Issue with 'rtems_shell_wait_for_input' function
vivek kukreja
vivekkukreja5 at gmail.com
Wed Apr 19 12:20:24 UTC 2017
Hello Chris,
Inside rtems_shell_wait_for_input we call the change_serial_settings
function which is returning RTEMS_UNSUCCESSFUL so the test doesn't start on
qemu. I tried the tests on gdb for other bsps and they work. I'm still
looking into this issue so I can start working on transports. If you have
any idea about this error, please suggest any docs to help solve it until
Sebastian is away. Thank you.
Regards,
Vivek
On Apr 19, 2017 6:03 AM, "Chris Johns" <chrisj at rtems.org> wrote:
> On 18/04/2017 20:12, vivek kukreja wrote:
>> Hello Sebastian, all,
>> Sir as you said the uart_set_attributes function for xilinx serial
>> driver simply returns false. I'm reffering the following file:
>> /c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c where the
>> tcsetattr function fails. I'm looking at the older implementations of
>> uart for xilinx and your recent commits to solve this issue. I'm also
>> studying the new Termios driver and it would be helpful if you can
>> refer some approach or other guidelines for this exercise.
> I do not think any termios attributes have been supported in the Zynq
> driver. I think Sebastian has made the call return false which is an error
> which is correct.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170419/28466226/attachment-0002.html>
