[PATCH 01/30] leon, GR-CPCI-GR740: Added peripheral PCI driver
Daniel Hellstrom daniel at gaisler.com
Thu Apr 13 19:31:10 UTC 2017
 c/src/lib/libbsp/sparc/Makefile.am                 |   2 +
 c/src/lib/libbsp/sparc/leon2/Makefile.am           |   2 +
 c/src/lib/libbsp/sparc/leon2/preinstall.am         |   4 +
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |   2 +
 c/src/lib/libbsp/sparc/leon3/preinstall.am         |   4 +
 .../libbsp/sparc/shared/include/gr_cpci_gr740.h    |  61 ++
 c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c  | 738 +++++++++++++++++++++
 cpukit/libdrvmgr/drvmgr_confdefs.h                 |   4 +
 cpukit/libpci/pci/ids_extra.h                      |   1 +
 cpukit/libpci/pci_bus.h                            |   1 +
 10 files changed, 819 insertions(+)
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/gr_cpci_gr740.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index af0df0a..f75790a 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -57,6 +57,7 @@ EXTRA_DIST += shared/include/gr_rasta_spw_router.h
 EXTRA_DIST += shared/include/gr_rasta_tmtc.h
 EXTRA_DIST += shared/include/gr_tmtc_1553.h
 EXTRA_DIST += shared/include/gr_leon4_n2x.h
+EXTRA_DIST += shared/include/gr_cpci_gr740.h
 EXTRA_DIST += shared/pci/gr_701.c
 EXTRA_DIST += shared/pci/gr_rasta_adcdac.c
 EXTRA_DIST += shared/pci/gr_rasta_io.c
@@ -64,6 +65,7 @@ EXTRA_DIST += shared/pci/gr_rasta_spw_router.c
 EXTRA_DIST += shared/pci/gr_rasta_tmtc.c
 EXTRA_DIST += shared/pci/gr_tmtc_1553.c
 EXTRA_DIST += shared/pci/gr_leon4_n2x.c
+EXTRA_DIST += shared/pci/gr_cpci_gr740.c
 # DEBUG
 EXTRA_DIST += shared/include/debug_defs.h
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 5ac0e04..bafa626 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -112,12 +112,14 @@ include_bsp_HEADERS += ../../sparc/shared/include/gr_rasta_io.h
 include_bsp_HEADERS += ../../sparc/shared/include/gr_rasta_spw_router.h
 include_bsp_HEADERS += ../../sparc/shared/include/gr_rasta_tmtc.h
 include_bsp_HEADERS += ../../sparc/shared/include/gr_leon4_n2x.h
+include_bsp_HEADERS += ../../sparc/shared/include/gr_cpci_gr740.h
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_701.c
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_rasta_adcdac.c
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_rasta_io.c
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_rasta_spw_router.c
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_rasta_tmtc.c
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_leon4_n2x.c
+libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_cpci_gr740.c
 # B1553BRM
 include_bsp_HEADERS += ../../sparc/shared/include/b1553brm.h
diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
index f4c8ca4..873cc17 100644
--- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
@@ -161,6 +161,10 @@ $(PROJECT_INCLUDE)/bsp/gr_leon4_n2x.h: ../../sparc/shared/include/gr_leon4_n2x.h
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/gr_leon4_n2x.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/gr_leon4_n2x.h
+$(PROJECT_INCLUDE)/bsp/gr_cpci_gr740.h: ../../sparc/shared/include/gr_cpci_gr740.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/gr_cpci_gr740.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/gr_cpci_gr740.h
 $(PROJECT_INCLUDE)/bsp/b1553brm.h: ../../sparc/shared/include/b1553brm.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/b1553brm.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/b1553brm.h
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index f2f690e..9a4737c 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -124,6 +124,7 @@ include_bsp_HEADERS += ../../sparc/shared/include/gr_rasta_spw_router.h
 include_bsp_HEADERS += ../../sparc/shared/include/gr_tmtc_1553.h
@@ -131,6 +132,7 @@ libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_rasta_spw_router.c
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_tmtc_1553.c
 # B1553BRM
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index 5ef0a63..d9bdf35 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -181,6 +181,10 @@ $(PROJECT_INCLUDE)/bsp/gr_leon4_n2x.h: ../../sparc/shared/include/gr_leon4_n2x.h
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_cpci_gr740.h b/c/src/lib/libbsp/sparc/shared/include/gr_cpci_gr740.h
new file mode 100644
index 0000000..55c28ac
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_cpci_gr740.h
@@ -0,0 +1,61 @@
+/*  GR-CPCI-GR740 PCI Peripheral driver
+ *  COPYRIGHT (c) 2017.
+ *  Cobham Gaisler AB.
+ *  The license and distribution terms for this file may be
+ *  found in found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+ *  Configures the GR-CPIC-GR740 interface PCI board in peripheral
+ *  mode. This driver provides a AMBA PnP bus by using the general part
+ *  of the AMBA PnP bus driver (ambapp_bus.c).
+ *  Driver resource options:
+ *   NAME          DEFAULT VALUE
+ *   ahbmst2pci    _RAM_START            AMBA->PCI translation PCI base address
+ *   ambaFreq      250000000 (250MHz)    AMBA system frequency of GR740
+ *   cgEnMask      0x1f (all)            Clock gating enable mask
+ * TODO/UNTESTED
+ *   Interrupt testing
+ *   bar0 RESOURCE 0x00000000            L2-Cache SDRAM memory
+ *   bar1 RESOURCE 0xf0000000            L2-Cache registers
+#ifndef __GR_CPCI_GR740_H__
+#define __GR_CPCI_GR740_H__
+#include <drvmgr/drvmgr.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* An array of pointers to GR-CPCI-GR740 resources. The resources will be
+ * used by the drivers controlling the cores on the GR-CPCI-GR740 target
+ * AMBA bus.
+ * The gr_cpci_gr740_resources is declared weak so that the user can override the
+ * default configuration. The array must be terminated with a NULL resource.
+extern struct drvmgr_bus_res *gr_cpci_gr740_resources[];
+/* Options to gr_cpci_gr740_print function */
+#define GR_CPCI_GR740_OPTIONS_AMBA   0x01 /* Print AMBA bus devices */
+/* Print information about all GR-CPCI-GR740 PCI boards */
+void gr_cpci_gr740_print(int options);
+/* Print information about one GR-CPCI-GR740 PCI board */
+void gr_cpci_gr740_print_dev(struct drvmgr_dev *dev, int options);
+/* Register GR-CPCI-GR740 driver */
+void gr_cpci_gr740_register_drv(void);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c b/c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c
index 0000000..3ba55c5
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c
@@ -0,0 +1,738 @@
+/*  GR-CPCI-GR740 PCI Target driver.
+ *  http://www.rtems.com/license/LICENSE.
+ *  Configures the GR-CPCI-GR740 interface PCI board in peripheral
+ *  of the AMBA PnP bus driver (ambapp_bus.c). Based on the
+ *  GR-RASTA-IO driver.
+ *   bar0          0x00000000            L2-Cache SDRAM memory
+ *   bar1          0xf0000000            L2-Cache registers
+ * TODO/UNTESTED
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <bsp.h>
+#include <rtems/bspIo.h>
+#include <pci.h>
+#include <ambapp.h>
+#include <grlib.h>
+#include <drvmgr/ambapp_bus.h>
+#include <drvmgr/pci_bus.h>
+#include <drvmgr/bspcommon.h>
+#include <bsp/genirq.h>
+#include <bsp/gr_cpci_gr740.h>
+/* Determines which PCI address the AHB masters on the GR740 board will
+ * access when accessing the AHB to PCI window, it should be set so that the
+ * masters can access the HOST RAM.
+ * Default is base of HOST RAM, HOST RAM is mapped 1:1 to PCI memory space.
+extern unsigned int _RAM_START;
+#define AHBMST2PCIADR (((unsigned int)&_RAM_START) & 0xc0000000)
+#define GRPCI2_BAR0_TO_AHB_MAP 0x04
+#define GRPCI2_BAR1_TO_AHB_MAP 0x08
+#define GRPCI2_BAR2_TO_AHB_MAP 0x0c
+#define GRPCI2_PCI_CONFIG      0x20
+#define CAP9_AHBPREF_OFS 0x3c
+/* #define DEBUG 1 */
+#ifdef DEBUG
+#define DBG(x...) printk(x)
+#else
+#define DBG(x...)
+#endif
+int gr_cpci_gr740_init1(struct drvmgr_dev *dev);
+int gr_cpci_gr740_init2(struct drvmgr_dev *dev);
+void gr_cpci_gr740_isr(void *arg);
+struct grpci2_regs {
+	volatile unsigned int ctrl;		/* 0x00 */
+	volatile unsigned int sts_cap;		/* 0x04 */
+	volatile unsigned int ppref;		/* 0x08 */
+	volatile unsigned int io_map;		/* 0x0C */
+	volatile unsigned int dma_ctrl;		/* 0x10 */
+	volatile unsigned int dma_bdbase;	/* 0x14 */
+	volatile unsigned int dma_chact;	/* 0x18 */
+	int res1;				/* 0x1C */
+	volatile unsigned int bars[6];		/* 0x20 */
+	int res2[2];				/* 0x38 */
+	volatile unsigned int ahbmst_map[16];	/* 0x40 */
+/* Clock gating unit register layout */
+struct gr740_grcg_regs {
+	volatile unsigned int unlock;
+	volatile unsigned int enable;
+	volatile unsigned int reset;
+	volatile unsigned int cpu_fpu;
+#define CG_MASK 0x3ff
+/* Private data structure for driver */
+struct gr_cpci_gr740_priv {
+	/* Driver management */
+	struct drvmgr_dev	*dev;
+	char			prefix[20];
+	/* PCI */
+	pci_dev_t		pcidev;
+	struct pci_dev_info	*devinfo;
+	uint32_t		ahbmst2pci_map;
+	/* IRQ */
+	int			eirq;
+	genirq_t		genirq;
+	/* GR-CPCI-GR740 */
+	unsigned int		amba_freq_hz;
+	unsigned int		cg_en_mask;		/* Enabled cores */
+	struct irqmp_regs	*irq;
+	struct gr740_grcg_regs	*cg;			/* Clock-gating unit */
+	struct grpci2_regs	*grpci2;
+	struct drvmgr_map_entry	bus_maps_up[2];
+	struct drvmgr_map_entry	bus_maps_down[4];
+	/* AMBA Plug&Play information on GR-CPCI-GR740 */
+	struct ambapp_bus	abus;
+	struct ambapp_mmap	amba_maps[5];
+	struct ambapp_config	config;
+int ambapp_gr740_int_register(
+	struct drvmgr_dev *dev,
+	int irq,
+	const char *info,
+	drvmgr_isr handler,
+	void *arg);
+int ambapp_gr740_int_unregister(
+	int irq,
+	void *arg);
+int ambapp_gr740_int_unmask(
+	int irq);
+int ambapp_gr740_int_mask(
+	int irq);
+int ambapp_gr740_int_clear(
+	int irq);
+int ambapp_gr740_get_params(
+	struct drvmgr_bus_params *params);
+static struct ambapp_ops ambapp_gr740_ops = {
+	.int_register = ambapp_gr740_int_register,
+	.int_unregister = ambapp_gr740_int_unregister,
+	.int_unmask = ambapp_gr740_int_unmask,
+	.int_mask = ambapp_gr740_int_mask,
+	.int_clear = ambapp_gr740_int_clear,
+	.get_params = ambapp_gr740_get_params
+struct drvmgr_drv_ops gr_cpci_gr740_ops =
+	.init = {gr_cpci_gr740_init1, gr_cpci_gr740_init2, NULL, NULL},
+	.remove = NULL,
+	.info = NULL
+struct pci_dev_id_match gr_cpci_gr740_ids[] =
+	PCIID_DEVVEND(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_CPCI_GR740),
+	PCIID_END_TABLE /* Mark end of table */
+struct pci_drv_info gr_cpci_gr740_info =
+		DRVMGR_OBJ_DRV,			/* Driver */
+		NULL,				/* Next driver */
+		NULL,				/* Device list */
+		DRIVER_PCI_GAISLER_CPCI_GR740_ID,	/* Driver ID */
+		"GR-CPCI-GR740",		/* Driver Name */
+		DRVMGR_BUS_TYPE_PCI,		/* Bus Type */
+		&gr_cpci_gr740_ops,
+		NULL,				/* Funcs */
+		0,				/* No devices yet */
+		sizeof(struct gr_cpci_gr740_priv),
+	&gr_cpci_gr740_ids[0]
+/* Driver resources configuration for the AMBA bus on the GR-CPCI-GR740 board.
+ * It is declared weak so that the user may override it from the project file,
+ * if the default settings are not enough.
+ * The configuration consists of an array of configuration pointers, each
+ * pointer determine the configuration of one GR-CPCI-GR740 board. Pointer
+ * zero is for board0, pointer 1 for board1 and so on.
+ * The array must end with a NULL pointer.
+struct drvmgr_bus_res *gr_cpci_gr740_resources[] __attribute__((weak)) =
+	NULL
+	DBG("Registering GR-CPCI-GR740 PCI driver\n");
+	drvmgr_drv_register(&gr_cpci_gr740_info.general);
+	struct gr_cpci_gr740_priv *priv = arg;
+	unsigned int status, tmp;
+	int irq, eirq;
+	tmp = status = priv->irq->ipend;
+	/* DBG("GR-CPCI-GR740: IRQ 0x%x\n",status); */
+	for(irq = 0; irq < 32; irq++) {
+		if (status & (1 << irq)) {
+			if (irq == priv->eirq) {
+				while ((eirq = priv->irq->intid[0] & 0x1f)) {
+					if ((eirq & 0x10) == 0)
+						continue;
+					genirq_doirq(priv->genirq, eirq);
+					priv->irq->iclear = (1 << eirq);
+			} else {
+				genirq_doirq(priv->genirq, irq);
+			priv->irq->iclear = (1 << irq);
+			status &= ~(1 << irq);
+			if ( status == 0 )
+				break;
+	/* ACK interrupt, this is because PCI is Level, so the IRQ Controller
+	 * still drives the IRQ
+	if ( tmp )
+		drvmgr_interrupt_clear(priv->dev, 0);
+	DBG("GR-CPCI-GR740-IRQ: 0x%x\n", tmp);
+static int gr_cpci_gr740_hw_init1(struct gr_cpci_gr740_priv *priv)
+	int i;
+	uint32_t data;
+	unsigned int ctrl;
+	uint8_t tmp2;
+	struct ambapp_dev *tmp;
+	struct ambapp_ahb_info *ahb;
+	uint8_t cap_ptr;
+	pci_dev_t pcidev = priv->pcidev;
+	struct pci_dev_info *devinfo = priv->devinfo;
+	unsigned int cgmask, enabled;
+	/* Check capabilities list bit and read its pointer */
+	pci_cfg_r8(pcidev, PCIR_STATUS, &tmp2);
+	if (!((tmp2 >> 4) & 1)) {
+		/* Capabilities list not available which it should be in the GRPCI2 */
+		return -2;
+	pci_cfg_r8(pcidev, PCIR_CAP_PTR, &cap_ptr);
+	/* Set AHB address mappings for target PCI bars
+	 *  BAR0 maps to 0x00000000-0x07ffffff 128MB (SDRAM/DDR2 memory)
+	 *  BAR1 maps to 0xf0000000-0xf7ffffff 128MB (L2-Cache regs/diagnostics)
+	 *  BAR2 maps to 0xff800000-0xffffffff   8MB (PnP, I/O regs)
+	pci_cfg_w32(pcidev, cap_ptr+GRPCI2_BAR0_TO_AHB_MAP, 0x00000000);
+	pci_cfg_w32(pcidev, cap_ptr+GRPCI2_BAR1_TO_AHB_MAP, 0xf0000000);
+	pci_cfg_w32(pcidev, cap_ptr+GRPCI2_BAR2_TO_AHB_MAP, 0xff800000);
+	/* Set PCI bus to be big endian */
+	pci_cfg_r32(pcidev, cap_ptr+GRPCI2_PCI_CONFIG, &data);
+	data = data & 0xFFFFFFFE;
+	pci_cfg_w32(pcidev, cap_ptr+GRPCI2_PCI_CONFIG, data);
+#if 0
+	/* set parity error response */
+	pci_cfg_r32(pcidev, PCIR_COMMAND, &data);
+	pci_cfg_w32(pcidev, PCIR_COMMAND, (data|PCIM_CMD_PERRESPEN));
+#endif
+	/* Scan AMBA Plug&Play */
+	/* AMBA MAP bar0 (in gr740) ==> 0x00000000 (remote amba address) */
+	priv->amba_maps[0].size = devinfo->resources[0].size;
+	priv->amba_maps[0].local_adr = devinfo->resources[0].address;
+	priv->amba_maps[0].remote_adr = 0x00000000;
+	priv->amba_maps[1].size = devinfo->resources[1].size;
+	priv->amba_maps[1].local_adr = devinfo->resources[1].address;
+	priv->amba_maps[1].remote_adr = 0xf0000000;
+	priv->amba_maps[2].size = devinfo->resources[2].size;
+	priv->amba_maps[2].local_adr = devinfo->resources[2].address;
+	priv->amba_maps[2].remote_adr = 0xff800000;
+	/* Addresses not matching with map be untouched */
+	priv->amba_maps[3].size = 0xfffffff0;
+	priv->amba_maps[3].local_adr = 0;
+	priv->amba_maps[3].remote_adr = 0;
+	/* Mark end of table */
+	priv->amba_maps[4].size=0;
+	/* Start AMBA PnP scan at first AHB bus */
+	ambapp_scan(
+		&priv->abus,
+		devinfo->resources[2].address + 0x00700000,
+		NULL,
+		&priv->amba_maps[0]);
+	/* Initialize Frequency of AMBA bus */
+	ambapp_freq_init(&priv->abus, NULL, priv->amba_freq_hz);
+	/* Find IRQ controller, Clear all current IRQs */
+	tmp = (struct ambapp_dev *)ambapp_for_each(&priv->abus,
+				(OPTIONS_ALL|OPTIONS_APB_SLVS),
+				VENDOR_GAISLER, GAISLER_IRQMP,
+				ambapp_find_by_idx, NULL);
+	if ( !tmp ) {
+		return -4;
+	priv->irq = (struct irqmp_regs *)DEV_TO_APB(tmp)->start;
+	/* Set up GR-CPCI-GR740 irq controller
+	 * Interrupts are routed from IRQCtrl0, we leave the configuration
+	 * for the other CPUs, as the board's CPUs may be running something.
+	 * We assume IRQCtrl has been set up properly, or at least the reset
+	 * values shuold work with this code..
+	priv->irq->mask[0] = 0;
+	priv->irq->iforce = 0;
+	priv->irq->force[0] = 0;
+	priv->irq->ilevel = 0;
+	priv->irq->ipend = 0;
+	priv->irq->iclear = 0xffffffff;
+	/* Get extended Interrupt controller IRQ number */
+	priv->eirq = (priv->irq->mpstat >> 16) & 0xf;
+	/* Find first Clock-Gating unit, enable/disable the requested cores */
+				VENDOR_GAISLER, GAISLER_CLKGATE,
+	if ( !tmp ) {
+		return -5;
+	priv->cg = (struct gr740_grcg_regs *)DEV_TO_APB(tmp)->start;
+	/* Do reset and enable sequence only if not already enabled */
+	if (priv->cg && ((enabled = priv->cg->enable) != priv->cg_en_mask)) {
+		/* First disable already enabled cores */
+		cgmask = ~priv->cg_en_mask & enabled;
+		if (cgmask) {
+			priv->cg->unlock = cgmask;
+			priv->cg->enable = enabled = ~cgmask & enabled;
+			priv->cg->unlock = 0;
+		/* Enable disabled cores */
+		cgmask = priv->cg_en_mask & ~enabled;
+		if (cgmask) {
+			priv->cg->reset |= cgmask;
+			priv->cg->enable = cgmask | enabled;
+			priv->cg->reset &= ~cgmask;
+	priv->bus_maps_down[0].name = "PCI BAR0 -> AMBA";
+	priv->bus_maps_down[0].size = priv->amba_maps[0].size;
+	priv->bus_maps_down[0].from_adr = (void *)priv->amba_maps[0].local_adr;
+	priv->bus_maps_down[0].to_adr = (void *)priv->amba_maps[0].remote_adr;
+	priv->bus_maps_down[1].name = "PCI BAR1 -> AMBA";
+	priv->bus_maps_down[1].size = priv->amba_maps[1].size;
+	priv->bus_maps_down[1].from_adr = (void *)priv->amba_maps[1].local_adr;
+	priv->bus_maps_down[1].to_adr = (void *)priv->amba_maps[1].remote_adr;
+	priv->bus_maps_down[2].name = "PCI BAR2 -> AMBA";
+	priv->bus_maps_down[2].size = priv->amba_maps[2].size;
+	priv->bus_maps_down[2].from_adr = (void *)priv->amba_maps[2].local_adr;
+	priv->bus_maps_down[2].to_adr = (void *)priv->amba_maps[2].remote_adr;
+	priv->bus_maps_down[3].size = 0;
+	/* Find GRPCI2 controller AHB Slave interface */
+					(OPTIONS_ALL|OPTIONS_AHB_SLVS),
+					VENDOR_GAISLER, GAISLER_GRPCI2,
+	if ( !tmp ) {
+		return -6;
+	ahb = (struct ambapp_ahb_info *)tmp->devinfo;
+	priv->bus_maps_up[0].name = "AMBA GRPCI2 Window";
+	priv->bus_maps_up[0].size = ahb->mask[0]; /* AMBA->PCI Window on GR-CPCI-GR740 board */
+	priv->bus_maps_up[0].from_adr = (void *)ahb->start[0];
+	priv->bus_maps_up[0].to_adr = (void *)
+				(priv->ahbmst2pci_map & ~(ahb->mask[0]-1));
+	priv->bus_maps_up[1].size = 0;
+	/* Find GRPCI2 controller APB Slave interface */
+	if ( !tmp ) {
+		return -7;
+	priv->grpci2 = (struct grpci2_regs *)
+		((struct ambapp_apb_info *)tmp->devinfo)->start;
+	/* Set AHB to PCI mapping for all AMBA AHB masters */
+	for(i = 0; i < 16; i++) {
+		priv->grpci2->ahbmst_map[i] = priv->ahbmst2pci_map &
+							~(ahb->mask[0]-1);
+	/* Make sure dirq(0) sampling is enabled */
+	ctrl = priv->grpci2->ctrl;
+	ctrl = (ctrl & 0xFFFFFF0F) | (1 << 4);
+	priv->grpci2->ctrl = ctrl;
+	/* Successfully registered the GR740 board */
+	return 0;
+static int gr_cpci_gr740_hw_init2(struct gr_cpci_gr740_priv *priv)
+	/* Enable DMA by enabling PCI target as master */
+	pci_master_enable(priv->pcidev);
+	return DRVMGR_OK;
+/* Called when a PCI target is found with the PCI device and vendor ID
+ * given in gr_cpci_gr740_ids[].
+	struct gr_cpci_gr740_priv *priv;
+	int status, i;
+	union drvmgr_key_value *value;
+	int resources_cnt;
+	priv = dev->priv;
+	if (!priv)
+		return DRVMGR_NOMEM;
+	memset(priv, 0, sizeof(*priv));
+	dev->priv = priv;
+	priv->dev = dev;
+	/* Determine number of configurations */
+	resources_cnt = get_resarray_count(gr_cpci_gr740_resources);
+	/* Generate Device prefix */
+	strcpy(priv->prefix, "/dev/gr7400");
+	priv->prefix[10] += dev->minor_drv;
+	mkdir(priv->prefix, S_IRWXU | S_IRWXG | S_IRWXO);
+	priv->prefix[11] = '/';
+	priv->prefix[12] = '\0';
+	priv->devinfo = devinfo = (struct pci_dev_info *)dev->businfo;
+	priv->pcidev = devinfo->pcidev;
+	printf("\n\n--- GR-CPCI-GR740[%d] ---\n", dev->minor_drv);
+	printf(" PCI BUS: 0x%x, SLOT: 0x%x, FUNCTION: 0x%x\n",
+		PCI_DEV_EXPAND(priv->pcidev));
+	printf(" PCI VENDOR: 0x%04x, DEVICE: 0x%04x\n",
+		devinfo->id.vendor, devinfo->id.device);
+	for (i = 0; i < 3; i++) {
+		printf(" PCI BAR[%d]: 0x%08lx - 0x%08lx\n",
+			i, devinfo->resources[i].address,
+			devinfo->resources[i].address +
+			(devinfo->resources[i].size - 1));
+		/* all neccessary space assigned to GR-CPCI-GR740 target? */
+		if (devinfo->resources[i].size == 0)
+			return DRVMGR_ENORES;
+	printf(" IRQ: %d\n\n\n", devinfo->irq);
+	/* Let user override which PCI address the AHB masters of the
+	 * GR740 board access when doing DMA to HOST RAM. The AHB masters
+	 * access the PCI Window of the AMBA bus, the MSB 2-bits of that address
+	 * is translated according this config option before the address goes
+	 * out on the PCI bus.
+	 * Only the 2 MSB bits have an effect.
+	value = drvmgr_dev_key_get(priv->dev, "ahbmst2pci", DRVMGR_KT_INT);
+	if (value)
+		priv->ahbmst2pci_map = value->i;
+	else
+		priv->ahbmst2pci_map = AHBMST2PCIADR; /* default */
+	/* Let user override the default AMBA system frequency of the
+	 * CPU-bus of the remote GR-CPCI-GR740. Default is 250MHz.
+	value = drvmgr_dev_key_get(priv->dev, "ambaFreq", DRVMGR_KT_INT);
+	if (value)
+		priv->amba_freq_hz = value->i;
+	else
+		priv->amba_freq_hz = 250000000; /* default */
+	/* Let user determine clock-gating unit configuration. The default
+	 * is to turn all cores on (disable gating). PCI is always turned ON.
+	value = drvmgr_dev_key_get(priv->dev, "cgEnMask", DRVMGR_KT_INT);
+	if (value)
+		priv->cg_en_mask = (value->i & CG_MASK) | 0x08;
+	else
+		priv->cg_en_mask = CG_MASK; /* default all ON */
+	priv->genirq = genirq_init(32);
+	if (priv->genirq == NULL)
+		return DRVMGR_FAIL;
+	if ((status = gr_cpci_gr740_hw_init1(priv)) != 0) {
+		genirq_destroy(priv->genirq);
+		printf(" Failed to initialize GR-CPCI-GR740 HW: %d\n", status);
+	/* Init amba bus */
+	priv->config.abus = &priv->abus;
+	priv->config.ops = &ambapp_gr740_ops;
+	priv->config.maps_up = &priv->bus_maps_up[0];
+	priv->config.maps_down = &priv->bus_maps_down[0];
+	if ( priv->dev->minor_drv < resources_cnt ) {
+		priv->config.resources = gr_cpci_gr740_resources[priv->dev->minor_drv];
+	} else {
+		priv->config.resources = NULL;
+	/* Create and register AMBA PnP bus. */
+	return ambapp_bus_register(dev, &priv->config);
+	struct gr_cpci_gr740_priv *priv = dev->priv;
+	/* Clear any old interrupt requests */
+	drvmgr_interrupt_clear(dev, 0);
+	/* Enable System IRQ so that GR-CPCI-GR740 PCI target interrupt
+	 * goes through.
+	 * It is important to enable it in stage init2. If interrupts were
+	 * enabled in init1 this might hang the system when more than one
+	 * PCI board is connected, this is because PCI interrupts might
+	 * be shared and PCI board 2 have not initialized and
+	 * might therefore drive interrupt already when entering init1().
+	drvmgr_interrupt_register(
+		dev,
+		0,
+		"gr_cpci_gr740",
+		gr_cpci_gr740_isr,
+		(void *)priv);
+	return gr_cpci_gr740_hw_init2(priv);
+	int irq,
+	const char *info,
+	void *arg)
+	struct gr_cpci_gr740_priv *priv = dev->parent->dev->priv;
+	rtems_interrupt_level level;
+	int status;
+	rtems_interrupt_disable(level);
+	status = genirq_register(priv->genirq, irq, handler, arg);
+	if (status == 0) {
+		/* Clear IRQ for first registered handler */
+		priv->irq->iclear = (1<<irq);
+	} else if (status == 1)
+		status = 0;
+	if (status != 0) {
+		rtems_interrupt_enable(level);
+	status = genirq_enable(priv->genirq, irq, handler, arg);
+	if ( status == 0 ) {
+		/* Enable IRQ for first enabled handler only */
+		priv->irq->mask[0] |= (1<<irq); /* unmask interrupt source */
+	} else if ( status == 1 )
+		status = 0;
+	return status;
+	int irq,
+	drvmgr_isr isr,
+	void *arg)
+	int status;
+	status = genirq_disable(priv->genirq, irq, isr, arg);
+		/* Disable IRQ only when no enabled handler exists */
+		priv->irq->mask[0] &= ~(1<<irq); /* mask interrupt source */
+	status = genirq_unregister(priv->genirq, irq, isr, arg);
+	if ( status != 0 )
+		status = DRVMGR_FAIL;
+	return status;
+	int irq)
+	DBG("GR740 IRQ %d: unmask\n", irq);
+	if ( genirq_check(priv->genirq, irq) )
+		return DRVMGR_EINVAL;
+	return DRVMGR_OK;
+	int irq)
+	DBG("GR740 IRQ %d: mask\n", irq);
+	/* Disable/mask IRQ */
+	return DRVMGR_OK;
+	int irq)
+	return DRVMGR_OK;
+int ambapp_gr740_get_params(struct drvmgr_dev *dev, struct drvmgr_bus_params *params)
+	/* Device name prefix pointer, skip /dev */
+	params->dev_prefix = &priv->prefix[5];
+	return 0;
+	uint32_t bar0, bar0_size;
+	/* Print */
+	printf("--- GR-CPCI-GR740 [bus 0x%x, dev 0x%x, fun 0x%x] ---\n",
+	bar0 = devinfo->resources[0].address;
+	bar0_size = devinfo->resources[0].size;
+	printf(" PCI BAR[0]: 0x%lx - 0x%lx\n", bar0, bar0 + bar0_size - 1);
+	printf(" IRQ REGS:        0x%x\n", (unsigned int)priv->irq);
+	printf(" IRQ:             %d\n", devinfo->irq);
+	printf(" PCI REVISION:    %d\n", devinfo->rev);
+	printf(" FREQ:            %d Hz\n", priv->amba_freq_hz);
+	printf(" IMASK:           0x%08x\n", priv->irq->mask[0]);
+	printf(" IPEND:           0x%08x\n", priv->irq->ipend);
+	/* Print amba config */
+	if (options & GR_CPCI_GR740_OPTIONS_AMBA)
+		ambapp_print(&priv->abus, 10);
+	struct pci_drv_info *drv = &gr_cpci_gr740_info;
+	dev = drv->general.dev;
+	while(dev) {
+		gr_cpci_gr740_print_dev(dev, options);
+		dev = dev->next_in_drv;
diff --git a/cpukit/libdrvmgr/drvmgr_confdefs.h b/cpukit/libdrvmgr/drvmgr_confdefs.h
index 22c7a90..7692650 100644
--- a/cpukit/libdrvmgr/drvmgr_confdefs.h
+++ b/cpukit/libdrvmgr/drvmgr_confdefs.h
@@ -72,6 +72,7 @@ extern void gr701_register_drv(void);
 extern void gr_tmtc_1553_register_drv(void);
 extern void gr_rasta_spw_router_register_drv(void);
 extern void gr_cpci_leon4_n2x_register_drv(void);
+extern void gr_cpci_gr740_register_drv(void);
 /* CONFIGURE DRIVER MANAGER */
@@ -192,6 +193,9 @@ drvmgr_drv_reg_func drvmgr_drivers[] = {
 #ifdef CONFIGURE_DRIVER_PCI_GR_LEON4_N2X
 	gr_cpci_leon4_n2x_register_drv,
 #endif
+#ifdef CONFIGURE_DRIVER_PCI_GR_CPCI_GR740
+	gr_cpci_gr740_register_drv,
+#endif
 /* Macros for adding custom drivers without needing to recompile
diff --git a/cpukit/libpci/pci/ids_extra.h b/cpukit/libpci/pci/ids_extra.h
index a7d2bc5..0b85fe2 100644
--- a/cpukit/libpci/pci/ids_extra.h
+++ b/cpukit/libpci/pci/ids_extra.h
@@ -19,3 +19,4 @@
 #define PCIID_DEVICE_GR_RASTA_SPW_RTR   0x0062  /* GR-RASTA-SPW-ROUTER */
 #define PCIID_DEVICE_GR_LEON4_N2X       0x0061  /* GR-CPCI-LEON4-N2X */
 #define PCIID_DEVICE_GR_NGMP_PROTO      0x0064  /* GR-NGMP_PROTO */
+#define PCIID_DEVICE_GR_CPCI_GR740      0x0740  /* GR-CPCI-GR740 */
diff --git a/cpukit/libpci/pci_bus.h b/cpukit/libpci/pci_bus.h
index 7a4e253..b426010 100644
--- a/cpukit/libpci/pci_bus.h
+++ b/cpukit/libpci/pci_bus.h
@@ -47,6 +47,7 @@ extern "C" {
 #define DRIVER_PCI_GAISLER_TMTC_1553_ID		DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_TMTC_1553)
 #define DRIVER_PCI_GAISLER_RASTA_SPW_ROUTER_ID	DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_SPW_RTR)
 #define DRIVER_PCI_GAISLER_LEON4_N2X_ID		DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_LEON4_N2X)
+#define DRIVER_PCI_GAISLER_CPCI_GR740_ID	DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_CPCI_GR740)
 struct pci_dev_id {
 	uint16_t		vendor;
2.7.4
