[PATCH 15/30] leon, grpci2: Make driver SMP safe
Daniel Hellstrom daniel at gaisler.com
Thu Apr 13 19:31:24 UTC 2017
 c/src/lib/libbsp/sparc/shared/pci/grpci2.c | 57 ++++++++++++++++++++++--------
 1 file changed, 42 insertions(+), 15 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
index be459cc..7556f68 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
@@ -41,17 +41,39 @@
 #include <ambapp.h>
 #include <drvmgr/pci_bus.h>
 #include <bsp/grpci2.h>
+#include <rtems/rtems/intr.h>
-#ifndef IRQ_GLOBAL_PREPARE
- #define IRQ_GLOBAL_PREPARE(level) rtems_interrupt_level level
-#endif
+/* Use interrupt lock privmitives compatible with SMP defined in
+ * RTEMS 4.11.99 and higher.
+#if (((__RTEMS_MAJOR__ << 16) | (__RTEMS_MINOR__ << 8) | __RTEMS_REVISION__) >= 0x040b63)
+#include <rtems/score/isrlock.h> /* spin-lock */
+/* map via ISR lock: */
+#define SPIN_DECLARE(lock) ISR_LOCK_MEMBER(lock)
+#define SPIN_INIT(lock, name) _ISR_lock_Initialize(lock, name)
+#define SPIN_LOCK(lock, level) _ISR_lock_Acquire_inline(lock, &level)
+#define SPIN_LOCK_IRQ(lock, level) _ISR_lock_ISR_disable_and_acquire(lock, &level)
+#define SPIN_UNLOCK(lock, level) _ISR_lock_Release_inline(lock, &level)
+#define SPIN_UNLOCK_IRQ(lock, level) _ISR_lock_Release_and_ISR_enable(lock, &level)
+#define SPIN_IRQFLAGS(k) ISR_lock_Context k
+#define SPIN_ISR_IRQFLAGS(k) SPIN_IRQFLAGS(k)
-#ifndef IRQ_GLOBAL_DISABLE
- #define IRQ_GLOBAL_DISABLE(level) rtems_interrupt_disable(level)
-#endif
+#else
-#ifndef IRQ_GLOBAL_ENABLE
- #define IRQ_GLOBAL_ENABLE(level) rtems_interrupt_enable(level)
+/* maintain single-core compatibility with older versions of RTEMS: */
+#define SPIN_DECLARE(name)
+#define SPIN_LOCK_IRQ(lock, level) rtems_interrupt_disable(level)
+#define SPIN_UNLOCK_IRQ(lock, level) rtems_interrupt_enable(level)
+#define SPIN_IRQFLAGS(k) rtems_interrupt_level k
+#ifdef RTEMS_SMP
+#error SMP mode not compatible with these interrupt lock primitives
+#endif
 #endif
 /* If defined to 1 - byte twisting is enabled by default */
@@ -233,7 +255,7 @@ struct grpci2_pcibar_cfg grpci2_default_bar_mapping[6] = {
 /* Driver private data struture */
 struct grpci2_priv {
-	struct drvmgr_dev	*dev;
+	struct drvmgr_dev		*dev;
 	struct grpci2_regs		*regs;
 	unsigned char			ver;
 	char				irq;
@@ -255,6 +277,8 @@ struct grpci2_priv {
 	struct drvmgr_map_entry		maps_up[7];
 	struct drvmgr_map_entry		maps_down[2];
 	struct pcibus_config		config;
+	SPIN_DECLARE(devlock)
 int grpci2_init1(struct drvmgr_dev *dev);
@@ -304,8 +328,8 @@ static int grpci2_cfg_r32(pci_dev_t dev, int ofs, uint32_t *val)
 	struct grpci2_priv *priv = grpci2priv;
 	volatile uint32_t *pci_conf;
 	unsigned int tmp, devfn;
-	IRQ_GLOBAL_PREPARE(oldLevel);
 	int retval, bus = PCI_DEV_BUS(dev);
+	SPIN_IRQFLAGS(irqflags);
 	if ((unsigned int)ofs & 0xffffff03) {
 		retval = PCISTS_EINVAL;
@@ -329,7 +353,7 @@ static int grpci2_cfg_r32(pci_dev_t dev, int ofs, uint32_t *val)
 	pci_conf = (volatile uint32_t *) (priv->pci_conf | (devfn << 8) | ofs);
-	IRQ_GLOBAL_DISABLE(oldLevel); /* protect regs */
+	SPIN_LOCK_IRQ(&priv->devlock, irqflags);
 	/* Select bus */
 	priv->regs->ctrl = (priv->regs->ctrl & ~(0xff<<16)) | (bus<<16);
@@ -352,7 +376,7 @@ static int grpci2_cfg_r32(pci_dev_t dev, int ofs, uint32_t *val)
 		retval = PCISTS_OK;
-	IRQ_GLOBAL_ENABLE(oldLevel);
+	SPIN_UNLOCK_IRQ(&priv->devlock, irqflags);
 out:
 	if (retval != PCISTS_OK)
@@ -397,7 +421,7 @@ static int grpci2_cfg_w32(pci_dev_t dev, int ofs, uint32_t val)
 	uint32_t value, devfn;
 		return PCISTS_EINVAL;
@@ -419,7 +443,7 @@ static int grpci2_cfg_w32(pci_dev_t dev, int ofs, uint32_t val)
 	/* Select bus */
@@ -439,7 +463,7 @@ static int grpci2_cfg_w32(pci_dev_t dev, int ofs, uint32_t val)
 	else
 		retval = PCISTS_OK;
 	DBG("pci_write - [%x:%x:%x] reg: 0x%x => addr: 0x%x, val: 0x%x  (%d)\n",
 		PCI_DEV_EXPAND(dev), ofs, pci_conf, value, retval);
@@ -745,6 +769,9 @@ static int grpci2_init(struct grpci2_priv *priv)
 	priv->irq_mode = (priv->regs->sts_cap & STS_IRQMODE) >> STS_IRQMODE_BIT;
 	priv->latency_timer = DEFAULT_LATENCY_TIMER;
+	/* Initialize Spin-lock for GRPCI2 Device. */
+	SPIN_INIT(&priv->devlock, "grpci2");
 	/* Calculate the PCI windows
 	 *  AMBA->PCI Window:                       AHB SLAVE AREA0
 	 *  AMBA->PCI I/O cycles Window:            AHB SLAVE AREA1 Lower half
2.7.4
