Help Request - Fix Out of Bounds Subscript Warning in Raspberry Pi
Mon Apr 24 23:44:58 UTC 2017
Hi
It would be appreciated if someone could look into this and fix it.
log/arm-raspberrypi2.log:../../../../../../../../rtems/c/src/lib/libbsp/arm/raspberrypi/../../shared/gpio.c:328:35:
warning: array subscript is outside array bounds [-Warray-bounds]
log/arm-raspberrypi.log:../../../../../../../../rtems/c/src/lib/libbsp/arm/raspberrypi/../../shared/gpio.c:328:35:
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170424/817f09ca/attachment.html>
