[PATCH 1/2] bsp/xilinx-zynq: Add SLCR driver
Patrick Gauvin pggauvin at gmail.com
Thu Apr 20 03:06:37 UTC 2017
 c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am       |  5 ++
 .../arm/xilinx-zynq/include/zynq-slcr-regs.h       | 84 ++++++++++++++++++++
 .../lib/libbsp/arm/xilinx-zynq/include/zynq-slcr.h | 70 +++++++++++++++++
 c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am     |  8 ++
 c/src/lib/libbsp/arm/xilinx-zynq/slcr/zynq-slcr.c  | 90 ++++++++++++++++++++++
 5 files changed, 257 insertions(+)
 create mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-slcr-regs.h
 create mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-slcr.h
 create mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/slcr/zynq-slcr.c
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index 1f9ed59..08024b9 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -49,6 +49,8 @@ include_bsp_HEADERS += include/i2c.h
 include_bsp_HEADERS += include/irq.h
 include_bsp_HEADERS += include/zynq-uart.h
 include_bsp_HEADERS += include/zynq-uart-regs.h
+include_bsp_HEADERS += include/zynq-slcr.h
+include_bsp_HEADERS += include/zynq-slcr-regs.h
 include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/arm-cp15.h
@@ -118,6 +120,9 @@ libbsp_a_SOURCES += ../shared/arm-a9mpcore-clock-config.c
 # I2C
 libbsp_a_SOURCES += i2c/cadence-i2c.c
+# System Level Control Registers
+libbsp_a_SOURCES += slcr/zynq-slcr.c
 # Cache
 libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
 libbsp_a_SOURCES += ../shared/include/arm-cache-l1.h
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-slcr-regs.h b/c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-slcr-regs.h
new file mode 100644
index 0000000..a4c8fdf
--- /dev/null
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-slcr-regs.h
@@ -0,0 +1,84 @@
+ * @file
+ * @ingroup zynq_slcr
+ * @brief SLCR register definitions.
+ * Copyright (c) 2017
+ *  NSF Center for High-Performance Reconfigurable Computing (CHREC),
+ *  University of Pittsburgh.  All rights reserved.
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
+ * IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+ * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
+ * PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER
+ * OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+ * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+ * PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+ * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+ * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * The views and conclusions contained in the software and documentation
+ * are those of the authors and should not be interpreted as representing
+ * official policies, either expressed or implied, of CHREC.
+ * Author: Patrick Gauvin <gauvin at hcs.ufl.edu>
+ * @defgroup zynq_slcr_regs SLCR Register Definitions
+ * @brief SLCR Register Definitions
+#ifndef LIBBSP_ARM_XILINX_ZYNQ_SLCR_REGS_H
+#define LIBBSP_ARM_XILINX_ZYNQ_SLCR_REGS_H
+#include <bsp/utility.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define ZYNQ_SLCR_BASE_ADDR ( 0xF8000000 )
+/* NOTE: QEMU gives a value of 0 for the pss_idcode. */
+#define ZYNQ_SLCR_PSS_IDCODE_OFF ( 0x530 )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_GET( reg ) BSP_FLD32GET( reg, 12, 16 )
+#define ZYNQ_SLCR_LVL_SHFTR_EN_OFF ( 0x900 )
+#define ZYNQ_SLCR_LVL_SHFTR_EN_DISABLE ( 0 )
+#define ZYNQ_SLCR_LVL_SHFTR_EN_PS_TO_PL ( 0xA )
+#define ZYNQ_SLCR_LVL_SHFTR_EN_ALL ( 0xF )
+#define ZYNQ_SLCR_LOCK_OFF ( 0x4 )
+#define ZYNQ_SLCR_LOCK_KEY ( 0x767b )
+#define ZYNQ_SLCR_UNLOCK_OFF ( 0x8 )
+#define ZYNQ_SLCR_UNLOCK_KEY ( 0xdf0d )
+#define ZYNQ_SLCR_FPGA_RST_CTRL_OFF ( 0x240 )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_7z007s ( 0x03 )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_7z012s ( 0x1c )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_7z014s ( 0x08 )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_7z010 ( 0x02 )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_7z015 ( 0x1b )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_7z020 ( 0x07 )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_7z030 ( 0x0c )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_7z035 ( 0x12 )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_7z045 ( 0x11 )
+#define ZYNQ_SLCR_PSS_IDCODE_DEVICE_7z100 ( 0x16 )
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_XILINX_ZYNQ_SLCR_REGS_H */
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-slcr.h b/c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-slcr.h
index 0000000..2303ff5
--- /dev/null
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-slcr.h
@@ -0,0 +1,70 @@
+ * @file
+ * @brief SLCR support.
+ * met:
+ * @defgroup zynq_slcr SLCR Support
+ * @ingroup arm_zynq
+ * @brief SLCR Support
+#ifndef LIBBSP_ARM_XILINX_ZYNQ_SLCR_H
+#define LIBBSP_ARM_XILINX_ZYNQ_SLCR_H
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+uint32_t zynq_slcr_pss_idcode_get( void );
+void zynq_slcr_fpga_clk_rst(
+  uint32_t val
+void zynq_slcr_level_shifter_enable(
+  uint32_t val
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_XILINX_ZYNQ_SLCR_H */
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am b/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
index a75c344..814095f 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
@@ -150,6 +150,14 @@ $(PROJECT_INCLUDE)/bsp/zynq-uart-regs.h: include/zynq-uart-regs.h $(PROJECT_INCL
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/zynq-uart-regs.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/zynq-uart-regs.h
+$(PROJECT_INCLUDE)/bsp/zynq-slcr.h: include/zynq-slcr.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/zynq-slcr.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/zynq-slcr.h
+$(PROJECT_INCLUDE)/bsp/zynq-slcr-regs.h: include/zynq-slcr-regs.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/zynq-slcr-regs.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/zynq-slcr-regs.h
 $(PROJECT_INCLUDE)/libcpu/arm-cp15.h: ../../../libcpu/arm/shared/include/arm-cp15.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/slcr/zynq-slcr.c b/c/src/lib/libbsp/arm/xilinx-zynq/slcr/zynq-slcr.c
index 0000000..8b10722
--- /dev/null
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/slcr/zynq-slcr.c
@@ -0,0 +1,90 @@
+ * SLCR Support Implementation
+ * At this point, only a few operations related to programming the FPGA are
+ * supported.
+ * met:
+#include <bsp/zynq-slcr.h>
+#include <bsp/zynq-slcr-regs.h>
+static void slcr_unlock( void )
+  volatile uint32_t *unlock;
+  unlock = (uint32_t *)( ZYNQ_SLCR_BASE_ADDR + ZYNQ_SLCR_UNLOCK_OFF );
+  *unlock = ZYNQ_SLCR_UNLOCK_KEY;
+static void slcr_lock( void )
+  volatile uint32_t *lock;
+  lock = (uint32_t *)( ZYNQ_SLCR_BASE_ADDR + ZYNQ_SLCR_LOCK_OFF );
+  *lock = ZYNQ_SLCR_LOCK_KEY;
+  uint32_t val
+  volatile uint32_t *fpga_rst_ctrl;
+  fpga_rst_ctrl =
+      (uint32_t *)( ZYNQ_SLCR_BASE_ADDR + ZYNQ_SLCR_FPGA_RST_CTRL_OFF );
+  slcr_unlock();
+  *fpga_rst_ctrl = 0xf & val;
+  slcr_lock();
+  uint32_t val
+  volatile uint32_t *lvl_shftr_en;
+  lvl_shftr_en =
+      (uint32_t *)( ZYNQ_SLCR_BASE_ADDR + ZYNQ_SLCR_LVL_SHFTR_EN_OFF );
+  slcr_unlock();
+  *lvl_shftr_en = val;
+  slcr_lock();
+uint32_t zynq_slcr_pss_idcode_get ( void )
+  volatile uint32_t *pss_idcode;
+  pss_idcode = (uint32_t *)( ZYNQ_SLCR_BASE_ADDR + ZYNQ_SLCR_PSS_IDCODE_OFF );
+  return *pss_idcode;
2.7.4
