[rtems commit] virtex5/startup/dummy_console.c: Fix no prototype warning
Wed Apr 26 01:02:34 UTC 2017
On Tue, Apr 25, 2017 at 7:21 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Apr 24, 2017 at 6:21 PM, Joel Sherrill <joel at rtems.org> wrote:
> > Module:    rtems
> > Branch:    master
> > Commit:    fd48b43007b001a6f31949952504c9b55d895c4f
> > Changeset: http://git.rtems.org/rtems/commit/?id=
> > Author:    Joel Sherrill <joel at rtems.org>
> > Date:      Mon Apr 24 11:15:53 2017 -0500
> >  c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c | 1 +
> >  1 file changed, 1 insertion(+)
> > diff --git a/c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c
> b/c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c
> > index 048133d..e62a9f0 100644
> > --- a/c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c
> > +++ b/c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c
> > @@ -26,6 +26,7 @@ rtems_device_driver console_control(rtems_device_major_number
> major,
> >                                      rtems_device_minor_number minor,
> >                                      void*                     arg);
> > +void BSP_output_char(char ch);
> Can we avoid declaring non-static functions in .c files? I would
> either see this in a header file, or see it declared as a static
> function.
It can't be static because it is in another file and used by both.
I suppose a bspimpl.h could be added if folks desire.
> >  ssize_t __bsp_memory_write(int minor, const char* buf, size_t len)
> > vc mailing list
> > vc at rtems.org
> > http://lists.rtems.org/mailman/listinfo/vc
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170425/3d1ba413/attachment.html>
