[PATCH 2/2] Merge tmacros.h PRIxxx constants from testsuites/ into <rtems/inttypes.h>
Sat Apr 15 13:17:38 UTC 2017
This completes the initial creation of rtems/inttypes.h based on all
existing PRIxxx definitions contained in RTEMS Project owned code.
closes #2983.
 cpukit/configure.ac                  | 36 +++++++++++++++-------
 cpukit/include/rtems/inttypes.h      | 60 ++++++++++++++++++++++++++++++------
 testsuites/support/include/tmacros.h | 42 +------------------------
 3 files changed, 77 insertions(+), 61 deletions(-)
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 28a11bd..ab01db8 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -238,6 +238,30 @@ RTEMS_CPUOPT([__RTEMS_ADA__],
   [1],
   [Define to 1 if ada/gnat bindings are built-in])
+# These are used to provide <rtems/inttypes.h
+AC_CHECK_SIZEOF([mode_t])
+AC_CHECK_SIZEOF([off_t])
+AC_CHECK_SIZEOF([time_t])
+AC_CHECK_SIZEOF([size_t])
+## Provide sizeof(mode_t) information via cpuopts.h
+RTEMS_CPUOPT([__RTEMS_SIZEOF_MODE_T__],
+  [true],
+  [${ac_cv_sizeof_mode_t}],
+  [sizeof(mode_t)])
+## Provide sizeof(off_t) information via cpuopts.h
+RTEMS_CPUOPT([__RTEMS_SIZEOF_OFF_T__],
+  [true],
+  [${ac_cv_sizeof_off_t}],
+  [sizeof(off_t)])
+## Provide sizeof(time_t) information via cpuopts.h
+RTEMS_CPUOPT([__RTEMS_SIZEOF_TIME_T__],
+  [true],
+  [${ac_cv_sizeof_time_t}],
+  [sizeof(time_t)])
 ## Then we propagate a private copy of the value into cpuopts.h
 ## so it is always available to the RTEMS header files.
@@ -251,7 +275,7 @@ RTEMS_CPUOPT([__RTEMS_MINOR__],
   [$rtems_minor],
   [minor version portion of an RTEMS release])
-RTEMS_CPUOPT([__RTEMS_REVISION__],
+RTEMS_CPUOPT([__RTEMS_REVISION___],
   [true],
   [$rtems_revision],
   [revision version portion of an RTEMS release])
@@ -278,16 +302,6 @@ RTEMS_CHECK_GCC_WEAK
 AC_CHECK_DECLS([_POSIX_LOGIN_NAME_MAX],,,[#include <limits.h>])
 AC_CHECK_DECLS([CHAR_BIT],,,[#include <limits.h>])
-# FIXME: We should get rid of this.
-# So far, only used in libfs/src/nfsclient/src/dirutils.c
-AC_CHECK_SIZEOF([mode_t])
-AC_CHECK_SIZEOF([off_t])
-# FIXME: We should get rid of this. It's a cludge.
-AC_CHECK_SIZEOF([time_t])
-AC_CHECK_SIZEOF([size_t])
 # FIXME: Mandatory in SUSv4, optional in SUSv3.
 #   Not implemented in GCC/newlib, so far.
 AC_CHECK_DECLS([WORD_BIT],,,[#include <limits.h>])
diff --git a/cpukit/include/rtems/inttypes.h b/cpukit/include/rtems/inttypes.h
index 19022af..ef02ccf 100644
--- a/cpukit/include/rtems/inttypes.h
+++ b/cpukit/include/rtems/inttypes.h
@@ -21,6 +21,7 @@
 #define _RTEMS_INTTYPES_H
 #include <inttypes.h>
+#include <rtems/score/cpuopts.h>
 #ifdef __cplusplus
 extern "C" {
@@ -34,41 +35,82 @@ extern "C" {
 /** Helper macro to print "modet" in octal */
-#if SIZEOF_MODE_T == 8
+#if __RTEMS_SIZEOF_MODE_T__ == 8
 #define PRIomode_t PRIo64
-#elif SIZEOF_MODE_T == 4
+#elif __RTEMS_SIZEOF_MODE_T__ == 4
 #define PRIomode_t PRIo32
 #else
-#error "PRIomode_t: unsupport size of mode_t"
+#error "PRIomode_t: unsupported size of mode_t"
 #endif
 /** Helper macro to print "off_t" in octal */
-#if SIZEOF_OFF_T == 8
+#if __RTEMS_SIZEOF_OFF_T__ == 8
 #define PRIooff_t PRIo64
-#elif SIZEOF_OFF_T == 4
+#elif __RTEMS_SIZEOF_OFF_T__ == 4
 #define PRIooff_t PRIo32
 #else
 #error "PRIooff_t: unsupported size of off_t"
 #endif
 /** Helper macro to print "off_t" in decimal */
 #define PRIdoff_t PRId64
 #define PRIdoff_t PRId32
 #else
 #error "PRIdoff_t: unsupported size of off_t"
 #endif
 /** Helper macro to print "time_t" in decimal */
-#if SIZEOF_TIME_T == 8
+#if __RTEMS_SIZEOF_TIME_T__ == 8
 #define PRIdtime_t PRId64
-#elif SIZEOF_TIME_T == 4
+#elif __RTEMS_SIZEOF_TIME_T__ == 4
 #define PRIdtime_t PRId32
 #else
 #error "PRIdtime_t: unsupported size of time_t"
 #endif
+ * Various inttypes.h-stype macros to assist printing
+ * certain system types on different targets.
+#if defined(RTEMS_USE_16_BIT_OBJECT)
+#define PRIxrtems_id PRIx16
+#else
+#define PRIxrtems_id PRIx32
+#endif
+/* c.f. cpukit/score/include/rtems/score/priority.h */
+#define PRIdPriority_Control PRIu64
+#define PRIxPriority_Control PRIx64
+/* rtems_task_priority is a typedef to Priority_Control */
+#define PRIdrtems_task_priority PRIu32
+#define PRIxrtems_task_priority PRIx32
+/* c.f. cpukit/score/include/rtems/score/watchdog.h */
+#define PRIdWatchdog_Interval PRIu32
+/* rtems_interval is a typedef to Watchdog_Interval */
+#define PRIdrtems_interval    PRIdWatchdog_Interval
+/* c.f. cpukit/score/include/rtems/score/thread.h */
+#define PRIdThread_Entry_numeric_type PRIuPTR
+/* rtems_task_argument is a typedef to Thread_Entry_numeric_type */
+#define PRIdrtems_task_argument PRIdThread_Entry_numeric_type
+/* rtems_event_set is a typedef to unit32_t */
+#define PRIxrtems_event_set PRIx32
+/* HACK: newlib defines pthread_t as a typedef to __uint32_t */
+/* HACK: There is no portable way to print pthread_t's */
+#define PRIxpthread_t PRIx32
+/* rtems_signal_set is a typedef to uint32_t */
+#define PRIxrtems_signal_set PRIx32
+/* newlib's ino_t is a typedef to "unsigned long" */
+#define PRIxino_t "lx"
 #ifdef __cplusplus
diff --git a/testsuites/support/include/tmacros.h b/testsuites/support/include/tmacros.h
index 4898aea..2b267ca 100644
--- a/testsuites/support/include/tmacros.h
+++ b/testsuites/support/include/tmacros.h
@@ -18,6 +18,7 @@
 #define __TMACROS_h
+#include <rtems/inttypes.h>
 #include <bsp.h>    /* includes <rtems.h> */
 #include <ctype.h>
@@ -305,47 +306,6 @@ extern "C" {
   } while (0)
- * Various inttypes.h-stype macros to assist printing
- * certain system types on different targets.
-#if defined(RTEMS_USE_16_BIT_OBJECT)
-#define PRIxrtems_id PRIx16
-#else
-#define PRIxrtems_id PRIx32
-#endif
-/* c.f. cpukit/score/include/rtems/score/priority.h */
-#define PRIdPriority_Control PRIu64
-#define PRIxPriority_Control PRIx64
-/* rtems_task_priority is a typedef to Priority_Control */
-#define PRIdrtems_task_priority PRIu32
-#define PRIxrtems_task_priority PRIx32
-/* c.f. cpukit/score/include/rtems/score/watchdog.h */
-#define PRIdWatchdog_Interval PRIu32
-/* rtems_interval is a typedef to Watchdog_Interval */
-#define PRIdrtems_interval    PRIdWatchdog_Interval
-/* c.f. cpukit/score/include/rtems/score/thread.h */
-#define PRIdThread_Entry_numeric_type PRIuPTR
-/* rtems_task_argument is a typedef to Thread_Entry_numeric_type */
-#define PRIdrtems_task_argument PRIdThread_Entry_numeric_type
-/* rtems_event_set is a typedef to unit32_t */
-#define PRIxrtems_event_set PRIx32
-/* HACK: newlib defines pthread_t as a typedef to __uint32_t */
-/* HACK: There is no portable way to print pthread_t's */
-#define PRIxpthread_t PRIx32
-/* rtems_signal_set is a typedef to uint32_t */
-#define PRIxrtems_signal_set PRIx32
-/* newlib's ino_t is a typedef to "unsigned long" */
-#define PRIxino_t "lx"
  * This assists in clearly disabling warnings on GCC in certain very
  * specific cases.
1.8.3.1
