[PATCH 5/7] Adding RTEMS support for FREEBSD TTY
Kevin Kirspel
kevin-kirspel at idexx.com
Thu Apr 6 01:11:16 UTC 2017
rtemsbsd/include/machine/rtems-bsd-commands.h | 2 +
rtemsbsd/include/machine/rtems-bsd-kernel-space.h | 1 +
rtemsbsd/include/rtems/bsd/local/opt_gdb.h | 1 +
rtemsbsd/include/rtems/netcmds-config.h | 2 +
rtemsbsd/rtems/rtems-bsd-shell-stty.c | 40 +++++++
rtemsbsd/sys/fs/devfs/devfs_devs.c | 86 +++++++++++++-
rtemsbsd/sys/fs/devfs/devfs_vnops.c | 136 ++++++++++++++++++++++
rtemsbsd/sys/net/ppp_tty.c | 10 +-
8 files changed, 263 insertions(+), 15 deletions(-)
create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_gdb.h
create mode 100644 rtemsbsd/rtems/rtems-bsd-shell-stty.c
mode change 100755 => 100644 rtemsbsd/sys/fs/devfs/devfs_devs.c
create mode 100644 rtemsbsd/sys/fs/devfs/devfs_vnops.c
diff --git a/rtemsbsd/include/machine/rtems-bsd-commands.h b/rtemsbsd/include/machine/rtems-bsd-commands.h
index c0524c8..9e9ed1c 100644
--- a/rtemsbsd/include/machine/rtems-bsd-commands.h
+++ b/rtemsbsd/include/machine/rtems-bsd-commands.h
@@ -70,6 +70,8 @@ int rtems_bsd_command_vmstat(int argc, char **argv);
int rtems_bsd_command_wlanstats(int argc, char **argv);
+int rtems_bsd_command_stty(int argc, char **argv);
__END_DECLS
#endif /* _RTEMS_BSD_MACHINE_RTEMS_BSD_COMMANDS_H_ */
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-space.h b/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
index 10ce9d2..9d0484a 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
@@ -48,6 +48,7 @@
#define __GLOBL(sym) __GLOBL1(sym)
#define O_CLOEXEC 0
+#define IO_NDELAY O_NONBLOCK
#define __FreeBSD__ 1
diff --git a/rtemsbsd/include/rtems/bsd/local/opt_gdb.h b/rtemsbsd/include/rtems/bsd/local/opt_gdb.h
new file mode 100644
index 0000000..936ffd8
--- /dev/null
+++ b/rtemsbsd/include/rtems/bsd/local/opt_gdb.h
@@ -0,0 +1 @@
+/* EMPTY */
diff --git a/rtemsbsd/include/rtems/netcmds-config.h b/rtemsbsd/include/rtems/netcmds-config.h
index b3bc66f..515b265 100644
--- a/rtemsbsd/include/rtems/netcmds-config.h
+++ b/rtemsbsd/include/rtems/netcmds-config.h
@@ -45,6 +45,8 @@ extern rtems_shell_cmd_t rtems_shell_VMSTAT_Command;
extern rtems_shell_cmd_t rtems_shell_WLANSTATS_Command;
+extern rtems_shell_cmd_t rtems_shell_STTY_Command;
#ifdef __cplusplus
#endif /* __cplusplus */
diff --git a/rtemsbsd/rtems/rtems-bsd-shell-stty.c b/rtemsbsd/rtems/rtems-bsd-shell-stty.c
index 0000000..530b442
--- /dev/null
+++ b/rtemsbsd/rtems/rtems-bsd-shell-stty.c
@@ -0,0 +1,40 @@
+ * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <rtems/netcmds-config.h>
+#include <machine/rtems-bsd-commands.h>
+rtems_shell_cmd_t rtems_shell_STTY_Command = {
+ .name = "stty",
+ .usage = "stty [args]",
+ .topic = "serial",
+ .command = rtems_bsd_command_stty
diff --git a/rtemsbsd/sys/fs/devfs/devfs_devs.c b/rtemsbsd/sys/fs/devfs/devfs_devs.c
old mode 100755
new mode 100644
index 0ee71ff..a91a02e
--- a/rtemsbsd/sys/fs/devfs/devfs_devs.c
+++ b/rtemsbsd/sys/fs/devfs/devfs_devs.c
@@ -36,6 +36,7 @@
#include <sys/kernel.h>
#include <sys/file.h>
#include <sys/malloc.h>
+#include <sys/proc.h>
#include <unistd.h>
@@ -50,8 +51,16 @@
const char rtems_cdev_directory[] = RTEMS_CDEV_DIRECTORY;
+ * The one true (but secret) list of active devices in the system.
+ * Locked by dev_lock()/devmtx
+struct cdev_priv_list cdevp_list = TAILQ_HEAD_INITIALIZER(cdevp_list);
struct unrhdr *devfs_inos;
+static MALLOC_DEFINE(M_CDEVP, "DEVFS1", "DEVFS cdev_priv storage");
static struct cdev *
devfs_imfs_get_context_by_iop(rtems_libio_t *iop)
@@ -62,11 +71,19 @@ static int
devfs_imfs_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
struct cdev *cdev = devfs_imfs_get_context_by_iop(iop);
+ struct file *fp = rtems_bsd_iop_to_fp(iop);
struct thread *td = rtems_bsd_get_curthread_or_null();
+ struct file *fpop;
int error;
if (td != NULL) {
+ fpop = td->td_fpop;
+ curthread->td_fpop = fp;
error = cdev->si_devsw->d_open(cdev, oflag, 0, td);
+ /* Clean up any cdevpriv upon error. */
+ if (error != 0)
+ devfs_clear_cdevpriv();
+ curthread->td_fpop = fpop;
} else {
error = ENOMEM;
@@ -78,12 +95,17 @@ static int
devfs_imfs_close(rtems_libio_t *iop)
int flags = rtems_libio_to_fcntl_flags(iop->flags);
int error;
if (td != NULL) {
error = cdev->si_devsw->d_close(cdev, flags, 0, td);
} else {
error = ENOMEM;
@@ -96,6 +118,7 @@ devfs_imfs_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt,
ssize_t total)
struct uio uio = {
.uio_iov = __DECONST(struct iovec *, iov),
@@ -106,11 +129,15 @@ devfs_imfs_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt,
.uio_rw = UIO_READ,
.uio_td = td
int error;
if (td != NULL) {
error = cdev->si_devsw->d_read(cdev, &uio,
rtems_libio_to_fcntl_flags(iop->flags));
+ td->td_fpop = fpop;
} else {
error = ENOMEM;
@@ -138,6 +165,7 @@ devfs_imfs_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt,
ssize_t total)
struct uio uio = {
@@ -148,11 +176,15 @@ devfs_imfs_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt,
.uio_rw = UIO_WRITE,
.uio_td = td
int error;
if (td != NULL) {
error = cdev->si_devsw->d_write(cdev, &uio,
} else {
error = ENOMEM;
@@ -179,13 +211,18 @@ static int
devfs_imfs_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
int error;
if (td != 0) {
error = cdev->si_devsw->d_ioctl(cdev, request, buffer, flags,
td);
} else {
error = ENOMEM;
@@ -197,17 +234,34 @@ static int
devfs_imfs_poll(rtems_libio_t *iop, int events)
+ struct thread *td = rtems_bsd_get_curthread_or_wait_forever();
+ int error;
+ error = cdev->si_devsw->d_poll(cdev, events, td);
- return (cdev->si_devsw->d_poll(cdev, events,
- rtems_bsd_get_curthread_or_wait_forever()));
+ return error;
static int
devfs_imfs_kqfilter(rtems_libio_t *iop, struct knote *kn)
+ int error;
+ error = cdev->si_devsw->d_kqfilter(cdev, kn);
- return (cdev->si_devsw->d_kqfilter(cdev, kn));
+ return error;
static const rtems_filesystem_file_handlers_r devfs_imfs_handlers = {
@@ -235,12 +289,17 @@ static const IMFS_node_control devfs_imfs_control = IMFS_GENERIC_INITIALIZER(
struct cdev *
devfs_alloc(int flags)
+ struct cdev_priv *cdp;
struct cdev *cdev;
- cdev = malloc(sizeof *cdev, M_TEMP, M_ZERO);
- if (cdev == NULL)
+ cdp = malloc(sizeof *cdp, M_CDEVP, M_ZERO |
+ ((flags & MAKEDEV_NOWAIT) ? M_NOWAIT : M_WAITOK));
+ if (cdp == NULL)
return (NULL);
+ cdev = &cdp->cdp_c;
+ LIST_INIT(&cdev->si_children);
memcpy(cdev->si_path, rtems_cdev_directory, sizeof(cdev->si_path));
return (cdev);
@@ -248,7 +307,11 @@ devfs_alloc(int flags)
void
devfs_free(struct cdev *cdev)
- free(cdev, M_TEMP);
+ cdp = cdev2priv(cdev);
+ devfs_free_cdp_inode(cdp->cdp_inode);
+ free(cdp, M_CDEVP);
@@ -286,6 +349,7 @@ devfs_create_directory(const char *devname)
void
devfs_create(struct cdev *dev)
int rv;
mode_t mode = S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO;
@@ -294,13 +358,23 @@ devfs_create(struct cdev *dev)
rv = IMFS_make_generic_node(dev->si_path, mode, &devfs_imfs_control,
dev);
BSD_ASSERT(rv == 0);
+ cdp = cdev2priv(dev);
+ cdp->cdp_flags |= CDP_ACTIVE;
+ cdp->cdp_inode = alloc_unrl(devfs_inos);
+ dev_refl(dev);
+ TAILQ_INSERT_TAIL(&cdevp_list, cdp, cdp_list);
void
devfs_destroy(struct cdev *dev)
int rv;
+ cdp->cdp_flags &= ~CDP_ACTIVE;
rv = unlink(dev->si_path);
diff --git a/rtemsbsd/sys/fs/devfs/devfs_vnops.c b/rtemsbsd/sys/fs/devfs/devfs_vnops.c
index 0000000..8c4a786
--- /dev/null
+++ b/rtemsbsd/sys/fs/devfs/devfs_vnops.c
@@ -0,0 +1,136 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * are met:
+ * SUCH DAMAGE.
+#include <machine/rtems-bsd-kernel-space.h>
+#include <sys/types.h>
+#include <sys/conf.h>
+#include <sys/kernel.h>
+#include <sys/file.h>
+#include <sys/malloc.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#include <fs/devfs/devfs_int.h>
+static MALLOC_DEFINE(M_CDEVPDATA, "DEVFSP", "Metainfo for cdev-fp data");
+struct mtx cdevpriv_mtx;
+MTX_SYSINIT(cdevpriv_mtx, &cdevpriv_mtx, "cdevpriv lock", MTX_DEF);
+int
+devfs_get_cdevpriv(void **datap)
+ struct file *fp;
+ struct cdev_privdata *p;
+ int error;
+ fp = curthread->td_fpop;
+ if (fp == NULL)
+ return (EBADF);
+ p = fp->f_cdevpriv;
+ if (p != NULL) {
+ error = 0;
+ *datap = p->cdpd_data;
+ } else
+ error = ENOENT;
+ return (error);
+int
+devfs_set_cdevpriv(void *priv, d_priv_dtor_t *priv_dtr)
+ struct file *fp;
+ int error;
+ if (fp == NULL)
+ return (ENOENT);
+ cdp = cdev2priv((struct cdev *)fp->f_data);
+ p = malloc(sizeof(struct cdev_privdata), M_CDEVPDATA, M_WAITOK);
+ p->cdpd_data = priv;
+ p->cdpd_dtr = priv_dtr;
+ p->cdpd_fp = fp;
+ mtx_lock(&cdevpriv_mtx);
+ if (fp->f_cdevpriv == NULL) {
+ LIST_INSERT_HEAD(&cdp->cdp_fdpriv, p, cdpd_list);
+ fp->f_cdevpriv = p;
+ mtx_unlock(&cdevpriv_mtx);
+ error = 0;
+ } else {
+ free(p, M_CDEVPDATA);
+ error = EBUSY;
+ return (error);
+void
+devfs_destroy_cdevpriv(struct cdev_privdata *p)
+ mtx_assert(&cdevpriv_mtx, MA_OWNED);
+ KASSERT(p->cdpd_fp->f_cdevpriv == p,
+ ("devfs_destoy_cdevpriv %p != %p", p->cdpd_fp->f_cdevpriv, p));
+ p->cdpd_fp->f_cdevpriv = NULL;
+ LIST_REMOVE(p, cdpd_list);
+ (p->cdpd_dtr)(p->cdpd_data);
+static void
+devfs_fpdrop(struct file *fp)
+ if ((p = fp->f_cdevpriv) == NULL) {
+ return;
+ devfs_destroy_cdevpriv(p);
+void
+devfs_clear_cdevpriv(void)
+ struct file *fp;
+ if (fp == NULL)
+ return;
+ devfs_fpdrop(fp);
diff --git a/rtemsbsd/sys/net/ppp_tty.c b/rtemsbsd/sys/net/ppp_tty.c
index 9d416ea..718b146 100644
--- a/rtemsbsd/sys/net/ppp_tty.c
+++ b/rtemsbsd/sys/net/ppp_tty.c
@@ -426,16 +426,8 @@ ppptioctl(struct rtems_termios_tty *tty, rtems_libio_ioctl_args_t *args)
struct ppp_softc *sc = tty->t_sc;
switch (cmd) {
- case RTEMS_IO_RCVWAKEUP:
case RTEMS_IO_SNDWAKEUP:
- case TIOCDRAIN:
- case TIOCFLUSH:
- case TIOCGETA:
- case TIOCGETD:
- case TIOCSETA:
- case TIOCSETAF:
- case TIOCSETAW:
- case TIOCSETD:
+ case RTEMS_IO_RCVWAKEUP:
error = rtems_termios_ioctl(args);
break;
1.9.1
