[PATCH v2 4/4] posix/src/mutexinit.c: Reorder to make priority a scoped variable
Thu Apr 27 02:02:59 UTC 2017
I might rather see the switch refactored to an if-then block, since it
has quite a bit of structure to it now.
On Wed, Apr 26, 2017 at 4:42 PM, Joel Sherrill <joel at rtems.org> wrote:
>  cpukit/posix/src/mutexinit.c | 41 +++++++++++++++++++----------------------
>  1 file changed, 19 insertions(+), 22 deletions(-)
> diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
> index 47e0bcb..cdbba11 100644
> --- a/cpukit/posix/src/mutexinit.c
> +++ b/cpukit/posix/src/mutexinit.c
> @@ -38,10 +38,6 @@ int pthread_mutex_init(
>    const pthread_mutexattr_t *the_attr;
>    POSIX_Mutex_Protocol       protocol;
>    const Scheduler_Control   *scheduler;
> -  Priority_Control           priority;
> -  /* initialize to avoid warning for used uninitialized */
> -  priority = 0;
>    if ( attr ) the_attr = attr;
>    else        the_attr = &_POSIX_Mutex_Default_attributes;
> @@ -109,23 +105,6 @@ int pthread_mutex_init(
>  #endif
> -  if ( protocol == POSIX_MUTEX_PRIORITY_CEILING ) {
> -    int  prio_ceiling;
> -    bool valid;
> -    scheduler = _Thread_Scheduler_get_home( _Thread_Get_executing() );
> -    prio_ceiling = the_attr->prio_ceiling;
> -    if ( prio_ceiling == INT_MAX ) {
> -      prio_ceiling = _POSIX_Priority_Get_maximum( scheduler );
> -    priority = _POSIX_Priority_To_core( scheduler, prio_ceiling, &valid );
> -    if ( !valid ) {
> -      return EINVAL;
>    the_mutex = _POSIX_Mutex_Allocate();
>    if ( !the_mutex ) {
> @@ -137,9 +116,27 @@ int pthread_mutex_init(
>    the_mutex->is_recursive = ( the_attr->type == PTHREAD_MUTEX_RECURSIVE );
>    switch ( protocol ) {
> -    case POSIX_MUTEX_PRIORITY_CEILING:
> +    case POSIX_MUTEX_PRIORITY_CEILING: {
> +      int               prio_ceiling;
> +      bool              valid;
> +      Priority_Control  priority;
> +      scheduler = _Thread_Scheduler_get_home( _Thread_Get_executing() );
> +      prio_ceiling = the_attr->prio_ceiling;
> +      if ( prio_ceiling == INT_MAX ) {
> +       prio_ceiling = _POSIX_Priority_Get_maximum( scheduler );
> +      priority = _POSIX_Priority_To_core( scheduler, prio_ceiling, &valid );
> +      if ( !valid ) {
> +        _POSIX_Mutex_Free(the_mutex);
> +        _Objects_Allocator_unlock();
> +       return EINVAL;
>        _CORE_ceiling_mutex_Initialize( &the_mutex->Mutex, scheduler, priority );
>        break;
>      default:
>        _Assert(
>          the_mutex->protocol == POSIX_MUTEX_NO_PROTOCOL
> 1.8.3.1
> devel mailing list
> devel at rtems.org
