freebsd/sys/kern/tty_outq.c
index 0000000..b6bc96d
--- /dev/null
+++ b/freebsd/sys/kern/tty_outq.c
@@ -0,0 +1,347 @@
+ * are met:
+ * SUCH DAMAGE.
+ * TTY output queue buffering.
+ * The previous design of the TTY layer offered the so-called clists.
+ * These clists were used for both the input queues and the output
+ * queue. We don't use certain features on the output side, like quoting
+ * bits for parity marking and such. This mechanism is similar to the
+ * old clists, but only contains the features we need to buffer the
+ * output.
+struct ttyoutq_block {
+ struct ttyoutq_block *tob_next;
+ char tob_data[TTYOUTQ_DATASIZE];
+static uma_zone_t ttyoutq_zone;
+#define TTYOUTQ_INSERT_TAIL(to, tob) do { \
+ if (to->to_end == 0) { \
+ tob->tob_next = to->to_firstblock; \
+ to->to_firstblock = tob; \
+ } else { \
+ tob->tob_next = to->to_lastblock->tob_next; \
+ to->to_lastblock->tob_next = tob; \
+ to->to_nblocks++; \
+} while (0)
+#define TTYOUTQ_REMOVE_HEAD(to) do { \
+ to->to_firstblock = to->to_firstblock->tob_next; \
+ to->to_nblocks--; \
+} while (0)
+#define TTYOUTQ_RECYCLE(to, tob) do { \
+ if (to->to_quota <= to->to_nblocks) \
+ uma_zfree(ttyoutq_zone, tob); \
+ else \
+ TTYOUTQ_INSERT_TAIL(to, tob); \
+} while(0)
+void
+ttyoutq_flush(struct ttyoutq *to)
+ to->to_begin = 0;
+ to->to_end = 0;
+int
+ttyoutq_setsize(struct ttyoutq *to, struct tty *tp, size_t size)
+ struct ttyoutq_block *tob;
+ to->to_quota = howmany(size, TTYOUTQ_DATASIZE);
+ while (to->to_quota > to->to_nblocks) {
+ tty_unlock(tp);
+ tob = uma_zalloc(ttyoutq_zone, M_WAITOK);
+ tty_lock(tp);
+ return (ENXIO);
+ return (0);
+void
+ttyoutq_free(struct ttyoutq *to)
+ ttyoutq_flush(to);
+ to->to_quota = 0;
+ while ((tob = to->to_firstblock) != NULL) {
+ TTYOUTQ_REMOVE_HEAD(to);
+ MPASS(to->to_nblocks == 0);
+size_t
+ttyoutq_read(struct ttyoutq *to, void *buf, size_t len)
+ char *cbuf = buf;
+ while (len > 0) {
+ if (to->to_begin == to->to_end)
+ break;
+ tob = to->to_firstblock;
+ if (tob == NULL)
+ break;
+ cbegin = to->to_begin;
+ cend = MIN(MIN(to->to_end, to->to_begin + len),
+ TTYOUTQ_DATASIZE);
+ /* Copy the data out of the buffers. */
+ memcpy(cbuf, tob->tob_data + cbegin, clen);
+ cbuf += clen;
+ len -= clen;
+ if (cend == to->to_end) {
+ /* Read the complete queue. */
+ to->to_begin = 0;
+ to->to_end = 0;
+ } else if (cend == TTYOUTQ_DATASIZE) {
+ /* Read the block until the end. */
+ to->to_begin = 0;
+ to->to_end -= TTYOUTQ_DATASIZE;
+ TTYOUTQ_RECYCLE(to, tob);
+ } else {
+ /* Read the block partially. */
+ to->to_begin += clen;
+ return (cbuf - (char *)buf);
+ * An optimized version of ttyoutq_read() which can be used in pseudo
+ * TTY drivers to directly copy data from the outq to userspace, instead
+ * of buffering it.
+ * We can only copy data directly if we need to read the entire block
+ * back to the user, because we temporarily remove the block from the
+ * queue. Otherwise we need to copy it to a temporary buffer first, to
+ * make sure data remains in the correct order.
+int
+ttyoutq_read_uio(struct ttyoutq *to, struct tty *tp, struct uio *uio)
+ while (uio->uio_resid > 0) {
+ int error;
+ return (0);
+ if (tob == NULL)
+ return (0);
+ cend = MIN(MIN(to->to_end, to->to_begin + uio->uio_resid),
+ if (cend == TTYOUTQ_DATASIZE || cend == to->to_end) {
+ to->to_begin = 0;
+ if (to->to_end <= TTYOUTQ_DATASIZE)
+ to->to_end = 0;
+ else
+ tty_unlock(tp);
+ error = uiomove(tob->tob_data + cbegin, clen, uio);
+ tty_lock(tp);
+ } else {
+ char ob[TTYOUTQ_DATASIZE - 1];
+ memcpy(ob, tob->tob_data + cbegin, clen);
+ MPASS(to->to_begin < TTYOUTQ_DATASIZE);
+ tty_unlock(tp);
+ error = uiomove(ob, clen, uio);
+ tty_lock(tp);
+ if (error != 0)
+ return (error);
+ return (0);
+size_t
+ttyoutq_write(struct ttyoutq *to, const void *buf, size_t nbytes)
+ size_t l;
+ boff = to->to_end % TTYOUTQ_DATASIZE;
+ MPASS(to->to_begin == 0);
+ if (tob == NULL) {
+ break;
+ to->to_lastblock = tob;
+ tob = to->to_lastblock->tob_next;
+ break;
+ } else {
+ tob = to->to_lastblock;
+ l = MIN(nbytes, TTYOUTQ_DATASIZE - boff);
+ MPASS(l > 0);
+ memcpy(tob->tob_data + boff, cbuf, l);
+ cbuf += l;
+ nbytes -= l;
+ to->to_end += l;
+int
+ttyoutq_write_nofrag(struct ttyoutq *to, const void *buf, size_t nbytes)
+ size_t ret;
+ if (ttyoutq_bytesleft(to) < nbytes)
+ return (-1);
+ ret = ttyoutq_write(to, buf, nbytes);
+ return (0);
+static void
+ttyoutq_startup(void *dummy)
+ ttyoutq_zone = uma_zcreate("ttyoutq", sizeof(struct ttyoutq_block),
+SYSINIT(ttyoutq, SI_SUB_DRIVERS, SI_ORDER_FIRST, ttyoutq_startup, NULL);
diff --git a/freebsd/sys/kern/tty_ttydisc.c b/freebsd/sys/kern/tty_ttydisc.c
new file mode 100644
index 0000000..edb1d15
--- /dev/null
+++ b/freebsd/sys/kern/tty_ttydisc.c
@@ -0,0 +1,1267 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2008 Ed Schouten <ed at FreeBSD.org>
+ * All rights reserved.
+ * Portions of this software were developed under sponsorship from Snow
+ * B.V., the Netherlands.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/sys/param.h>
+#include <sys/fcntl.h>
+#include <sys/filio.h>
+#include <sys/kernel.h>
+#include <sys/signal.h>
+#include <sys/sysctl.h>
+#include <sys/systm.h>
+#include <sys/tty.h>
+#include <sys/ttycom.h>
+#include <sys/ttydefaults.h>
+#include <sys/vnode.h>
+ * Standard TTYDISC `termios' line discipline.
+/* Statistics. */
+static unsigned long tty_nin = 0;
+SYSCTL_ULONG(_kern, OID_AUTO, tty_nin, CTLFLAG_RD,
+ &tty_nin, 0, "Total amount of bytes received");
+static unsigned long tty_nout = 0;
+SYSCTL_ULONG(_kern, OID_AUTO, tty_nout, CTLFLAG_RD,
+ &tty_nout, 0, "Total amount of bytes transmitted");
+/* termios comparison macro's. */
+#define CMP_CC(v,c) (tp->t_termios.c_cc[v] != _POSIX_VDISABLE && \
+ tp->t_termios.c_cc[v] == (c))
+#define CMP_FLAG(field,opt) (tp->t_termios.c_ ## field ## flag & (opt))
+/* Characters that cannot be modified through c_cc. */
+#define CTAB '\t'
+#define CNL '\n'
+#define CCR '\r'
+/* Character is a control character. */
+#define CTL_VALID(c) ((c) == 0x7f || (unsigned char)(c) < 0x20)
+/* Control character should be processed on echo. */
+#define CTL_ECHO(c,q) (!(q) && ((c) == CERASE2 || (c) == CTAB || \
+ (c) == CNL || (c) == CCR))
+/* Control character should be printed using ^X notation. */
+#define CTL_PRINT(c,q) ((c) == 0x7f || ((unsigned char)(c) < 0x20 && \
+ ((q) || ((c) != CTAB && (c) != CNL))))
+/* Character is whitespace. */
+#define CTL_WHITE(c) ((c) == ' ' || (c) == CTAB)
+/* Character is alphanumeric. */
+#define CTL_ALNUM(c) (((c) >= '0' && (c) <= '9') || \
+ ((c) >= 'a' && (c) <= 'z') || ((c) >= 'A' && (c) <= 'Z'))
+#define TTY_STACKBUF 256
+void
+ttydisc_open(struct tty *tp)
+void
+ttydisc_close(struct tty *tp)
+ /* Clean up our flags when leaving the discipline. */
+ tp->t_flags &= ~(TF_STOPPED|TF_HIWAT|TF_ZOMBIE);
+ * POSIX states that we must drain output and flush input on
+ * last close. Draining has already been done if possible.
+ tty_flush(tp, FREAD | FWRITE);
+ if (ttyhook_hashook(tp, close))
+ ttyhook_close(tp);
+static int
+ttydisc_read_canonical(struct tty *tp, struct uio *uio, int ioflag)
+ char breakc[4] = { CNL }; /* enough to hold \n, VEOF and VEOL. */
+ int error;
+ size_t clen, flen = 0, n = 1;
+ unsigned char lastc = _POSIX_VDISABLE;
+#define BREAK_ADD(c) do { \
+ if (tp->t_termios.c_cc[c] != _POSIX_VDISABLE) \
+ breakc[n++] = tp->t_termios.c_cc[c]; \
+} while (0)
+ /* Determine which characters we should trigger on. */
+ BREAK_ADD(VEOF);
+ BREAK_ADD(VEOL);
+#undef BREAK_ADD
+ breakc[n] = '\0';
+ do {
+ error = tty_wait_background(tp, curthread, SIGTTIN);
+ if (error)
+ return (error);
+ * Quite a tricky case: unlike the old TTY
+ * implementation, this implementation copies data back
+ * to userspace in large chunks. Unfortunately, we can't
+ * calculate the line length on beforehand if it crosses
+ * ttyinq_block boundaries, because multiple reads could
+ * then make this code read beyond the newline.
+ * This is why we limit the read to:
+ * - The size the user has requested
+ * - The blocksize (done in tty_inq.c)
+ * - The amount of bytes until the newline
+ * This causes the line length to be recalculated after
+ * each block has been copied to userspace. This will
+ * cause the TTY layer to return data in chunks using
+ * the blocksize (except the first and last blocks).
+ clen = ttyinq_findchar(&tp->t_inq, breakc, uio->uio_resid,
+ &lastc);
+ /* No more data. */
+ if (clen == 0) {
+ return (0);
+ else if (ioflag & IO_NDELAY)
+ return (EWOULDBLOCK);
+ error = tty_wait(tp, &tp->t_inwait);
+ if (error)
+ return (error);
+ continue;
+ /* Don't send the EOF char back to userspace. */
+ if (CMP_CC(VEOF, lastc))
+ flen = 1;
+ MPASS(flen <= clen);
+ /* Read and throw away the EOF character. */
+ error = ttyinq_read_uio(&tp->t_inq, tp, uio, clen, flen);
+ if (error)
+ return (error);
+ } while (uio->uio_resid > 0 && lastc == _POSIX_VDISABLE);
+ return (0);
+static int
+ttydisc_read_raw_no_timer(struct tty *tp, struct uio *uio, int ioflag)
+ size_t vmin = tp->t_termios.c_cc[VMIN];
+ ssize_t oresid = uio->uio_resid;
+ int error;
+ MPASS(tp->t_termios.c_cc[VTIME] == 0);
+ * This routine implements the easy cases of read()s while in
+ * non-canonical mode, namely case B and D, where we don't have
+ * any timers at all.
+ for (;;) {
+ if (error)
+ return (error);
+ uio->uio_resid, 0);
+ if (error)
+ return (error);
+ if (uio->uio_resid == 0 || (oresid - uio->uio_resid) >= vmin)
+ return (0);
+ /* We have to wait for more. */
+ return (0);
+ if (error)
+ return (error);
+static int
+ttydisc_read_raw_read_timer(struct tty *tp, struct uio *uio, int ioflag,
+ int oresid)
+ size_t vmin = MAX(tp->t_termios.c_cc[VMIN], 1);
+ unsigned int vtime = tp->t_termios.c_cc[VTIME];
+ struct timeval end, now, left;
+ int error, hz;
+ MPASS(tp->t_termios.c_cc[VTIME] != 0);
+ /* Determine when the read should be expired. */
+ end.tv_sec = vtime / 10;
+ end.tv_usec = (vtime % 10) * 100000;
+ getmicrotime(&now);
+ timevaladd(&end, &now);
+ for (;;) {
+ if (error)
+ return (error);
+ if (error)
+ return (error);
+ return (0);
+ /* Calculate how long we should wait. */
+ if (timevalcmp(&now, &end, >))
+ return (0);
+ left = end;
+ timevalsub(&left, &now);
+ hz = tvtohz(&left);
+ * We have to wait for more. If the timer expires, we
+ * should return a 0-byte read.
+ return (0);
+ error = tty_timedwait(tp, &tp->t_inwait, hz);
+ if (error)
+ return (error == EWOULDBLOCK ? 0 : error);
+ return (0);
+static int
+ttydisc_read_raw_interbyte_timer(struct tty *tp, struct uio *uio, int ioflag)
+ int error;
+ MPASS(tp->t_termios.c_cc[VMIN] != 0);
+ * When using the interbyte timer, the timer should be started
+ * after the first byte has been received. We just call into the
+ * generic read timer code after we've received the first byte.
+ for (;;) {
+ if (error)
+ return (error);
+ if (error)
+ return (error);
+ return (0);
+ * Not enough data, but we did receive some, which means
+ * we'll now start using the interbyte timer.
+ if (oresid != uio->uio_resid)
+ break;
+ return (0);
+ if (error)
+ return (error);
+ return ttydisc_read_raw_read_timer(tp, uio, ioflag, oresid);
+int
+ttydisc_read(struct tty *tp, struct uio *uio, int ioflag)
+ int error;
+ tty_lock_assert(tp, MA_OWNED);
+ if (uio->uio_resid == 0)
+ return (0);
+ if (CMP_FLAG(l, ICANON))
+ error = ttydisc_read_canonical(tp, uio, ioflag);
+ else if (tp->t_termios.c_cc[VTIME] == 0)
+ error = ttydisc_read_raw_no_timer(tp, uio, ioflag);
+ else if (tp->t_termios.c_cc[VMIN] == 0)
+ error = ttydisc_read_raw_read_timer(tp, uio, ioflag,
+ uio->uio_resid);
+ else
+ error = ttydisc_read_raw_interbyte_timer(tp, uio, ioflag);
+ if (ttyinq_bytesleft(&tp->t_inq) >= tp->t_inlow ||
+ ttyinq_bytescanonicalized(&tp->t_inq) == 0) {
+ /* Unset the input watermark when we've got enough space. */
+ return (error);
+static __inline unsigned int
+ttydisc_findchar(const char *obstart, unsigned int oblen)
+ const char *c = obstart;
+ while (oblen--) {
+ if (CTL_VALID(*c))
+ break;
+ c++;
+ return (c - obstart);
+static int
+ttydisc_write_oproc(struct tty *tp, char c)
+ unsigned int scnt, error;
+ MPASS(CMP_FLAG(o, OPOST));
+ MPASS(CTL_VALID(c));
+#define PRINT_NORMAL() ttyoutq_write_nofrag(&tp->t_outq, &c, 1)
+ switch (c) {
+ case CEOF:
+ /* End-of-text dropping. */
+ if (CMP_FLAG(o, ONOEOT))
+ return (0);
+ return PRINT_NORMAL();
+ case CERASE2:
+ /* Handle backspace to fix tab expansion. */
+ if (PRINT_NORMAL() != 0)
+ return (-1);
+ if (tp->t_column > 0)
+ tp->t_column--;
+ return (0);
+ case CTAB:
+ /* Tab expansion. */
+ scnt = 8 - (tp->t_column & 7);
+ if (CMP_FLAG(o, TAB3)) {
+ error = ttyoutq_write_nofrag(&tp->t_outq,
+ " ", scnt);
+ } else {
+ error = PRINT_NORMAL();
+ if (error)
+ return (-1);
+ tp->t_column += scnt;
+ MPASS((tp->t_column % 8) == 0);
+ return (0);
+ case CNL:
+ /* Newline conversion. */
+ if (CMP_FLAG(o, ONLCR)) {
+ /* Convert \n to \r\n. */
+ error = ttyoutq_write_nofrag(&tp->t_outq, "\r\n", 2);
+ } else {
+ if (error)
+ return (-1);
+ if (CMP_FLAG(o, ONLCR|ONLRET)) {
+ tp->t_column = tp->t_writepos = 0;
+ ttyinq_reprintpos_set(&tp->t_inq);
+ return (0);
+ case CCR:
+ /* Carriage return to newline conversion. */
+ if (CMP_FLAG(o, OCRNL))
+ c = CNL;
+ /* Omit carriage returns on column 0. */
+ if (CMP_FLAG(o, ONOCR) && tp->t_column == 0)
+ return (0);
+ return (-1);
+ return (0);
+ * Invisible control character. Print it, but don't
+ * increase the column count.
+#undef PRINT_NORMAL
+ * Just like the old TTY implementation, we need to copy data in chunks
+ * into a temporary buffer. One of the reasons why we need to do this,
+ * is because output processing (only TAB3 though) may allow the buffer
+ * to grow eight times.
+int
+ttydisc_write(struct tty *tp, struct uio *uio, int ioflag)
+ char ob[TTY_STACKBUF];
+ char *obstart;
+ int error = 0;
+ unsigned int oblen = 0;
+ return (EIO);
+ * We don't need to check whether the process is the foreground
+ * process group or if we have a carrier. This is already done
+ * in ttydev_write().
+ unsigned int nlen;
+ MPASS(oblen == 0);
+ /* Step 1: read data. */
+ obstart = ob;
+ nlen = MIN(uio->uio_resid, sizeof ob);
+ tty_unlock(tp);
+ error = uiomove(ob, nlen, uio);
+ tty_lock(tp);
+ if (error != 0)
+ break;
+ oblen = nlen;
+ if (tty_gone(tp)) {
+ error = ENXIO;
+ break;
+ MPASS(oblen > 0);
+ /* Step 2: process data. */
+ do {
+ unsigned int plen, wlen;
+ /* Search for special characters for post processing. */
+ if (CMP_FLAG(o, OPOST)) {
+ plen = ttydisc_findchar(obstart, oblen);
+ } else {
+ plen = oblen;
+ if (plen == 0) {
+ * We're going to process a character
+ * that needs processing
+ if (ttydisc_write_oproc(tp, *obstart) == 0) {
+ obstart++;
+ oblen--;
+ tp->t_writepos = tp->t_column;
+ continue;
+ } else {
+ /* We're going to write regular data. */
+ wlen = ttyoutq_write(&tp->t_outq, obstart, plen);
+ obstart += wlen;
+ oblen -= wlen;
+ tp->t_column += wlen;
+ if (wlen == plen)
+ continue;
+ /* Watermark reached. Try to sleep. */
+ tp->t_flags |= TF_HIWAT_OUT;
+ if (ioflag & IO_NDELAY) {
+ error = EWOULDBLOCK;
+ goto done;
+ * The driver may write back the data
+ * synchronously. Be sure to check the high
+ * water mark before going to sleep.
+ ttydevsw_outwakeup(tp);
+ if ((tp->t_flags & TF_HIWAT_OUT) == 0)
+ continue;
+ error = tty_wait(tp, &tp->t_outwait);
+ if (error)
+ goto done;
+ if (tp->t_flags & TF_ZOMBIE) {
+ error = EIO;
+ goto done;
+ } while (oblen > 0);
+done:
+ * Add the amount of bytes that we didn't process back to the
+ * uio counters. We need to do this to make sure write() doesn't
+ * count the bytes we didn't store in the queue.
+ uio->uio_resid += oblen;
+ return (error);
+void
+ttydisc_optimize(struct tty *tp)
+ if (ttyhook_hashook(tp, rint_bypass)) {
+ tp->t_flags |= TF_BYPASS;
+ } else if (ttyhook_hashook(tp, rint)) {
+ tp->t_flags &= ~TF_BYPASS;
+ } else if (!CMP_FLAG(i, ICRNL|IGNCR|IMAXBEL|INLCR|ISTRIP|IXON) &&
+ (!CMP_FLAG(i, BRKINT) || CMP_FLAG(i, IGNBRK)) &&
+ (!CMP_FLAG(i, PARMRK) ||
+ CMP_FLAG(i, IGNPAR|IGNBRK) == (IGNPAR|IGNBRK)) &&
+ !CMP_FLAG(l, ECHO|ICANON|IEXTEN|ISIG|PENDIN)) {
+ } else {
+void
+ttydisc_modem(struct tty *tp, int open)
+ if (open)
+ cv_broadcast(&tp->t_dcdwait);
+ * Ignore modem status lines when CLOCAL is turned on, but don't
+ * enter the zombie state when the TTY isn't opened, because
+ * that would cause the TTY to be in zombie state after being
+ * opened.
+ if (!tty_opened(tp) || CMP_FLAG(c, CLOCAL))
+ return;
+ if (open == 0) {
+ * Lost carrier.
+ tp->t_flags |= TF_ZOMBIE;
+ tty_signal_sessleader(tp, SIGHUP);
+ tty_flush(tp, FREAD|FWRITE);
+ } else {
+ * Carrier is back again.
+ /* XXX: what should we do here? */
+static int
+ttydisc_echo_force(struct tty *tp, char c, int quote)
+ if (CMP_FLAG(o, OPOST) && CTL_ECHO(c, quote)) {
+ * Only perform postprocessing when OPOST is turned on
+ * and the character is an unquoted BS/TB/NL/CR.
+ return ttydisc_write_oproc(tp, c);
+ } else if (CMP_FLAG(l, ECHOCTL) && CTL_PRINT(c, quote)) {
+ * Only use ^X notation when ECHOCTL is turned on and
+ * we've got an quoted control character.
+ * Print backspaces when echoing an end-of-file.
+ char ob[4] = "^?\b\b";
+ /* Print ^X notation. */
+ if (c != 0x7f)
+ ob[1] = c + 'A' - 1;
+ if (!quote && CMP_CC(VEOF, c)) {
+ return ttyoutq_write_nofrag(&tp->t_outq, ob, 4);
+ } else {
+ tp->t_column += 2;
+ return ttyoutq_write_nofrag(&tp->t_outq, ob, 2);
+ } else {
+ /* Can just be printed. */
+ tp->t_column++;
+ return ttyoutq_write_nofrag(&tp->t_outq, &c, 1);
+static int
+ttydisc_echo(struct tty *tp, char c, int quote)
+ * Only echo characters when ECHO is turned on, or ECHONL when
+ * the character is an unquoted newline.
+ if (!CMP_FLAG(l, ECHO) &&
+ (!CMP_FLAG(l, ECHONL) || c != CNL || quote))
+ return (0);
+ return ttydisc_echo_force(tp, c, quote);
+static void
+ttydisc_reprint_char(void *d, char c, int quote)
+ struct tty *tp = d;
+ ttydisc_echo(tp, c, quote);
+static void
+ttydisc_reprint(struct tty *tp)
+ cc_t c;
+ /* Print ^R\n, followed by the line. */
+ c = tp->t_termios.c_cc[VREPRINT];
+ if (c != _POSIX_VDISABLE)
+ ttydisc_echo(tp, c, 0);
+ ttydisc_echo(tp, CNL, 0);
+ ttyinq_reprintpos_reset(&tp->t_inq);
+ ttyinq_line_iterate_from_linestart(&tp->t_inq, ttydisc_reprint_char, tp);
+struct ttydisc_recalc_length {
+ struct tty *tp;
+ unsigned int curlen;
+static void
+ttydisc_recalc_charlength(void *d, char c, int quote)
+ struct ttydisc_recalc_length *data = d;
+ struct tty *tp = data->tp;
+ if (CTL_PRINT(c, quote)) {
+ if (CMP_FLAG(l, ECHOCTL))
+ data->curlen += 2;
+ } else if (c == CTAB) {
+ data->curlen += 8 - (data->curlen & 7);
+ } else {
+ data->curlen++;
+static unsigned int
+ttydisc_recalc_linelength(struct tty *tp)
+ struct ttydisc_recalc_length data = { tp, tp->t_writepos };
+ ttyinq_line_iterate_from_reprintpos(&tp->t_inq,
+ ttydisc_recalc_charlength, &data);
+ return (data.curlen);
+static int
+ttydisc_rubchar(struct tty *tp)
+ char c;
+ int quote;
+ unsigned int prevpos, tablen;
+ if (ttyinq_peekchar(&tp->t_inq, &c, "e) != 0)
+ return (-1);
+ ttyinq_unputchar(&tp->t_inq);
+ if (CMP_FLAG(l, ECHO)) {
+ * Remove the character from the screen. This is even
+ * safe for characters that span multiple characters
+ * (tabs, quoted, etc).
+ if (tp->t_writepos >= tp->t_column) {
+ /* Retype the sentence. */
+ ttydisc_reprint(tp);
+ } else if (CMP_FLAG(l, ECHOE)) {
+ /* Remove ^X formatted chars. */
+ if (CMP_FLAG(l, ECHOCTL)) {
+ tp->t_column -= 2;
+ ttyoutq_write_nofrag(&tp->t_outq,
+ "\b\b \b\b", 6);
+ } else if (c == ' ') {
+ /* Space character needs no rubbing. */
+ tp->t_column -= 1;
+ ttyoutq_write_nofrag(&tp->t_outq, "\b", 1);
+ * Making backspace work with tabs is
+ * quite hard. Recalculate the length of
+ * this character and remove it.
+ * Because terminal settings could be
+ * changed while the line is being
+ * inserted, the calculations don't have
+ * to be correct. Make sure we keep the
+ * tab length within proper bounds.
+ prevpos = ttydisc_recalc_linelength(tp);
+ if (prevpos >= tp->t_column)
+ tablen = 1;
+ else
+ tablen = tp->t_column - prevpos;
+ if (tablen > 8)
+ tablen = 8;
+ tp->t_column = prevpos;
+ "\b\b\b\b\b\b\b\b", tablen);
+ return (0);
+ } else {
+ * Remove a regular character by
+ * punching a space over it.
+ ttyoutq_write_nofrag(&tp->t_outq, "\b \b", 3);
+ } else {
+ /* Don't print spaces. */
+ ttydisc_echo(tp, tp->t_termios.c_cc[VERASE], 0);
+ return (0);
+static void
+ttydisc_rubword(struct tty *tp)
+ char c;
+ int quote, alnum;
+ /* Strip whitespace first. */
+ for (;;) {
+ return;
+ if (!CTL_WHITE(c))
+ break;
+ ttydisc_rubchar(tp);
+ * Record whether the last character from the previous iteration
+ * was alphanumeric or not. We need this to implement ALTWERASE.
+ alnum = CTL_ALNUM(c);
+ for (;;) {
+ return;
+ if (CTL_WHITE(c))
+ return;
+ if (CMP_FLAG(l, ALTWERASE) && CTL_ALNUM(c) != alnum)
+ return;
+int
+ttydisc_rint(struct tty *tp, char c, int flags)
+ int signal, quote = 0;
+ char ob[3] = { 0xff, 0x00 };
+ size_t ol;
+ atomic_add_long(&tty_nin, 1);
+ if (ttyhook_hashook(tp, rint))
+ return ttyhook_rint(tp, c, flags);
+ if (tp->t_flags & TF_BYPASS)
+ goto processed;
+ if (flags) {
+ if (flags & TRE_BREAK) {
+ if (CMP_FLAG(i, IGNBRK)) {
+ /* Ignore break characters. */
+ return (0);
+ } else if (CMP_FLAG(i, BRKINT)) {
+ /* Generate SIGINT on break. */
+ tty_signal_pgrp(tp, SIGINT);
+ return (0);
+ } else {
+ /* Just print it. */
+ goto parmrk;
+ } else if (flags & TRE_FRAMING ||
+ (flags & TRE_PARITY && CMP_FLAG(i, INPCK))) {
+ if (CMP_FLAG(i, IGNPAR)) {
+ /* Ignore bad characters. */
+ return (0);
+ } else {
+ goto parmrk;
+ /* Allow any character to perform a wakeup. */
+ if (CMP_FLAG(i, IXANY))
+ /* Remove the top bit. */
+ if (CMP_FLAG(i, ISTRIP))
+ c &= ~0x80;
+ /* Skip input processing when we want to print it literally. */
+ if (tp->t_flags & TF_LITERAL) {
+ tp->t_flags &= ~TF_LITERAL;
+ quote = 1;
+ goto processed;
+ /* Special control characters that are implementation dependent. */
+ if (CMP_FLAG(l, IEXTEN)) {
+ /* Accept the next character as literal. */
+ if (CMP_CC(VLNEXT, c)) {
+ if (CMP_FLAG(l, ECHOE))
+ ttyoutq_write_nofrag(&tp->t_outq, "^\b", 2);
+ else
+ tp->t_flags |= TF_LITERAL;
+ return (0);
+ * Handle signal processing.
+ if (CMP_FLAG(l, ISIG)) {
+ if (CMP_FLAG(l, ICANON|IEXTEN) == (ICANON|IEXTEN)) {
+ if (CMP_CC(VSTATUS, c)) {
+ tty_signal_pgrp(tp, SIGINFO);
+ return (0);
+ * When compared to the old implementation, this
+ * implementation also flushes the output queue. POSIX
+ * is really brief about this, but does makes us assume
+ * we have to do so.
+ signal = 0;
+ if (CMP_CC(VINTR, c)) {
+ signal = SIGINT;
+ } else if (CMP_CC(VQUIT, c)) {
+ signal = SIGQUIT;
+ } else if (CMP_CC(VSUSP, c)) {
+ signal = SIGTSTP;
+ if (signal != 0) {
+ * Echo the character before signalling the
+ * processes.
+ if (!CMP_FLAG(l, NOFLSH))
+ tty_signal_pgrp(tp, signal);
+ return (0);
+ * Handle start/stop characters.
+ if (CMP_FLAG(i, IXON)) {
+ if (CMP_CC(VSTOP, c)) {
+ /* Stop it if we aren't stopped yet. */
+ if ((tp->t_flags & TF_STOPPED) == 0) {
+ return (0);
+ * Fallthrough:
+ * When VSTART == VSTOP, we should make this key
+ * toggle it.
+ if (!CMP_CC(VSTART, c))
+ return (0);
+ if (CMP_CC(VSTART, c)) {
+ return (0);
+ /* Conversion of CR and NL. */
+ switch (c) {
+ case CCR:
+ if (CMP_FLAG(i, IGNCR))
+ return (0);
+ if (CMP_FLAG(i, ICRNL))
+ c = CNL;
+ break;
+ case CNL:
+ if (CMP_FLAG(i, INLCR))
+ c = CCR;
+ break;
+ /* Canonical line editing. */
+ if (CMP_FLAG(l, ICANON)) {
+ if (CMP_CC(VERASE, c) || CMP_CC(VERASE2, c)) {
+ return (0);
+ } else if (CMP_CC(VKILL, c)) {
+ while (ttydisc_rubchar(tp) == 0);
+ return (0);
+ } else if (CMP_FLAG(l, IEXTEN)) {
+ if (CMP_CC(VWERASE, c)) {
+ ttydisc_rubword(tp);
+ return (0);
+ } else if (CMP_CC(VREPRINT, c)) {
+ return (0);
+processed:
+ if (CMP_FLAG(i, PARMRK) && (unsigned char)c == 0xff) {
+ /* Print 0xff 0xff. */
+ ob[1] = 0xff;
+ ol = 2;
+ quote = 1;
+ } else {
+ ob[0] = c;
+ ol = 1;
+ goto print;
+parmrk:
+ if (CMP_FLAG(i, PARMRK)) {
+ /* Prepend 0xff 0x00 0x.. */
+ ob[2] = c;
+ ol = 3;
+ quote = 1;
+ } else {
+ ob[0] = c;
+ ol = 1;
+print:
+ /* See if we can store this on the input queue. */
+ if (ttyinq_write_nofrag(&tp->t_inq, ob, ol, quote) != 0) {
+ if (CMP_FLAG(i, IMAXBEL))
+ ttyoutq_write_nofrag(&tp->t_outq, "\a", 1);
+ * Prevent a deadlock here. It may be possible that a
+ * user has entered so much data, there is no data
+ * available to read(), but the buffers are full anyway.
+ * Only enter the high watermark if the device driver
+ * can actually transmit something.
+ if (ttyinq_bytescanonicalized(&tp->t_inq) == 0)
+ return (0);
+ tty_hiwat_in_block(tp);
+ return (-1);
+ * In raw mode, we canonicalize after receiving a single
+ * character. Otherwise, we canonicalize when we receive a
+ * newline, VEOL or VEOF, but only when it isn't quoted.
+ if (!CMP_FLAG(l, ICANON) ||
+ (!quote && (c == CNL || CMP_CC(VEOL, c) || CMP_CC(VEOF, c)))) {
+ return (0);
+size_t
+ttydisc_rint_simple(struct tty *tp, const void *buf, size_t len)
+ const char *cbuf;
+ if (ttydisc_can_bypass(tp))
+ return (ttydisc_rint_bypass(tp, buf, len));
+ for (cbuf = buf; len-- > 0; cbuf++) {
+ if (ttydisc_rint(tp, *cbuf, 0) != 0)
+ break;
+size_t
+ttydisc_rint_bypass(struct tty *tp, const void *buf, size_t len)
+ size_t ret;
+ MPASS(tp->t_flags & TF_BYPASS);
+ atomic_add_long(&tty_nin, len);
+ return ttyhook_rint_bypass(tp, buf, len);
+ ret = ttyinq_write(&tp->t_inq, buf, len, 0);
+ if (ret < len)
+ return (ret);
+void
+ttydisc_rint_done(struct tty *tp)
+ if (ttyhook_hashook(tp, rint_done))
+ ttyhook_rint_done(tp);
+ /* Wake up readers. */
+ /* Wake up driver for echo. */
+size_t
+ttydisc_rint_poll(struct tty *tp)
+ size_t l;
+ if (ttyhook_hashook(tp, rint_poll))
+ return ttyhook_rint_poll(tp);
+ * XXX: Still allow character input when there's no space in the
+ * buffers, but we haven't entered the high watermark. This is
+ * to allow backspace characters to be inserted when in
+ * canonical mode.
+ l = ttyinq_bytesleft(&tp->t_inq);
+ if (l == 0 && (tp->t_flags & TF_HIWAT_IN) == 0)
+ return (1);
+ return (l);
+static void
+ttydisc_wakeup_watermark(struct tty *tp)
+ size_t c;
+ c = ttyoutq_bytesleft(&tp->t_outq);
+ if (tp->t_flags & TF_HIWAT_OUT) {
+ /* Only allow us to run when we're below the watermark. */
+ if (c < tp->t_outlow)
+ return;
+ /* Reset the watermark. */
+ } else {
+ /* Only run when we have data at all. */
+ if (c == 0)
+ return;
+size_t
+ttydisc_getc(struct tty *tp, void *buf, size_t len)
+ if (tp->t_flags & TF_STOPPED)
+ return (0);
+ if (ttyhook_hashook(tp, getc_inject))
+ return ttyhook_getc_inject(tp, buf, len);
+ len = ttyoutq_read(&tp->t_outq, buf, len);
+ if (ttyhook_hashook(tp, getc_capture))
+ ttyhook_getc_capture(tp, buf, len);
+ ttydisc_wakeup_watermark(tp);
+ atomic_add_long(&tty_nout, len);
+ return (len);
+int
+ttydisc_getc_uio(struct tty *tp, struct uio *uio)
+ int error = 0;
+ ssize_t obytes = uio->uio_resid;
+ size_t len;
+ char buf[TTY_STACKBUF];
+ return (0);
+ * When a TTY hook is attached, we cannot perform unbuffered
+ * copying to userspace. Just call ttydisc_getc() and
+ * temporarily store data in a shadow buffer.
+ if (ttyhook_hashook(tp, getc_capture) ||
+ ttyhook_hashook(tp, getc_inject)) {
+ /* Read to shadow buffer. */
+ len = ttydisc_getc(tp, buf,
+ MIN(uio->uio_resid, sizeof buf));
+ if (len == 0)
+ break;
+ /* Copy to userspace. */
+ tty_unlock(tp);
+ error = uiomove(buf, len, uio);
+ tty_lock(tp);
+ if (error != 0)
+ break;
+ } else {
+ error = ttyoutq_read_uio(&tp->t_outq, tp, uio);
+ atomic_add_long(&tty_nout, obytes - uio->uio_resid);
+ return (error);
+size_t
+ttydisc_getc_poll(struct tty *tp)
+ return (0);
+ if (ttyhook_hashook(tp, getc_poll))
+ return ttyhook_getc_poll(tp);
+ return ttyoutq_bytesused(&tp->t_outq);
+ * XXX: not really related to the TTYDISC, but we'd better put
+ * tty_putchar() here, because we need to perform proper output
+ * processing.
+int
+tty_putchar(struct tty *tp, char c)
+ if (tty_gone(tp))
+ return (-1);
+ ttydisc_echo_force(tp, c, 0);
+ return (0);
diff --git a/freebsd/sys/sys/cons.h b/freebsd/sys/sys/cons.h
index 0000000..78cba61
--- /dev/null
+++ b/freebsd/sys/sys/cons.h
@@ -0,0 +1,144 @@
+ * Copyright (c) 1988 University of Utah.
+ * Copyright (c) 1991 The Regents of the University of California.
+ * This code is derived from software contributed to Berkeley by
+ * the Systems Programming Group of the University of Utah Computer
+ * Science Department.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ * may be used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * SUCH DAMAGE.
+ * from: @(#)cons.h 7.2 (Berkeley) 5/9/91
+ * $FreeBSD$
+#ifndef _MACHINE_CONS_H_
+#define _MACHINE_CONS_H_
+struct consdev;
+struct tty;
+typedef void cn_probe_t(struct consdev *);
+typedef void cn_init_t(struct consdev *);
+typedef void cn_term_t(struct consdev *);
+typedef void cn_grab_t(struct consdev *);
+typedef void cn_ungrab_t(struct consdev *);
+typedef int cn_getc_t(struct consdev *);
+typedef void cn_putc_t(struct consdev *, int);
+struct consdev_ops {
+ cn_probe_t *cn_probe;
+ /* probe hardware and fill in consdev info */
+ cn_init_t *cn_init;
+ /* turn on as console */
+ cn_term_t *cn_term;
+ /* turn off as console */
+ cn_getc_t *cn_getc;
+ /* kernel getchar interface */
+ cn_putc_t *cn_putc;
+ /* kernel putchar interface */
+ cn_grab_t *cn_grab;
+ /* grab console for exclusive kernel use */
+ cn_ungrab_t *cn_ungrab;
+ /* ungrab console */
+struct consdev {
+ const struct consdev_ops *cn_ops;
+ /* console device operations. */
+ short cn_pri; /* pecking order; the higher the better */
+ void *cn_arg; /* drivers method argument */
+ int cn_flags; /* capabilities of this console */
+ char cn_name[SPECNAMELEN + 1]; /* console (device) name */
+/* values for cn_pri - reflect our policy for console selection */
+#define CN_DEAD 0 /* device doesn't exist */
+#define CN_LOW 1 /* device is a last restort only */
+#define CN_NORMAL 2 /* device exists but is nothing special */
+#define CN_INTERNAL 3 /* "internal" bit-mapped display */
+#define CN_REMOTE 4 /* serial interface with remote bit set */
+/* Values for cn_flags. */
+#define CN_FLAG_NODEBUG 0x00000001 /* Not supported with debugger. */
+#define CN_FLAG_NOAVAIL 0x00000002 /* Temporarily not available. */
+/* Visibility of characters in cngets() */
+#define GETS_NOECHO 0 /* Disable echoing of characters. */
+#define GETS_ECHO 1 /* Enable echoing of characters. */
+#define GETS_ECHOPASS 2 /* Print a * for every character. */
+#ifdef _KERNEL
+extern struct msgbuf consmsgbuf; /* Message buffer for constty. */
+extern struct tty *constty; /* Temporary virtual console. */
+#define CONSOLE_DEVICE(name, ops, arg) \
+ static struct consdev name = { \
+ .cn_ops = &ops, \
+ .cn_arg = (arg), \
+ DATA_SET(cons_set, name)
+#define CONSOLE_DRIVER(name) \
+ static const struct consdev_ops name##_consdev_ops = { \
+ .cn_probe = name##_cnprobe, \
+ .cn_init = name##_cninit, \
+ .cn_term = name##_cnterm, \
+ .cn_getc = name##_cngetc, \
+ .cn_putc = name##_cnputc, \
+ .cn_grab = name##_cngrab, \
+ .cn_ungrab = name##_cnungrab, \
+ CONSOLE_DEVICE(name##_consdev, name##_consdev_ops, NULL)
+/* Other kernel entry points. */
+void cninit(void);
+void cninit_finish(void);
+int cnadd(struct consdev *);
+void cnavailable(struct consdev *, int);
+void cnremove(struct consdev *);
+void cnselect(struct consdev *);
+void cngrab(void);
+void cnungrab(void);
+int cncheckc(void);
+int cngetc(void);
+void cngets(char *, size_t, int);
+void cnputc(int);
+void cnputs(char *);
+int cnunavailable(void);
+void constty_set(struct tty *tp);
+void constty_clear(void);
+/* sc(4) / vt(4) coexistence shim */
+#define VTY_SC 0x01
+#define VTY_VT 0x02
+int vty_enabled(unsigned int);
+void vty_set_preferred(unsigned int);
+#endif /* _KERNEL */
+#endif /* !_MACHINE_CONS_H_ */
diff --git a/freebsd/sys/sys/serial.h b/freebsd/sys/sys/serial.h
index 0000000..1a149a9
--- /dev/null
+++ b/freebsd/sys/sys/serial.h
@@ -0,0 +1,92 @@
+ * Copyright (c) 2004 Poul-Henning Kamp
+ * are met:
+ * SUCH DAMAGE.
+ * This file contains definitions which pertain to serial ports as such,
+ * (both async and sync), but which do not necessarily have anything to
+ * do with tty processing.
+ * $FreeBSD$
+#ifndef _SYS_SERIAL_H_
+#define _SYS_SERIAL_H_
+ * Indentification of modem control signals. These definitions match
+ * the TIOCMGET definitions in <sys/ttycom.h> shifted a bit down, and
+ * that identity is enforced with CTASSERT at the bottom of kern/tty.c
+ * Both the modem bits and delta bits must fit in 16 bit.
+#define SER_DTR 0x0001 /* data terminal ready */
+#define SER_RTS 0x0002 /* request to send */
+#define SER_STX 0x0004 /* secondary transmit */
+#define SER_SRX 0x0008 /* secondary receive */
+#define SER_CTS 0x0010 /* clear to send */
+#define SER_DCD 0x0020 /* data carrier detect */
+#define SER_RI 0x0040 /* ring indicate */
+#define SER_DSR 0x0080 /* data set ready */
+#define SER_MASK_STATE 0x00ff
+/* Delta bits, used to indicate which signals should/was affected */
+#define SER_DELTA(x) ((x) << 8)
+#define SER_DDTR SER_DELTA(SER_DTR)
+#define SER_DRTS SER_DELTA(SER_RTS)
+#define SER_DSTX SER_DELTA(SER_STX)
+#define SER_DSRX SER_DELTA(SER_SRX)
+#define SER_DCTS SER_DELTA(SER_CTS)
+#define SER_DDCD SER_DELTA(SER_DCD)
+#define SER_DRI SER_DELTA(SER_RI)
+#define SER_DDSR SER_DELTA(SER_DSR)
+#define SER_MASK_DELTA SER_DELTA(SER_MASK_STATE)
+#ifdef _KERNEL
+ * Specification of interrupt sources typical for serial ports. These are
+ * useful when some umbrella driver like scc(4) has enough knowledge of
+ * the hardware to obtain the set of pending interrupts but does not itself
+ * handle the interrupt. Each interrupt source can be given an interrupt
+ * resource for which inferior drivers can install handlers. The lower 16
+ * bits are kept free for the signals above.
+#define SER_INT_OVERRUN 0x010000
+#define SER_INT_BREAK 0x020000
+#define SER_INT_RXREADY 0x040000
+#define SER_INT_SIGCHG 0x080000
+#define SER_INT_TXIDLE 0x100000
+#define SER_INT_MASK 0xff0000
+#define SER_INT_SIGMASK (SER_MASK_DELTA | SER_MASK_STATE)
+#ifndef LOCORE
+typedef int serdev_intr_t(void*);
+#endif
+#endif /* !_SYS_SERIAL_H_ */
1.9.1
