[PATCH 1/2] Using inttypes macros fixes 4 format warnings
Cillian O'Donnell
cpodonnell8 at gmail.com
Fri Apr 7 14:11:19 UTC 2017
cpukit/libdl/rtl-obj-cache.c | 21 ++++++++++++---------
1 file changed, 12 insertions(+), 9 deletions(-)
diff --git a/cpukit/libdl/rtl-obj-cache.c b/cpukit/libdl/rtl-obj-cache.c
index a4676cf..c859f60 100644
--- a/cpukit/libdl/rtl-obj-cache.c
+++ b/cpukit/libdl/rtl-obj-cache.c
@@ -22,6 +22,7 @@
#include <unistd.h>
+#include <inttypes.h>
#include <rtems/rtl/rtl-allocator.h>
#include "rtl-obj-cache.h"
@@ -78,11 +79,12 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
struct stat sb;
if (rtems_rtl_trace (RTEMS_RTL_TRACE_CACHE))
- printf ("rtl: cache: %2d: fd=%d offset=%d length=%d area=[%d,%d] cache=[%d,%d] size=%d\n",
- fd, cache->fd, (int) offset, (int) *length,
- (int) offset, (int) offset + *length,
- (int) cache->offset, (int) cache->offset + cache->level,
- (int) cache->file_size);
+ printf ("rtl: cache: %2d: fd=%d offset=%" PRIdMAX "length=%zu area=[%"
+ PRIdMAX ",%" PRIdMAX "] cache=[%" PRIdMAX ",%" PRIdMAX "] size=%zu\n",
+ fd, cache->fd, offset, *length,
+ offset, offset + *length,
+ cache->offset, cache->offset + cache->level,
+ cache->file_size);
if (*length > cache->size)
@@ -172,10 +174,11 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
- printf ("rtl: cache: %2d: seek: offset=%d buffer_offset=%d read=%d cache=[%d,%d] dist=%d\n",
- fd, (int) offset + buffer_offset, (int) buffer_offset, (int) buffer_read,
- (int) offset, (int) offset + buffer_read,
- (int) (cache->file_size - offset));
+ printf ("rtl: cache: %2d: seek: offset=%" PRIdMAX "buffer_offset=%zu"
+ "read=%zu cache=[%" PRIdMAX ",%" PRIdMAX "] dist=%" PRIdMAX "\n",
+ fd, offset + buffer_offset, buffer_offset, buffer_read,
+ offset, offset + buffer_read,
+ (cache->file_size - offset));
if (lseek (fd, offset + buffer_offset, SEEK_SET) < 0)
2.7.4
