GSOC application
faizan khan faizan10114 at gmail.com
Sun Apr 2 13:17:33 UTC 2017
yes I am working on the getting started thing. I thought, I was supposed to
port the complete bsp, not just one device. So I can choose anyone device
in this case can and write driver for it..
I think bbb is getting too much attention so I am looking into other
projects. Do you know who worked on the v8 port. I did a failed experiment
of porting it on Nucleus for k70. Eventually I settled with a lighweight v7
(which is used by mongoose IOT platform). So would love to discuss that..
Also dont you guys use irc....
cheers,
Faizan
On Sun, Apr 2, 2017 at 6:10 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Apr 2, 2017 at 9:09 AM, Gedare Bloom <gedare at rtems.org> wrote:
> > On Sun, Apr 2, 2017 at 5:17 AM, Christian Mauderer
> > <christian.mauderer at embedded-brains.de> wrote:
> >> ----- Ursprüngliche Mail -----
> >>> Von: "faizan khan" <faizan10114 at gmail.com>
> >>> An: devel at rtems.org
> >>> Gesendet: Sonntag, 2. April 2017 00:44:27
> >>> Betreff: GSOC application
> >>> Hi everyone,
> >>> I know I am late to the party but just got my confirmation letter. I
> have 2
> >>> years of experience porting device drivers for Nucleus RTOS. I wanted
> to
> >>> know about the list of projects.
> >>> https://devel.rtems.org/query?status=!closed&desc=1&
> keywords=~SoC&report=10
> >>> Is this all of it. I can easily take care of #2891, bbb, I have already
> >>> ported bbb bsp for nucleus. Just to understand the project. All I have
> to
> >>> do is port the device drivers mentioned and fix any hardware bugs in
> the
> >>> test coverage, right???
> >>> cheers,
> >>> Faizan
> >>> _______________________________________________
> >>> devel mailing list
> >>> devel at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/devel
> >> Hello Faizan,
> >> I think that there are quite some more projects that are not converted
> to TRACK. See https://devel.rtems.org/wiki/Developer/OpenProjects
> >> If you are interested in one of the projects, just contact the possible
> mentors or ask on the mailing list.
> > There are definitely other good projects to consider that haven't had
> > as much attention as the BB projects. Also note that you should
> > complete https://devel.rtems.org/wiki/GSoC/GettingStarted and begin to
> > prepare your proposal immediately. Your best bet is to find a project
> > matching your interest/skills that has a suitable amount of
> > information posted about it, since you are not likely to get a lot of
> > feedback on your proposal before the deadline.
> P.S. if you propose a BB project, you should also complete the
> GettingStarted using whichever BB board you have.
> > For the BB projects, I suspect the Framebuffer or CAN would be good
> > directions to push. Framebuffer support exists in a few scattered
> > BSPs, but we could use a consistent approach and more uniform API for
> > framebuffer devices. For CAN there was a project a couple years ago
> > that made some progress in simulating CAN with Qemu, but never got to
> > the point of getting a CAN package to integrate easily with RTEMS.
> > There was a follow-up proposal by the same student for the project,
> > but we did not accept it [1].
> > [1] https://docs.google.com/document/d/12T2Sd9vDBGfMhlansaW0Ti2OmtrpR
> PgAXxdPuOHbM78/edit?usp=sharing
> >> Please also note that there are already some other students interested
> in some of the projects (especially the ones that are already converted to
> TRAC tickets): https://devel.rtems.org/wiki/GSoC/2017
> >> Kind regards
> >> Christian
> >> embedded brains GmbH
> >> Christian Mauderer
> >> Dornierstr. 4
> >> D-82178 Puchheim
> >> Germany
> >> email: christian.mauderer at embedded-brains.de
> >> Phone: +49-89-18 94 741 - 18
> >> Fax:   +49-89-18 94 741 - 08
> >> PGP: Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> >> devel mailing list
> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170402/2a7c7502/attachment-0002.html>
