[PATCH 07/30] leon, cons: drvmgr cons interface uses new TERMIOS
Daniel Hellstrom daniel at gaisler.com
Thu Apr 13 19:31:16 UTC 2017
LEON driver manager console driver interface (cons) and the APBUART cons driver
(apbuart_cons) have been updated for recent TERMIOS interface changes. The
legacy callback API is not used anymore and deprecated functions are
eliminated.
This new implementation is based on RTEMS BSP and Device Driver Development
Guide, chapter named "Console Driver".
- Functions marked as deprecated (rtems_termios_open() and
  rtems_termios_close()) have been updated with the present-day versions.
- The legacy "callback" interface is replaced with the "handler" interface.
- Implementation is inspired by the documentation example, the non-driver
  manager driver for APBUART (apbuart_termios).
- Polled, interrupt and task mode is supported.
 c/src/lib/libbsp/sparc/shared/include/cons.h      |  12 +-
 c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c | 320 ++++++++++++++--------
 c/src/lib/libbsp/sparc/shared/uart/cons.c         | 105 ++-----
 3 files changed, 232 insertions(+), 205 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/cons.h b/c/src/lib/libbsp/sparc/shared/include/cons.h
index 4e095e5..9a26a26 100644
--- a/c/src/lib/libbsp/sparc/shared/include/cons.h
+++ b/c/src/lib/libbsp/sparc/shared/include/cons.h
@@ -16,22 +16,20 @@
 #ifndef __CONS_H__
 #define __CONS_H__
+#include <rtems/termiostypes.h>
 struct console_dev;
 #define CONSOLE_FLAG_SYSCON      0x01
-struct console_cons_ops {
-	void (*get_uart_attrs)(struct console_dev *, struct termios *t);
 struct console_dev {
-	/* Set to non-zero if this UART should be system console and/or
+	rtems_termios_device_context base;
+	/* Set to CONSOLE_FLAG_SYSCON if this UART should be system console and/or
 	 * debug console.
 	int flags;
 	char *fsname; /* File system prefix */
-	const struct rtems_termios_callbacks *callbacks; /* TERMIOS Callbacks */
-	struct console_cons_ops ops;
+	const rtems_termios_device_handler *handler;
 extern void console_dev_register(struct console_dev *dev);
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
index 50805f1..b070db5 100644
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
+++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
@@ -18,7 +18,6 @@
 /******************* Driver manager interface ***********************/
 #include <bsp.h>
-#include <rtems/libio.h>
 #include <assert.h>
 #include <rtems/bspIo.h>
@@ -55,23 +54,63 @@ struct apbuart_priv {
 	struct console_dev condev;
 	struct drvmgr_dev *dev;
 	struct apbuart_regs *regs;
+	struct rtems_termios_tty *tty;
 	char devName[32];
-	void *cookie;
-	int sending;
+	volatile int sending;
 	int mode;
+/* Getters for different interfaces. It happens to be just casting which we do
+ * in one place to avoid getting cast away. */
+static struct console_dev *base_get_condev(rtems_termios_device_context *base)
+	return (struct console_dev *) base;
+static struct apbuart_priv *condev_get_priv(struct console_dev *condev)
+	return (struct apbuart_priv *) condev;
+static struct apbuart_priv *base_get_priv(rtems_termios_device_context *base)
+	return condev_get_priv(base_get_condev(base));
 /* TERMIOS Layer Callback functions */
-void apbuart_get_attributes(struct console_dev *condev, struct termios *t);
-int apbuart_set_attributes(int minor, const struct termios *t);
-ssize_t apbuart_write_polled(int minor, const char *buf, size_t len);
-int apbuart_pollRead(int minor);
-ssize_t apbuart_write_intr(int minor, const char *buf, size_t len);
-int apbuart_pollRead_task(int minor);
-int apbuart_firstOpen(int major, int minor, void *arg);
-int apbuart_lastClose(int major, int minor, void *arg);
-void apbuart_isr(void *arg);
+static bool first_open(
+  rtems_termios_tty *tty,
+  rtems_termios_device_context *base,
+  struct termios *term,
+  rtems_libio_open_close_args_t *args
+static void last_close(
+static void write_interrupt(
+  const char *buf,
+  size_t len
+static bool set_attributes(
+	const struct termios *t
+static void get_attributes(
+	struct termios *t
+static int read_polled(rtems_termios_device_context *base);
+static int read_task(rtems_termios_device_context *base);
+static void write_polled(
+  const char *buf,
+  size_t len
+static void apbuart_cons_isr(void *arg);
 int apbuart_get_baud(struct apbuart_priv *uart);
 int apbuart_init1(struct drvmgr_dev *dev);
@@ -121,40 +160,30 @@ void apbuart_cons_register_drv (void)
 	drvmgr_drv_register(&apbuart_drv_info.general);
-/* Interrupt mode routines */
-static const rtems_termios_callbacks Callbacks_intr = {
-    apbuart_firstOpen,           /* firstOpen */
-    apbuart_lastClose,           /* lastClose */
-    NULL,                        /* pollRead */
-    apbuart_write_intr,          /* write */
-    apbuart_set_attributes,      /* setAttributes */
-    NULL,                        /* stopRemoteTx */
-    NULL,                        /* startRemoteTx */
-    TERMIOS_IRQ_DRIVEN           /* outputUsesInterrupts */
+static const rtems_termios_device_handler handler_interrupt = {
+	.first_open     = first_open,
+	.last_close     = last_close,
+	.write          = write_interrupt,
+	.set_attributes = set_attributes,
+	.mode           = TERMIOS_IRQ_DRIVEN
-/* Polling mode routines */
-static const rtems_termios_callbacks Callbacks_task = {
-    apbuart_pollRead_task,       /* pollRead */
-    TERMIOS_TASK_DRIVEN          /* outputUsesInterrupts */
+static const rtems_termios_device_handler handler_task = {
+	.poll_read      = read_task,
+	.mode           = TERMIOS_TASK_DRIVEN
-static const rtems_termios_callbacks Callbacks_poll = {
-    apbuart_pollRead,            /* pollRead */
-    apbuart_write_polled,        /* write */
-    TERMIOS_POLLED               /* outputUsesInterrupts */
+static const rtems_termios_device_handler handler_polled = {
+	.poll_read      = read_polled,
+	.write          = write_polled,
+	.mode           = TERMIOS_POLLED
@@ -247,7 +276,6 @@ int apbuart_init1(struct drvmgr_dev *dev)
 	priv->condev.fsname = NULL;
-	priv->condev.ops.get_uart_attrs = apbuart_get_attributes;
 	/* Select 0=Polled, 1=IRQ, 2=Task-Driven UART Mode */
 	value = drvmgr_dev_key_get(priv->dev, "mode", DRVMGR_KT_INT);
@@ -255,12 +283,13 @@ int apbuart_init1(struct drvmgr_dev *dev)
 		priv->mode = value->i;
 	else
 		priv->mode = TERMIOS_POLLED;
+	/* TERMIOS device handlers */
 	if (priv->mode == TERMIOS_IRQ_DRIVEN) {
-		priv->condev.callbacks = &Callbacks_intr;
+		priv->condev.handler = &handler_interrupt;
 	} else if (priv->mode == TERMIOS_TASK_DRIVEN) {
-		priv->condev.callbacks = &Callbacks_task;
+		priv->condev.handler = &handler_task;
 	} else {
-		priv->condev.callbacks = &Callbacks_poll;
+		priv->condev.handler = &handler_polled;
 	/* Get Filesystem name prefix */
@@ -367,39 +396,58 @@ int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
 #endif
-	struct apbuart_priv *uart = (struct apbuart_priv *)minor;
-	rtems_libio_open_close_args_t *ioarg = arg;
+	struct apbuart_priv *uart = base_get_priv(base);
-	if ( ioarg && ioarg->iop )
-		uart->cookie = ioarg->iop->data1;
-	else
-		uart->cookie = NULL;
+	uart->tty = tty;
+	/* Preserve values set by bootloader */
+	get_attributes(base, term);
+	term->c_oflag |= ONLCR;
+	set_attributes(base, term);
 	/* Enable TX/RX */
-	uart->regs->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
+	uart->regs->ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE;
 	if (uart->mode != TERMIOS_POLLED) {
+		int ret;
 		/* Register interrupt and enable it */
-		drvmgr_interrupt_register(uart->dev, 0, "apbuart",
-						apbuart_isr, uart);
+		ret = drvmgr_interrupt_register(
+			uart->dev, 0, "apbuart", apbuart_cons_isr, tty
+		if (ret) {
+			return false;
 		uart->sending = 0;
 		/* Turn on RX interrupts */
-		uart->regs->ctrl |= LEON_REG_UART_CTRL_RI;
+		uart->regs->ctrl |= APBUART_CTRL_RI;
-	return 0;
+	return true;
+	rtems_interrupt_lock_context lock_context;
 		/* Turn off RX interrupts */
-		uart->regs->ctrl &= ~(LEON_REG_UART_CTRL_RI);
+		rtems_termios_device_lock_acquire(base, &lock_context);
+		uart->regs->ctrl &= ~(APBUART_CTRL_RI);
+		rtems_termios_device_lock_release(base, &lock_context);
 		/**** Flush device ****/
 		while (uart->sending) {
@@ -407,42 +455,42 @@ int apbuart_lastClose(int major, int minor, void *arg)
 		/* Disable and unregister interrupt handler */
-		drvmgr_interrupt_unregister(uart->dev, 0, apbuart_isr, uart);
+		drvmgr_interrupt_unregister(uart->dev, 0, apbuart_cons_isr, tty);
 #ifdef LEON3
 	/* Disable TX/RX if not used for DEBUG */
 	if (uart->regs != dbg_uart)
-		uart->regs->ctrl &= ~(LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE);
+		uart->regs->ctrl &= ~(APBUART_CTRL_RE | APBUART_CTRL_TE);
 #endif
-	return 0;
 	return apbuart_inbyte_nonblocking(uart->regs);
 	int c, tot;
 	char buf[32];
+	tty = uart->tty;
 	tot = 0;
 	while ((c=apbuart_inbyte_nonblocking(uart->regs)) != EOF) {
 		buf[tot] = c;
 		tot++;
 		if (tot > 31) {
-			rtems_termios_enqueue_raw_characters(uart->cookie, buf, tot);
+			rtems_termios_enqueue_raw_characters(tty, buf, tot);
 			tot = 0;
 	if (tot > 0)
 	return EOF;
@@ -517,13 +565,17 @@ static struct apbuart_baud *apbuart_get_baud_closest(struct apbuart_priv *uart)
 	return apbuart_baud_find_closest(apbuart_get_baud(uart));
 	unsigned int core_clk_hz;
 	unsigned int scaler;
 	unsigned int ctrl;
 	int baud;
 	switch(t->c_cflag & CSIZE) {
 		default:
@@ -531,11 +583,13 @@ int apbuart_set_attributes(int minor, const struct termios *t)
 		case CS6:
 		case CS7:
 			/* Hardware doesn't support other than CS8 */
-			return -1;
+			return false;
 		case CS8:
 			break;
 	/* Read out current value */
 	ctrl = uart->regs->ctrl;
@@ -566,6 +620,8 @@ int apbuart_set_attributes(int minor, const struct termios *t)
 	/* Update new settings */
 	uart->regs->ctrl = ctrl;
 	/* Baud rate */
 	baud = apbuart_baud_num2baud(t->c_cflag & CBAUD);
 	if (baud > 0){
@@ -579,12 +635,15 @@ int apbuart_set_attributes(int minor, const struct termios *t)
 		uart->regs->scaler = scaler;
-	return 0;
+	return true;
+	struct termios *t
-	struct apbuart_priv *uart = (struct apbuart_priv *)condev;
 	unsigned int ctrl;
 	struct apbuart_baud *baud;
@@ -609,82 +668,109 @@ void apbuart_get_attributes(struct console_dev *condev, struct termios *t)
 	t->c_cflag |= baud->num;
+	const char *buf,
+	size_t len
 	int nwrite = 0;
 	while (nwrite < len) {
 		apbuart_outbyte_polled(uart->regs, *buf++, 0, 0);
 		nwrite++;
-	return nwrite;
+	const char *buf,
+	size_t len
-	unsigned int oldLevel;
+	struct apbuart_regs *regs = uart->regs;
+	int sending;
 	unsigned int ctrl;
-	rtems_interrupt_disable(oldLevel);
+	ctrl = regs->ctrl;
-	/* Enable TX interrupt */
-	ctrl = uart->regs->ctrl;
-	uart->regs->ctrl = ctrl | LEON_REG_UART_CTRL_TI;
-	if (ctrl & LEON_REG_UART_CTRL_FA) {
-		/* APBUART with FIFO.. Fill as many as FIFO allows */
-		uart->sending = 0;
-		while (((uart->regs->status & LEON_REG_UART_STATUS_TF) == 0) &&
-		       (uart->sending < len)) {
-			uart->regs->data = *buf;
-			buf++;
-			uart->sending++;
+	if (len > 0) {
+		 * sending is used to remember how much we have outstanding so
+		 * we can tell termios later.
+		/* Enable TX interrupt (interrupt is edge-triggered) */
+		regs->ctrl = ctrl | APBUART_CTRL_TI;
+		if (ctrl & APBUART_CTRL_FA) {
+			/* APBUART with FIFO.. Fill as many as FIFO allows */
+			sending = 0;
+			while (
+				((regs->status & APBUART_STATUS_TF) == 0) &&
+				(sending < len)
+				regs->data = *buf;
+				buf++;
+				sending++;
+		} else {
+			/* start UART TX, this will result in an interrupt when done */
+			sending = 1;
 	} else {
-		/* start UART TX, this will result in an interrupt when done */
+		/* No more to send, disable TX interrupts */
+		regs->ctrl = ctrl & ~APBUART_CTRL_TI;
-		uart->sending = 1;
+		/* Tell close that we sent everything */
+		sending = 0;
-	rtems_interrupt_enable(oldLevel);
-	return 0;
+	uart->sending = sending;
 /* Handle UART interrupts */
-	struct apbuart_priv *uart = arg;
+	rtems_termios_tty *tty = arg;
+	struct console_dev *condev = rtems_termios_get_device_context(tty);
+	struct apbuart_priv *uart = condev_get_priv(condev);
 	unsigned int status;
 	char data;
 	int cnt;
-	/* Get all received characters */
 	if (uart->mode == TERMIOS_TASK_DRIVEN) {
-		if ((status=uart->regs->status) & LEON_REG_UART_STATUS_DR)
-			rtems_termios_rxirq_occured(uart->cookie);
+		if ((status=regs->status) & APBUART_STATUS_DR) {
+			/* Activate termios RX daemon task */
+			rtems_termios_rxirq_occured(tty);
 	} else {
-		while ((status=uart->regs->status) & LEON_REG_UART_STATUS_DR) {
+		/* Get all received characters */
+		while ((status=regs->status) & APBUART_STATUS_DR) {
 			/* Data has arrived, get new data */
-			data = uart->regs->data;
+			data = regs->data;
 			/* Tell termios layer about new character */
-			rtems_termios_enqueue_raw_characters(uart->cookie, &data, 1);
+			rtems_termios_enqueue_raw_characters(tty, &data, 1);
-	if (uart->sending && (status & LEON_REG_UART_STATUS_THE)) {
-		/* Sent the one char, we disable TX interrupts */
-		uart->regs->ctrl &= ~LEON_REG_UART_CTRL_TI;
+	if (uart->sending && (status & APBUART_STATUS_TE)) {
 		cnt = uart->sending;
 		uart->sending = 0;
-		/* apbuart_write_intr() will get called from this function */
-		rtems_termios_dequeue_characters(uart->cookie, cnt);
+		 * Tell termios how much we have sent. dequeue() may call
+		 * write_interrupt() to refill the transmitter.
+		 * write_interrupt() will eventually be called with 0 len to
+		 * disable TX interrupts.
+		rtems_termios_dequeue_characters(tty, cnt);
diff --git a/c/src/lib/libbsp/sparc/shared/uart/cons.c b/c/src/lib/libbsp/sparc/shared/uart/cons.c
index 7d113b2..8426add 100644
--- a/c/src/lib/libbsp/sparc/shared/uart/cons.c
+++ b/c/src/lib/libbsp/sparc/shared/uart/cons.c
@@ -14,9 +14,8 @@
 #include <bsp.h>
-#include <rtems/bspIo.h>
 #include <bsp/cons.h>
+#include <rtems/console.h>
 #ifdef RTEMS_DRVMGR_STARTUP
@@ -26,25 +25,26 @@
  * handle interrupts.
-int console_initialized = 0;
-rtems_device_major_number console_major = 0;
+static int console_initialized = 0;
 #define FLAG_SYSCON 0x01
 struct console_priv {
-	unsigned char flags; /* 0x1=SystemConsole */
-	unsigned char minor;
+	int flags; /* 0x1=SystemConsole */
+	int minor;
 	struct console_dev *dev;
 #define CONSOLE_MAX BSP_NUMBER_OF_TERMIOS_PORTS
 struct console_priv cons[CONSOLE_MAX] = {{0,0},};
-/* Register Console to TERMIOS layer and initialize it */
-static void console_dev_init(struct console_priv *con, int minor)
+/* Install Console in TERMIOS layer */
+static void console_dev_init(struct console_priv *con)
 	char name[16], *fsname;
 	rtems_status_code status;
+	int minor;
+	minor = con->minor;
 	if (!con->dev->fsname) {
 		strcpy(name, "/dev/console_a");
 		/* Special console name and MINOR for SYSTEM CONSOLE */
@@ -55,11 +55,18 @@ static void console_dev_init(struct console_priv *con, int minor)
 	} else {
 		fsname = con->dev->fsname;
-	status = rtems_io_register_name(fsname, console_major, minor);
-	if ((minor == 0) && (status != RTEMS_SUCCESSFUL))
+	status = rtems_termios_device_install(
+		fsname,
+		con->dev->handler,
+		NULL,
+		&con->dev->base
+	if (status != RTEMS_SUCCESSFUL) {
 		rtems_fatal_error_occurred(status);
+/* Called by device driver to register itself to the cons interface. */
 	int i, minor = 0;
@@ -87,11 +94,12 @@ void console_dev_register(struct console_dev *dev)
 	con->dev = dev;
 	con->minor = minor;
-	/* Console layer is already initialized, that means that we can
-	 * register termios interface directly.
-	if (console_initialized)
-		console_dev_init(con, minor);
+	if (console_initialized) {
+		/* Console layer is already initialized, that means that we can
+		 * register termios interface directly.
+		console_dev_init(con);
 #if 0
@@ -108,14 +116,12 @@ rtems_device_driver console_initialize(
 	int i;
-	console_major = major;
 	rtems_termios_initialize();
 	/* Register all Console a file system device node */
 	for (i=0; i<CONSOLE_MAX; i++) {
 		if (cons[i].dev)
-			console_dev_init(&cons[i], i);
+			console_dev_init(&cons[i]);
 	console_initialized = 1;
@@ -123,67 +129,4 @@ rtems_device_driver console_initialize(
 	return RTEMS_SUCCESSFUL;
-rtems_device_driver console_open(
-	rtems_device_major_number	major,
-	rtems_device_minor_number	minor,
-	void				*arg)
-	rtems_status_code status;
-	struct termios term;
-	if ((minor >= CONSOLE_MAX) || !cons[minor].dev)
-		return RTEMS_INVALID_NUMBER;
-	status = rtems_termios_open(
-			major,
-			(int)cons[minor].dev,
-			arg,
-			cons[minor].dev->callbacks);
-	/* Inherit UART hardware parameters from bootloader on system console */
-	if ((status == RTEMS_SUCCESSFUL) && (cons[minor].flags & FLAG_SYSCON) &&
-	    (cons[minor].dev->ops.get_uart_attrs != NULL)) {
-		if (tcgetattr(STDIN_FILENO, &term) >= 0) {
-			cons[minor].dev->ops.get_uart_attrs(cons[minor].dev,
-								&term);
-			term.c_oflag |= ONLCR;
-			tcsetattr(STDIN_FILENO, TCSANOW, &term);
-	return status;
-rtems_device_driver console_close(
-	void				*arg)
-	return rtems_termios_close(arg);
-rtems_device_driver console_read(
-	void				*arg)
-	return rtems_termios_read(arg);
-rtems_device_driver console_write(
-	void				*arg)
-	return rtems_termios_write(arg);
-rtems_device_driver console_control(
-	void				*arg)
-	return rtems_termios_ioctl(arg);
 #endif
2.7.4
