[PATCH 02/05] Add USB headers to support USB Serial drivers
Kevin Kirspel
kevin-kirspel at idexx.com
Fri Apr 7 20:13:47 UTC 2017
freebsd/sys/dev/usb/uftdiio.h | 99 +++++++++++++++++++++++++++++++++++++++++++
1 file changed, 99 insertions(+)
create mode 100644 freebsd/sys/dev/usb/uftdiio.h
diff --git a/freebsd/sys/dev/usb/uftdiio.h b/freebsd/sys/dev/usb/uftdiio.h
new file mode 100644
index 0000000..b624483
--- /dev/null
+++ b/freebsd/sys/dev/usb/uftdiio.h
@@ -0,0 +1,99 @@
+ * Copyright 2008-2012 - Symmetricom, Inc.
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions, and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE FOR
+ * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+ * FTDI USB serial converter chip ioctl commands.
+#ifndef _USB_UFTDIIO_H_
+#define _USB_UFTDIIO_H_
+#include <sys/ioccom.h>
+enum uftdi_bitmodes
+ UFTDI_BITMODE_ASYNC = 0,
+ UFTDI_BITMODE_MPSSE = 1,
+ UFTDI_BITMODE_SYNC = 2,
+ UFTDI_BITMODE_CPU_EMUL = 3,
+ UFTDI_BITMODE_FAST_SERIAL = 4,
+ UFTDI_BITMODE_CBUS = 5,
+ UFTDI_BITMODE_NONE = 0xff, /* aka UART mode. */
+ * For UFTDIIOC_SET_BITMODE:
+ * mode = One of the uftdi_bitmodes enum values.
+ * iomask = Mask of bits enabled for bitbang output.
+ * For UFTDIIOC_GET_BITMODE:
+ * mode = Mode most recently set using UFTDIIOC_SET_BITMODE.
+ * iomask = Returned snapshot of DBUS0..DBUS7 pin states at time of call.
+ * Pin states can be read in any mode, not just bitbang modes.
+struct uftdi_bitmode
+ uint8_t mode;
+ uint8_t iomask;
+ * For UFTDIIOC_READ_EEPROM, UFTDIIOC_WRITE_EEPROM:
+ * IO is done in 16-bit words at the chip level; offset and length are in bytes,
+ * but must each be evenly divisible by two.
+ * It is not necessary to erase before writing. For the FT232R device (only)
+ * you must set the latency timer to 0x77 before doing a series of eeprom writes
+ * (and restore it to the prior value when done).
+struct uftdi_eeio
+ uint16_t offset;
+ uint16_t length;
+ uint16_t data[64];
+/* Pass this value to confirm that eeprom erase request is not accidental. */
+#define UFTDI_CONFIRM_ERASE 0x26139108
+#define UFTDIIOC_RESET_IO _IO('c', 0) /* Reset config, flush fifos.*/
+#define UFTDIIOC_RESET_RX _IO('c', 1) /* Flush input fifo. */
+#define UFTDIIOC_RESET_TX _IO('c', 2) /* Flush output fifo. */
+#define UFTDIIOC_SET_BITMODE _IOW('c', 3, struct uftdi_bitmode)
+#define UFTDIIOC_GET_BITMODE _IOR('c', 4, struct uftdi_bitmode)
+#define UFTDIIOC_SET_ERROR_CHAR _IOW('c', 5, int) /* -1 to disable */
+#define UFTDIIOC_SET_EVENT_CHAR _IOW('c', 6, int) /* -1 to disable */
+#define UFTDIIOC_SET_LATENCY _IOW('c', 7, int) /* 1-255 ms */
+#define UFTDIIOC_GET_LATENCY _IOR('c', 8, int)
+#define UFTDIIOC_GET_HWREV _IOR('c', 9, int)
+#define UFTDIIOC_READ_EEPROM _IOWR('c', 10, struct uftdi_eeio)
+#define UFTDIIOC_WRITE_EEPROM _IOW('c', 11, struct uftdi_eeio)
+#define UFTDIIOC_ERASE_EEPROM _IOW('c', 12, int)
+#endif
1.9.1
