[PATCH 1/2] rtems/inttypes.h: New file. Uses contents from cpukit
Sat Apr 15 13:17:37 UTC 2017
Provide extentions to <inttpes.h> PRIxxx constants for more POSIX types.
Start with existing definitions found in RTEMS Project owned code
in cpukit/.
updates #2983.
 cpukit/Makefile.am                          |  1 +
 cpukit/include/rtems/inttypes.h             | 78 +++++++++++++++++++++++++++++
 cpukit/libdl/rtl-shell.c                    | 11 +---
 cpukit/libfs/src/nfsclient/src/dirutils.c   | 19 +------
 cpukit/libfs/src/rfs/rtems-rfs-dir.c        |  9 +---
 cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c |  9 +---
 cpukit/libfs/src/rfs/rtems-rfs-rtems.c      |  8 +--
 cpukit/libmisc/shell/main_time.c            | 10 +---
 cpukit/preinstall.am                        |  4 ++
 9 files changed, 90 insertions(+), 59 deletions(-)
 create mode 100644 cpukit/include/rtems/inttypes.h
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 755bc11..1987586 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -111,6 +111,7 @@ include_rtems_debugger_HEADERS +=  libdebugger/rtems-debugger-remote.h
 endif
 include_rtems_HEADERS += include/rtems/bspIo.h
+include_rtems_HEADERS += include/rtems/inttypes.h
 include_rtems_HEADERS += include/rtems/print.h
 include_rtems_HEADERS += include/rtems/printer.h
 include_rtems_HEADERS += include/rtems/userenv.h
diff --git a/cpukit/include/rtems/inttypes.h b/cpukit/include/rtems/inttypes.h
new file mode 100644
index 0000000..19022af
--- /dev/null
+++ b/cpukit/include/rtems/inttypes.h
@@ -0,0 +1,78 @@
+ * @file rtems/inttypes.h
+ * @brief Provide printf() PRIxxx Constante Beyond Standards
+ * This include file defines PRIxxx constants beyond those in
+ * the C and POSIX standards. These are used to write portable
+ * printf() format strings for POSIX and RTEMS types not in
+ * <inttypes.h>
+ *  COPYRIGHT (c) 2017 On-Line Applications Research Corporation.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifndef _RTEMS_INTTYPES_H
+#define _RTEMS_INTTYPES_H
+#include <inttypes.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMS inttypes.h Extensions
+ * This module defines portable PRIxxx constants beyond those
+ * in the C and POSIX standard.
+/** Helper macro to print "modet" in octal */
+#if SIZEOF_MODE_T == 8
+#define PRIomode_t PRIo64
+#elif SIZEOF_MODE_T == 4
+#define PRIomode_t PRIo32
+#else
+#error "PRIomode_t: unsupport size of mode_t"
+#endif
+/** Helper macro to print "off_t" in octal */
+#if SIZEOF_OFF_T == 8
+#define PRIooff_t PRIo64
+#elif SIZEOF_OFF_T == 4
+#define PRIooff_t PRIo32
+#else
+#error "PRIooff_t: unsupported size of off_t"
+#endif
+/** Helper macro to print "off_t" in decimal */
+#define PRIdoff_t PRId64
+#define PRIdoff_t PRId32
+#else
+#error "PRIdoff_t: unsupported size of off_t"
+#endif
+/** Helper macro to print "time_t" in decimal */
+#if SIZEOF_TIME_T == 8
+#define PRIdtime_t PRId64
+#elif SIZEOF_TIME_T == 4
+#define PRIdtime_t PRId32
+#else
+#error "PRIdtime_t: unsupported size of time_t"
+#endif
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/libdl/rtl-shell.c b/cpukit/libdl/rtl-shell.c
index a10c931..0bb3519 100644
--- a/cpukit/libdl/rtl-shell.c
+++ b/cpukit/libdl/rtl-shell.c
@@ -20,16 +20,7 @@
 #endif
- *  Flag the targets where off_t is 32 bits. This is not a compiler type
- *  so we can't rely on prerdefines.
-#if defined(__moxie__)
-#define PRIdoff_t PRIo32
-#else
-#define PRIdoff_t PRIo64
-#endif
+#include <rtems/inttypes.h>
diff --git a/cpukit/libfs/src/nfsclient/src/dirutils.c b/cpukit/libfs/src/nfsclient/src/dirutils.c
index 5dd7fcf..7155ef9 100644
--- a/cpukit/libfs/src/nfsclient/src/dirutils.c
+++ b/cpukit/libfs/src/nfsclient/src/dirutils.c
@@ -70,22 +70,7 @@
 #include <limits.h> /* PATH_MAX */
 #include <inttypes.h> /* PRI* */
-#if SIZEOF_MODE_T == 8
-#define PRIomode_t PRIo64
-#elif SIZEOF_MODE_T == 4
-#define PRIomode_t PRIo32
-#else
-#error "unsupport size of mode_t"
-#endif
-#if SIZEOF_OFF_T == 8
-#elif SIZEOF_OFF_T == 4
-#else
-#error "unsupported size of off_t"
-#endif
+#include <rtems/inttypes.h> /* extended PRI* */
 #ifdef HAVE_CEXP
 #include <cexpHelp.h>
@@ -142,7 +127,7 @@ char *t;
 						t = "@"; break;
-	printf("%10li, %10" PRIdoff_t "b, %5i.%-5i 0%04" PRIomode_t " %s%s\n",
+	printf("%10li, %10" PRIooff_t "b, %5i.%-5i 0%04" PRIomode_t " %s%s\n",
 				buf->st_ino,
 				buf->st_size,
 				buf->st_uid,
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-dir.c b/cpukit/libfs/src/rfs/rtems-rfs-dir.c
index 5a39cd4..58bf305 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-dir.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-dir.c
@@ -28,16 +28,9 @@
 #endif
-#define PRIooff_t PRIo64
-#define PRIooff_t PRIo32
-#else
-#endif
 #include <rtems/rfs/rtems-rfs-block.h>
 #include <rtems/rfs/rtems-rfs-buffer.h>
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
index 8902a0d..31df78a 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
@@ -21,16 +21,9 @@
 #endif
-#define PRIdoff_t PRId64
-#define PRIdoff_t PRId32
-#else
-#endif
 #include <rtems/rfs/rtems-rfs-file.h>
 #include "rtems-rfs-rtems.h"
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
index d3393d6..5ce526a 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
@@ -25,13 +25,7 @@
-#else
-#endif
 #include <rtems/rfs/rtems-rfs-dir.h>
diff --git a/cpukit/libmisc/shell/main_time.c b/cpukit/libmisc/shell/main_time.c
index 5ea1bf7..61fc22a 100644
--- a/cpukit/libmisc/shell/main_time.c
+++ b/cpukit/libmisc/shell/main_time.c
@@ -22,17 +22,9 @@
 #include <rtems/shell.h>
 #include "internal.h"
-/* Helper macro to print "time_t" */
-#if SIZEOF_TIME_T == 8
-#define PRIdtime_t PRId64
-#elif SIZEOF_TIME_T == 4
-#define PRIdtime_t PRId32
-#else
-#error "PRIdtime_t: unsupported size of time_t"
-#endif
 static int rtems_shell_main_time(
   int   argc,
   char *argv[]
diff --git a/cpukit/preinstall.am b/cpukit/preinstall.am
index 598d034..2ae31ef 100644
--- a/cpukit/preinstall.am
+++ b/cpukit/preinstall.am
@@ -263,6 +263,10 @@ $(PROJECT_INCLUDE)/rtems/bspIo.h: include/rtems/bspIo.h $(PROJECT_INCLUDE)/rtems
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/bspIo.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/bspIo.h
+$(PROJECT_INCLUDE)/rtems/inttypes.h: include/rtems/inttypes.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/inttypes.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/inttypes.h
 $(PROJECT_INCLUDE)/rtems/print.h: include/rtems/print.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/print.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/print.h
1.8.3.1
