[PATCH 0/2] Zynq7000 series device configuration driver
Thu Apr 20 22:37:16 UTC 2017
On 21/04/2017 07:55, Patrick Gauvin wrote:
> Gedare,
>     if the test programs are specific to the Zynq BSP, then we don't
>     currently have a very good mechanism for maintaining them. Probably
>     submitting them as "example programs" in the
>     git.rtems.org/examples-v2.git <http://git.rtems.org/examples-v2.git>
>     is the best place to look at integrating
>     application/bsp-level tests. This is an area in need of longer-term
>     solutions.
> OK, I will plan on putting them there.
What happens with bitfiles? For example I have a MicroZed with a 7Z010
and I am not sure what a Zedboard has?
Do you have a simple bitfile we can load?
A bitfile that is not secured can compress well. Once this driver is in
RTEMS it would be nice to add another layer to load compressed files.
