[rtems commit] posix/src/mutexinit.c: Fix used before initialized warning
Joel Sherrill
joel at rtems.org
Wed Apr 26 00:59:18 UTC 2017
On Tue, Apr 25, 2017 at 7:25 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Apr 25, 2017 at 7:14 PM, Joel Sherrill <joel at rtems.org> wrote:
> > Module: rtems
> > Branch: master
> > Commit: 6601684f74f0ea1ec44fb52ec75d52215af11f5f
> > Changeset: http://git.rtems.org/rtems/commit/?id=
> > Author: Joel Sherrill <joel at rtems.org>
> > Date: Tue Apr 25 13:57:03 2017 -0500
> > cpukit/posix/src/mutexinit.c | 3 +++
> > 1 file changed, 3 insertions(+)
> > diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
> > index 39139a4..47e0bcb 100644
> > --- a/cpukit/posix/src/mutexinit.c
> > +++ b/cpukit/posix/src/mutexinit.c
> > @@ -40,6 +40,9 @@ int pthread_mutex_init(
> > const Scheduler_Control *scheduler;
> > Priority_Control priority;
> > + /* initialize to avoid warning for used uninitialized */
> > + priority = 0;
> The warning is spurious. You could refactor the code so the compiler
> doesn't get confused.
If you see how to do it, please go ahead. I have looked into this multiple
times over the years and not found the magic.
> > if ( attr ) the_attr = attr;
> > else the_attr = &_POSIX_Mutex_Default_attributes;
> > vc mailing list
> > vc at rtems.org
> > http://lists.rtems.org/mailman/listinfo/vc
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170425/fd92af70/attachment.html>
