[PATCH] libmisc/monitor: Correctly print unlimited configuration table entries.
Chris Johns
chrisj at rtems.org
Tue Apr 18 02:45:47 UTC 2017
Closes #2997.
cpukit/libmisc/monitor/mon-config.c | 31 ++++++++++++++++++++-----------
1 file changed, 20 insertions(+), 11 deletions(-)
diff --git a/cpukit/libmisc/monitor/mon-config.c b/cpukit/libmisc/monitor/mon-config.c
index f09c7cb195..bb804c5c63 100644
--- a/cpukit/libmisc/monitor/mon-config.c
+++ b/cpukit/libmisc/monitor/mon-config.c
@@ -116,18 +116,27 @@ rtems_monitor_config_dump(
length = 0;
length += fprintf(stdout,"MAXIMUMS");
length += rtems_monitor_pad(DATACOL, length);
- length += fprintf(stdout,"tasks: %" PRId32 "; timers: %" PRId32 "; sems: %" PRId32 "; que's: %" PRId32 "; ext's: %" PRId32 "\n",
- monitor_config->maximum_tasks,
- monitor_config->maximum_timers,
- monitor_config->maximum_semaphores,
- monitor_config->maximum_message_queues,
- monitor_config->maximum_extensions);
+ length += fprintf(stdout,"tasks: %" PRId32 "%c; timers: %" PRId32 "%c; sems: %" PRId32 "%c; que's: %" PRId32 "%c; ext's: %" PRId32 "%c;\n",
+ monitor_config->maximum_tasks & ~OBJECTS_UNLIMITED_OBJECTS,
+ (monitor_config->maximum_tasks & OBJECTS_UNLIMITED_OBJECTS) == 0 ? ' ' : '+',
+ monitor_config->maximum_timers & ~OBJECTS_UNLIMITED_OBJECTS,
+ (monitor_config->maximum_timers & OBJECTS_UNLIMITED_OBJECTS) == 0 ? ' ' : '+',
+ monitor_config->maximum_semaphores & ~OBJECTS_UNLIMITED_OBJECTS,
+ (monitor_config->maximum_semaphores & OBJECTS_UNLIMITED_OBJECTS) == 0 ? ' ' : '+',
+ monitor_config->maximum_message_queues & ~OBJECTS_UNLIMITED_OBJECTS,
+ (monitor_config->maximum_message_queues & OBJECTS_UNLIMITED_OBJECTS) == 0 ? ' ' : '+',
+ monitor_config->maximum_extensions & ~OBJECTS_UNLIMITED_OBJECTS,
+ (monitor_config->maximum_extensions & OBJECTS_UNLIMITED_OBJECTS) == 0 ? ' ' : '+');
length = 0;
length += rtems_monitor_pad(CONTCOL, length);
- length += fprintf(stdout,"partitions: %" PRId32 "; regions: %" PRId32 "; ports: %" PRId32 "; periods: %" PRId32 "\n",
- monitor_config->maximum_partitions,
- monitor_config->maximum_regions,
- monitor_config->maximum_ports,
- monitor_config->maximum_periods);
+ length += fprintf(stdout,"partitions: %" PRId32 "%c; regions: %" PRId32 "%c; ports: %" PRId32 "%c; periods: %" PRId32 "%c;\n",
+ monitor_config->maximum_partitions & ~OBJECTS_UNLIMITED_OBJECTS,
+ (monitor_config->maximum_partitions & OBJECTS_UNLIMITED_OBJECTS) == 0 ? ' ' : '+',
+ monitor_config->maximum_regions & ~OBJECTS_UNLIMITED_OBJECTS,
+ (monitor_config->maximum_regions & OBJECTS_UNLIMITED_OBJECTS) == 0 ? ' ' : '+',
+ monitor_config->maximum_ports & ~OBJECTS_UNLIMITED_OBJECTS,
+ (monitor_config->maximum_ports & OBJECTS_UNLIMITED_OBJECTS) == 0 ? ' ' : '+',
+ monitor_config->maximum_periods & ~OBJECTS_UNLIMITED_OBJECTS,
+ (monitor_config->maximum_periods & OBJECTS_UNLIMITED_OBJECTS) == 0 ? ' ' : '+');
return length;
2.11.0
