[PATCH] Update:Change format specifiers to fix 4 warnings.
Cillian O'Donnell cpodonnell8 at gmail.com
Thu Apr 6 21:10:06 UTC 2017
2 of the warnings cropped up on further testing of other BSPs. Sorry, should of been more careful.
Also git send-email format.
 cpukit/libdl/rtl-obj-cache.c | 18 +++++++++---------
 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/cpukit/libdl/rtl-obj-cache.c b/cpukit/libdl/rtl-obj-cache.c
index a4676cf..d3cd953 100644
--- a/cpukit/libdl/rtl-obj-cache.c
+++ b/cpukit/libdl/rtl-obj-cache.c
@@ -78,11 +78,11 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
   struct stat sb;
   if (rtems_rtl_trace (RTEMS_RTL_TRACE_CACHE))
-    printf ("rtl: cache: %2d: fd=%d offset=%d length=%d area=[%d,%d] cache=[%d,%d] size=%d\n",
-            fd, cache->fd, (int) offset, (int) *length,
-            (int) offset, (int) offset + *length,
-            (int) cache->offset, (int) cache->offset + cache->level,
-            (int) cache->file_size);
+    printf ("rtl: cache: %2d: fd=%d offset=%llu length=%d area=[%d,%llu] cache=[%llu,%llu] size=%lu\n",
+            fd, cache->fd, offset, (int) *length,
+            (int) offset, offset + *length,
+            cache->offset, cache->offset + cache->level,
+            (unsigned long) cache->file_size);
   if (*length > cache->size)
@@ -172,10 +172,10 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
-      printf ("rtl: cache: %2d: seek: offset=%d buffer_offset=%d read=%d cache=[%d,%d] dist=%d\n",
-              fd, (int) offset + buffer_offset, (int) buffer_offset, (int) buffer_read,
-              (int) offset, (int) offset + buffer_read,
-              (int) (cache->file_size - offset));
+      printf ("rtl: cache: %2d: seek: offset=%llu buffer_offset=%lu read=%d cache=[%d,%llu] dist=%llu\n",
+              fd, offset + buffer_offset, (unsigned long) buffer_offset, (int) buffer_read,
+              (int) offset, offset + buffer_read,
+              (cache->file_size - offset));
     if (lseek (fd, offset + buffer_offset, SEEK_SET) < 0)
2.7.4
