[PATCH 0/2] Zynq7000 series device configuration driver
Patrick Gauvin pggauvin at gmail.com
Fri Apr 21 15:44:09 UTC 2017
I'll plan on storing a few bitfiles for common platforms, like the MicroZed
(7Z010) and the ZedBoard (7Z020), with the test. I do have a simple
bitfile, but it currently targets the ZedBoard. If you'd like, I can send a
version for the MicroZed when I send the updated patches next week (should
I attach it to the mailing list? I'm not sure what the etiquette is for
large attachments).
I worry about the processing system initialization (such as FCLK frequency)
being mismatched with the bitstream. I think the SDK generates a GPLed FSBL
source now, so maybe including that will do. If there is an alternative I'd
love to hear it, I dislike being tied to the SDK for initialization.
-Patrick
On Thu, Apr 20, 2017 at 6:37 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 21/04/2017 07:55, Patrick Gauvin wrote:
>> Gedare,
>>     if the test programs are specific to the Zynq BSP, then we don't
>>     currently have a very good mechanism for maintaining them. Probably
>>     submitting them as "example programs" in the
>>     git.rtems.org/examples-v2.git <http://git.rtems.org/examples-v2.git>
>>     is the best place to look at integrating
>>     application/bsp-level tests. This is an area in need of longer-term
>>     solutions.
>> OK, I will plan on putting them there.
> What happens with bitfiles? For example I have a MicroZed with a 7Z010 and
> I am not sure what a Zedboard has?
> Do you have a simple bitfile we can load?
> A bitfile that is not secured can compress well. Once this driver is in
> RTEMS it would be nice to add another layer to load compressed files.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170421/b9b6bf8a/attachment-0002.html>
