[PATCH v2 4/4] posix/src/mutexinit.c: Reorder to make priority a scoped variable
Thu Apr 27 20:40:53 UTC 2017
On Wed, Apr 26, 2017 at 10:59 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Apr 26, 2017 at 9:02 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> I might rather see the switch refactored to an if-then block, since it
>> has quite a bit of structure to it now.
> How about it includes all cases?
It is better written as an if-else the way it looks now. The switch is
unnecessary
> --joel
>> On Wed, Apr 26, 2017 at 4:42 PM, Joel Sherrill <joel at rtems.org> wrote:
>> >  cpukit/posix/src/mutexinit.c | 41
>> >  1 file changed, 19 insertions(+), 22 deletions(-)
>> > diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
>> > index 47e0bcb..cdbba11 100644
>> > --- a/cpukit/posix/src/mutexinit.c
>> > +++ b/cpukit/posix/src/mutexinit.c
>> > @@ -38,10 +38,6 @@ int pthread_mutex_init(
>> >    const pthread_mutexattr_t *the_attr;
>> >    POSIX_Mutex_Protocol       protocol;
>> >    const Scheduler_Control   *scheduler;
>> > -  Priority_Control           priority;
>> > -  /* initialize to avoid warning for used uninitialized */
>> > -  priority = 0;
>> >    if ( attr ) the_attr = attr;
>> >    else        the_attr = &_POSIX_Mutex_Default_attributes;
>> > @@ -109,23 +105,6 @@ int pthread_mutex_init(
>> >  #endif
>> > -  if ( protocol == POSIX_MUTEX_PRIORITY_CEILING ) {
>> > -    int  prio_ceiling;
>> > -    bool valid;
>> > -    scheduler = _Thread_Scheduler_get_home( _Thread_Get_executing() );
>> > -    prio_ceiling = the_attr->prio_ceiling;
>> > -    if ( prio_ceiling == INT_MAX ) {
>> > -      prio_ceiling = _POSIX_Priority_Get_maximum( scheduler );
>> > -    priority = _POSIX_Priority_To_core( scheduler, prio_ceiling, &valid
>> > -    if ( !valid ) {
>> > -      return EINVAL;
>> >    the_mutex = _POSIX_Mutex_Allocate();
>> >    if ( !the_mutex ) {
>> > @@ -137,9 +116,27 @@ int pthread_mutex_init(
>> >    the_mutex->is_recursive = ( the_attr->type == PTHREAD_MUTEX_RECURSIVE
>> >    switch ( protocol ) {
>> > -    case POSIX_MUTEX_PRIORITY_CEILING:
>> > +    case POSIX_MUTEX_PRIORITY_CEILING: {
>> > +      int               prio_ceiling;
>> > +      bool              valid;
>> > +      Priority_Control  priority;
>> > +      scheduler = _Thread_Scheduler_get_home( _Thread_Get_executing()
>> > +      prio_ceiling = the_attr->prio_ceiling;
>> > +      if ( prio_ceiling == INT_MAX ) {
>> > +       prio_ceiling = _POSIX_Priority_Get_maximum( scheduler );
>> > +      priority = _POSIX_Priority_To_core( scheduler, prio_ceiling,
>> > &valid );
>> > +      if ( !valid ) {
>> > +        _POSIX_Mutex_Free(the_mutex);
>> > +        _Objects_Allocator_unlock();
>> > +       return EINVAL;
>> >        _CORE_ceiling_mutex_Initialize( &the_mutex->Mutex, scheduler,
>> > priority );
>> >        break;
>> >      default:
>> >        _Assert(
>> >          the_mutex->protocol == POSIX_MUTEX_NO_PROTOCOL
>> > 1.8.3.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
