GSOC 2017 RTEMS-libbsd issue
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Apr 19 15:05:24 UTC 2017
----- Ursprüngliche Mail -----
> Von: "赵 思晨" <zsc19940506 at outlook.com>
> An: "Christian Mauderer" <christian.mauderer at embedded-brains.de>, "RTEMS" <devel at rtems.org>
> Gesendet: Mittwoch, 19. April 2017 16:41:20
> Betreff: Re: GSOC 2017 RTEMS-libbsd issue
> Hi Christian Mauderer,
> 1. I haven't put these change in my git repo yet.
> 2.Yes, i verified that by the console output , the below snapshot :
> including some debug info. just forget it.
> [cid:4fb54908-2ff4-4098-9f94-6f2aa529babf]
> 3.The application i use is testsuite/usb01, i debug it, and it loop at the
> uhub_explore function in usb_hub.c, and didn't reach the umass_probe function.
> 4. I noticed that the pin USB1_DRVVBUS and USBx_VBUSIN is always low, so i think
> it can't detect the new device.
> Best Regards
> Sichen Zhao
Hello Sichen Zhao,
point 4 sounds like you found your problem. According to the schematics, there is a TPS2051 on the BBB to switch the power of the USB. This chip has an active high enable input. So USB1_DRVVBUS should be high.
For a quick try, you could connect a self powered hub. But sooner or later, you should just switch the pin on. Please note that it might would be a good idea to use it to reset the connected devices on a reboot.
Kind regards
Christian
embedded brains GmbH
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
