[PATCH v2 4/4] posix/src/mutexinit.c: Reorder to make priority a scoped variable
Joel Sherrill
joel at rtems.org
Thu Apr 27 02:59:45 UTC 2017
On Wed, Apr 26, 2017 at 9:02 PM, Gedare Bloom <gedare at rtems.org> wrote:
> I might rather see the switch refactored to an if-then block, since it
> has quite a bit of structure to it now.
How about it includes all cases?
--joel
> On Wed, Apr 26, 2017 at 4:42 PM, Joel Sherrill <joel at rtems.org> wrote:
> > cpukit/posix/src/mutexinit.c | 41 +++++++++++++++++++-----------
> > 1 file changed, 19 insertions(+), 22 deletions(-)
> > diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
> > index 47e0bcb..cdbba11 100644
> > --- a/cpukit/posix/src/mutexinit.c
> > +++ b/cpukit/posix/src/mutexinit.c
> > @@ -38,10 +38,6 @@ int pthread_mutex_init(
> > const pthread_mutexattr_t *the_attr;
> > POSIX_Mutex_Protocol protocol;
> > const Scheduler_Control *scheduler;
> > - Priority_Control priority;
> > - /* initialize to avoid warning for used uninitialized */
> > - priority = 0;
> > if ( attr ) the_attr = attr;
> > else the_attr = &_POSIX_Mutex_Default_attributes;
> > @@ -109,23 +105,6 @@ int pthread_mutex_init(
> > #endif
> > - if ( protocol == POSIX_MUTEX_PRIORITY_CEILING ) {
> > - int prio_ceiling;
> > - bool valid;
> > - scheduler = _Thread_Scheduler_get_home( _Thread_Get_executing() );
> > - prio_ceiling = the_attr->prio_ceiling;
> > - if ( prio_ceiling == INT_MAX ) {
> > - prio_ceiling = _POSIX_Priority_Get_maximum( scheduler );
> > - priority = _POSIX_Priority_To_core( scheduler, prio_ceiling, &valid
> > - if ( !valid ) {
> > - return EINVAL;
> > the_mutex = _POSIX_Mutex_Allocate();
> > if ( !the_mutex ) {
> > @@ -137,9 +116,27 @@ int pthread_mutex_init(
> > the_mutex->is_recursive = ( the_attr->type == PTHREAD_MUTEX_RECURSIVE
> > switch ( protocol ) {
> > - case POSIX_MUTEX_PRIORITY_CEILING:
> > + case POSIX_MUTEX_PRIORITY_CEILING: {
> > + int prio_ceiling;
> > + bool valid;
> > + Priority_Control priority;
> > + scheduler = _Thread_Scheduler_get_home( _Thread_Get_executing() );
> > + prio_ceiling = the_attr->prio_ceiling;
> > + if ( prio_ceiling == INT_MAX ) {
> > + prio_ceiling = _POSIX_Priority_Get_maximum( scheduler );
> > + priority = _POSIX_Priority_To_core( scheduler, prio_ceiling,
> &valid );
> > + if ( !valid ) {
> > + _POSIX_Mutex_Free(the_mutex);
> > + _Objects_Allocator_unlock();
> > + return EINVAL;
> > _CORE_ceiling_mutex_Initialize( &the_mutex->Mutex, scheduler,
> priority );
> > break;
> > default:
> > _Assert(
> > the_mutex->protocol == POSIX_MUTEX_NO_PROTOCOL
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170426/6a154f6f/attachment.html>
