[PATCH 1/2] Using inttypes macros fixes 4 format warnings
Joel Sherrill
joel at rtems.org
Fri Apr 7 20:29:55 UTC 2017
I'm OK with both these patches but not in a good
position to apply them right now.
Gedare/Chris.. can you apply these?
Thanks.
--joel
On Fri, Apr 7, 2017 at 9:11 AM, Cillian O'Donnell <cpodonnell8 at gmail.com>
wrote:
> cpukit/libdl/rtl-obj-cache.c | 21 ++++++++++++---------
> 1 file changed, 12 insertions(+), 9 deletions(-)
> diff --git a/cpukit/libdl/rtl-obj-cache.c b/cpukit/libdl/rtl-obj-cache.c
> index a4676cf..c859f60 100644
> --- a/cpukit/libdl/rtl-obj-cache.c
> +++ b/cpukit/libdl/rtl-obj-cache.c
> @@ -22,6 +22,7 @@
> #include <stdio.h>
> #include <string.h>
> #include <unistd.h>
> +#include <inttypes.h>
> #include <rtems/rtl/rtl-allocator.h>
> #include "rtl-obj-cache.h"
> @@ -78,11 +79,12 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
> struct stat sb;
> if (rtems_rtl_trace (RTEMS_RTL_TRACE_CACHE))
> - printf ("rtl: cache: %2d: fd=%d offset=%d length=%d area=[%d,%d]
> cache=[%d,%d] size=%d\n",
> - fd, cache->fd, (int) offset, (int) *length,
> - (int) offset, (int) offset + *length,
> - (int) cache->offset, (int) cache->offset + cache->level,
> - (int) cache->file_size);
> + printf ("rtl: cache: %2d: fd=%d offset=%" PRIdMAX "length=%zu area=[%"
> + PRIdMAX ",%" PRIdMAX "] cache=[%" PRIdMAX ",%" PRIdMAX "]
> size=%zu\n",
> + fd, cache->fd, offset, *length,
> + offset, offset + *length,
> + cache->offset, cache->offset + cache->level,
> + cache->file_size);
> if (*length > cache->size)
> @@ -172,10 +174,11 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t*
> cache,
> - printf ("rtl: cache: %2d: seek: offset=%d buffer_offset=%d read=%d
> cache=[%d,%d] dist=%d\n",
> - fd, (int) offset + buffer_offset, (int) buffer_offset,
> (int) buffer_read,
> - (int) offset, (int) offset + buffer_read,
> - (int) (cache->file_size - offset));
> + printf ("rtl: cache: %2d: seek: offset=%" PRIdMAX
> "buffer_offset=%zu"
> + "read=%zu cache=[%" PRIdMAX ",%" PRIdMAX "] dist=%" PRIdMAX
> "\n",
> + fd, offset + buffer_offset, buffer_offset, buffer_read,
> + offset, offset + buffer_read,
> + (cache->file_size - offset));
> if (lseek (fd, offset + buffer_offset, SEEK_SET) < 0)
> 2.7.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170407/cfa35d87/attachment.html>
