[PATCH 5/9] virtex5/startup/bspstart.c: Use %p to fix 11 warnings.
Cillian O'Donnell cpodonnell8 at gmail.com
Sat Apr 8 11:30:17 UTC 2017
 .../lib/libbsp/powerpc/virtex5/startup/bspstart.c  | 27 +++++++++++-----------
 1 file changed, 14 insertions(+), 13 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c b/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
index 9d610e4..93f99ad 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
@@ -69,6 +69,7 @@
 #include <fcntl.h>
+#include <inttypes.h>
 #define DO_DOWN_ALIGN(x,a) ((x) & ~((a)-1))
@@ -227,20 +228,20 @@ void bsp_start(void)
   /* Let the user know what parameters we were compiled with */
   printk("                  Base/Start     End         Size\n"
-         "RAM:              0x%08x              0x%x\n"
-         "RTEMS:                        0x%08x\n"
+         "RAM:              %p                    %p\n"
+         "RTEMS:                           %p\n"
          "Interrupt Stack:  0x%08x              0x%x\n"
-         "Stack:            0x%08x  0x%08x  0x%x\n"
-         "Workspace:        0x%08x  0x%08x\n"
-         "MsgArea:          0x%08x              0x%x\n"
-         "Physical RAM                  0x%08x\n",
-         (uint32_t)RamBase,                               (uint32_t)RamSize,
-         (uint32_t)__rtems_end,
-         intrStackStart,                                  intrStackSize,
-         (uint32_t)__stack_base, (uint32_t)_stack,        (uint32_t)StackSize,
-         (uint32_t)WorkAreaBase, (uint32_t)__bsp_ram_end,
-         (uint32_t)MsgAreaBase,                           (uint32_t)MsgAreaSize,
-         (uint32_t)__phy_ram_end);
+         "Stack:            %p             %p          %p\n"
+         "Workspace:        %p             %p\n"
+         "MsgArea:          %p             %p\n"
+         "Physical RAM                     %p\n",
+         RamBase,        RamSize,
+         __rtems_end,
+         intrStackStart,                intrStackSize,
+         __stack_base,   _stack,        StackSize,
+         WorkAreaBase,   __bsp_ram_end,
+         MsgAreaBase,    MsgAreaSize,
+         __phy_ram_end);
    * Initialize RTEMS IRQ system
2.7.4
