Issue with 'rtems_shell_wait_for_input' function
vivek kukreja
vivekkukreja5 at gmail.com
Tue Apr 18 10:12:28 UTC 2017
Hello Sebastian, all,
Sir as you said the uart_set_attributes function for xilinx serial
driver simply returns false. I'm reffering the following file:
/c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c where the
tcsetattr function fails. I'm looking at the older implementations of
uart for xilinx and your recent commits to solve this issue. I'm also
studying the new Termios driver and it would be helpful if you can
refer some approach or other guidelines for this exercise.
Regards,
Vivek
On Tue, Mar 7, 2017 at 8:21 PM, Sebastian Huber
> On 03/03/17 23:50, vivek kukreja wrote:
>> Hello all,
>> I made few changes to the fileio test to run NFS using libbsd. The test
>> compiles and when i run it on qemu NFS is initialised.
>> The test starts with the 'rtems_shell_wait_for_input' function which
>> returns RTEMS_UNSATISFIED so the test quits as soon as it begins. I read
>> this means the terminal related attributes could not be set. When i bypass
>> this function to directly start the test it works fine. Im not sure this is
>> a bug or some problem with my configuration. Any help with this issue is
>> appreciated!
> The serial driver doesn't implement the set attributes device handler
> properly and returns an error.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
