[PATCH] Update:Change format specifiers to fix 4 warnings.
Thu Apr 6 22:30:52 UTC 2017
Following up on my own post. You can avoid some casts.
This is also an example of how pulling a thread can lead
somewhere more complicated. :)
%z should work portably for size_t and should avoid a cast.
libdl already has this in libdl/rtl-shell.c which tries to provide a
C99 inttypes.h like constant.
if defined(__moxie__)
#define PRIdoff_t PRIo32
#else
#define PRIdoff_t PRIo64
#endif
Unfortunately, there is something similar defined in
testsuites/psxtests/include/pmacros.h which looks to be
better done.
Searching in cpukit for similar code turns up a number of
other types and repetitions.
grep -r "#define PRI" . | grep -v PRIORITY | grep -v PRINT
I would suggest the more elegant solution for the PRI constant
off_t, time_t, and mode_t would be
cpukit/include/rtems/inttypes_extensions.h
and that the best of all the duplicated definitions be moved there.
That centralizes them and them everyone uses the same ones.
I suspect that many of the remaining printf format warnings can then
be resolved using these helpers or by adding more.
This idea needs a review and approval by at least one other
developer. Especially the file name.
--joel
On Thu, Apr 6, 2017 at 4:10 PM, Cillian O'Donnell <cpodonnell8 at gmail.com>
wrote:
> 2 of the warnings cropped up on further testing of other BSPs. Sorry,
> should of been more careful.
> Also git send-email format.
>  cpukit/libdl/rtl-obj-cache.c | 18 +++++++++---------
>  1 file changed, 9 insertions(+), 9 deletions(-)
> diff --git a/cpukit/libdl/rtl-obj-cache.c b/cpukit/libdl/rtl-obj-cache.c
> index a4676cf..d3cd953 100644
> --- a/cpukit/libdl/rtl-obj-cache.c
> +++ b/cpukit/libdl/rtl-obj-cache.c
> @@ -78,11 +78,11 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
>    struct stat sb;
>    if (rtems_rtl_trace (RTEMS_RTL_TRACE_CACHE))
> -    printf ("rtl: cache: %2d: fd=%d offset=%d length=%d area=[%d,%d]
> cache=[%d,%d] size=%d\n",
> -            fd, cache->fd, (int) offset, (int) *length,
> -            (int) offset, (int) offset + *length,
> -            (int) cache->offset, (int) cache->offset + cache->level,
> -            (int) cache->file_size);
> +    printf ("rtl: cache: %2d: fd=%d offset=%llu length=%d area=[%d,%llu]
> cache=[%llu,%llu] size=%lu\n",
> +            fd, cache->fd, offset, (int) *length,
> +            (int) offset, offset + *length,
> +            cache->offset, cache->offset + cache->level,
> +            (unsigned long) cache->file_size);
>    if (*length > cache->size)
> @@ -172,10 +172,10 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t*
> cache,
> -      printf ("rtl: cache: %2d: seek: offset=%d buffer_offset=%d read=%d
> cache=[%d,%d] dist=%d\n",
> -              fd, (int) offset + buffer_offset, (int) buffer_offset,
> (int) buffer_read,
> -              (int) offset, (int) offset + buffer_read,
> -              (int) (cache->file_size - offset));
> +      printf ("rtl: cache: %2d: seek: offset=%llu buffer_offset=%lu
> read=%d cache=[%d,%llu] dist=%llu\n",
> +              fd, offset + buffer_offset, (unsigned long) buffer_offset,
> (int) buffer_read,
> +              (int) offset, offset + buffer_read,
> +              (cache->file_size - offset));
>      if (lseek (fd, offset + buffer_offset, SEEK_SET) < 0)
> 2.7.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170406/39ac4601/attachment-0002.html>
