[PATCH 0/2] xz Warning Removal Patches
Thu Apr 6 05:27:16 UTC 2017
I think the main issue is:
Support for 64-bit CRC is build although XZ_USE_CRC64 is not defined
https://devel.rtems.org/ticket/2909
On 05/04/17 19:06, Joel Sherrill wrote:
> Hi
> I tried to take a direct and minimal approach to removing
> the warnings in xz that appear in every BSP build. I used
> the rule of only adding lines.
> Joel Sherrill (2):
>    xz/xz_config.h: Define __always_inline to inline to avoid warnings
>    xz/xz_crc64.c: Add prototypes to fix warnings
>   cpukit/libmisc/xz/xz_config.h | 6 ++++++
>   cpukit/libmisc/xz/xz_crc64.c  | 5 +++++
>   2 files changed, 11 insertions(+)
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
