[PATCH 17/30] leon, grpci2dma: add GR740 PCI DMA driver
Daniel Hellstrom daniel at gaisler.com
Thu Apr 13 19:31:26 UTC 2017
 c/src/lib/libbsp/sparc/Makefile.am                |    2 +
 c/src/lib/libbsp/sparc/leon2/Makefile.am          |    2 +
 c/src/lib/libbsp/sparc/leon2/preinstall.am        |    4 +
 c/src/lib/libbsp/sparc/leon3/Makefile.am          |    2 +
 c/src/lib/libbsp/sparc/leon3/preinstall.am        |    4 +
 c/src/lib/libbsp/sparc/shared/include/grpci2dma.h |  263 +++
 c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c     | 2060 +++++++++++++++++++++
 7 files changed, 2337 insertions(+)
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/grpci2dma.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index f75790a..0691dd4 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -42,9 +42,11 @@ EXTRA_DIST += shared/timer/tlib_ckinit.c
 # PCI bus
 EXTRA_DIST += shared/include/grpci.h
 EXTRA_DIST += shared/include/grpci2.h
+EXTRA_DIST += shared/include/grpci2dma.h
 EXTRA_DIST += shared/include/pcif.h
 EXTRA_DIST += shared/pci/grpci.c
 EXTRA_DIST += shared/pci/grpci2.c
+EXTRA_DIST += shared/pci/grpci2dma.c
 EXTRA_DIST += shared/pci/pcif.c
 EXTRA_DIST += shared/pci/pci_memreg_sparc_le.c
 EXTRA_DIST += shared/pci/pci_memreg_sparc_be.c
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index bafa626..8e424d8 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -96,9 +96,11 @@ libbsp_a_SOURCES += ../../sparc/shared/timer/tlib.c
 # PCI
 include_bsp_HEADERS += ../../sparc/shared/include/grpci.h
 include_bsp_HEADERS += ../../sparc/shared/include/grpci2.h
+include_bsp_HEADERS += ../../sparc/shared/include/grpci2dma.h
 include_bsp_HEADERS += ../../sparc/shared/include/pcif.h
 include_bsp_HEADERS += include/at697_pci.h
 libbsp_a_SOURCES += ../../sparc/shared/pci/grpci2.c
+libbsp_a_SOURCES += ../../sparc/shared/pci/grpci2dma.c
 libbsp_a_SOURCES += ../../sparc/shared/pci/grpci.c
 libbsp_a_SOURCES += ../../sparc/shared/pci/pcif.c
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/pci_memreg_sparc_le.c
diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
index 873cc17..f249c3c 100644
--- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
@@ -129,6 +129,10 @@ $(PROJECT_INCLUDE)/bsp/grpci2.h: ../../sparc/shared/include/grpci2.h $(PROJECT_I
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/grpci2.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/grpci2.h
+$(PROJECT_INCLUDE)/bsp/grpci2dma.h: ../../sparc/shared/include/grpci2dma.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/grpci2dma.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/grpci2dma.h
 $(PROJECT_INCLUDE)/bsp/pcif.h: ../../sparc/shared/include/pcif.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/pcif.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/pcif.h
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 9a4737c..fe17bf0 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -109,9 +109,11 @@ libbsp_a_SOURCES += \
 # PCI
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/pci_memreg_sparc_be.c
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index d9bdf35..b517758 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -149,6 +149,10 @@ $(PROJECT_INCLUDE)/bsp/grpci2.h: ../../sparc/shared/include/grpci2.h $(PROJECT_I
diff --git a/c/src/lib/libbsp/sparc/shared/include/grpci2dma.h b/c/src/lib/libbsp/sparc/shared/include/grpci2dma.h
new file mode 100644
index 0000000..c1a2663
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/grpci2dma.h
@@ -0,0 +1,263 @@
+ *  GRPCI2 DMA Driver
+ *  COPYRIGHT (c) 2017
+ *  Cobham Gaisler AB
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+ *  OVERVIEW
+ *  This driver controls the DMA on the GRPCI2 device, located
+ *  at an on-chip AMBA.
+#ifndef __GRPCI2DMA_H__
+#define __GRPCI2DMA_H__
+#include <stdint.h>
+#include <stdio.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Error return codes */
+#define GRPCI2DMA_ERR_OK 0
+#define GRPCI2DMA_ERR_WRONGPTR -1
+#define GRPCI2DMA_ERR_NOINIT -2
+#define GRPCI2DMA_ERR_TOOMANY -3
+#define GRPCI2DMA_ERR_ERROR -4
+#define GRPCI2DMA_ERR_STOPDMA -5
+#define GRPCI2DMA_ERR_NOTFOUND -6
+/* Size of a dma descriptors */
+#define GRPCI2DMA_BD_CHAN_SIZE 0x10
+#define GRPCI2DMA_BD_DATA_SIZE 0x10
+/* Alignment of dma descriptors */
+#define GRPCI2DMA_BD_CHAN_ALIGN 0x10
+#define GRPCI2DMA_BD_DATA_ALIGN 0x10
+/* User-helper functions to allocate/deallocate
+ * channel and data descriptors
+extern void * grpci2dma_channel_new(int number);
+extern void grpci2dma_channel_delete(void * chanbd);
+extern void * grpci2dma_data_new(int number);
+extern void grpci2dma_data_delete(void * databd);
+/* Function:
+ *  -grpci2dma_prepare
+ * Description:
+ *  -Prepare a transfer, initializing the required data descriptors
+ * Parameters:
+ *  -pci_start: Where in PCI/remote starts the transfer
+ *  -ahb_start: Where in AHB/local starts the transfer
+ *  -dir: Direction of the transfer (AHBTOPCI or PCITOAHB)
+ *  -endianness: Endianness of the transfer (LITTLEENDIAN or BIGENDIAN)
+ *  -size: Size in bytes of the transfer (the function will calculate if there
+ *  are enough descriptors)
+ *  -databd: Pointer to the data descriptor buffer
+ *  -bdindex: Where in the buffer to start the transfer
+ *  -bdmax: Maximum index for the data descriptor buffer
+ *  -block_size: Size in bytes for each PCI transaction (or block). Guaranteed
+ *  to be at least smaller that this value. Put 0 to use default.
+ *  Default is maximum, which is 0x10000*4 bytes.
+ * Returns:
+ *  -WRONGPTR: Wrong input parameters
+ *  -TOOMANY: Not enough data descriptors in the buffer
+ *  -value > 0: A positive return value means the number of data descriptors
+ *  prepared/used in the buffer, starting from index.
+#define GRPCI2DMA_AHBTOPCI 1
+#define GRPCI2DMA_PCITOAHB 0
+#define GRPCI2DMA_LITTLEENDIAN 1
+#define GRPCI2DMA_BIGENDIAN 0
+extern int grpci2dma_prepare(
+        uint32_t pci_start, uint32_t ahb_start, int dir, int endianness,
+        int size, void * databd, int bdindex, int bdmax, int block_size);
+/* Function:
+ *  -grpci2dma_status
+ * Description:
+ *  -Status of an transfer:
+ * Parameters:
+ *  -bdindex: Where in the buffer starts the transfer
+ *  -bdsize: Number of descriptors used by the transfer
+ * Returns:
+ *  -GRPCI2DMA_BD_DATA_STATUS_ERR: If at least one of the descriptors has an
+ *  error
+ *  -GRPCI2DMA_BD_DATA_STATUS_ENABLED: If at least one of the descriptors is
+ *  enabled, which means that the transfer is still not finished.
+ *  -GRPCI2DMA_BD_DATA_STATUS_DISABLED: If all the descriptors are disabled,
+ *  which means that either the transfer finished or it was never prepared.
+#define GRPCI2DMA_BD_STATUS_DISABLED 0
+#define GRPCI2DMA_BD_STATUS_ENABLED 1
+#define GRPCI2DMA_BD_STATUS_ERR 2
+extern int grpci2dma_status(void *databd, int bdindex, int bdsize);
+/* Function Interrupt-Code ISR callback prototype.
+ * arg     - Custom arg provided by user
+ * cid     - Channel ID that got the interrupt
+ * status  - Error status of the DMA core
+typedef void (*grpci2dma_isr_t)(void *arg, int cid, unsigned int status);
+/* Function:
+ *  -grpci2dma_isr_register
+ * Description:
+ *  -Register an ISR for a channel (and enable interrupts if disabled)
+ * Parameters:
+ *  -chan_no: ID of the channel
+ *  -dmaisr: ISR
+ *  -arg: Argument to pass to the ISR when called
+ * Returns:
+ *  -NOINIT: GRPCI2 DMA not initialized
+ *  -OK (=0): Done
+extern int grpci2dma_isr_register(
+        int chan_no, grpci2dma_isr_t dmaisr, void *arg);
+/* Function:
+ *  -grpci2dma_isr_unregister
+ * Description:
+ *  -Unregister an ISR for a channel (and enable interrupts if disabled)
+ * Parameters:
+ * Returns:
+ *  -OK (=0): Done
+extern int grpci2dma_isr_unregister(int chan_no);
+/* Function:
+ *  -grpci2dma_open
+ * Description:
+ *  -Open a channel (and allocate the descriptor if the user does not provide
+ *  one).
+ * Parameters:
+ *  -chan: Descriptor for the channel (must be aligned to 0x10)
+ * Returns:
+ *  -TOOMANY: Maximum number of channels already opened.
+ *  -ERROR: Inconsistent state found in driver
+ *  -value > 0: A positive return value means the id for the channel.
+extern int grpci2dma_open(void * chan);
+/* Function:
+ *  -grpci2dma_close
+ * Description:
+ *  -Stop and close a channel (and deallocate it if the user did not provide a
+ *  pointer when opening it)
+ * Parameters:
+ *  -chan_no: Id of the channel
+ * Returns:
+ *  -NOTFOUND: Channel not opened.
+ *  -STOPDMA: Cannot stop channel.
+ *  -OK (=0): Done.
+extern int grpci2dma_close(int chan_no);
+/* Function:
+ *  -grpci2dma_start
+ * Description:
+ *  -Start a channel
+ * Parameters:
+ *  -options: Maximum number of data descriptors to be executed before moving
+ *  to next channel (up to 0x10000)
+ * Returns:
+ *  -OK (=0): Done.
+extern int grpci2dma_start(int chan_no, int options);
+/* Function:
+ *  -grpci2dma_stop
+ * Description:
+ * Parameters:
+ * Returns:
+ *  -OK (=0): Done.
+extern int grpci2dma_stop(int chan_no);
+/* Function:
+ *  -grpci2dma_push
+ * Description:
+ *  -Push a transfer into a channel (already started or not)
+ * Parameters:
+ * Returns:
+ *  -OK (=0): Done.
+extern int grpci2dma_push(int chan_no, void *databd, int bdindex, int bdsize);
+/* Function:
+ *  -grpci2dma_active
+ * Description:
+ *  -Check if dma is active
+ * Parameters:
+ * Returns:
+ *  -(!=0): Active.
+ *  -(=0): Not active.
+extern int grpci2dma_active(void);
+/* Function:
+ *  -grpci2dma_interrupt_enable
+ * Description:
+ *  -Enable interrupt for a transfer
+ * Parameters:
+ *  -bdmax: Upper limit for index. index < bdmax
+ *  -options:
+ *      (=GRPCI2DMA_OPTIONS_ALL)=Enable interrupt on all transfer descriptors.
+ *      (=GRPCI2DMA_OPTIONS_ONE)=Enable interrupt on transfer descriptor
+ *              indicated by bdindex.
+ * Returns:
+ *  -OK (=0): Done.
+#define GRPCI2DMA_OPTIONS_ALL 1
+#define GRPCI2DMA_OPTIONS_ONE 0
+extern int grpci2dma_interrupt_enable(
+        void *databd, int bdindex, int bdmax, int options);
+/* Debug function: print dma channel and associated data descriptors.
+ * Only prints if driver internal DEBUG flag is defined. */
+extern int grpci2dma_print(int chan_no);
+extern int grpci2dma_print_bd(void * data);
+#ifdef __cplusplus
+#endif
+#endif /* __GRPCI2DMA_H__ */
diff --git a/c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c b/c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c
index 0000000..558f680
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c
@@ -0,0 +1,2060 @@
+#include <stdlib.h>
+#include <stddef.h>
+#include <drvmgr/drvmgr.h>
+#include <rtems.h>
+#include <rtems/bspIo.h>  /* for printk */
+#include <bsp.h>
+#include <bsp/grpci2dma.h>
+/* This driver has been prepared for SMP operation
+/* Use interrupt lock privmitives compatible with SMP defined in
+ * RTEMS 4.11.99 and higher.
+#if (((__RTEMS_MAJOR__ << 16) | (__RTEMS_MINOR__ << 8) | __RTEMS_REVISION__) >= 0x040b63)
+#include <rtems/score/isrlock.h> /* spin-lock */
+/* map via ISR lock: */
+#define SPIN_DECLARE(lock) ISR_LOCK_MEMBER(lock)
+#define SPIN_INIT(lock, name) _ISR_lock_Initialize(lock, name)
+#define SPIN_LOCK(lock, level) _ISR_lock_Acquire_inline(lock, &level)
+#define SPIN_LOCK_IRQ(lock, level) _ISR_lock_ISR_disable_and_acquire(lock, &level)
+#define SPIN_UNLOCK(lock, level) _ISR_lock_Release_inline(lock, &level)
+#define SPIN_UNLOCK_IRQ(lock, level) _ISR_lock_Release_and_ISR_enable(lock, &level)
+#define SPIN_IRQFLAGS(k) ISR_lock_Context k
+#define SPIN_ISR_IRQFLAGS(k) SPIN_IRQFLAGS(k)
+#else
+/* maintain single-core compatibility with older versions of RTEMS: */
+#define SPIN_DECLARE(name)
+#define SPIN_LOCK_IRQ(lock, level) rtems_interrupt_disable(level)
+#define SPIN_UNLOCK_IRQ(lock, level) rtems_interrupt_enable(level)
+#define SPIN_IRQFLAGS(k) rtems_interrupt_level k
+#ifdef RTEMS_SMP
+#error SMP mode not compatible with these interrupt lock primitives
+#endif
+#endif
+/*#define STATIC*/
+#define STATIC static
+/*#define INLINE*/
+#define INLINE inline
+/*#define UNUSED*/
+#define UNUSED __attribute__((unused))
+/*#define DEBUG 1*/
+#ifdef DEBUG
+#define DBG(x...) printf(x)
+#else
+#define DBG(x...)
+#endif
+#define BD_CHAN_EN (1<<BD_CHAN_EN_BIT)
+#define BD_CHAN_ID (0x3<<BD_CHAN_ID_BIT)
+#define BD_CHAN_TYPE (0x3<<BD_CHAN_TYPE_BIT)
+#define BD_CHAN_TYPE_DMA (0x1<<BD_CHAN_TYPE_BIT)
+#define BD_CHAN_BDCNT (0xffff<<BD_CHAN_BDCNT_BIT)
+#define BD_CHAN_EN_BIT 31
+#define BD_CHAN_ID_BIT 22
+#define BD_CHAN_TYPE_BIT 20
+#define BD_CHAN_BDCNT_BIT 0
+#define BD_DATA_EN (0x1<<BD_DATA_EN_BIT)
+#define BD_DATA_IE (0x1<<BD_DATA_IE_BIT)
+#define BD_DATA_DR (0x1<<BD_DATA_DR_BIT)
+#define BD_DATA_BE (0x1<<BD_DATA_BE_BIT)
+#define BD_DATA_TYPE (0x3<<BD_DATA_TYPE_BIT)
+#define BD_DATA_TYPE_DATA (0x0<<BD_DATA_TYPE_BIT)
+#define BD_DATA_ER (0x1<<BD_DATA_ER_BIT)
+#define BD_DATA_LEN (0xffff<<BD_DATA_LEN_BIT)
+#define BD_DATA_EN_BIT 31
+#define BD_DATA_IE_BIT 30
+#define BD_DATA_DR_BIT 29
+#define BD_DATA_BE_BIT 28
+#define BD_DATA_TYPE_BIT 20
+#define BD_DATA_ER_BIT 19
+#define BD_DATA_LEN_BIT 0
+#define DMACTRL_SAFE (0x1<<DMACTRL_SAFE_BIT)
+#define DMACTRL_WCLEAR (0x1fff<<DMACTRL_ERR_BIT)
+#define DMACTRL_ERR (0x1f<<DMACTRL_ERR_BIT)
+#define DMACTRL_CHIRQ (0xff<<DMACTRL_CHIRQ_BIT)
+#define DMACTRL_NUMCH (0x7<<DMACTRL_NUMCH_BIT)
+#define DMACTRL_DIS (0x1<<DMACTRL_DIS_BIT)
+#define DMACTRL_IE (0x1<<DMACTRL_IE_BIT)
+#define DMACTRL_ACT (0x1<<DMACTRL_ACT_BIT)
+#define DMACTRL_EN (0x1<<DMACTRL_EN_BIT)
+#define DMACTRL_SAFE_BIT 31
+#define DMACTRL_CHIRQ_BIT 12
+#define DMACTRL_ERR_BIT 7
+#define DMACTRL_NUMCH_BIT 4
+#define DMACTRL_DIS_BIT 2
+#define DMACTRL_IE_BIT 1
+#define DMACTRL_ACT_BIT 3
+#define DMACTRL_EN_BIT 0
+/* GRPCI2 DMA does not allow more than 8 DMA chans */
+#define MAX_DMA_CHANS 8
+/* GRPCI2 DMA does not allow transfer of more than 0x10000 words */
+#define MAX_DMA_TRANSFER_SIZE (0x10000*4)
+/* We use the following limits as default */
+#define MAX_DMA_DATA 128
+/* Memory and HW Registers Access routines. All 32-bit access routines */
+#define BD_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (unsigned int)(val))
+/*#define BD_READ(addr) (*(volatile unsigned int *)(addr))*/
+#define BD_READ(addr) leon_r32_no_cache((unsigned long)(addr))
+#define REG_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (unsigned int)(val))
+#define REG_READ(addr) (*(volatile unsigned int *)(addr))
+ * GRPCI2 DMA Channel descriptor
+struct grpci2_bd_chan {
+	volatile unsigned int ctrl;	/* 0x00 DMA Control */
+	volatile unsigned int nchan;	/* 0x04 Next DMA Channel Address */
+	volatile unsigned int nbd;	/* 0x08 Next Data Descriptor in channel */
+	volatile unsigned int res;	/* 0x0C Reserved */
+ * GRPCI2 DMA Data descriptor
+struct grpci2_bd_data {
+	volatile unsigned int ctrl;	/* 0x00 DMA Data Control */
+	volatile unsigned int pci_adr;	/* 0x04 PCI Start Address */
+	volatile unsigned int ahb_adr;	/* 0x08 AHB Start address */
+	volatile unsigned int next;	/* 0x0C Next Data Descriptor in channel */
+ * GRPCI2 DMA APB Register MAP
+struct grpci2dma_regs {
+	volatile unsigned int dma_ctrl;		/* 0x00 */
+	volatile unsigned int dma_bdbase;	/* 0x04 */
+	volatile unsigned int dma_chact;	/* 0x08 */
+#define DEVNAME_LEN 11
+ * GRPCI2 DMA Driver private data struture
+struct grpci2dma_priv {
+	/* DMA control registers */
+	struct grpci2dma_regs	*regs;
+	char devname[DEVNAME_LEN];
+	/* Channel info */
+	struct {
+		/* Channel pointer. Indicates the assigned channel
+		 * for a given cid (used as index). NULL if not assigned.
+		struct grpci2_bd_chan * ptr;
+		/* Is this channel allocated by the driver */
+		int allocated;
+		/* Last added data descriptor for each channel.
+		 * This simplifies/speeds up adding data descriptors
+		 * to the channel*/
+		struct grpci2_bd_data * lastdata;
+		/* Is this channel active */
+		int active;
+		/* Interrupt-code Handling
+		 * - isr: Holds the ISR for each channel
+		 * - isr_arg: Holds the ISR arg for each channel
+		grpci2dma_isr_t isr;
+		void * isr_arg;
+		/* DMA Channel Semaphore */
+		rtems_id sem;
+	} channel[MAX_DMA_CHANS];
+	/* Indicates the number of channels. */
+	int nchans;
+	/* Indicates the number of active channels. */
+	int nactive;
+	/* Indicates if the number of DMA ISR that have been registered
+	 * into the GRPCI2 DRIVER */
+	int isr_registered;
+	/* Callback to register the DMA ISR into the GRPCI2 DRIVER */
+	void (*isr_register)( void (*isr)(void*), void * arg);
+	/* Spin-lock ISR protection */
+	SPIN_DECLARE(devlock);
+/* The GRPCI2 DMA semaphore */
+rtems_id grpci2dma_sem;
+ * GRPCI2 DMA internal prototypes
+/* -Descriptor linked-list functions*/
+STATIC int grpci2dma_channel_list_add(struct grpci2_bd_chan * list,
+		struct grpci2_bd_chan * chan);
+STATIC int grpci2dma_channel_list_remove(struct grpci2_bd_chan * chan);
+STATIC int grpci2dma_data_list_add(struct grpci2_bd_chan * chan,
+		struct grpci2_bd_data * data, struct grpci2_bd_data * last_chan_data);
+STATIC int grpci2dma_data_list_remove(struct grpci2_bd_chan * chan,
+		struct grpci2_bd_data * data);
+STATIC int grpci2dma_channel_list_foreach(struct grpci2_bd_chan * chan,
+		int func( struct grpci2_bd_chan * chan), int maxindex);
+STATIC int grpci2dma_data_list_foreach(struct grpci2_bd_data * data,
+		int func( struct grpci2_bd_data * data), int maxindex);
+/* -DMA ctrl access functions */
+STATIC INLINE int grpci2dma_ctrl_init(void);
+STATIC INLINE int grpci2dma_ctrl_start(struct grpci2_bd_chan * chan);
+STATIC INLINE int grpci2dma_ctrl_stop(void);
+STATIC INLINE int grpci2dma_ctrl_resume(void);
+STATIC INLINE unsigned int grpci2dma_ctrl_status(void);
+STATIC INLINE unsigned int grpci2dma_ctrl_base(void);
+STATIC INLINE unsigned int grpci2dma_ctrl_active(void);
+STATIC INLINE int grpci2dma_ctrl_numch_set(int numch);
+STATIC INLINE int grpci2dma_ctrl_interrupt_status(void);
+STATIC INLINE int grpci2dma_ctrl_interrupt_enable(void);
+STATIC INLINE int grpci2dma_ctrl_interrupt_disable(void);
+STATIC INLINE int grpci2dma_ctrl_interrupt_clear(void);
+/* -Descriptor access functions */
+STATIC int grpci2dma_channel_bd_init(struct grpci2_bd_chan * chan);
+STATIC int grpci2dma_data_bd_init(struct grpci2_bd_data * data,
+		uint32_t pci_adr, uint32_t ahb_adr, int dir, int endianness,
+		int size, struct grpci2_bd_data * next);
+STATIC int grpci2dma_channel_bd_enable(struct grpci2_bd_chan * chan,
+		unsigned int options);
+STATIC int grpci2dma_channel_bd_disable(struct grpci2_bd_chan * chan);
+STATIC void grpci2dma_channel_bd_set_cid(struct grpci2_bd_chan * chan,
+		int cid);
+STATIC int grpci2dma_channel_bd_get_cid(struct grpci2_bd_chan * chan);
+STATIC int grpci2dma_data_bd_status(struct grpci2_bd_data *data);
+STATIC int grpci2dma_data_bd_disable(struct grpci2_bd_data *desc);
+STATIC int grpci2dma_data_bd_interrupt_enable(struct grpci2_bd_data * data);
+STATIC struct grpci2_bd_data * grpci2dma_channel_bd_get_data(
+STATIC void grpci2dma_channel_bd_set_data(struct grpci2_bd_chan * chan,
+STATIC struct grpci2_bd_chan * grpci2dma_channel_bd_get_next(
+STATIC struct grpci2_bd_data * grpci2dma_data_bd_get_next(
+STATIC void grpci2dma_channel_bd_set_next(struct grpci2_bd_chan * chan,
+		struct grpci2_bd_chan * next);
+STATIC void grpci2dma_data_bd_set_next(struct grpci2_bd_data * data,
+		struct grpci2_bd_data * next);
+/* -Channel functions */
+STATIC int grpci2dma_channel_open(struct grpci2_bd_chan * chan, int cid);
+STATIC int grpci2dma_channel_free_id(void);
+STATIC struct grpci2_bd_chan * grpci2dma_channel_get_active_list(void);
+STATIC int grpci2dma_channel_start(int chan_no, int options);
+STATIC int grpci2dma_channel_stop(int chan_no);
+STATIC int grpci2dma_channel_push(int chan_no, void *dataptr, int index,
+		int ndata);
+STATIC int grpci2dma_channel_close(int chan_no);
+STATIC int grpci2dma_channel_isr_unregister(int chan_no);
+/* -ISR functions*/
+STATIC void grpci2dma_isr(void *arg);
+/* -Init function called by GRPCI2*/
+int grpci2dma_init(void * regs,
+		void isr_register( void (*isr)(void*), void * arg));
+#ifdef DEBUG
+STATIC int grpci2dma_channel_print(struct grpci2_bd_chan * chan);
+STATIC int grpci2dma_data_print(struct grpci2_bd_data * data);
+#endif
+static struct grpci2dma_priv *grpci2dmapriv = NULL;
+/* All data linked list must point to a disabled descriptor at the end.
+ * We use this DISABLED_DESCRIPTOR as a list end for all channels.
+#define ALIGNED __attribute__((aligned(GRPCI2DMA_BD_DATA_ALIGN)))
+static ALIGNED struct grpci2_bd_data disabled_data = {
+	/*.ctrl=*/0,
+	/*.pci_adr=*/0,
+	/*.ahb_adr=*/0,
+	/*.next=*/0
+#define DISABLED_DESCRIPTOR (&disabled_data)
+/*** START OF DESCRIPTOR LINKED-LIST HELPER FUNCTIONS ***/
+/* This functions adds a channel descriptor to the DMA channel
+ * linked list. It assumes that someone has check the input
+ * parameters already.
+	DBG("Adding channel (0x%08x) to GRPCI2 DMA driver\n", (unsigned int) chan);
+	/* Add channel to the linnked list */
+	if (list == chan) {
+		/* No previous channels. Finish. */
+		return GRPCI2DMA_ERR_OK;
+	} else {
+		/* Get next chan from list */
+		struct grpci2_bd_chan * nchan = grpci2dma_channel_bd_get_next(list);
+		/* Close the circular linked list */
+		grpci2dma_channel_bd_set_next(chan,nchan);
+		/* Attach the new channel in the middle */
+		grpci2dma_channel_bd_set_next(list, chan);
+/* This functions removes a channel descriptor from the DMA channel
+ * It returns 0 if successfull. Otherwise,
+ * it can return:
+ * - ERROR: Different causes:
+ *	  x Number of channels is corrupted.
+	DBG("Removing channel (0x%08x) from GRPCI2 DMA driver\n",
+			(unsigned int) chan);
+	/* Remove channel from the linnked list */
+	struct grpci2_bd_chan * nchan = grpci2dma_channel_bd_get_next(chan);
+	if (nchan != chan){
+		/* There are more channels */
+		/* Since this is a circular linked list, we need to find last channel
+		 * and update the pointer to the next element */
+		/* Use index to avoid having an infinite loop in case of corrupted
+		 * channels */
+		struct grpci2_bd_chan * new_first_chan = nchan;
+		struct grpci2_bd_chan * curr_chan;
+		int i=1;
+		while((nchan != chan) && (i<MAX_DMA_CHANS)){
+			curr_chan = nchan;
+			nchan = grpci2dma_channel_bd_get_next(curr_chan);
+			i++;
+		if (nchan != chan) {
+			DBG("Maximum DMA channels exceeded. Maybe corrupted?\n");
+			return GRPCI2DMA_ERR_ERROR;
+		} else {
+			/* Update the pointer */
+			grpci2dma_channel_bd_set_next(curr_chan, new_first_chan);
+	}else{
+		/* There are no more channels */
+/* This functions adds a data descriptor to the channel's data
+ * linked list. The function assumes, that the data descriptor
+ * points to either a DISABLED_DESCRIPTOR or to linked list of
+ * data descriptors that ends with a DISABLED_DESCRIPTOR.
+ * It returns the number of active data descriptors
+ * if successfull. Otherwise, it can return:
+ *	  x Last linked list element is not pointing to the first.
+	DBG("Adding data (0x%08x) to channel (0x%08x)\n",
+			(unsigned int) data, (unsigned int) chan);
+	/* Add data to the linnked list */
+	/* 1st- Get current data */
+	struct grpci2_bd_data * first_data = grpci2dma_channel_bd_get_data(chan);
+	if (first_data == NULL) {
+		/* Channel should always be pointing to a disabled descriptor */
+		DBG("Channel not pointing to disabled descpriptor\n");
+	} else if (first_data == DISABLED_DESCRIPTOR){
+		/* No previous data. Assign this one and finish. */
+		grpci2dma_channel_bd_set_data(chan, data);
+	} else {
+		/* Let's add the data to the last data pointer added to this channel */
+		/* Attach the new data */
+		grpci2dma_data_bd_set_next(last_chan_data, data);
+		/* 2nd- Let's check again to make sure that the DMA did not finished
+		 * while we were inserting the new data */
+		first_data = grpci2dma_channel_bd_get_data(chan);
+		if (first_data == DISABLED_DESCRIPTOR){
+/* This functions removes a data descriptor from the channel's data
+ * linked list. Note that in a normal execution, the DMA will remove
+ * the data descriptors from the linked list, so there is no need to
+ * use this function. It returns 0 if successfull. Otherwise,
+ * it can return:
+ * - WRONGPTR: The chan (or data) pointer is either NULL or not aligned to
+ *	 0x10.
+ * - STOPDMA: The DMA is running, cannot add channels while DMA is running.
+ * - TOOMANY: The max number of data is reached.
+ *	  x There are no free channel id numbers.
+UNUSED STATIC int grpci2dma_data_list_remove(struct grpci2_bd_chan * chan,
+	DBG("Removing data (0x%08x) from channel (0x%08x)\n",
+	/* Remove data from the linked list */
+	/* 1st- Get current DMA data */
+		/* No previous data. Cannot detach */
+		DBG("No data to detach.\n");
+		return GRPCI2DMA_ERR_NOTFOUND;
+	} else {
+		/* 2nd- Already available data, let's find the data */
+		if (first_data == data) {
+			/* 3rd- It is the first one. */
+			struct grpci2_bd_data *current = first_data;
+			struct grpci2_bd_data *next = grpci2dma_data_bd_get_next(current);
+			if (next != DISABLED_DESCRIPTOR){
+				/* There are more data */
+				/* Set channel next data descriptor to data*/
+				grpci2dma_channel_bd_set_data(chan, next);
+				/* Update the removed data */
+				grpci2dma_data_bd_set_next(data, DISABLED_DESCRIPTOR);
+			}else{
+				/* No more data */
+				/* Clear DMA NBD */
+				grpci2dma_channel_bd_set_data(chan, DISABLED_DESCRIPTOR);
+		} else {
+			/* It is not the first data. Let's find it */
+			struct grpci2_bd_data * current = first_data;
+			struct grpci2_bd_data * next = grpci2dma_data_bd_get_next(current);
+			while( (next != data) && (next != DISABLED_DESCRIPTOR) &&
+					(next != NULL)){
+				current = next;
+				next = grpci2dma_data_bd_get_next(current);
+			if (next != data) {
+				DBG("Maximum DMA data exceeded. Maybe corrupted?\n");
+			} else {
+				/* Detach the data */
+				next = grpci2dma_data_bd_get_next(data);
+				grpci2dma_data_bd_set_next(current, next);
+/* Iterate through all channel starting in FIRST_CHAN up to MAXINDEX
+ * and execute FUNC*/
+UNUSED STATIC int grpci2dma_channel_list_foreach(
+		struct grpci2_bd_chan * first_chan,
+	if (maxindex <= 0) return 0;
+	if (first_chan == NULL) {
+		/* No previous channels */
+		return 0;
+	} else {
+		/* Available channels */
+		/* Iterate through next channels */
+		 * channels */
+		int i=0;
+		int ret;
+		struct grpci2_bd_chan * curr_chan = first_chan;
+		struct grpci2_bd_chan * nchan;
+		do{
+			if (curr_chan == NULL) return GRPCI2DMA_ERR_WRONGPTR;
+			ret = func(curr_chan);
+			if (ret < 0){
+				/* error */
+				return ret;
+			i++;
+		}while((curr_chan != first_chan) && (i < maxindex));
+	return 0;
+/* Iterate through all data starting in FIRST_DATA up to MAXINDEX
+STATIC int grpci2dma_data_list_foreach(struct grpci2_bd_data * first_data,
+	if (first_data == NULL) return GRPCI2DMA_ERR_WRONGPTR;
+	/* Available data */
+	/* Iterate through next data */
+	 * channels */
+	int i=0;
+	int ret;
+	struct grpci2_bd_data * curr_data = first_data;
+	struct grpci2_bd_data * ndata;
+	while((curr_data != DISABLED_DESCRIPTOR) && (i < maxindex)){
+		if (curr_data == NULL) return GRPCI2DMA_ERR_WRONGPTR;
+		ret = func(curr_data);
+		if (ret < 0){
+			/* error */
+			return ret;
+		ndata = grpci2dma_data_bd_get_next(curr_data);
+		curr_data = ndata;
+		i++;
+	return 0;
+/*** END OF DESCRIPTOR LINKED-LIST HELPER FUNCTIONS ***/
+/*** START OF DMACTRL ACCESS FUNCTIONS ***/
+/* Initialize the DMA Ctrl*/
+STATIC INLINE int grpci2dma_ctrl_init()
+	struct grpci2dma_priv *priv = grpci2dmapriv;
+	/* Clear DMA Control: clear IRQ and ERR status */
+	REG_WRITE(&priv->regs->dma_ctrl, 0|DMACTRL_SAFE|DMACTRL_CHIRQ|DMACTRL_ERR);
+	/* Clear DMA BASE */
+	REG_WRITE(&priv->regs->dma_bdbase, 0);
+	/* Clear DMA Chan */
+	REG_WRITE(&priv->regs->dma_chact, 0);
+	return 0;
+/* Stop the DMA */
+STATIC INLINE int grpci2dma_ctrl_stop( void )
+	/* Stop DMA */
+	unsigned int ctrl = REG_READ(&priv->regs->dma_ctrl);
+	REG_WRITE(&priv->regs->dma_ctrl, (ctrl & ~(DMACTRL_WCLEAR | DMACTRL_EN)) |
+			DMACTRL_DIS);
+	return 0;
+/* Start the DMA */
+STATIC INLINE int grpci2dma_ctrl_start( struct grpci2_bd_chan * chan)
+	/* Set BDBASE to linked list of chans */
+	REG_WRITE(&priv->regs->dma_bdbase, (unsigned int) chan);
+	/* Start DMA */
+	REG_WRITE(&priv->regs->dma_ctrl, (ctrl & ~(DMACTRL_WCLEAR | DMACTRL_DIS)) |
+			DMACTRL_EN);
+	return 0;
+/* Resume the DMA */
+STATIC INLINE int grpci2dma_ctrl_resume( void )
+	/* Resume DMA */
+			DMACTRL_EN);
+	return 0;
+/* Interrupt status*/
+	return (ctrl & DMACTRL_IE);
+/* Enable interrupts */
+	if (ctrl & DMACTRL_IE){
+		/* Nothing to do. Already enabled */
+		return 0;
+	/* Clear pending CHIRQ and errors */
+	ctrl = ctrl | (DMACTRL_CHIRQ | DMACTRL_ERR);
+	/* Enable interrupts */
+	ctrl = ctrl | DMACTRL_IE;
+	REG_WRITE(&priv->regs->dma_ctrl, ctrl );
+	return 0;
+/* Disable interrupts */
+	if ((ctrl & DMACTRL_IE) == 0){
+		/* Nothing to do. Already disabled */
+		return 0;
+	/* Disable interrupts */
+	ctrl = ctrl & ~(DMACTRL_IE);
+	return 0;
+/* Clear interrupts */
+	REG_WRITE(&priv->regs->dma_ctrl, (ctrl | DMACTRL_ERR | DMACTRL_CHIRQ));
+	return 0;
+STATIC INLINE unsigned int grpci2dma_ctrl_status()
+	/* Read DMA */
+	return (REG_READ(&priv->regs->dma_ctrl));
+STATIC INLINE unsigned int grpci2dma_ctrl_base()
+	/* Read DMA */
+	return (REG_READ(&priv->regs->dma_bdbase));
+UNUSED STATIC INLINE unsigned int grpci2dma_ctrl_active()
+	/* Read DMA */
+	return (REG_READ(&priv->regs->dma_chact));
+/* Set the DMA CTRL register NUMCH field */
+	/* Clear old value */
+	ctrl = (ctrl & ~(DMACTRL_NUMCH));
+	/* Put new value */
+	ctrl = (ctrl | ( (numch << DMACTRL_NUMCH_BIT) & DMACTRL_NUMCH));
+	REG_WRITE(&priv->regs->dma_ctrl, ctrl & ~(DMACTRL_WCLEAR));
+	return 0;
+/*** END OF DMACTRL ACCESS FUNCTIONS ***/
+/*** START OF DESCRIPTOR ACCESS FUNCTIONS ***/
+		uint32_t pci_adr, uint32_t ahb_adr, int dir, int endianness, int size,
+	BD_WRITE(&data->ctrl, 0 |
+			(BD_DATA_EN) |
+			(BD_DATA_TYPE_DATA) |
+			(dir == GRPCI2DMA_AHBTOPCI? BD_DATA_DR:0) |
+			(endianness == GRPCI2DMA_LITTLEENDIAN? BD_DATA_BE:0) |
+			( (size << BD_DATA_LEN_BIT) & BD_DATA_LEN )
+	BD_WRITE(&data->pci_adr, pci_adr);
+	BD_WRITE(&data->ahb_adr, ahb_adr);
+	BD_WRITE(&data->next, (unsigned int) next);
+	return 0;
+	BD_WRITE(&chan->ctrl, 0 | BD_CHAN_TYPE_DMA | BD_CHAN_EN);
+	BD_WRITE(&chan->nchan, (unsigned int) chan);
+	BD_WRITE(&chan->nbd, (unsigned int) DISABLED_DESCRIPTOR);
+	return 0;
+/* Enable a channel with options.
+ * options include:
+ * - options & 0xFFFF: Maximum data descriptor count before
+ *	 moving to next DMA channel.
+	unsigned int ctrl = BD_READ(&chan->ctrl);
+	ctrl = (ctrl & ~(BD_CHAN_BDCNT));
+	BD_WRITE(&chan->ctrl, (ctrl | BD_CHAN_EN |
+				( (options << BD_CHAN_BDCNT_BIT) & BD_CHAN_BDCNT)));
+	return 0;
+/* Disable channel.
+	BD_WRITE(&chan->ctrl, (ctrl & ~(BD_CHAN_EN)));
+	return 0;
+/* Get the CID of a channel.
+UNUSED STATIC int grpci2dma_channel_bd_get_cid(struct grpci2_bd_chan * chan)
+	/* Get cid from chan */
+	unsigned ctrl = BD_READ(&chan->ctrl);
+	unsigned cid  = (ctrl & (BD_CHAN_ID)) >> BD_CHAN_ID_BIT;
+	return cid;
+/* Set the CID of a channel. */
+STATIC void grpci2dma_channel_bd_set_cid(struct grpci2_bd_chan * chan, int cid)
+	/* Set cid from chan */
+	ctrl = (ctrl & ~(BD_CHAN_ID)) | ((cid << BD_CHAN_ID_BIT) & BD_CHAN_ID);
+	BD_WRITE(&chan->ctrl,ctrl);
+	return;
+/* Disable data descriptor*/
+UNUSED STATIC int grpci2dma_data_bd_disable(struct grpci2_bd_data *desc)
+	BD_WRITE(&desc->ctrl,0);
+	return 0;
+/* Return status of data descriptor*/
+STATIC int grpci2dma_data_bd_status(struct grpci2_bd_data *desc)
+	int status = BD_READ(&desc->ctrl);
+	if (status & BD_DATA_ER) {
+		return GRPCI2DMA_BD_STATUS_ERR;
+	}else if (status & BD_DATA_EN) {
+		return GRPCI2DMA_BD_STATUS_ENABLED;
+	}else {
+		return GRPCI2DMA_BD_STATUS_DISABLED;
+/* Enable interrupts in data descriptor*/
+	unsigned int ctrl = BD_READ(&data->ctrl);
+	BD_WRITE(&data->ctrl, ctrl | BD_DATA_IE);
+	return 0;
+/* Get data descriptor */
+	return	(struct grpci2_bd_data *) BD_READ(&chan->nbd);
+/* Set data descriptorl */
+	BD_WRITE(&chan->nbd, (unsigned int) data);
+/* Get next channel */
+	return	(struct grpci2_bd_chan *) BD_READ(&chan->nchan);
+/* Get next data */
+	return	(struct grpci2_bd_data *) BD_READ(&data->next);
+/* Set next channel */
+	BD_WRITE(&chan->nchan,(unsigned int) next);
+/* Set next data */
+	BD_WRITE(&data->next,(unsigned int) next);
+/*** END OF DESCRIPTOR ACCESS FUNCTIONS ***/
+/*** START OF CHANNEL FUNCTIONS ***/
+	int allocated = 0;
+	/* Get pointer */
+	if (chan == NULL) {
+		/* User does not provide channel, let's create it */
+		chan = grpci2dma_channel_new(1);
+		allocated = 1;
+	}else{
+		/* Make sure the pointer is not already on the linked list */
+		int i;
+		for (i=0; i<MAX_DMA_CHANS; i++){
+			if (priv->channel[i].ptr == chan){
+				return GRPCI2DMA_ERR_WRONGPTR;
+	DBG("Opening channel %d (0x%08x)\n", cid, (unsigned int) chan);
+	/* Init channel descriptor */
+	grpci2dma_channel_bd_init(chan);
+	/* Assign cid to chan */
+	priv->channel[cid].ptr = chan;
+	grpci2dma_channel_bd_set_cid(chan, cid);
+	/* Increase number of channels */
+	priv->nchans++;
+	DBG("number of channels: %d\n", priv->nchans);
+	/* Initialize channel data */
+	priv->channel[cid].allocated = allocated;
+	priv->channel[cid].active = 0;
+	/* Initialize record of last added data */
+	priv->channel[cid].lastdata = DISABLED_DESCRIPTOR;
+	return cid;
+/* Get first free CID.
+STATIC int grpci2dma_channel_free_id()
+	/* Find the first free CID */
+	int i;
+		if (priv->channel[i].ptr == NULL){
+			return i;
+	return GRPCI2DMA_ERR_TOOMANY;
+/* Get the active channel circular linked list */
+STATIC struct grpci2_bd_chan * grpci2dma_channel_get_active_list()
+	int i;
+	/* Just get the first non NULL associated cid */
+	for (i=0; i< MAX_DMA_CHANS; i++){
+		if ((priv->channel[i].ptr != NULL) && (priv->channel[i].active)){
+			return priv->channel[i].ptr;
+	return NULL;
+/* Start a channel */
+	struct grpci2_bd_chan *chan;
+	SPIN_IRQFLAGS(irqflags);
+	/* Get chan pointer */
+	chan = priv->channel[chan_no].ptr;
+	/* Check if channel is active */
+	if (priv->channel[chan_no].active){
+		/* nothing to do */
+	/* Get the max descriptor count */
+	unsigned int desccnt;
+	if (options == 0){
+		/* Default */
+		desccnt = 0xffff;
+	}else{
+		desccnt = options & 0xffff;
+	/* Start the channel by enabling it.
+	 * HWNOTE: In GRPCI2 this bit does not work as it is supposed.
+	 * So we better add/remove the channel from the active linked
+	 * list. */
+	grpci2dma_channel_bd_enable(chan, desccnt);
+	priv->channel[chan_no].active = 1;
+	priv->nactive++;
+	/* Get active linked list */
+	struct grpci2_bd_chan * list = grpci2dma_channel_get_active_list();
+	if (list == NULL){
+		/* No previous channels. New list */
+		list = chan;
+	/* Add channel from the linked list */
+	if (grpci2dma_channel_list_add(list, chan) < 0){
+	/* Increase NUMCH in DMA ctrl */
+	SPIN_LOCK_IRQ(&priv->devlock, irqflags);
+	grpci2dma_ctrl_numch_set( (priv->nactive? priv->nactive -1:0));
+	/* Check if DMA is active */
+	if (!grpci2dma_active()){
+		/* Start DMA */
+		grpci2dma_ctrl_start(chan);
+	SPIN_UNLOCK_IRQ(&priv->devlock, irqflags);
+	DBG("Channel %d started (0x%08x)\n", chan_no, (unsigned int) chan);
+/* Stop a channel */
+	int resume;
+	if (!priv->channel[chan_no].active){
+	/* First remove channel from the linked list */
+	if (grpci2dma_channel_list_remove(chan) < 0){
+	/* Update driver struct */
+	priv->channel[chan_no].active = 0;
+	priv->nactive--;
+	/* Check if DMA is active and it the removed
+	 * channel is the active */
+	resume = 0;
+	if (grpci2dma_active() && (grpci2dma_ctrl_active() == (unsigned int)chan)){
+		/* We need to stop the DMA */
+		grpci2dma_ctrl_stop();
+		/* Wait until DMA stops */
+		while (grpci2dma_active()){}
+		/* We need to check later to resume the DMA */
+		resume = 1;
+	}else{
+	/* Now either the DMA is stopped, or it is processing
+	 * a different channel and the removed channel is no
+	 * longer in the linked list */
+	/* Now is safe to update the removed channel */
+	grpci2dma_channel_bd_set_next(chan, chan);
+	/* Stop the channel by disabling it.
+	 * So we better remove the channel from the active linked
+	 * list. */
+	grpci2dma_channel_bd_disable(chan);
+	/* Point channel to disabled descriptor */
+	DBG("Channel %d stoped (0x%08x)\n", chan_no, (unsigned int) chan);
+	/* Decrease NUMCH in DMA ctrl */
+	/* Reactivate DMA only if we stopped */
+	if (resume){
+		/* We have two options, either we stopped when the active
+		 * channel was still the active one, or we stopped when
+		 * the active channel was a different one */
+		if (grpci2dma_ctrl_active() == (unsigned int) chan){
+			/* In this case, we need to start the DMA with
+			 * any active channel on the list */
+			int i;
+				if (priv->channel[i].active){
+					grpci2dma_ctrl_start(priv->channel[i].ptr);
+					break;
+		}else{
+			/* In this case, we need to resume the DMA operation */
+			/* HWNOTE: The GRPCI2 core does not update the channel next
+			 * data descriptor if we stopped a channel. This means that
+			 * we need to resume the DMA from the descriptor is was,
+			 * by only setting the enable bit, and not changing the
+			 * base register */
+			grpci2dma_ctrl_resume();
+		int ndata)
+	struct grpci2_bd_chan * chan;
+	struct grpci2_bd_data * data = dataptr;
+	/* Get channel */
+	DBG("Pushing %d data (starting at 0x%08x) to channel %d (0x%08x)\n",
+			ndata, (unsigned int) &data[index], chan_no, (unsigned int) chan);
+	/* Get last added data */
+	struct grpci2_bd_data * last_added = priv->channel[chan_no].lastdata;
+	/* Add data to channel */
+	grpci2dma_data_list_add(chan, &data[index], last_added);
+	/* Update last added */
+	priv->channel[chan_no].lastdata = &data[index + ndata-1];
+	/* Get channel */
+	DBG("Closing channel %d (0x%08x)\n", chan_no, (unsigned int) chan);
+	/* Stop channel */
+	if (grpci2dma_channel_stop(chan_no) != GRPCI2DMA_ERR_OK ){
+		DBG("Cannot stop channel!.\n");
+		return GRPCI2DMA_ERR_STOPDMA;
+	/* Unregister channel ISR */
+	grpci2dma_channel_isr_unregister(chan_no);
+	/* Free the cid */
+	priv->channel[chan_no].ptr = NULL;
+	/* Remove the ISR */
+	priv->channel[chan_no].isr = NULL;
+	priv->channel[chan_no].isr_arg = NULL;
+	/* Deallocate channel if needed */
+	if (priv->channel[chan_no].allocated){
+		grpci2dma_channel_delete((void *)chan);
+	/* Decrease number of channels */
+	priv->nchans--;
+	/* Everything OK */
+/* Register channel ISR */
+	/* Unregister DMA ISR in GRPCI2 if needed */
+	priv->isr_registered--;
+	if(priv->isr_registered == 0){
+		/* Disable DMA Interrupts */
+		grpci2dma_ctrl_interrupt_disable();
+		(priv->isr_register)( NULL, NULL);
+/*** END OF CHANNEL FUNCTIONS ***/
+/*** START OF ISR FUNCTIONS ***/
+/* PCI DMA Interrupt handler, called when there is a PCI DMA interrupt */
+	struct grpci2dma_priv *priv = arg;
+	SPIN_ISR_IRQFLAGS(irqflags);
+	unsigned int ctrl = grpci2dma_ctrl_status();
+	/* Clear Interrupts */
+	SPIN_LOCK(&priv->devlock, irqflags);
+	grpci2dma_ctrl_interrupt_clear();
+	SPIN_UNLOCK(&priv->devlock, irqflags);
+	unsigned int sts = (ctrl & DMACTRL_CHIRQ) >> DMACTRL_CHIRQ_BIT;
+	unsigned int errsts = (ctrl & DMACTRL_ERR);
+	/* Error interrupt */
+	if(errsts){
+		/* Find which channels had the error.
+		 * The GRPCI2DMA core does not indicate which channel
+		 * had the error, so we need to get 1st the base descriptor register
+		 * and see if it a channel. If is not a channel, then the active
+		 * channel register tells us which channel is.
+		 * After having the channel we need to find out which channel was. */
+		struct grpci2_bd_chan * chan =
+			(struct grpci2_bd_chan *) grpci2dma_ctrl_base();
+		/* Check if the base is a channel descriptor */
+		if ((BD_READ(&chan->ctrl) & BD_CHAN_TYPE) != BD_CHAN_TYPE_DMA){
+			/* Is not a channel, so the channel is in the channel active
+			 * register */
+			chan = (struct grpci2_bd_chan *) grpci2dma_ctrl_active();
+		int i;
+			if (chan == priv->channel[i].ptr){
+				/* Found */
+				if (priv->channel[i].isr != NULL){
+					(priv->channel[i].isr)(priv->channel[i].isr_arg,i,errsts);
+				}else{
+					printk("Unhandled GRPCI2 DMA error interrupt, sts:0x%02x\n", errsts);
+				break;
+		if (i == MAX_DMA_CHANS){
+			printk("Unhandled GRPCI2 DMA error interrupt , sts:0x%02x\n", errsts);
+	/* Normal packet interrupt */
+	int cid=0;
+	/* Find which channels have interrupts */
+	while(sts){
+		/* Find if current channel has an interrupt*/
+		if(sts & 0x1){
+			/* Find if current channel has an ISR */
+			if (priv->channel[cid].isr != NULL){
+				(priv->channel[cid].isr)(
+						priv->channel[cid].isr_arg, cid, errsts);
+			}else{
+				printk("Unhandled GRPCI2 DMA interrupt in channel %d, sts:0x%02x\n", cid, 0);
+		/* Next channel */
+		sts = sts >> 1;
+		cid++;
+/*** END OF ISR FUNCTIONS ***/
+/*** START OF DEBUG HELPERS ***/
+#ifdef DEBUG
+	printf("  GRPCI2 DMA channel descriptor\n");
+	printf("	  0x%08x  DMA channel control					  0x%08x\n", (unsigned int) chan, chan->ctrl);
+	printf("	  31	 en				   0x%01x		  Channel descriptor enable.\n", (chan->ctrl >> 31) & (0x1));
+	printf("	  24:22  cid			   0x%01x		  Channel ID.\n", (chan->ctrl >> 22) & (0x7));
+	printf("	  21:20  type			   0x%01x		  Descriptor type. 01=DMA channel descriptor.\n", (chan->ctrl >> 20) & (0x3));
+	printf("	  15:0	 dlen			0x%04x		   Data descriptor count.\n", (chan->ctrl >> 0) & (0xffff));
+	printf("\n");
+	printf("	  0x%08x  Next DMA channel						  0x%08x\n", (unsigned int) &(chan->nchan), chan->nchan);
+	printf("	  31:0	 nc			0x%08x		   Next DMA channel.\n", chan->nchan);
+	printf("\n");
+	printf("	  0x%08x  Next data descriptor					  0x%08x\n" , (unsigned int) &(chan->nbd), chan->nbd);
+	printf("	  31:0	 nd			0x%08x		   Next data descriptor.\n", chan->nbd);
+	printf("\n");
+	return 0;
+	printf("  GRPCI2 DMA data descriptor\n");
+	printf("	  0x%08x  DMA data control						  0x%08x\n", (unsigned int) data, data->ctrl);
+	printf("	  31	 en				   0x%01x		  Data descriptor enable.\n" , (data->ctrl >> 31) & (0x1));
+	printf("	  30	 ie				   0x%01x		  Interrupt generation enable.\n" , (data->ctrl >> 30) & (0x1));
+	printf("	  29	 dr				   0x%01x		  Tranfer direction.\n" , (data->ctrl >> 29) & (0x1));
+	printf("	  28	 be				   0x%01x		  Bus endianess.\n" , (data->ctrl >> 28) & (0x1));
+	printf("	  21:20  type			   0x%01x		  Descriptor type. 00=DMA data descriptor.\n" , (data->ctrl >> 20) & (0x3));
+	printf("	  19	 er				   0x%01x		  Error status.\n" , (data->ctrl >> 19) & (0x1));
+	printf("	  15:0	 len			0x%04x		   Transfer lenght (in words) - 1.\n" ,  (data->ctrl >> 0) & (0xffff));
+	printf("\n");
+	printf("	  0x%08x  32-bit PCI start address				  0x%08x\n" , (unsigned int) &(data->pci_adr), data->pci_adr);
+	printf("	  31:0	 pa			0x%08x		   PCI address.\n" , data->pci_adr);
+	printf("\n");
+	printf("	  0x%08x  32-bit AHB start address				  0x%08x\n" , (unsigned int) &(data->ahb_adr), data->ahb_adr);
+	printf("	  31:0	 aa			0x%08x		   AHB address.\n" , data->ahb_adr);
+	printf("\n");
+	printf("	  0x%08x  Next data descriptor					  0x%08x\n" , (unsigned int) &(data->next), data->next);
+	printf("	  31:0	 nd			0x%08x		   Next data descriptor.\n" , data->next);
+	printf("\n");
+	return 0;
+#endif
+/*** END OF DEBUG HELPERS ***/
+/*** START OF MEMORY ALLOCATION FUNCTIONS ***/
+void * grpci2dma_channel_new(int number)
+	/* Allocate memory */
+	unsigned int * orig_ptr = (unsigned int *) malloc(
+			(GRPCI2DMA_BD_CHAN_SIZE)*number + GRPCI2DMA_BD_CHAN_ALIGN);
+	if (orig_ptr == NULL) return NULL;
+	/* Get the aligned pointer */
+	unsigned int aligned_ptr = (
+		((unsigned int) orig_ptr + GRPCI2DMA_BD_CHAN_ALIGN) &
+		 ~(GRPCI2DMA_BD_CHAN_ALIGN - 1));
+	/* Save the original pointer just before the aligned pointer */
+	unsigned int ** tmp_ptr =
+		(unsigned int **) (aligned_ptr - sizeof(orig_ptr));
+	*tmp_ptr= orig_ptr;
+	/* Return aligned pointer */
+	return (void *) aligned_ptr;
+void grpci2dma_channel_delete(void * chan)
+	/* Recover orignal pointer placed just before the aligned pointer */
+	unsigned int * orig_ptr;
+	unsigned int ** tmp_ptr =  (unsigned int **) (chan - sizeof(orig_ptr));
+	orig_ptr = *tmp_ptr;
+	/* Deallocate memory */
+	free(orig_ptr);
+void * grpci2dma_data_new(int number)
+			(GRPCI2DMA_BD_DATA_SIZE)*number + GRPCI2DMA_BD_DATA_ALIGN);
+		((unsigned int) orig_ptr + GRPCI2DMA_BD_DATA_ALIGN) &
+		~(GRPCI2DMA_BD_DATA_ALIGN - 1));
+	/* Save the original pointer before the aligned pointer */
+void grpci2dma_data_delete(void * data)
+	unsigned int ** tmp_ptr =  (unsigned int **) (data - sizeof(orig_ptr));
+	free(orig_ptr);
+/*** END OF MEMORY ALLOCATION FUNCTIONS ***/
+/*** START OF USER API ***/
+/* Initialize GRPCI2 DMA: GRPCI2 DRIVER calls this
+ * using a weak function definition */
+		void * regs, void isr_register( void (*isr)(void*), void * arg))
+	struct grpci2dma_priv *priv;
+	int i;
+	DBG("Registering GRPCI2 DMA driver with arg: 0x%08x\n",
+			(unsigned int) regs);
+	/* We only allow one GRPCI2 DMA */
+	if (grpci2dmapriv) {
+		DBG("Driver only supports one PCI DMA core\n");
+		return DRVMGR_FAIL;
+	/* Device Semaphore created with count = 1 */
+	if (rtems_semaphore_create(rtems_build_name('G', 'P', '2', 'D'), 1,
+		RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE | \
+		RTEMS_NO_INHERIT_PRIORITY | RTEMS_LOCAL | \
+		RTEMS_NO_PRIORITY_CEILING, 0, &grpci2dma_sem) != RTEMS_SUCCESSFUL)
+		return -1;
+	/* Allocate and init Memory for DMA */
+	int size = sizeof(struct grpci2dma_priv);
+	priv = (struct grpci2dma_priv *) malloc(size);
+	if (priv == NULL)
+		return DRVMGR_NOMEM;
+	/* Initialize all fields */
+	memset(priv, 0, size);
+	priv->regs = regs;
+	strncpy(&priv->devname[0], "grpci2dma0", DEVNAME_LEN);
+	/* Initialize Spin-lock for GRPCI2dma Device. */
+	SPIN_INIT(&priv->devlock, priv->devname);
+	/* Channel Sempahores */
+		/* set to NULL, they are created when openning channels */
+		priv->channel[i].sem = RTEMS_ID_NONE;
+	/* Register device */
+	grpci2dmapriv = priv;
+	/* Initialize Ctrl regs */
+	grpci2dma_ctrl_init();
+	/* Install DMA ISR */
+	priv->isr_register = isr_register;
+	/* Startup actions:
+	 * - stop DMA
+	return DRVMGR_OK;
+/* Assign ISR Function to DMA IRQ */
+int grpci2dma_isr_register(int chan_no, grpci2dma_isr_t dmaisr, void *data)
+	if (!priv){
+		/* DMA not initialized */
+		return GRPCI2DMA_ERR_NOINIT;
+	/* Check isr */
+	if (dmaisr == NULL){
+		/* No ISR */
+	if ((chan_no < 0 ) || (chan_no >= MAX_DMA_CHANS)) {
+		/* Wrong channel id */
+	/* Check chan is open */
+	if (priv->channel[chan_no].ptr == NULL){
+		/* No channel */
+	/* Take driver lock - Wait until we get semaphore */
+	if (rtems_semaphore_obtain(grpci2dma_sem, RTEMS_WAIT, RTEMS_NO_TIMEOUT)
+		!= RTEMS_SUCCESSFUL){
+	/* Take channel lock - Wait until we get semaphore */
+	if (rtems_semaphore_obtain(priv->channel[chan_no].sem, RTEMS_WAIT, RTEMS_NO_TIMEOUT)
+		rtems_semaphore_release(grpci2dma_sem);
+	/* Register channel ISR */
+	priv->channel[chan_no].isr_arg = data;
+	priv->channel[chan_no].isr = dmaisr;
+	/* Register DMA ISR in GRPCI2 if not done yet */
+		(priv->isr_register)( grpci2dma_isr, (void *) priv);
+		/* Enable DMA Interrupts */
+		grpci2dma_ctrl_interrupt_enable();
+	priv->isr_registered++;
+	/* Release channel sempahore */
+	rtems_semaphore_release(priv->channel[chan_no].sem);
+	/* Release driver sempahore */
+int grpci2dma_isr_unregister(int chan_no)
+	int ret;
+	if (!priv){
+		/* No channel */
+	/* Get chan ISR */
+	if (priv->channel[chan_no].isr == NULL){
+		/* Nothing to do */
+	ret = grpci2dma_channel_isr_unregister(chan_no);
+	return ret;
+int grpci2dma_open(void * chanptr)
+	int cid;
+	int ret;
+	if (!priv){
+	/* Check alignment */
+	if (((unsigned int ) chanptr) & (GRPCI2DMA_BD_CHAN_ALIGN-1)) {
+		/* Channel is not properly aligned */
+	/* Get free channel id */
+	cid = grpci2dma_channel_free_id();
+	if (cid < 0 ){
+	/* Open channel */
+	ret = grpci2dma_channel_open((struct grpci2_bd_chan *) chanptr, cid);
+	/* Create channel semaphore with count = 1 */
+	if (ret >= 0){
+					rtems_build_name('P', 'D', '0', '0' + cid), 1,
+					RTEMS_NO_PRIORITY_CEILING, 0, &priv->channel[cid].sem
+					) != RTEMS_SUCCESSFUL) {
+			priv->channel[cid].sem = RTEMS_ID_NONE;
+	/* Release driver semaphore */
+	/* Return channel id */
+	return ret;
+int grpci2dma_close(int chan_no)
+	int ret;
+	if (!priv){
+	if ((chan_no < 0) || (chan_no >= MAX_DMA_CHANS)){
+		/* No channel */
+	/* Close channel */
+	ret = grpci2dma_channel_close(chan_no);
+	/* Delete channel semaphore */
+	if (ret == GRPCI2DMA_ERR_OK){
+		if (rtems_semaphore_delete(priv->channel[chan_no].sem)
+	return ret;
+/* Transfer_size =0 means maximum */
+int grpci2dma_prepare(
+		int size, void * dataptr, int index, int ndata, int transfer_size)
+	/* Check data pointer */
+	if ((data == NULL) ||
+			(((unsigned int ) data) & (GRPCI2DMA_BD_DATA_ALIGN-1))){
+	/* Check indexes */
+	int maxdata = ndata - index;
+	if ((maxdata < 1) || (index < 0)){
+		/* No data descriptors to use */
+	/* Check PCI transfer size */
+	if ( (transfer_size < 0) ||
+			(transfer_size > MAX_DMA_TRANSFER_SIZE) ||
+			(transfer_size%4 != 0) ) {
+	if (transfer_size == 0){
+		transfer_size = MAX_DMA_TRANSFER_SIZE;
+	/* Check total size */
+	if ( (size <=0) || (size % 4 != 0)){
+	/* Calculate number of data descriptors needed */
+	int words = size/4;
+	int blocksize = transfer_size/4;
+	int datacnt = words/blocksize + (words%blocksize != 0? 1: 0);
+	/* Check that we can transfer the data */
+	if (datacnt > maxdata) {
+	/* Prepare data descriptors */
+	int i;
+	uint32_t pci_adr;
+	uint32_t ahb_adr;
+	int remaining=words;
+	int datasize;
+	struct grpci2_bd_data * next;
+	for (i=0; i<datacnt; i++){
+		/* Get PCI and AHB start addresses */
+		pci_adr = pci_start + i*blocksize;
+		ahb_adr = ahb_start + i*blocksize;
+		/* Get current data size */
+		if (remaining >= blocksize){
+			datasize = blocksize - 1;
+			remaining -= blocksize;
+		} else {
+			datasize = remaining -1;
+			remaining = 0;
+		/* Get linked list pointers */
+		if (i == datacnt - 1){
+			/* Last transfer */
+			next = DISABLED_DESCRIPTOR;
+		}else{
+			next = &data[i+index+1];
+		/* Set Data descriptor */
+		grpci2dma_data_bd_init(&data[i+index], pci_adr, ahb_adr, dir, endianness, datasize, next);
+	/* Return number of transfers used */
+	return datacnt;
+int grpci2dma_status(void *dataptr, int index, int ndata)
+	int i;
+	/* Check maxdata */
+	/* Check status of all packets in transfer */
+	int status;
+	for (i=0; i< maxdata; i++){
+		status = grpci2dma_data_bd_status(&data[i+index]);
+		if (status == GRPCI2DMA_BD_STATUS_ERR){
+			/* Error in one packet, means error in transfer */
+			return status;
+		} else if (status == GRPCI2DMA_BD_STATUS_ENABLED){
+			/* If one packet is enabled, means transfer is not done */
+			return status;
+	/* If we reach here it means they are all disabled */
+	return status;
+int grpci2dma_print(int chan_no)
+	if (!priv){
+		DBG("DMA not initialized.\n");
+	if ( (chan_no < 0) || (chan_no >= MAX_DMA_CHANS )){
+		/* Wrong chan no*/
+	#ifdef DEBUG
+	/* Print channel state */
+	grpci2dma_channel_print(chan);
+	/* Get current DATA desc */
+	struct grpci2_bd_data * first_data = (struct grpci2_bd_data *) BD_READ(&chan->nbd);
+	/* Print data state */
+	grpci2dma_data_list_foreach(first_data, grpci2dma_data_print, MAX_DMA_DATA);
+	#endif
+int grpci2dma_print_bd(void * dataptr)
+	struct grpci2_bd_data * data = (struct grpci2_bd_data *) dataptr;
+	if (!priv){
+	if ( data == NULL ){
+	#ifdef DEBUG
+	grpci2dma_data_list_foreach(data, grpci2dma_data_print, MAX_DMA_DATA);
+	#endif
+int grpci2dma_interrupt_enable(
+		void *dataptr, int index, int maxindex, int options)
+	if (!priv){
+	/* Check index */
+	if ((index < 0) || (maxindex < 1) || (index >= maxindex)){
+	if (options & GRPCI2DMA_OPTIONS_ALL){
+		/* Enable all interrupts */
+		if (grpci2dma_data_list_foreach(
+					&data[index],
+					grpci2dma_data_bd_interrupt_enable, maxindex -index)){
+	}else{
+		/* Enable one packet interrupts */
+		grpci2dma_data_bd_interrupt_enable(&data[index]);
+	/* Finally enable DMA interrupts if they are not already enabled */
+	if (grpci2dma_ctrl_interrupt_status()==0){
+	DBG("Interrupts enabled for data (0x%08x), index:%d, maxindex:%d, %s.\n",
+			(unsigned int) data, index, maxindex,
+			(options & GRPCI2DMA_OPTIONS_ALL)? "ALL":"ONE" );
+int grpci2dma_push(int chan_no, void *dataptr, int index, int ndata)
+	int ret;
+	if (!priv){
+	if ((dataptr == NULL) ||
+			(((unsigned int ) dataptr) & (GRPCI2DMA_BD_DATA_ALIGN-1))){
+	/* Check index */
+	if ((ndata < 1) || (index < 0)){
+	/* Check chan_no */
+		/* No channel */
+	/* push data to channel */
+	ret = grpci2dma_channel_push(chan_no, dataptr, index, ndata);
+	if (ret != GRPCI2DMA_ERR_OK){
+		/* Release channel lock */
+		return ret;
+	/* Start DMA if it is not active and channel is active*/
+	if ((!grpci2dma_active()) && (priv->channel[chan_no].active)){
+		grpci2dma_ctrl_start(priv->channel[chan_no].ptr);
+	return ret;
+/* Start the channel */
+int grpci2dma_start(int chan_no, int options)
+	int ret;
+	if (!priv){
+	if ((chan_no < 0 ) || (chan_no >= MAX_DMA_CHANS )) {
+	if ( options < 0 ) {
+		/* Wrong options */
+		/* No channel */
+	/* Start the channel */
+	ret = grpci2dma_channel_start(chan_no, options);
+	/* Release driver lock */
+	return ret;
+/* Stop the channel, but don't stop ongoing transfers! */
+int grpci2dma_stop(int chan_no)
+	int ret;
+	if (!priv){
+		/* No channel */
+	/* Stop the channel */
+	ret = grpci2dma_channel_stop(chan_no);
+	return ret;
+int grpci2dma_active()
+	return ((grpci2dma_ctrl_status()) & DMACTRL_ACT) >> DMACTRL_ACT_BIT;
2.7.4
